Make Cat-5 with Belden 1701A
sivat
#1 erstellt: 04. Sep 2006, 08:26
I have purchased a lot of Belden 1701A for making "Cat-5 Speaker Cable". This is a premium BONDED version with teflon insulation and a good alternative to 1585A. A litte more effort required...but the sound is also a little better !!
You can take any quantity you want....price is Rs.17.5 per feet. If intrested, please email info@corrson.com
http://www.venhaus1.com/diycatfivecables.html
Regards
Siva.
[Beitrag von sivat am 04. Sep 2006, 08:40 bearbeitet]
Amp_Nut
#2 erstellt: 04. Sep 2006, 08:49
Hi Siva,
This is GODSENT !
I have been looking for this cable for AGES.
The bonded pairs ensures that the twist between the conductor pairs is retained at all times, and the Twist plays a key role in the performance of the cable.
I will estimate the quantity that I need.... If memory serves me correct, I need Nine times the length for the TNT cable ?
Will also buy for making Interconnects.
Will PM you shortly. Hope you can despatch to Mumbai without too much freight !
Cheers
sivat
#3 erstellt: 04. Sep 2006, 09:55
We regularly ship via reliable couriers to places like Mumbai and Delhi. I'm not aware of variour shipping options and cost.
But if you can email your total requirement to info@corrson.com ... someone will respond immediately with all the detail including cost for shipping.
Can i suggest that you take Chris's approach ... than what is recommended in TNT. It gives better result.
For a 8 feet pair of speaker cable...you will require about 168 feet of this cable.
Regards
Siva.
Amp_Nut
#4 erstellt: 04. Sep 2006, 11:24
Hi Siva,
Great to hear from someone who has tried Both... the TNT & Chri's config.
Which one of the TNT speaker cables did you try ?
Also any similar advice for CAT-5 interconnects ?
zhopudey
#5 erstellt: 04. Sep 2006, 17:10
Errr.....super noob question coming up
The only cat5 cable I know of is used to connect computers together. Is this the same or some different cat5?
sivat
#6 erstellt: 05. Sep 2006, 02:29
Amp_Nut schrieb:
Hi Siva,
It was the triple T. An alternative would be to make the same cable after stripping the external sleeve....that might give an advantage...i think !!.
For interconnect...you can take just one pair of bonded cables. You can also try by braiding together 2 or 3 pairs. I have not tried this so far..
Regards
Siva.
sivat
#7 erstellt: 05. Sep 2006, 02:31
Yes; But a specific grade. This particular cable is almost 3 times more expensive that what is commonly availble in the market...and not generally available. The Belden distributor had to get this from Singapore...
abhi.pani
#8 erstellt: 05. Sep 2006, 04:50
Where do I go..
A week back I started this project to build a CAT5 based Speaker cable with Chris VenHaus recipe. I contacted Belden (Bangalore) they didnt have the teflon coated 1585A in stock hence I went ahead with 1583A (PVC coated). I always wished I could find the 1585A (Teflon coated) for my project. Now the project is 25% done...I see this thread from Siva...Where do I go..
[Beitrag von abhi.pani am 05. Sep 2006, 06:02 bearbeitet]
sivat
#9 erstellt: 05. Sep 2006, 05:12
That's going to be a hell a lot of PVC in your end-product. Infact more PVC than copper !!!
....not a very good idea Abhi.
You can still save 75% of work ...considering how much of effort it really is..
Regards
Siva.
abhi.pani
#10 erstellt: 05. Sep 2006, 06:11
Ya..
But what about the money spent ?? I paid 20 bucks per meter.
Now do I throw away that money or continue or...some thing else
SUB_BOSS
Gesperrt
#11 erstellt: 05. Sep 2006, 06:15
Ya..
Don't get disheartnede friend return back to dealer.. if he doesn't then you could possily complete your project.
abhi.pani
#12 erstellt: 05. Sep 2006, 06:26
May be I can try that.
But most probably he wont as he has cut 20 mtr piece from the spool for me...what will he do with it if I return ? ..But still I will try.
ALS
#13 erstellt: 06. Sep 2006, 07:54
Abhi, No doubt you 've to use Belden cat-5 with teflon quoting. Still, you proceed with your project. It's new to you & it's learning process & the investment is not that big to worry about. Brading is the trick of your project & it's not that easy to carry on. Pl see that, all the knots are reasonably tight & equidistant.
Later you can plan for with teflon coated. This braiding reduces the cable's indcutance to a max level. Since my cat-5 worked well in your system (they are not even Belden, just ordinary cat-5) teflon coated cables should do much much better in your system. You can buy the cable from Siva & keep it, it may not be available in retail.
