Gehe zu Seite: |vorherige| Erste . 10 . 16 17 18 19 20 21 22 23 24 25 . 30 . 40 . 50 . 60 .. 100 .. 200 .. Letzte |nächste|
[Sammelthread] Western Digital TV HD Media Player
dickbrave
#954 erstellt: 23. Dez 2008, 01:36
auch wenns schon spät ist
auch ich mache es eben mal
dickbrave
#955 erstellt: 23. Dez 2008, 01:42
also so soll man vorgehen
die dateien ins root menü entpacken
How to Install the Product Update:
1. Open the firmware update .ZIP file and extract the two files (.BIN and .VER) to a
USB drive's main directory
2. Turn the WD TV on and connect your USB drive
3. Use the remote control to select SETTINGS from the home screen
4. Highlight the firmware upgrade icon, and press ENTER on the remote
5. You will be prompted to perform the firmware upgrade. Select OK and press ENTER.
This will restart the system
6. After restarting, the system automatically enters firmware upgrade mode
7. Once the update process is completed, the HD media player will restart again
New Features:
* Added .MKV chapter selection for video playback for MKV with chapter support
* Added .MTS file extension support
* Added .TP file extension support
* Added .TS file extension support
* Added 1080p 24hz support
* Added disk volume name to folder navigation in list mode
* Added EXIF orientation flag functionality for auto picture rotate
* Added file size in filename
* Added jump feature to the remote: While fast forwarding or reversing, if the “Next” or “Prev” buttons are pressed, video will jump 10 minutes in the respective direction
* Added progress indicator for the duration of the FF or REV function
* Added a blinking status LED behavior while drive is mounting; previously the light just stayed on
* Added sequential .M2TS file playback function
* Added additional subtitle support (SMI, SUB, ASS, SSA)
* Added user selectable font size for subtitle support
* Added song title scroll in music playback to prevent truncation
* Added embedded subtitle display in .MKV files
* Added additional subtitle encoding support for the following: Western Europe (ISO), Traditional Chinese (Big5), Simplified Chinese (GB18030), Japanese (Shift-JIS), Korean (EUC-KR), Cyrillic (Windows-1251), Cyrillic (KOI8-R), Greek (ISO); previously only UTF-8 was supported
* Added display sizing menu for photo playback: Fit to Screen, Full Screen, Keep as Original
* Added accelerating scroll speed based on how long the arrow is held down on the remote when navigating folders with a large number of files; previously only one, constant speed was available
[Beitrag von dickbrave am 23. Dez 2008, 01:45 bearbeitet]
nuhbiwan
#956 erstellt: 23. Dez 2008, 01:45
Ob dadurch einige 1080/24p MKVs artefaktfrei werden?
Sp0KI
#957 erstellt: 23. Dez 2008, 01:46
Hast du die Dateien ins root Verzeichnis kopiert? Also bei mir gings ohne Probleme.
dickbrave
#958 erstellt: 23. Dez 2008, 01:50
habs geändert
nach dem ins root entpacken war auch der button da...
ich spiel gleich bissel rum
testen tu ich morgen erst richtig
EDIT:
24p lief bei mir ohne probs
keine ruckler oder micro ruckler oder artefakte gehabt
untertitel ist im menü einstellbar welche größe; mit vorschau funktion
[Beitrag von dickbrave am 23. Dez 2008, 02:02 bearbeitet]
gigi2006
#959 erstellt: 23. Dez 2008, 02:56
also ich bin begeistert... was mich bist jetzt total geärgert hatte war das die subs nicht alle angezeigt wurden, jetzt aber passt alles
alles andere ging schon davor bei mir, also ich hatte bis heute keine beschwerden
DANKE WD
kikki
#960 erstellt: 23. Dez 2008, 07:02
Endlich spielt das Teil auch .ts Dateien ab!
Das navigieren geht auch etwas flüssiger.
