For Sale: Mint condition ‘Cadence Arita ‘ bookshelves with ‘Cadence’ stands.
G_S_Madhav
#1 erstellt: 06. Mai 2008, 15:00
Mint condition ‘Cadence Arita‘ bookshelves with matching ‘Cadence’ stands.
About Cadence: (www.cadenceaudio.com)
Cadence needs no introduction on this forum! Cadence is the first and still the only high fidelity company in the Indian sub-continent. Cadence is committed to innovative designs and Quality without any compromise.
About the speakers:
First have a look at it:
(http://www.cadenceaudio.com/productfr.html)
ARITA is the smallest loudspeaker in the Cadence range and is a compact bookshelf with a performance that defies its size. ARITA is famous for its precise imaging, sound staging, neutrality and above all musicality.
Build, fit and finish:
ARITA looks very attractive with its well-proportioned body, clean lines and smoothly curved surfaces. The whole cabinet is made of 25 mm thick MDF to minimize the cabinet resonance. A 4 mm layer of REAL wood veneer (in mahogany or teak) is provided on all surfaces to give Arita that extra rich look and feel. The quarter-round fillets further provide a soft and smooth contour to all edges.
With 14.2 Kg each Arita is fairly heavy, well braced, damped and can easily pass the knuckle test with flying colors.
Overall the fit ,finish and build quality is World class!
Inside story:
Arita has two driver units. The Ferro-fluid cooled titanium dome type Tweeter is sourced from Vifa while the 7-inch bass unit is from Eton. This Eton bass unit has a ‘super fast’ cone, which comprises a sandwich of one layer of Nomex between two layers of Kevlar, providing rigid and quick-reacting piston-like motion. Termination is through a rubber surround. Both drivers are set flush into the front baffle.
The crossover network is designed with extra damping components to produce seamless integration of the system, and is linked with Van Den Hul (VDH) cable to very robust WBT terminals recessed low down on the back panel.
The reflex-loaded enclosure is lined with absorbent material and is braced near the middle and at the corners.
The silk-covered grille covers almost three forth of the frontal area, leaving the two reflex ports as a clearly visible feature.
NOTE: Arita comes with only one pair of speaker terminals so bi wiring is not possible.
Floor spikes are screwed into the base with help of large locking nuts and are reversible with a flat end for floor surfaces, which might be damaged by the sharp points.
Technical Specifications:
Bass/Mid:Super fast Dynamic Woofer with Kevlar/Nomex/Kevlar Cone System
High Freq: Titanium Dome Driver with Ferro Fluid Cooling
Crossover: Linkwitz Filters, additional damping
Crossover frequency: 2.4 kHz
Sensitivity: 86 dBs
Impedance: 8 Ohms
Listening Room Freq Response: 45Hz - 25 kHz (+/- 3dB)
Power handling:100 W RMS (each speaker)
Loudspeaker Terminals: Gold Plated, Oxygen Free
Internal Wiring:VDH OFC Carbon Hybrid Cable
Cabinet Material: Cadence proprietary composite-concrete Low Resonance cabinets
Ports: Low Resonance material bass ports
Finish:Cherry, Mahogany and Teak
Dimensions:443 X 212 X 290 MM (HWD)
Weight:14.2 Kgs each (without packing)
Cadence Speaker stands:
These aesthetically pleasing and sturdy like a rock speaker stands are specially designed and tuned for ARITA to attain maximum synergy between these two components.
These are not an ordinary pieces of wood but believe me a lot of engineering has gone into designing these stands. I don’t think any after market stands could match to these stands on quality and performance. After market stands might save a buck or two but at the cost of synergy.
These stands are so beautiful that as a stand alone entity they can serve as a nice pillar post to grace some nice brass/copper artifacts (antique)!
Performance:
Well after owning ARITA for last 18 odd months I can go on and on praising these babies but I restrict myself only to some salient features and weaknesses.
