| HIFI-FORUM » English » Other hifi (Engl.) » NEw car audio system | |
NEw car audio system+A -A |
kewl
erstellt: 23. Okt 2005, 18:43
hello ! i have a set of JBL GTO 936e's in my car with pioneer TS-20 tweeters,,, Plan to get a Pioneer DEH-7700MP... please help with the amp and woofer...amp ..4-5k..and woofer..4-5k.. thanks |
benkenobi
erstellt: 23. Okt 2005, 19:31
All three are excellent choices.. very decent setup IMHo |
kewl
erstellt: 23. Okt 2005, 20:19
okay..thanks...i also thought of getting a 4channel sony amp....wht is the diff between sony XM-SD46X and the sony XM-504Z .. other than price..and size...plz help here also.. cheErs |
kewl
erstellt: 28. Okt 2005, 16:19
hello ppll...help pls.. also for woofers... i had a look at the sony XS-L122PS... so now i am in between pionner ts-306dvc..and the sony one.. please help me decide... |
benkenobi
erstellt: 29. Okt 2005, 01:48
The pioneer is much better..but you would need to decide on the amp before going ahead. Check the impedance at maximum output is attained by the amp before purchasing. |
kewl
erstellt: 29. Okt 2005, 17:59
hey ben had a look on the piooneer woofer n sony amp.. pioneer woofer - impedance - SVC-4ohm...DVC-2or8ohm.. sony xm-504z ...2ch x 125w + 1ch x 300w.. at 4oh.. and sony XM-SD46X ... 2ch x 120w + 1ch x 300 at 4ohm.. which amp shud i go for ....the latter has a heatsink also.. |
benkenobi
erstellt: 29. Okt 2005, 18:45
Hey Kewl, Well why don't u look at Sony's two channel amps.. since u are looking only to add a sub, one 2 channel amp would more than suffice.. besides tyou would get around 500 watts RMS at 4 ohms.. For this i think you would have to look at a sub with 4 ohms SVC or DVC with dual 2 ohm VC or dual 8 ohm VC.. Check out these two models.. the first one is better IMHO.. SONY-XM2200GTX Sony XM-SD22X Cheers, Sachi |
kewl
erstellt: 29. Okt 2005, 20:02
hey benni want atelast 3 channels coz want to power the jbl's also !! so ... |
kewl
erstellt: 29. Okt 2005, 20:03
sorry ben |
benkenobi
erstellt: 30. Okt 2005, 03:48
Hey kewl, okay..i guess u will need some juice to power the JBLs.. well in that case i think either of the amps will do.. Regarding the sub.. i suggest you look at pioneer 306 SVC model. compare it with the sony sub in your car.. ask the person from whom ur buying to show them both for you.. Cheers, Sachi |
kewl
erstellt: 31. Okt 2005, 08:24
oki..ben..then i will go for ne amp... and reg. the woofer..i asked the person..he said go for pioneer...so i think i will go for pioneer ... and one more thing..like r there 2 models in pioneer svc and dvc...single n double voice coils...what difference doest it make.. cheErs |
kewl
erstellt: 08. Nov 2005, 15:02
helo...now i am thinkin of a lil diff setup !! sony - 504z amp for rear jbl..and the front speakers or tweeters..( which shud i amplify..the speakers or tweeters?? ) and a 2 channel amp...bridged to 1 channel for the pioneer 306c woofer...also can i use the 2nd amp..the 2 channel one..in 2ohm mode..and get a pioneer dual voice coil model... pls suggest chEers |
kewl
erstellt: 08. Nov 2005, 17:12
one more thing..i have these 2 headunits on my mind.. pioneer DEH-7750MP and DEH-P1Y..which one shud i choose..i knw tht the p1y has a motorised face place and is 60x4 watts..also one more difference is 7750 has Direct Sub Drive (from headunit power) and in the p1y Direct Subwoofer Drive not supported...what does this mean !! pls help.. chEers |
benkenobi
erstellt: 08. Nov 2005, 17:22
well. i think you can go for this setup.. you may have to check the piower rating on the tweeters to see if they can handle the power..frankly you don't need an external amp to drive the tweeters..the 17-23watts(depending on the headunit)is more than sufficient..use the preout for the fronts to power the front speakers and the preouts of the rears to power the rear speaker.. with the front speaker output of the headunit(the power out not preout) i think you can power the tweeters with a crosssover in the signal line. but check with the electrician on that or with the tweeter setup manual. Regarding powering the DVC with a 2 channel amp in bridged mode..well i haven't come across many amps that can drive 2 ohms bridged..that would mean the amp will have to be stable at 1 ohm!! most of the JBL amps are 1 ohm stable.i know mine is:D i feel its better to go for the single voice coil version where in you can feed the 350/400 watts bridged into 4 ohms. Hope that helps. Regards, Benkenobi [Beitrag von benkenobi am 08. Nov 2005, 17:25 bearbeitet] |
benkenobi
erstellt: 08. Nov 2005, 17:33
Bothj are excellent units.. If it were me i would go for the P1y.. Let me give you my reasons. The only grouse i have with piooneer flip down units are that with usage the conection tends to become lose and becomes unbearable.. i don't know how reliable the motorized faceplate will be..but i am guessing its a better choice than the flip down. Direct sub drive means you can drive the sub directly from the headunit without an external amplifier.. since you are not doing this(and i feel its not going to be worth your while to consider this as an option) and the fact that you get 6.5V preouts on the P1Y..i would definitely go for that. Hope that was lucid enough. Regards, Benkenobi |
kewl
erstellt: 08. Nov 2005, 17:51
oki..i think i will gor wid one 4channel amp ..bridged for use in 3channel mode..2 for rears..n 1 for woofer.. and will go for single coil version..thns for all th info..i will chek wiith the electrician reg the tweets ... thankksss |
kewl
erstellt: 08. Nov 2005, 17:52
ya ..i am wid u ..p1y...the only thing i had is the direct sub drive..but as i hve to use the amp...it doesnt matter..and p1y ..has 60 x 4..better for the tweeters also....thankss cheErs |
Car Audio neono am 06.09.2011 – Letzte Antwort am 07.09.2011 – 6 Beiträge |
NEWBIE : ALPINE CAR SYSTEM razakhan am 28.07.2003 – Letzte Antwort am 21.09.2003 – 3 Beiträge |
Car Audio gbharani am 11.09.2006 – Letzte Antwort am 18.09.2006 – 13 Beiträge |
information needed in car audio system rajeshmathew am 20.08.2004 – Letzte Antwort am 29.04.2005 – 3 Beiträge |
Car Audio setup cheraz am 27.06.2009 – Letzte Antwort am 16.03.2018 – 15 Beiträge |
New Look AV Max Amp_Nut am 25.01.2008 – Letzte Antwort am 01.02.2008 – 4 Beiträge |
Need Suggestions For Car Hi Fi Amp_Nut am 09.01.2008 – Letzte Antwort am 14.01.2008 – 46 Beiträge |
Linn appoints new Managing Director Prithvi am 30.06.2006 – Letzte Antwort am 30.06.2006 – 10 Beiträge |
Mid-fi Car Audio: Where to start, how to go about? abhi.pani am 24.10.2006 – Letzte Antwort am 30.04.2007 – 2 Beiträge |
Car-fi in Bangalore soulforged am 12.07.2007 – Letzte Antwort am 15.08.2007 – 14 Beiträge |
- Registrierte Mitglieder930.634 ( Heute: 3 )
- Neuestes Mitgliedmikolaj
- Gesamtzahl an Themen1.563.372
- Gesamtzahl an Beiträgen21.823.603