Alle mkv's mit Bildfehlern spielt er jetzt sauber ab
Leider immer noch kein Ton bei fast allen ISO's
kikki
#961 erstellt: 23. Dez 2008, 07:15
...........und irgendwie ist das Bild heller,milchiger???
Kann das jemand bestätigen?
Jane_Dee
#962 erstellt: 23. Dez 2008, 08:01
Platte bleibt bei mir immer noch an. Desweiteren kann ich nicht mehr auf PAL wechseln. Meine von Premiere HD aufgenommenen Streams ruckeln nach wie vor aller 2-3 Sekunden.
Fazit: Für mich keine Verbesserung nach dem Patch.
Ja, ich!
Bild ist definitiv heller...
[Beitrag von Jane_Dee am 23. Dez 2008, 08:24 bearbeitet]
sound67-again
Gesperrt
#963 erstellt: 23. Dez 2008, 09:02
Die Umschaltung von NTSC auf PAL ist auch bei mir weg. Nicht so tragisch, weil meine Videos zum größten Teil eh NTSC sind. Aber - was soll das?
Bei mir erscheint das Bild bei 1080p/60Hz auch heller, aber wenn ich auf 1080p/24Hz umstelle wird es wieder dunkler. Ahhh, ja.
Gehen jetzt IFO-DVD-Strukturen? Kann's heute morgen nicht selbst probieren. Vermutlich nicht ...
Gruß, Thomas
ShadowSAW
#964 erstellt: 23. Dez 2008, 09:19
Hallo, das 1. Firmware Update für den Western Digital Media Player ist nun verfügbar:
Download: WD HD TV Firmware WDTV_FW_1_01_01.
New Features:
WD TV™ HD Media Player 1.01.01 Firmware Release Notes 3
Resolved Issues:
Resolved issue when 2 drives were connected, then one drive was disconnected, the files from the disconnected drive still showed up on the file list but were not playable
Resolved "repeat one" failure during music playback; previously songs would not repeat
Resolved artist name truncation issue during music playback
Resolved issue where WD TV would not turn back on with remote after extended period of inactivity; previously WD TV had to be unplugged and was unrecoverable with the remote
Resolved image size and position issues during video playback; previously the image displayed did not fill the screen until the picture was zoomed in and then out again
Resolved info bar display issues in PAL (European display standard) mode
Resolved issue of the slideshow playing while in the Option menu during playback, slideshow now pauses if the Option menu is accessed
Resolved issues surrounding drives going to “sleep” and folders showing as empty; previously drives equipped with a sleep feature would not re-initialize before the WD TV timed out and displayed the folders as empty
Resolved issues with DVR-MS file playback, FF and REV now function properly; previously FF or REV during a DVR-MS file would cause the file to stop playing and the video signal to be lost
Resolved issues with forced resolution changes dropping video signal; previously the signal would be lost if the user switched between forced resolution and auto
Resolved photo self re-sizing issue; previously during photo playback the pictures would randomly re-size themselves
Resolved Status LED behavior by blinking to reflect accurate read cycles while data is being read; previously the LED just stayed on
Resolved subtitle default to “on” issue (subtitles now default to “off”, unless there is an external subtitle file created, then subtitles default to “on”)
Resolved subtitle position issue, the subtitles were moved down towards bottom of screen; previously during playback of some files subtitles were positioned too high blocking the view of the video
Resolved the 1-2 second FF during initial playback of .MPG video; previously video would play in what appeared to be FF for the first 1-2 seconds and then slow to standard play rate
Resolved video signal failure when pan function in video files with subtitles is used; previously subtitles would stop functioning, video would stop playing, or TV would lose signal
Resolved zoom issues while file info is displayed during video playback; previously signal would fail or video would stop playing
Resolved zooming issues while subtitles were on; previously the screen used to go black and the video would stop playing
sound67-again
Gesperrt
#965 erstellt: 23. Dez 2008, 09:26
Hallo?
