| HIFI-FORUM » English » Stereo (Engl.) » Good speakers for old system | |
Good speakers for old system+A -A |
kousik_s
erstellt: 06. Mai 2006, 09:35
Hi, I have a old Philips CD Mini System with twin cassette deck, FM and CD player. The model name is FW 630. Its output rated at 600W PMPO. The loudspeaker model is LSB650. It has terminals for 4 loudspeakers. Impedance of supplied loudspeaker is 6 ohm. If other front speakers are used, they should have same impedance. The speakers are 3 way bass reflex speakers with 5 1/4" woofer and mid treble is 2 1/2" tweeter. Upper treble is a piezo tweeter. Its amplifier is rated at 2x45W RMS/ 6 ohm/ THD 10%. Signal to noise ratio is 67 dBA. Frequency response is 40 - 20000 Hz. Now the issue.... I am not satisfied with the sound of the speakers. When something with heavy bass is played, the speakers start making metallic noise and there is too much distortion. Also, at high treble, the sound is not clear. I have already bought the Sonodyne Cinque 5.1 HT package. But, the Philips System do not have a line out. I can connect the Philips to AV Receiver only using Headphone out. I have decided to replace the speakers and keep the system intact (rather than selling it). For speakers I have chosen the Sonodyne bookshelves whose specifications are as below: Description : Bookshelf Speaker System : 2-way vented Enclosure : 15mm MDF internally braced Transducer Complements : 1 x 5¼“ Polypropylene Cone Midrange 1 x 1” Fabric Dome Tweeter Nominal Impedance : 8 Ohm Frequency Response (+3dB) : 45 Hz ~ 22 kHz Sensitivity (1w/1m) : 88 dB Continuous Power : 60 watt Crossover Frequency : 1.5 kHz Crossover Type : 4th order Linkwitz Riley Grill : Heavy duty black knit stretched on a single MDF frame Finish : Natural wood with high gloss top and bottom Dimensions (hxwxd) mm : (312 x 200 x 215) Net Weight : 5.3 Kg Please suggest whether these speakers can be used with my Philips system. Thanks. |
Amp_Nut
erstellt: 06. Mai 2006, 14:40
I GUESS that in honest terms, that translates into 25 Watts per channel into 8 ohms.... just so that you can compare realistically.... 600 Watts ... Whew ! I suspect it does not even draw that much power from the mains...
Careful.... the dsitortion that you hear could as well be from Amplifier overload, though I suspect the entire system is throwing in the towel... Try another pair of speakers from a friend, before you put good money after bad. Time marches on and even Great Men Fade Away.... Technology and the market today offer good options, to hear good sound. Enjoy yourself and visit a few Hi Fi Outlets to see what is on offer now a days... Cheers |
kousik_s
erstellt: 07. Mai 2006, 05:42
Amp Nut, before even trying another pair of speakers I need to know whether the speakers will be damaged if used with my Philips system. I have heard the Sonodyne bookshelves with their Stereo Amplifier, but not sure if that can be used in my system. If other speakers cannot be used, then I have the option to replace the whole system. But then, I have to buy a separate Dual Cassette Deck (Onkyo is 18000, nothing else available in Kolkata), a Stereo Amplifier (maybe Sonodyne) and Sonodyne Bookshelves (Rs.8500), which is a costlier option. |
Arj
erstellt: 07. Mai 2006, 09:39
most of the minicompos have speakers more or less designed for them.. and the limiting factor for sound include the amp itself as mentioned by amp_nut. I would also be worried about the amp damaging itself as well whe you do try them on dont increase the volume cotrol too much even if the sepakers are not playing loud enough ! |
Amp_Nut
erstellt: 07. Mai 2006, 11:40
Hi Kausik, Nah... the external speakers are most unlikely to be damaged when connected to your combo saystem. Give it a try, and see if the Combo + New speaker played together give the desired results .... Sound volume and quality. If they do, then they are fairly "Matched". Cheers |
