Car Audio
neono
#1 erstellt: 06. Sep 2011, 10:57
Hi friends , im planning on a basic music setup in my santro.
What i had in mind is a new JBL usb only head unit, which could output 25watt to a 4 ohm load according to the manual..My doubt is this- Could i connect my old sony mini-hifi bookshelf, probably rated at 8ohm to this head unit.Im not looking for window shattering loudness etc...
[Beitrag von neono am 06. Sep 2011, 11:13 bearbeitet]
Amp_Nut
#2 erstellt: 06. Sep 2011, 13:13
Hi Neono,
Using a Car Unit as a basic Home Stereo is not an unusual solution, and these can sound quite respectable if used with good speakers in the home.
To answer your question, YES, you can connect a 4 Ohm output Car unit to 8 ohm speakers. The only penalty will be lower output volume from the speakers.
If yr speakers are small and the shop keeeper obliging, you could even take yr speakers for a actual listen before buying ...
A couple of suggestions, if I may :
1. Use a HEFTY 12 VDC PSU to feed the unit. Atleast 3 Amperes DC output @ 12 Volts. A 5 Ampere or more output would be even better.
2. A couple of years ago when i was in the market for a unit for my car, I found the Alpine Units FAR superior to the Pioneer ones, and all other available at that ytime. Alpine is more expensive, and scan of features, but the sound quality, particularly clean treble, which had a delicacy to the sound. Do give it a listen.
All the best, and do post yr final purchase and your thoughts ...
neono
#3 erstellt: 06. Sep 2011, 16:07
Im not planning to use the car unit @ home. ..the other way round ....To use the sony bookshelves ,in my car boot..
Anyway thanks ampnut.. .just wanted to know whether , will it damage the headunit or something..lower volume is ok.
[Beitrag von neono am 06. Sep 2011, 18:01 bearbeitet]
Amp_Nut
#4 erstellt: 06. Sep 2011, 18:26
Oops ! Sorry about my wrong assumption.
A word of caution... the car has very high levels of ambient noise and car speakers are called on to play much louder than in a home environment.
Also, the car is very different acoustically from the home. Dont be surprised if you dont recognise the sound of your home speakers when they are doing duty in yr car ...
Arj
#5 erstellt: 07. Sep 2011, 01:22
Adding to AN, home speakers are not designed to take vibrations..you will have problems not just placing it but also about keeping it safe from mechanical dmamage (Crossovers/drivers/cabinet could all come loose)
neono
#6 erstellt: 07. Sep 2011, 12:15
Agree. Mine,i seldom use these days,hence it doest matter even if it falls apart...
Car Audio setup
cheraz am 27.06.2009  –  Letzte Antwort am 16.03.2018  –  15 Beiträge
Best Speakers to get within my range?
Archangelx99x am 07.04.2004  –  Letzte Antwort am 23.05.2005  –  11 Beiträge
Mid-fi Car Audio: Where to start, how to go about?
abhi.pani am 24.10.2006  –  Letzte Antwort am 30.04.2007  –  2 Beiträge
TV - which is better.Sony Wega or Philips?
juggy_25 am 10.07.2006  –  Letzte Antwort am 09.10.2006  –  32 Beiträge
Help finding best speakers within my price range
Archangelx99x am 08.04.2004  –  Letzte Antwort am 01.05.2005  –  5 Beiträge
Need Suggestions For Car Hi Fi
Amp_Nut am 09.01.2008  –  Letzte Antwort am 14.01.2008  –  46 Beiträge
information needed in car audio system
rajeshmathew am 20.08.2004  –  Letzte Antwort am 29.04.2005  –  3 Beiträge
Need Advice On A 2 Channel Sound Card
Amp_Nut am 02.12.2006  –  Letzte Antwort am 06.12.2006  –  23 Beiträge
NEw car audio system
kewl am 23.10.2005  –  Letzte Antwort am 08.11.2005  –  17 Beiträge
CDP Output impedance
Manek am 19.08.2007  –  Letzte Antwort am 22.08.2007  –  20 Beiträge
2011
  • Registrierte Mitglieder930.950 ( Heute: 3 )
  • Neuestes MitgliedBlackx_
  • Gesamtzahl an Themen1.564.234
  • Gesamtzahl an Beiträgen21.847.817