Worüber haben wir die ganze Zeit geredet?
pafo300
#966 erstellt: 23. Dez 2008, 09:57
Was hat das für Auswirkungen, wenn nur noch NTSC und nicht mehr PAL auswählbar ist?
Bild milchiger, wie ist es im Automodus?
Das Festplatte/ USB immer noch nicht abschaltet, find ich schon schwach...auch die Sprungmöglichkeiten sollten komfortabler sein, am Besten %
Gruß,
Oliver
Barcal
#967 erstellt: 23. Dez 2008, 10:00
Klar und dies alles für 99.-
pafo300
#968 erstellt: 23. Dez 2008, 10:19
Barcal, ich rede hier über Softwarelösungen, nicht über Hardware, Lizenzen etc. die wesentlich merh Einfluß auf den Preis haben...
Phita
#969 erstellt: 23. Dez 2008, 10:29
Coole Sache. Kann kaum erwarten das zu Hause auszuprobieren. Nur von Cover für Videos les ich leider nix. Schade!
TheShortOfIt
#970 erstellt: 23. Dez 2008, 10:32
Na klaaaar... die Firmware programmieren ja kleine Marsmenschen, die kosten ja kein Geld und haben ne Infrastruktur die nicht bezahlt werden muss
Solche Leute wie du hab ich echt gefressen...
Dir ist schon klar, dass WD das theoretisch garnicht machen müsste oder?
Denn alle Funktionen die auf der Schachtel beworben werden, werden auch unterstützt..
Das Gerät ist keine 2 Monate aufm Markt und WD haut hier imho ne ziemlich gute neue Firmware raus, die z.B. gleich 2 Makel beseitigt, die ich bisher hatte.
Und dazu noch Features wie 24p etc.
Aber ist wohl leider immer noch deutsche Mentalität an allem zu nörgeln, als auch mal die positiven Aspekte zu sehen.
[Beitrag von TheShortOfIt am 23. Dez 2008, 10:33 bearbeitet]
plop73
#971 erstellt: 23. Dez 2008, 10:36
AAAAlso:
-Bei mir habe ich immer noch Pal.
-USB schaltet immer noch nicht ab
-Festplatte (WD MyBook) wird jetzt schon ca. 5 Min. erkannt und findet kein Ende!
-Untertitel werden bei VOBs immer noch nicht gezeigt
...muss jetzt wieder zur Arbeit. Fazit Momentan: eher Verschlechterungen als Verbesserungen.
Werde nachher nochmal die vom Player erstellte Datei auf der Platte löschen und dann mal schauen ob sie dann schneller erkannt wird und der Erkennungsvorgang dann auch mal abgeschlossen wird
Und nochwas: Funktionen wie z.B. Abschalten der USB Platte und ein "echtes" Standby sollten eigentlich schon funktionieren-auch bei 99€ Geräten
[Beitrag von plop73 am 23. Dez 2008, 10:38 bearbeitet]
Barcal
#972 erstellt: 23. Dez 2008, 10:36
Genau so meinte ich das
nidm
#973 erstellt: 23. Dez 2008, 10:38
Rock n´Roll. Direkt mal ausprobieren.
Außerdem wissen wir´s nun definitiv: ScottWD ist tatsächlich der Produktmanager vom WD TV.
nailwood
#974 erstellt: 23. Dez 2008, 10:45
Hallo Leute, da ich mir überlege, diesen Player zu kaufen und noch keine Information auf sonstigen Seiten gefunden habe, eine kurze Frage an alle, die dieses Gerät schon haben:
Betrifft die JPG-Darstellung: Hat schon jemand die tatsächliche Auflösung getestet, z.B. mit dem FullHD-Testbild 4 von Burosch.de?
