What are Dipole & bipole speakers
SUNILYO
#1 erstellt: 24. Jul 2006, 07:59
could anybody help me what are dipole/bipole speakers and where can they be best used.
If there is any previous thread on this topic please let me know.
SDhawan
#2 erstellt: 24. Jul 2006, 13:46
Two similar speakers mounted on a single cabinet back to back (at about 90 degree) and with a phase difference of 180 degree. These are used as surrounds to give a diffuse sound and a greater "ambience" effect.
They are used in 5.1 movie setup but are not of any use in 6.1 or 7.1 setup and should not be used in multichannel music setup.
I think Bipole & Dipole are same (?)
Regards
Sanjay
[Beitrag von SDhawan am 24. Jul 2006, 13:49 bearbeitet]
SUNILYO
#3 erstellt: 25. Jul 2006, 05:59
This is what i read at AVForums yesterday.
"The drivers (the speaker in a speaker box) of a bipole speaker fire in different directions but in phase to diffuse the sound as opposed to dipoles which fire in different directions out of phase (ie 180 degree) - that means while one driver pushes the other one retracts.
Dipoles are supposed to be the most diffuse and hence very suitable for creating ambience of movie soundtracks while normal speakers (also called monopoles) are very directional and hence preferred for music.
Bipoles are somewhere in between and (can) have a better bass response as dipoles where the sound of the bass from both drivers cancels each other out due to the design (speakers operating out of phase)."
topic link
SDhawan
#4 erstellt: 25. Jul 2006, 07:51
Yes I just confirmed that's right:
Bipole - in phase
Dipole - out of phase by 180 degrees
I wasn't sure earlier that's why I had put (?)
Regards
Sanjay
Debu
#5 erstellt: 07. Aug 2006, 18:45
You can also mount the monopole (typically surrounds) at a higher height, so that the sound gets easily reflected by the roof and opposite wall, thereby creating a diffuse effect. IMO, instead of a dipole, using monopole in this way is better if you are interested in both music and movies.
- Debu
SUNILYO
#6 erstellt: 08. Aug 2006, 05:29
Hi Debu,
thanks for that suggestion.
Earlier I was thinking of adding towers for the surrounds. According to you is it advisable.
Regards - SY
SDhawan
#7 erstellt: 08. Aug 2006, 06:55
Dipole should be avoided if you are planning to:
- play multi-channel music
- have 6.1 or 7.1 speaker configuration system
Regards
Sanjay
SUNILYO
#8 erstellt: 08. Aug 2006, 07:18
Doc/Debu
You mean i should go for standmount/satelites for the surrounds ???
If so which one would you advise.
Debu
#9 erstellt: 08. Aug 2006, 17:30
There are some people who make high towers for surrounds, check surround towers.
However, most popular are wall mounted surrounds, you may use a wall bracket, or make a wooden one using carpenter help. Also it is advisable to leave some gap (typically 6-8 inches) between the speaker and the wall for a good sound quality.
- Debu
Debu
#10 erstellt: 08. Aug 2006, 17:33
Yes, bookshelf/ wall mount are typically used as surrounds, as they dont do as much work as front speakers and of course, it saves money.
- Debu
SDhawan
#11 erstellt: 08. Aug 2006, 19:30
In a surround system about 70 % of the job is done by center speaker, 25 % by fronts + sub and only about 5 % by surrounds.
So, don't waste you money in floorstanders for surrounds. Bookshelf are more than enough - decent ones easily go as low as 50-60 Hz - the rest is taken care of by Sub.
Regards
Sanjay
Klegg speakers!
atmadesh am 19.07.2005  –  Letzte Antwort am 21.07.2005  –  5 Beiträge
what are the HT speaker packages available in 30 to 35k
Sonic_Master am 11.04.2006  –  Letzte Antwort am 17.08.2006  –  8 Beiträge
What is impedance and ohms?
SUNILYO am 03.07.2006  –  Letzte Antwort am 06.07.2006  –  9 Beiträge
Help me decide on Speakers & Receiver
vjsvohra am 21.04.2004  –  Letzte Antwort am 20.10.2004  –  17 Beiträge
Short Term & Long Term Power in Speakers
SUNILYO am 07.07.2006  –  Letzte Antwort am 17.07.2006  –  17 Beiträge
Which Denon AVR & which speakers?
SDhawan am 21.08.2004  –  Letzte Antwort am 29.02.2016  –  13 Beiträge
a/v reciever and speakers
chrismac am 21.03.2005  –  Letzte Antwort am 13.06.2005  –  7 Beiträge
Where to purchase stereo speakers??
dsantamassino am 24.02.2004  –  Letzte Antwort am 15.10.2004  –  3 Beiträge
Speakers for yamaha rx-v450
pranab31 am 06.09.2005  –  Letzte Antwort am 11.09.2005  –  12 Beiträge
I need advice on speakers
Mikeelikeit am 27.02.2005  –  Letzte Antwort am 21.03.2005  –  5 Beiträge
2006
  • Registrierte Mitglieder930.935 ( Heute: 8 )
  • Neuestes Mitgliedchrisjeff
  • Gesamtzahl an Themen1.564.208
  • Gesamtzahl an Beiträgen21.846.835
