10" Driver for Mid bass will it be ok?
Sonic_Master
#1 erstellt: 12. Dez 2005, 06:58
Im planning to use a 10 inch driver for Midbass application
The woofer had got natural freq roll off after 2.2khz
I want to use the crossover point at 1800hz since the Tweeter can be crossed very easily...
The system is a two way speaker system who loves good bass with excellent treble...But I need to know what about mids with the 10 inch driver...
Ive seen many Studio Monitors using 10 inch driver in their two way active system. But a bit in Dylema regarding this..
Bookshelf with 10 inch driver? will it be good? but the front baffle will be exactly 10 inch as the driver
I need comments and suggestions for this...any drawbacks with this config?
cheers,
Sandeep
Vadi
#2 erstellt: 12. Dez 2005, 07:01
I think you should've posted in the DIY section.
Sonic_Master
#3 erstellt: 12. Dez 2005, 08:56
hi vadi
Im not talkin about the diy system. I am a Manufacturer so I just wanted to know the opinions...
cheers,
Sandeep
Sonic_Master
#4 erstellt: 12. Dez 2005, 08:58
The 10" driver is very fast in the response...so my intension is about to use it in the midbass kind...
Let me know ur opinion..
cheers,
Sandeep
newtohifi
#5 erstellt: 12. Dez 2005, 10:24
Do you already have the 10 inch driver?
what are the specs?
manufacturer?
price?
eric_clapton
#6 erstellt: 12. Dez 2005, 12:26
You shouldn't. A typical 10" will start beaming at around 700 Hz, affecting response in the 600-fc range. Unless it's exceptionally well-made. A lot of fullrange speakers are 8" and more, crossing over only at about 3-5 KHz to a supertweeter. But they are $upremely expensive.
The advantage of the bigger cone will be that excursion will be less for a given frequency, reducing IMD and doppler effects. But beaming is a more severe problem.
The reason you can get away with it in studio environments is that listening is mostly nearfield to midfield, and the drivers can be focused into one specific area. In home environments such tight specifications cannot be imposed on the room.
You can get away with 6" drivers albeit at a much higher cost. The Adire extremis is a good example, it's only 6.5" but couples a superb motor to a very good mechanical assembly to provide extreme linear excurions and yet preserve good piston movement up to about 4KHz.
If that is not an option, then you might try and implement a 2.5 way system with a couple of 6.5" drivers. That will keep the source size manageable and you get the benefit of doubled drivers.
If you still want to show off a 10" Woofer, consider mounting it on the side and powering it like Def. Tech. The effect is nice for HT, but for music it is not the best - though there's really no accounting for taste, your client may like it. You'll then need something to take care of midbass and high end, consider using a small coaxial or a small two-three driver complement.
deaf
#7 erstellt: 12. Dez 2005, 18:06
You will need an exceptional 10" woofer to go till 1.8kHz.Assuming that you do get one,the real deal will be how you cross over to the high frequency device.Let me assure you that none of the standard x-over topologies will get you the correct power response. .You will really have to search hard to find the correct x-over.It is there, but not published freely.Best of luck finding it.
Regards Deaf.
Will a MX power strip work for my amp?
zhopudey am 07.08.2007  –  Letzte Antwort am 07.08.2007  –  4 Beiträge
single driver vs conventional speakers
stevieboy am 24.10.2006  –  Letzte Antwort am 26.10.2006  –  30 Beiträge
your vote would be for Rotel, Marantz or NAD
Harmon_Bro am 09.08.2005  –  Letzte Antwort am 12.08.2005  –  14 Beiträge
Advise for speaker selection
sanjay am 11.09.2004  –  Letzte Antwort am 26.10.2004  –  41 Beiträge
Voltage Converter for nad320bee amplifier.
Hemanth am 17.01.2005  –  Letzte Antwort am 18.01.2005  –  2 Beiträge
Professional Amps for home audio
Manek am 01.07.2006  –  Letzte Antwort am 03.07.2006  –  10 Beiträge
Section for HDD/Computer Audio
Krish am 02.11.2010  –  Letzte Antwort am 02.11.2010  –  4 Beiträge
Standmounts for bedroom
myriad am 10.01.2005  –  Letzte Antwort am 13.01.2005  –  8 Beiträge
Would a Mini-compo be a good source?
Neutral am 15.06.2005  –  Letzte Antwort am 09.09.2005  –  26 Beiträge
Shud Center Channel be placed Vertical?
juggy_25 am 07.02.2007  –  Letzte Antwort am 11.02.2007  –  6 Beiträge
2005
  • Registrierte Mitglieder930.676 ( Heute: 2 )
  • Neuestes MitgliedRain_Ed
  • Gesamtzahl an Themen1.563.496
  • Gesamtzahl an Beiträgen21.827.118