Mein Philips-TV 42PFL9803H zeigt Bilder über USB total unscharf an, auch wenn sie in der passenden Auflösung 1920x1080 vorliegen und Fullscreen angezeigt werden. Da wird anscheinend intern noch herumskaliert, und das kann man auch nicht per Menü verhindern (wie z.B. bei HDMI über die Option "unskaliert"). Das möchte ich also mit dem WD TV über HDMI-Zuspielung lösen.
Viele Grüße, Markus
[Beitrag von nailwood am 23. Dez 2008, 13:44 bearbeitet]
sound67-again
Gesperrt
#975 erstellt: 23. Dez 2008, 10:58
Finde auch, dass man das positiv sehen sollte. Vom WD Service hatte man bis dato nie was positives gehört, deshalb überraschen Tempo und Umfang des Updates schon.
Dass allerdings die Umschaltung auf PAL nicht mehr klappt ist schon seltsam. Andere Leute können nach dem Update noch umschalten?
Und bitte mal IFO ausprobieren, obwohl ich da wenig Hoffnung habe.
Gruß, Thomas
[Beitrag von sound67-again am 23. Dez 2008, 10:59 bearbeitet]
stoin
#976 erstellt: 23. Dez 2008, 11:20
am besten von einem kleinen usb-stick updaten, mit meiner 1TB Festplatte hat der WD TV die ganze zeit rebooted.
[Beitrag von stoin am 23. Dez 2008, 11:20 bearbeitet]
nidm
#977 erstellt: 23. Dez 2008, 11:24
Erstes Testresultat:
die 24p-Ausgabe führt bei mir zu gelegentlich (ca. alle 40-60 Sekunden)aufkommendem Ruckeln. So läuft mein 24p-Testsample rund aber gelegentlich ruckelt es. Fühlt sich so an, als würde etwas beim nachladen/puffern nicht ganz rund laufen.
Hat jemand ähnliche Erfahrungen gemacht? Vielleicht liegts ja an meiner Festplatte.
So würde ich jedenfalls das Pull-Down-Ruckeln bei 60hz eher in Kauf nehmen als das Ruckeln im 24p-Modus.
p.s.: jaja, mein TV kann 24p darstellen Anschluss via Denon 1909 per HDMI.
vad
#978 erstellt: 23. Dez 2008, 11:24
muss man vorher USB stick formatieren oder einfach ein order mit update drauf???
ShadowSAW
#979 erstellt: 23. Dez 2008, 11:32
sound67-again schrieb:
Hallo?
Worüber haben wir die ganze Zeit geredet? :D
Hab ich nicht gelesen sorry
Meiner ist heute auch gekommen, bekomm ich aber erst morgen als Geschenk.
Komisch laut hardwarversand.de sollte der Player erst mitte Januar eintreffen.
vad
#980 erstellt: 23. Dez 2008, 11:34
Ich habe auch bei Hardwareversand bestellt, noch nicht bekommen.
wann hast du bestellt?
sound67-again
Gesperrt
#981 erstellt: 23. Dez 2008, 11:42
Einfach die Firmware unzippen und auf den Stick ins Stammverzeichnis kopieren (Stick muss ansonsten nicht leergeräumt werden).
gigi2006
#982 erstellt: 23. Dez 2008, 11:57
also ich hab auch ein stick benutzt, aber der war fast rand voll sogar im stammverzeichniss... ich denk das macht dem nix aus
stoin
#983 erstellt: 23. Dez 2008, 12:04
Leider wurde das Problem mit fehlerhafter Anzeige einiger Videos nur rund zur 50% gelöst. Die anderen 50% laufen immer noch mit Bildfehlern
Angeschlossene USB-Platte schaltet sich immer noch nicht ab, wenn WD TV aus ist...
Naddel81
#984 erstellt: 23. Dez 2008, 12:08
das bild ist milchiger? wie bitte? ich dachte, bei dem gerät wäre der eigentliche vorteil die bildqualität in HD, was bisher nur mit teureren geräten möglich war. und nun wird per update die bildquali verschlimmbessert? kann das jemand bestätigen?
stoin
#985 erstellt: 23. Dez 2008, 12:11
Also für mich ist das Bild gleich geblieben.