ALS
#14 erstellt: 06. Sep 2006, 08:00
it should 've been teflon coated/insulated, Abhi sorry for the spel mistake.
sivat
#15 erstellt: 08. Sep 2006, 05:57
Just for clarification, based on multiple request that we received.
This is NOT a regular item for sale from Corrson...
I had bought couple of rolls (since the distributor refused to import smaller quantities) for personal use. Thanks to the good response from this ad....only about 600 feet is left(Sufficient for about 3 pairs of speaker cable)
It is available only on First come basis..
Regards
Siva.
ani
#16 erstellt: 08. Sep 2006, 06:06
Abhi,
I would like to bring one point to your attention.
All CAT 5 cables have some kind of Poly Ethlene insulation for induvidual conductors, some may use XLPE, Flurinated PE (that is what we call teflon which is not true). The outer sheath is mostly PVC. The Flurinated PE is used for conductor insulation to provide better fire extinguishing property. This Flurinated PE insulation is not at all comparable to real Teflon insulation as far as electrical properties are concerned.
Flurinated PE is also used in majority of so called highend cables and marketed as Teflon insulation.
So don't worry much about the PE insulated belden you have wih you, go ahead, I am sure you will end up with a good pair of cables. I have tried three types, oridnary CAT5 (Rs6/m), belden CAT5(Rs19/m) and belden 1701A(Rs.60/m).
There was a clear difference between ordinary CAT5 and beldens, but I couldnt hear any difference between Beldens.
All three were disposed off and am using a cheap QED Silver BiWire in single wire format now
abhi.pani
#17 erstellt: 08. Sep 2006, 07:01
Ani,
Thanks for the clarification, it has really inspired me.
BTW, can I ask why did you dump your Belden CAT5 and go for QED ? Did you find any clear negative aspects about Belden CAT5 based cables ?
sivat
#18 erstellt: 08. Sep 2006, 09:14
My experience is different Ani. I thought the same initially...until i tried the 1701A. It gave a signigicant improvement over the 1583A...especially the highs.
However, i'm not sure whether the difference is solely due to insultation material. It could also be due to the fact these are bonded cable and hence the uniformity of the braiding could have helped...my two cents !!
Regards
Siva.
[Beitrag von sivat am 08. Sep 2006, 09:26 bearbeitet]
ani
#19 erstellt: 08. Sep 2006, 16:59
Sivat,
I think you are right about the bonded pairs, both beldens I used were of bonded type and they were sounding better on HF than the ordinary cat5. Beldens HF was revealing but without any kind of edgeness.
Abhi.. the reason why I changed it is because I found a better placement for my speakers that gives me more depth and width, this called for very long 7.5m long speaker cables and when I tried connecting my CAT braid whole thing just didnt work, may be it is the capacitance god only knows. So I came across this QED which was working fine with my tube amp even at this very long lengths and was relativly cheap too.
warm regards
Anil
DIY Tube Preamp for Sale
sivat am 18.09.2007  –  Letzte Antwort am 28.09.2007  –  14 Beiträge
Mission DAD 5 and DAC 5
m2catter am 29.06.2009  –  Letzte Antwort am 18.07.2009  –  2 Beiträge
For Sale: Sennheiser HD580 with DIY amp and Kimberkable
zhopudey am 11.01.2006  –  Letzte Antwort am 02.02.2006  –  17 Beiträge
For Sale: Mint condition ?Cadence Arita ? bookshelves with ?Cadence? stands.
G_S_Madhav am 06.05.2008  –  Letzte Antwort am 15.06.2008  –  4 Beiträge
For Sale: Harmony 890 Universal Remote with RF
msb1 am 08.07.2009  –  Letzte Antwort am 08.07.2009  –  2 Beiträge
Tube Preamp: Acoustic Portrait Reference PM-1 for SALE
abhi.pani am 29.06.2009  –  Letzte Antwort am 27.07.2010  –  35 Beiträge
CRUCC 2.0 - Car Radio Universal Code Calculator ©2.0
CRUCC am 30.09.2005  –  Letzte Antwort am 09.05.2006  –  2 Beiträge
IEC Female Connector - to buy
bhagwan69 am 05.10.2005  –  Letzte Antwort am 06.10.2005  –  3 Beiträge
speakers for sale
Deb am 12.05.2006  –  Letzte Antwort am 12.05.2006  –  2 Beiträge
Dynaudio audiance 72
bobbybpl am 02.01.2009  –  Letzte Antwort am 18.01.2009  –  21 Beiträge
2006
  • Gesamtzahl an Beiträgen21.826.980
