| HIFI-FORUM » English » Offtopic (Engl.) » external dvd writer | |
external dvd writer+A -A |
gbharani
erstellt: 12. Feb 2007, 08:09
guys.... what would be a good external dvd-writer to buy... or would it be better to buy a internal dvd writer and a casing for the same ? what would be the cost and what brand ? thanks. |
SUNILYO
erstellt: 12. Feb 2007, 14:08
Hi, I think the latter will be do the job @ low cost. regards - sunil |
zhopudey
erstellt: 12. Feb 2007, 14:40
A DVD-writer will be around 1800/- LG 42N is currently the best. A casing will be about 300 bucks. But this will not be very reliable. An external writer was around 4-5K last time I checked. Might have reduced by now. |
Kamal
erstellt: 12. Feb 2007, 17:56
Is an externalDVD writer really necessary? I mean, can't you go in for an internal one? Reason IMHO ,externals connect thru a USB port which is much slower compared to an internal which connects to the MB bus-much, much faster. |
reignofchaos
erstellt: 12. Feb 2007, 20:49
The interface speed really doesn't matter in case of optical drives cos no optical drive can saturate the ~35MB/s bandwidth of USB2. In any case, you can buy an LG H42N or Asus 1608p3s (a rebadged pioneer) and put it in a cheap casing like the zippys (~1200 bucks). Easily the best solution. |
gbharani
erstellt: 13. Feb 2007, 04:46
thanks guys... will check out the options in the market and come back with what is available |
gbharani
erstellt: 14. Feb 2007, 12:50
guys... bought LG H42N + zippy casing... damage ==> 1900+800 |
Kamal
erstellt: 14. Feb 2007, 17:34
Congrats-& enjoy! |
Neutral
erstellt: 17. Feb 2007, 10:40
What is this casing for? To provide mechanical protection to the drive? Does your writer write double-sided DVD 9. That's very useful for backing up large movie DVDs. |
Amp_Nut
erstellt: 17. Feb 2007, 11:48
What does a Double sided DVD blank cost, vis-a-vis a single sided DVD ? |
zhopudey
erstellt: 17. Feb 2007, 11:55
^Neutral, the casing is to make the drive external. It provides USB connectivity. And I think you guys mean Dual Layer DVDs. They are available for around 150-200 I think. All the recent DVD writers can write to Dual Layer DVDs. As for dual sided DVD, I don't know the cost, but any writer will be able to write on it. |
Amp_Nut
erstellt: 17. Feb 2007, 14:44
Hi zhopudey , You are correct. Thanks. I did mean Dual Layered DVDs... Given the fact that they are almost 10 x more expensive than single layers DVDs, recommending them would seem difficult, unless absolutely necessary... such as probably High Quality DVD movie copying. Most DVD rippers (software ) provide the facility to selectively copy chapters of the DVD and drop stuff like the trailers etc... Most DVD copy software will also compress and write a 2 layered DVD onto a single layer .... ofcourse at a compromised quality... |
zhopudey
erstellt: 17. Feb 2007, 15:13
^^ DVD Shrink is the best for this. However, most new movies exceed 4.3gb even when all menus and extras are removed. Fitting these onto a single layer DVD needs compression to 75-80%. Not such a bad idea I guess, unless one has a 100" screen and needs 100% quality |
Kamal
erstellt: 17. Feb 2007, 17:19
Original pressed movies often exceed 4.5 GB, the max a DVD-R will take. The answer is,as mentioned above By Amp_Nut, to use software that helps get rid of unecessary stuff,& if that does not reduce the size to 4.5 GB, then to compress the movie at the cost of quality OR to use software that splits the movie so that it can be recorded onto 2 DVD's. Did this with some movies like Gladiator, shakespeare in love to preserve the sharpness/detail. |
Neutral
erstellt: 18. Feb 2007, 10:05
Oops Yes, I was referring to dual-layered DVDs. As pointed out by you folks, most good English movies are too big to fit onto a single DVD. Unfortunately, I don't know how to remove 'unnecessary' details or split a movie. Those in the know, please suggest an online guide for me. As for dual-layered DVDs being costly, DVD prices are crashing. Give it a few months, and they will cost change As soon as they become affordable, I would suggest that you guys back up all your music on them. Optical discs are fragile. At my friend's place, there are over 10 dics which won't play correctly! A loss of Rs 4,500 (450 x 10) at least. You will need just 10 DVDs (to back up an average collection of 100 CDs). So, go protect your investment of Rs 45,000. ![]() BTW, we only need the English DD soundtrack, so all others can be safely removed. |
zhopudey
erstellt: 18. Feb 2007, 10:49
Neutral, you can use DVDshrink + DVD43. Both are free software. DVDshrink will let you remove unwanted parts of the movie. DVD43 is to override the macro protection on DVDs. |
Kamal
erstellt: 18. Feb 2007, 20:25
You could also check out afterdawn.com for more such software tools. |
Kamal
erstellt: 18. Feb 2007, 20:26
Nope, you can't back up music Cd's on DVD's |
gbharani
erstellt: 22. Feb 2007, 08:57
as zhopudey ... the casing is for making the drive external. wanted to use one for my laptop which had a dvd rom. cheaper this way to move it around when i go in for a new machine.. its cheaper to buy 10 blank single sided dvd's than buy a double sided one ... |
stevieboy
erstellt: 22. Feb 2007, 16:46
you mean if dvd's are copy protected and wont copy the normal way, this software will help me copy the dvd? mmmmmm |
Neutral
erstellt: 25. Feb 2007, 20:35
Thanks Zhopudey, I will do my R&D to find out how the DVD Shrink works. So wish that things were simple. But, anyway thank goodness that it is possible. BTW, does DVD Shrink back up to MP2 or MP4? Will a DVD created using this software work on any DVD player or just on computers? |
zhopudey
erstellt: 26. Feb 2007, 06:10
DVDshrink is very easy to use. And it always keeps the DVD compatible with all players. I am not aware of the codecs or techniques it uses. |
Which DVD Writer to go for ? SUNILYO am 04.09.2006 – Letzte Antwort am 30.09.2006 – 16 Beiträge |
what people say and mean...funny stuff square_wave am 02.10.2005 – Letzte Antwort am 02.10.2005 – 2 Beiträge |
300% as much the price of the system isnt it cheap? i think its cheap what do u say. Sonic_Master am 09.09.2006 – Letzte Antwort am 13.09.2006 – 3 Beiträge |
which 29" telly to buy? srikarkav am 09.07.2006 – Letzte Antwort am 13.07.2006 – 22 Beiträge |
What is a worthy achievement in a hifidelity system ? square_wave am 17.06.2011 – Letzte Antwort am 24.06.2011 – 26 Beiträge |
AND THE WINNER IS!---BLU RAY vs HD DVD Kamal am 21.02.2008 – Letzte Antwort am 22.02.2008 – 10 Beiträge |
Looking for a room JJHeimerSchmitz am 28.03.2012 – Letzte Antwort am 28.03.2012 – 3 Beiträge |
Roll Call : For all the old members of this forum abhi.pani am 14.03.2012 – Letzte Antwort am 06.03.2016 – 19 Beiträge |
The way High-End should be done SWITCH-IT-ON am 16.10.2007 – Letzte Antwort am 19.10.2007 – 18 Beiträge |
I never a favor! alldeleslagom am 19.07.2011 – Letzte Antwort am 19.07.2011 – 2 Beiträge |
2007
- Registrierte Mitglieder930.929 ( Heute: )
- Neuestes MitgliedMagic_Teddy
- Gesamtzahl an Themen1.564.183
- Gesamtzahl an Beiträgen21.845.991