Amp_Nut
erstellt: 07. Mai 2006, 15:12
Hi kaousik, Just slipped my minfd... you coulkd also get the old speaker fixed... should cost you approx Rs 100 ! Cheers |
square_wave
erstellt: 08. Mai 2006, 08:12
You can get plenty of slightly used cassette decks from makes like technics, pioneer, yamaha etc.. for 5k or less. Believe me, there are lots of them in the market. They will easily serve you for another 5 to six years. Paying 18k for an Onkyo deck is daylight robbery. Somebody selling that stuff for that kind of money at this age should be whipped. Norge amp and Norge bookshelf speakers will cost 7k each. Both better than the sonodyne stuff. Go for something like this if you want decent sound. Good sound needs good synergy and each component will contribute for good or worse. Plonking a good speaker on an old Philips war-horse is the worse thing that you can do. |
kousik_s
erstellt: 08. Mai 2006, 09:02
I problem is I stay at Kolkata where only Sonodyne has a proper outlet - a listening room, and Onkyo has a single dealer. There are grey market in areas like Chandney Chowk and Madan Street, and they have no knowledge of good brands like Norge or even other good Indian hi fi. My choices are limited. On the twin cassette deck, ProFX site lists denon at around Rs.18,500 (Model No DRW695). Anyway, there are no dealers in Kolkata. Even Sony Centre here does not keep the Sony Cassesste Decks. They only sell HTiB or the Combo systems. Sonodyne, Philips no longer makes cassette decks. I have loads of cassettes and also do tape to tape dubbing. And cannot give up on cassettes and convert everything to MP3. Cassette deck is the only reason I am not selling off my Philips system. And I don't want a non-branded local model available in places like Chandney Chowk. |
kousik_s
erstellt: 08. Mai 2006, 09:07
Thought about that. But after hearing Sonodyne Cinque, I heard better sound than Philips. And the speakers are working, so minor repair will not improve the quality of sound that it is capable of. Hence, the decision to replace the speakers. The only reason to hold on to the main system is the twin cassette deck as the alternative separate from Onkyo costs more than I expected. I can go upto Rs.10000 for a twin cassette deck. [Beitrag von kousik_s am 08. Mai 2006, 09:09 bearbeitet] |
abhi.pani
erstellt: 08. Mai 2006, 10:16
Hi Koushik, Where are you man...You can get a Yamaha twin cassette player (without built-in amp) for 9k...brand new with papers and awesome results. Its the same player that Sonodyne uses in its Bangalore showroom to play cassettes while displaying its amps and speakers. You can even ask Sonodyne if they can get it for you...Dont go for anything beyond that. That Sonodyne bookshelves you are considering are not so good..they are okay...if you like their sound then its cool. |
kousik_s
erstellt: 09. Mai 2006, 10:19
I know that Sonodyne bookshelves are medium quality. But I can't expect better for Rs.8500. And I can't go for towers due to space constraint, else their Sonus 2605 is very good. Can you suggest any better bookshelves for below Rs.10k available with papers. |
soulforged
erstellt: 09. Mai 2006, 10:38
Kausik, check out the other Indian makes in the market - Space (music ranch), Torvin (audio planet) and Sanen (dunno if its available in Bangalore), you might find a good pair of bookshelves within your price range... However, if you can stretch your budget to around 15K, then the range expands to include Wharfedale, Boston, Polk Audio and even Kef (I think)... *edit* Just read that you are from Kolkata not Bangalore...but you can find these brands there as well. I would suggest you to check out Sanen once. [Beitrag von soulforged am 09. Mai 2006, 10:40 bearbeitet] |
abhi.pani
erstellt: 09. Mai 2006, 10:56