Was ist eigentlich die beste Ausgabeeinstellung, auto?
wird bei auto automatisch 1080p24 gewählt wenn der Fernseher 24p unterstützt?
[Beitrag von stoin am 23. Dez 2008, 12:22 bearbeitet]
sound67-again
Gesperrt
#986 erstellt: 23. Dez 2008, 12:22
Von "milchiger" weiß ich auch nichts zu berichten. Nur heller (bis zu Umschaltung auf 1080p24).
Speaking of which ... sollte das nicht alle "Ruckelprobleme" beseitigen - egal ob Quelle NTSC oder PAL?
Gruß, Thomas
nidm
#987 erstellt: 23. Dez 2008, 13:28
zu 1: die, die der Auflösung/fps der Quelldatei entspricht, welche Du abspielen möchtest.
zu 2: nein
nidm
#988 erstellt: 23. Dez 2008, 13:36
Nach dem Entzippen musst Du die 2 Dateien in dem neu entstandenen Verzeichnis in das Root-Verzeichnis des USB-Sticks packen. Dann geht´s, egal, ob der Stick leer oder randvoll ist.
[Beitrag von nidm am 23. Dez 2008, 13:36 bearbeitet]
plop73
#989 erstellt: 23. Dez 2008, 13:43
Update: WD MyBook wurde nach 6Min. Durchsuchen (ging sonst schneller) komplett erkannt!
Und siehe da: der 1. VC-1 Film läuft!!! Yeah!
Zum Pal/NTSC Problem: Bei mir kann ich nicht wählen. Steht auf PAL und lässt sich nicht anwählen.
Bild ist bei mir unverändert sehr gut!
An dieser Stelle ein dickes
THANK YOU MR. SCOTT!!!
Auch wenn das update noch längst nicht vollständig ist und es noch einige Bugs zu beseitigen gibt. Aber jetzt sieht man, dass daran gearbeitet wird und WD am Ball ist! Das ist sehr beruhigend.
[Beitrag von plop73 am 23. Dez 2008, 13:51 bearbeitet]
schimi2k
#990 erstellt: 23. Dez 2008, 14:00
kleiner zwischenbericht:
1. Untertitel:
Subs werden jetzt im EUROPE ISO style angezeigt - also keine probleme mehr mit ä,ö,ü,ß
Subs werden auch angezeigt, wenn sie IM mkv eingebettet sind ( muss man allerdings jedesmal erst per option aktivieren - aber is ja auch net schlimm )
ACHTUNG!
externe Subs im .srt format werden bei mir NICHT ! synchron angezeigt ( also wie vor dem FW update ) eingebaute subs im MKV file sind perfekt !
