Umfrage
Biwire or not
1. Biwiring works in all setups (8.3 %, 1 Stimmen)
2. Biwiring works in mediocre setups (16.7 %, 2 Stimmen)
3. Biwiring works only in high or extreme goos set-ups (16.7 %, 2 Stimmen)
4. It's better to put money on good CD's (58.3 %, 7 Stimmen)
(Die Umfrage ist beendet)
Biwire or not
SUB_BOSS
Gesperrt
#1 erstellt: 02. Mrz 2006, 10:25
Does biwiring help?? Linn's can be tri-wired ..oops triple your speaker cable budget if your amp permits..does this really benefit you in proportion ??.....
Arj
#2 erstellt: 02. Mrz 2006, 10:33
well it really depends on the speaker. some speakers take to it, some dont and some dont even have that option.
IMHO if you have a budget for cables better to spend it all on the best quality cable rather than 2 lower quality cables... but again other may have a different opinion. and some dont believe cables make a difference (Do they ?)
in the end i prefer the final option of spending it all on CDs
Manek
#3 erstellt: 02. Mrz 2006, 13:05
bi-wire with bi-amping sometimes would make a difference in sound quality.
Just simple biwiring(two sets of wires from the same amp terminals to speakers) is a no no in my books. Just use the same small piece of jumper wire as the speaker cable and you are set.
Manek.
Manek.
Amp_Nut
#4 erstellt: 02. Mrz 2006, 13:23
Maneck said: Just simple biwiring(two sets of wires from the same amp terminals to speakers) is a no no in my books. Just use the same small piece of jumper wire as the speaker cable and you are set.
I totally agree !
Shahrukh
#5 erstellt: 02. Mrz 2006, 13:40
A cable company that doesn't believe in biwiring? Now that's an interesting read:
http://www.cobaltcab...s.htm?source=Adwords
square_wave
#6 erstellt: 02. Mrz 2006, 13:56
I agree with ARJ. If it works for you, do it. Endless debates are there on numerous audio forums. End of the day, it is like the “electrical cable vs hi-end cable” debate only. Some can make out the difference, others can’t.
nindo
#7 erstellt: 02. Mrz 2006, 14:04
guys...i think the bi-wire funda was introduced by the cable manufacturers just to boost the sales...rather double it....
Shahrukh
#8 erstellt: 02. Mrz 2006, 14:08
nindo schrieb:
guys...i think the bi-wire funda was introduced by the cable manufacturers just to boost the sales...rather double it.... :D
Not all cable manufacturers nindo. Refer to my last post.
bombaywalla
#9 erstellt: 02. Mrz 2006, 20:07
Amp_Nut schrieb:
Manek said: Just simple biwiring(two sets of wires from the same amp terminals to speakers) is a no no in my books. Just use the same small piece of jumper wire as the speaker cable and you are set.
I totally agree ! :)
Amp_nut, Manek: can you please explain why you guys think that "two sets of wires from the same amp terminals to speakers is a no no in my books"?
Thanks!
Re. biwiring, my experience seems to mirror what "Arj" said earlier: some speakers take well to it, others are ho-hum about it & in still others it makes no diff.
There seem to be several reasons to biwire (or not) & one of the reasons is back-EMF from the speaker drivers into the x-over network.
When I used to have B&W speakers, upon the manuf suggestion, I did biwire them in the "no-no" method cited by Manek & I can tell you that it made a diff to the sound for the better. I did compare the sound thru them single-wired & biwired. The jumpers I used were from the same manuf as the speaker cables.
I'm not sure that I have a concrete explanation for why the "no-no" biwiring method was successful but 1 hypothesis that I had was that with biwiring, the tweeter-mid xover & the woofer xover BOTH saw a low impedance (that of the amp) at the same time. Hence, if there was any back-EMF from the drivers to the x-over, there was a very low imp path for it rather than this back-EMF running around the x-over boards & polluting everything.
Empirically, I find that those speakers whose x-overs are carefully & well-designed, biwiring has little or no effect on their overall sound. In fact, manuf of those speakers specifically tell the user to not biwire.
Amp_Nut
#10 erstellt: 03. Mrz 2006, 06:24
Hi Bombaywalla,
I agree, that bi-wiring should in theory better seperate the Back EMF paths, and each damped seperately, at the speaker terminals.
However, my limited Practical experience showed no difference.... but I must admit that I tried alny using ordinary ( but thick, multi starnded ) wire.
I did not have at hand, 2 pairs of exotic cables...
Even when I tried 1 exortic pair + 1 ordinary pair, bi wiring.... the result was worse than no bi wiring.
I agree that results will probably vary with speakers and amp used in the set up.
Cheers
stevieboy
#11 erstellt: 03. Mrz 2006, 06:28
those whose tastes don't run to straight wiring can use 'bi' wire.
i agree with bombaywalla and amp nut. i think it all depends on the speaker and amp that you have.
Manek
#12 erstellt: 03. Mrz 2006, 07:29
bombaywalla,
hi
I agree on theory that providing a dedicated route for back-EMF, practically whenever I have tried it, its been an extremely small difference or no difference at all. As a matter of fact the times I thought there was a minor difference, I wondered if it were my ears just playing tricks with me or was there a real difference. Not a large enough difference to convince me that it actually is benificial.
But if it has worked for you......great !
Manek.
Does CDP really matter
Debu am 14.07.2006  –  Letzte Antwort am 25.07.2006  –  39 Beiträge
Does this price seem right to you?
Virgil am 19.07.2005  –  Letzte Antwort am 20.07.2005  –  7 Beiträge
Can You Hear A High Frequency 'Squeal' Your Colour TV ?
Amp_Nut am 30.06.2006  –  Letzte Antwort am 04.07.2006  –  17 Beiträge
Proportion of spending on respective equipments
SUB_BOSS am 03.02.2006  –  Letzte Antwort am 06.02.2006  –  15 Beiträge
Need your help, folks !
sandeep am 23.06.2005  –  Letzte Antwort am 24.06.2005  –  13 Beiträge
Need your opinion
novice00 am 25.04.2005  –  Letzte Antwort am 28.04.2005  –  3 Beiträge
How does this Cheap Set-Up Sound?
gplatt2000 am 01.11.2003  –  Letzte Antwort am 11.11.2003  –  7 Beiträge
Digital Cable Help
Arj am 24.03.2009  –  Letzte Antwort am 30.03.2009  –  19 Beiträge
Your signature
SUB_BOSS am 04.12.2006  –  Letzte Antwort am 02.01.2007  –  109 Beiträge
The Perfect Question
Sonic_Master am 20.12.2006  –  Letzte Antwort am 28.12.2006  –  36 Beiträge
2006
  • Registrierte Mitglieder930.973 ( Heute: 2 )
  • Neuestes Mitgliedtimhase2025
  • Gesamtzahl an Themen1.564.293
  • Gesamtzahl an Beiträgen21.849.652
