| HIFI-FORUM » English » Tuning & Voodoo (Engl.) » Shorting plugs | |
Shorting plugs+A -A |
Manek
erstellt: 15. Jul 2008, 05:54
Hi How many of you are using shorting plugs on your rca inputs ? Was reading article on plugs with 2k resistors soldered onto rca plugs for analogue inputs. How would this help ? and 75 ohm resistor on a digital output ! Wouldn't this destroy the circuit ? Manek |
Amp_Nut
erstellt: 15. Jul 2008, 07:51
The Shorting Plugs, just prevent stray noise pick up from the un-used inputs. These would be most effective for low level inputs such as Mic or Phono ( Moving Coil or Moving Magnet ) inputs, which see a substantial voltage gain at these inputs. Actually, the unused inputs are typically left 'Open" not connected, at the selector switch, and the argument is that the signal will 'Jump Across' the open contacts, and polute the active input. SOME amplifiers are designed that all unused inputs are automatically grounded thru an appropriate resistor ( Typically 10K or 100K ) The digital Output is designed to ideally feed 75 Ohms cables and a 75 Ohms impedance ( or 50 Ohms, depending on the design ). Hence this is the ideal load for it. It would be happiest into a 75 Ohms. [Beitrag von Amp_Nut am 15. Jul 2008, 08:08 bearbeitet] |
Manek
erstellt: 15. Jul 2008, 10:20
Worth trying then on digital ? ....And loads of 100k on analogue outputs? Manek [Beitrag von Manek am 15. Jul 2008, 10:24 bearbeitet] |
Amp_Nut
erstellt: 16. Jul 2008, 01:45
As they say .... : Your Milage May Vary " ... No harm done though ! P.S. Why 100K ? The shorting plug will not load any external device ( unlike a built in loading resistor ). Go with the low value ( eg 2 K ) for lowest noise. [Beitrag von Amp_Nut am 16. Jul 2008, 01:48 bearbeitet] |
bombaywalla
erstellt: 17. Jul 2008, 01:14
Manek, Cardas provides RCA shorting plugs where the analog inputs are shorted to ground by connecting the center pin to the outer metal ring of the RCA jack. So, I'm wondering why Amp_Nut is recommending 100K??? I have left my analog inputs floating for the last 6+ years & I do not feel that I'm missing anything. FWIW. |
Amp_Nut
erstellt: 17. Jul 2008, 02:00
Bombaywalla said :
Actually, Amp_Nut said :
bombaywalla
erstellt: 18. Jul 2008, 01:26
yes, Amp_Nut, I now see that! I must have not registered it when I read your post. I think that we agree to leave the analog outputs un-touched, correct? And, the unused digital o/p connected to 75-Ohms to give max load xfer of rail-rail digital output so as to reduce square wave harmonics spewing everywhere, correct? So, my question is: why not simply short the analog inputs to ground like the Cardas plugs? |
Amp_Nut
erstellt: 18. Jul 2008, 06:50
bombaywalla said :
Yes, Sir ! I agree with you.However, since Maneck was quoting someone's earlier advice of 2K Ohms, I stayed with that figure.... |
bombaywalla
erstellt: 19. Jul 2008, 01:11
Ach! OK. Thanks! |
Manek
erstellt: 19. Jul 2008, 12:23
Yes was reading some notes and they have 100k on unused outputs and 2k mentioned for inputs. Manek |
How does Inflated Tube help CDP ? SDhawan am 03.10.2006 – Letzte Antwort am 21.11.2006 – 24 Beiträge |
Perspectives on cables Arj am 28.04.2009 – Letzte Antwort am 30.12.2010 – 43 Beiträge |
power! outtake from hifi-forum.de tomhifi am 06.07.2003 – Letzte Antwort am 09.10.2003 – 10 Beiträge |
THE 'SOUND' OF FUSES Amp_Nut am 19.02.2010 – Letzte Antwort am 09.01.2013 – 18 Beiträge |
power cords sivat am 30.11.2009 – Letzte Antwort am 16.04.2010 – 261 Beiträge |
scratchy mp3 anirvan am 16.05.2006 – Letzte Antwort am 16.05.2006 – 3 Beiträge |
Remote Control DMR-E100H Sybarit am 27.03.2005 – Letzte Antwort am 27.03.2005 – 2 Beiträge |
"Dear customer" kimber-frank am 26.07.2003 – Letzte Antwort am 10.01.2013 – 33 Beiträge |
can composite cables be used for component connection? souravin am 06.09.2007 – Letzte Antwort am 11.09.2007 – 12 Beiträge |
Stuffing the box Matic am 20.05.2004 – Letzte Antwort am 19.01.2005 – 3 Beiträge |
Top Produkte in Tuning & Voodoo (Engl.)
- Registrierte Mitglieder930.640 ( Heute: 11 )
- Neuestes MitgliedBrummkreisel17
- Gesamtzahl an Themen1.563.391
- Gesamtzahl an Beiträgen21.823.998