EDIT:
SMI - so asynch wie SRT files
SSA - nicht ganz so asynch wie SRT oder SMI aber nicht ganz perfekt wie bei den eingebauten MKV SUB ! (ASS wird wohl das selbe sein )
2. USB Abschaltung wenn WD aus ist
Klappt bei mir NICHT ! ich hab ne WD Essential 1TB drann - die " fährt " zwar den lesekopf runter aber wenn ich meinen CRUZER USB Stick drann habe, leuchtet der munter weiter wenn die WD aus ist - ist aber für mich nicht so schlimm
3. es wird jetzt auch die filegrösse mit angezeigt... fände es besser, wen man das irgendwo einstellen könnte, weil bei der WD is mir das ehrlich gesagt egal ^^ zuviel info ^^
4. Kapitel im mkv
kann man leider nicht DIREKT per FB anwählen ( hab alles probiert - nix passierte ) wenn ich auf next gedrückt habe, hat er das nächste video gewählt
man muss erst auf options - dann auf kapitel gehen - dann is BILD WEG und man is im KAPITELMENÜ ! da kann man kapitel auswählen und dann geht der film von da weiter...is n bissi umständlich - hätte man vielleicht auf die cursortasten legen können
5. VORLAUF 10min
klappt ! man muss allerdings erst einmal vorlaufen lassen (2x reicht ) und wenn man dann auf next klickt gehts 10min vor ! wenn man zurück will, muss man erst zurückspulen ( 2x ) und dann auf PREV klicken - dann gehts erst 10min zurück ... auch hier wäre vielleicht entweder direkt die option per CURSOR TASTEN direkt n bissi schöner, oder sonst irgendwie ^^
fehlerhafte videos hatte ich leider keine mehr, also kann ich da nix testen - dvd isos spiele ich eh net ab damit, also kann ich da auch noch nichts berichten
ich werd heute noch den SCHWARZ/WEIß effekt testen und nochn bissi rumspielen ^^
( fehlt noch das COVER anzeigen bei MKVs sollte doch irgendwie machbar sein, wenn man ein JPG oder so von spezieller grösse mit selben namen im verzeichnis hat )
alles in allem bin ich alleine schon mit den UNTERTITEL Verbesserungen verdammt glücklich, und die anderen verbesserungen sind auch schonmal ein schönes weihnachtsgeschenk ! und somit sind die 100€ für das gerät mehr als ein schnäppchen !
sobalt ich was neues entdeckt habe, werde ich diesen Post editieren ^^
[Beitrag von schimi2k am 23. Dez 2008, 14:32 bearbeitet]
pafo300
#991 erstellt: 23. Dez 2008, 14:03
@ barcal und TheShortOfIt
meine einzige Antwort, um den Thread nicht aufzublähen, ihr
versteht als einzige nichts und werdet gleich rotznasig, was ihr wahrscheinlich auch noch seid, von zuvielen Hormonen gesteuerte Jünglinge...
R0K
#992 erstellt: 23. Dez 2008, 14:28
sagt mal, wie lange hat denn das Update der Firmware gedauert? Bei mir tut sich nach fast 1 Stunde immer noch nichts, ausser dass das blaue WD Logo zu sehen ist. Hatte das Update auf der MyPassport drauf. Was nun? Reseten?
kikki
#993 erstellt: 23. Dez 2008, 14:48
Gruß, Thomas
Hi
Heller ist für mich gleichzeitig auch milchig.
Wenn du bei deinem TV die Helligkeit zu hoch drehst werden die Letterboxbalken heller und milchig,oder?
Also bei mir schon,vorher waren die tiefschwarz.
nidm
#994 erstellt: 23. Dez 2008, 14:54
Oha, hab auch von HD geupdated, ging aber erheblich schneller: gefühlte 10 Minuten - hab nicht auf die Uhr geschaut.
hierlima
#995 erstellt: 23. Dez 2008, 14:54
ich bin neu hier und habe den ganzen Thread quer gelesen.
Ich habe dennoch eine Frage!
Ist das Gerät für jemand geeignet, der eigentlich nur ganz komfortabel sein Urlaubs und sonstigen Bilder auf einem Sony 40 Full Hd in best möglicher Qualität betrachten und vorführen will! Es muß auch absolut seniorentauglich sein!
Videos + Musik ist eher zweitrangig!
Hierlima
catrix
#996 erstellt: 23. Dez 2008, 14:56
Noch immer kein DTS Downmix ? Somit ist das Teil für Leute die kein DD Reciver haben also noch immer nutzlos außer jeder will seine DTS Files Konvertieren
R0K
#997 erstellt: 23. Dez 2008, 14:58
Mist, reset bringt nichts, immernoch keine Reaktion. Hab das Ding vor 2 Stunden ausgepackt. Was nun? Keiner Erfahrung damit, wenn es nicht mehr will? Davor hat es zumindestens gut funktioniert...
schimi2k
#998 erstellt: 23. Dez 2008, 15:38
hab dir im anderen forum schon was geschrieben rok ^^
verstehe ich es richtig ? deine WD box geht garnimmer an ? also alles abstecken ausser strom und HDMI/COMPOSITE stecker ? dann kommt auch nix ? wenn NICHT, dann is die box defekt
wenn es da geht, sollteste vielleicht das FW update neu ziehen und die sachen NEU ins ROOT deiner HDD entpacken...vielleicht is da was schief gelaufen ? und haste deine HD auch in FAT32 oder NTFS formatiert ??? alles andere soll laut anleitung NICHT funzen !!!
