REL ACOUSTICS - NOW IN INDIA
bhagwan69
#51 erstellt: 09. Jun 2010, 22:06
Arj schrieb:
BTW had a very very surprising result today. at a suggestion of a friend tried the crossover at 25Hz. getting the best results I have so far !!! no boom, clear Midrange and a lot of low level information which was missing. If I switch the sub off i feel like stopping the music !
I must be 75% there.
Amp_Nut
#52 erstellt: 10. Jun 2010, 08:02
REL Recommends Corner placement of their Subs, while conventional wisdow indicates that full range speakers be placed AWAY from room corners.
Thoughts anyone ?
Arj
#53 erstellt: 10. Jun 2010, 09:16
AN, from what I have figured, REL is different because it does not have a conventional low pass Crossover. The setting you make is for the peak set of values and upper frequecies decay naturally with the Box simulating a 2nd order crossover.
Thats the reason a REL is supposed to Augment the speaker. hence the REL is to be set such that the response decay of the lower end of the speaker and the upper end of the Sub add up and Lock in to simulate some sort of an even response....and hence setting and placement being important for the right lock in
Since the 3 wall give a natural 9DB boost, it will go down lower near the walls and the same decay experienced at a lower amplifier volume.
BTW The above is based on what I have eperienced and what I have read up on REL in forums and discussions and any inputs to this will only be continuing education to me
Amp_Nut
#54 erstellt: 10. Jun 2010, 09:27
Thanks, Arj ! MUCH Appreciated
bhagwan69
#55 erstellt: 10. Jun 2010, 15:50
1 wall = 3 dB
2 walls = 6 dB
3 walls = 9 dB
This is when a speaker [sub woofer] is placed close to walls.
The advantage of corner placement is that the sub can play a higher spl with lower amplifier need.
The F3 of the sub does not change...
square_wave
#56 erstellt: 11. Jun 2010, 08:39
How do you achieve 3 walls in a corner ? A corner has only two walls right ?
Arj
#57 erstellt: 11. Jun 2010, 08:49
Floor :). as Bhagwan said 3db of each near surface..2 walls and the floor..OR cieling depending where you place it
bhagwan69
#58 erstellt: 11. Jun 2010, 09:07
correct;
free standing = floor = 1 wall = 3 db
This hold true for all speakers too.
Hence Tannoy corner horns are ment to be placed right up against a wall [3 of them]
The bass gets re-enforced by 10 ++ db's
Westminster Royal etc.
Arj
#59 erstellt: 11. Jun 2010, 10:17
same about Klipsch-Horns. sounds thin and bright away form the walls. I beleive Audio note speakers also sound better near the walls.
bhagwan69
#60 erstellt: 11. Jun 2010, 16:48
100 % correct !
However, I have never heard an audio note speaker.
Amps yes, speakers never..
Some day - inshahallah !
Arj
#61 erstellt: 06. Jan 2011, 04:08
an important update in the journey of my subs. one of my subs developed multiple problems and in the end the driver and the amp module had to be replaced...after over 3 months finally have both subs working.
So its back to square 1 in terms of dialling in of the subs now
Finally
I simply have to put in a word of my appreciation for Jay (SNV) in this whole process, despite the fact that I neither had not bought the sub from him and nor has this been under warranty, Still the amount of cooperation and help I have received from him is nothing short of remarkable in terms of
-coordination with REL for 2 driver shipments (2 failures ! all due to an faulty amp module)
-Coordination with REL in identification of the problem
-I got a replacement amp module for almost free !!!!
clearly one of the best cases of dealer support i have ever received !!. Jay..may your tribe increase.with this kind of support REL and all your other brands can only do well !!
Amp_Nut
#62 erstellt: 06. Jan 2011, 12:08
Arj, its Always Lovely to read actual reports of good service offered here in India, despite the obvious obstacles in getting spares etc.
Its even more laudable when that service is rendered for a product not bought from that dealer.
CONGRATS ! Jay (SNV)
To that, I would like to add my personal experience too. Jay kindly had loaned me for a HOME AUDITION the dCS Puccini CD Player + the 2 Box Cyrus CD Transport + DAC and CHORD interconnects. There was no pressure to quickly return the products or to buy.
I truely appreciated that too, Jay. Thank You.
Manek
#63 erstellt: 06. Jan 2011, 16:33
This is definately reassuring.
Manek
CYRUS AUDIO now in India
SNV am 04.01.2007  –  Letzte Antwort am 03.05.2007  –  62 Beiträge
WILSON BENESCH now in India
SNV am 28.03.2007  –  Letzte Antwort am 13.04.2007  –  20 Beiträge
SONUS FABER - NOW IN INDIA
SNV am 17.09.2009  –  Letzte Antwort am 18.10.2009  –  38 Beiträge
UNISON RESEARCH - NOW IN INDIA
SNV am 03.08.2010  –  Letzte Antwort am 06.08.2010  –  11 Beiträge
EINSTEIN & BLUMENHOFER in India
goolimangala am 18.08.2010  –  Letzte Antwort am 30.08.2010  –  42 Beiträge
Ecosse Reference Cables now in India
SNV am 25.01.2007  –  Letzte Antwort am 17.02.2007  –  15 Beiträge
WORLDS BEST FRONT END : DCS ? NOW IN INDIA
SNV am 28.02.2008  –  Letzte Antwort am 23.06.2010  –  99 Beiträge
ADVANCE ACOUSTIC - NOW WITH SOUND & VISION
SNV am 31.08.2011  –  Letzte Antwort am 03.09.2011  –  7 Beiträge
Export from India to US
Savyasaachi am 15.01.2009  –  Letzte Antwort am 16.01.2009  –  3 Beiträge
Now - Theta Sold !
Amp_Nut am 17.02.2008  –  Letzte Antwort am 18.02.2008  –  5 Beiträge
  • Registrierte Mitglieder930.643 ( Heute: 6 )
  • Neuestes MitgliedFisics
  • Gesamtzahl an Themen1.563.411
  • Gesamtzahl an Beiträgen21.824.590