Boston Acoustics has a good bookshelf model in 11k range and Wharfdale diamond 9.1 is again 12k. You can get most of these at Kolkatta, but you have to do some more dealer search. Else contact the dealers here at Blore and ask about their counterparts in Kolkatta. |
kousik_s
erstellt: 09. Mai 2006, 12:25
Wharfedale has a dealer at Dover Lane, Kolkata. I thought they were more expensive. But, I have to make some provision for a dual cassette deck as well, since some postings suggests that pairing better speakers with my Philips combo could damage the speakers. |
diskspinner
erstellt: 10. Mai 2006, 03:31
There are couple of specialist audio shops at Sarat Bose Road as well (near lake gardens), but at 10k mini compo with cassette deck is the only way to go. If not Philips/Sony look for other company, somebody must have a tape system. Even I have so many tapes left behind at my home. I have upgraded many of them to CDs (I mean... bought CDs). |
abhi.pani
erstellt: 10. Mai 2006, 04:19
Hey guys cmon, just try and catch hold of a guy who can get you Yamaha products (AVR etc...), Yamaha has a very good dual cassette player for 9.5k (no amps in built). I am sure any Yammy dealer or retailer can get you one. Its available in plenty. |
Shahrukh
erstellt: 10. Mai 2006, 06:11
Fancy market dude. Go to the Kideerpore electronics market.. you're bound to get some decent stuff there! |
souravin
erstellt: 10. Mai 2006, 12:09
Hi Kaushik, there is a dealer at Sarat Bose Road.just opposite to Padmapukur S.K.Traders.They keep a lot of music stuff and within a low to high range.Ask there. Regards Sourav |
myriad
erstellt: 11. Mai 2006, 03:10
Hello Kaushik, Here's a list of Kolkata dealers and the brands they deal in: 1. Japanico International 7th Floor, Vasundhara Building, Sarat Bose Road. Tel No.24743968 Brands:- Yamaha, Denon, Pioneer, Klipsch. Very soon getting Paradigm also. 2. SKS Traders. Opposite Paddapukur, Beltala, Sarat Bose Road Contact Mr.Subho Pathak, 30940539 Brands:- Project, Wharfedale, Dali, Cambridge audio, Nad 3. Digital Acoustics, Dover lane Tel No.24617594 Brands:- Tannoy, B&W, Harman Kardon, Onkyo, Invisible Velodyne, JBL For used stuff you can check out with Rajesh Tanna. His cell no 9331840158. Most of the time he has Denon, technics, yamaha and nakamichi cassette decks in stock. Good luck |
abhi.pani
erstellt: 12. Mai 2006, 05:12
What else do you want buddy Koushik......... |
souravin
erstellt: 17. Mai 2006, 06:15
thanx myriad for this useful dealer info in Kolkata. There r a lot of people in Kolkata searching 4 HI Fi Systems sply turntables but have to satisfy themselves buying pre owned stuff just becoz of lack of dealers and proper info.This will serve them a lot & all Kolkatans like us can find the right music stuff 4 as per our requirements and budget. thanx again. Regards Sourav a vinyl lover |
speakers for my computer sledgehammer am 09.01.2004 – Letzte Antwort am 14.01.2004 – 5 Beiträge |
Good front speakers for Sony STR-DE597 Alymangy am 10.01.2005 – Letzte Antwort am 10.01.2005 – 2 Beiträge |
Speakers for Quad 22 amps udit am 12.03.2004 – Letzte Antwort am 15.03.2004 – 5 Beiträge |
speakers for marantz pm7001 bobbybpl am 25.03.2007 – Letzte Antwort am 06.04.2007 – 11 Beiträge |
Speakers for a Nad 370 Porkstone am 17.01.2004 – Letzte Antwort am 23.01.2004 – 5 Beiträge |
speakers for NAD C521BEE/C320BEE mr_vishal am 01.02.2005 – Letzte Antwort am 13.09.2006 – 162 Beiträge |
Jamo Speakers Manek am 08.01.2004 – Letzte Antwort am 07.02.2004 – 3 Beiträge |
a good stereo system kishore am 31.07.2004 – Letzte Antwort am 12.08.2004 – 6 Beiträge |
suggest good rear speakers / bookshelves for under 10,000 trivisingh am 09.03.2005 – Letzte Antwort am 10.03.2005 – 21 Beiträge |
Speakers for NAD C352 in_step am 29.03.2005 – Letzte Antwort am 29.03.2005 – 8 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.676 ( Heute: 7 )
- Neuestes MitgliedRemklep
- Gesamtzahl an Themen1.563.504
- Gesamtzahl an Beiträgen21.827.345