R0K
#999 erstellt: 23. Dez 2008, 15:47
Danke, bei USB und Formatierung hat's gefunkt! Ich hatte davor die Passport NTFS formatiert und obwohl die 2 Firmwaredateien im Root waren, hat die Box es beim Updaten nicht mehr erkannt. Habe die Dateien auf nen USB Stick gepackt (Fat32), die Box resetet und den Stick reingesteckt und Gott sei Dank hat alles funktioniert!
kikki
#1000 erstellt: 23. Dez 2008, 16:11
Genau,konvertieren oder endlich mal den passenden AV-Receiver kaufen!
Dany2k
#1001 erstellt: 23. Dez 2008, 16:19
Also mit der aktuellen FW ist das Teil ein Traum, MKV's die vorher nicht gefunzt haben werden jetzt abgespielt. Auch die 24p Ausgabe funktioniert Super !!
Also ich bin mit dem Teil jetzt Super zufrieden, für den Preis echt voll ok.
Meinen HTPC hab ich schon abgebaut. Echt Wahnsinn was das kleine Ding da alles macht.
Jemand Interesse an einem HTPC mit dem Maßen 41x40x20cm ?
Lowfiler
#1002 erstellt: 23. Dez 2008, 16:22
Bei mir das selbe 24p Ausgabe also unbrauchbar. Irgendjemand ne Lösung?
Naddel81
#1003 erstellt: 23. Dez 2008, 16:22
Gruß, Thomas
Hi
und das kann man nicht zurpckregeln per TV-einstellung?
catrix
#1004 erstellt: 23. Dez 2008, 16:28
Firmware Updaten....
Okmonik am 25.06.2009  –  Letzte Antwort am 25.06.2009  –  2 Beiträge
Bugliste: Western Digital TV HD Media Player
jjules am 18.11.2008  –  Letzte Antwort am 27.04.2010  –  81 Beiträge
Western Digital WD TV® HD Media Player
gude100 am 10.11.2009  –  Letzte Antwort am 10.11.2009  –  2 Beiträge
Western Digital TV HD Media Player 1080p
SkELEt0R am 19.07.2010  –  Letzte Antwort am 23.07.2010  –  2 Beiträge
Western Digital WDBABG0000NBK TV HD
hifsagunto am 02.12.2009  –  Letzte Antwort am 13.12.2009  –  2 Beiträge
Western Digital WD HD Media Player
dieter00 am 11.08.2009  –  Letzte Antwort am 12.08.2009  –  3 Beiträge
Western Digital TV HD Media Player an Heimkinoanlage anschließen !
mschmid75 am 12.12.2008  –  Letzte Antwort am 24.03.2009  –  8 Beiträge
Western Digital WD TV® HD Media Player ( Quallität der FIilme) !
McRocket am 13.04.2009  –  Letzte Antwort am 20.05.2009  –  9 Beiträge
Abspielproblem mit Western Digital TV HD Media Player
w1cht* am 18.04.2009  –  Letzte Antwort am 19.04.2009  –  4 Beiträge
Popcorn A-110 oder Western Digital TV HD Media Player
Aendni am 08.05.2009  –  Letzte Antwort am 08.05.2009  –  4 Beiträge
  • Registrierte Mitglieder930.662 ( Heute: 8 )
  • Neuestes Mitgliednormawurst30237
  • Gesamtzahl an Themen1.563.463
  • Gesamtzahl an Beiträgen21.826.224