Strengths:
·Top notch build quality at par or even better than many leading international brands.
·Precise timing, Very neutral and non-fatiguing sound.
·The sound quality is unbelievable, especially live and natural vocal, with breath taking details.
·Very detailed mids and highs with tight and accurate base response.
·Crystal clear from top to bottom with quick transients, pitch-black silences and very wide soundstage.
·Bass is fully articulated, natural sounding, fast and controlled.
·The front-facing reflex port allows a location quite close to the rear wall if required, and the wide dispersion characteristics make inward angling less critical.
Last but not the least:
·Extremely musical and emotionally touching
Weaknesses:
None!
However,
·Some may find its bass lacking ear-catching thumps.
·With 86-db sensitivity, ARITA need slightly higher power with some good quality upstream electronics and really come alive when cranked up.
Final Words:
Arita is the Winner in every respect. It’s a great value. The clarity, imaging and realism of the sound, everything is beyond compare at this price.
Want a second opinion?
Just search on this forum for ‘Arita’ you will find good and only good comments on Arita. Our forum moderator Manek also owns a pair of Arita.
From where I got it?
Speakers are purchased from Oceanic – Pune in Oct 2006.
Why it is on Sale?
I have upgraded to Cadence ANINA hybrid electrostatic floor standers.
It is really sad to let go these cute Arita babies, it is rare to find anybody selling Aritas, in almost all cases, people even after upgrading to something else keep Aritas perhaps to build a nice HT system or small system in a bedroom; but unfortunately I am not that affluent, I need the cash for the upgrade.
What is in the box?
Just the speakers!
Original box: Unfortunately the original cardboard carton got damaged last year due to unexpected heavy rain. But I will provide some good packaging while shipping the unit.
Age and Condition of the speakers:
Just 18 months (purchased in Oct 2006) old and in MINT condition! The plastic on the speaker stands is still on.
Shipping and Insurance:
On actual, approx. Rs 2500`-3500 by road. (GATI)
Local taxes like octroi etc:Buyer to pay
Payment method:
Full cash payment in advance.
Papers:
I will issue my own receipt and a photocopy of the original invoice. Original invoice is available for verification
Audition:
Only on weekends with prior appointments.
Availability: Immediate, the Speakers are ready for shipping.
Price:
My investment:
Speakers: Rs 50625 (Rs 45000 + 12.5% Tax)
Stands: Rs. 15750 (Rs 14000 + 12.5% Tax)
Expected price:
Make your best offer.
Though I would prefer a buyer buying speakers and stands together, I can consider offers for individual components
SUhas
Source: AudioNote 3.1 X CD player
Control: Cadence VA1 20W pue class A
Monitor: Cadence ANINA hybrid Electrostat
Interconnect: VDH D-103 MKIII
Speaker Cables : VDH Gold water
[Beitrag von G_S_Madhav am 07. Mai 2008, 02:46 bearbeitet]
G_S_Madhav
#2 erstellt: 21. Mai 2008, 13:37
Guys, Cadence is increasing their prices, especially ARITA speakers and Arita speaker stands. There is a substantial price hike (almost double in case of ARITA speakers).
According to new price list w.e.f 1 June 2008, , ARITA speaker pair will cost Rs 90000 (including VAT) and stands will cost Rs 19125 (including VAT) so the combo will cost Rs 109125!
My ARITA pair with stands is still on Sale.
Right from the begining of the Sale I have kept the price tag rather on higher side (and was very strict about it_ because my ARITA pair is in Super MINT condition . But that eluded some potential buyers because then the difference between my price and the list price was not much. They must have been thinking that it is better to buy a new, fresh piece from the factory.
But now with the increase in the price by Cadence, the whole equation got changed. I am still sticking to my price, while the difference between my price and the list price is now quite huge!!!
It is rare to see a Cadence ARITA pair on sale, so hurry, perhaps this could be your last chance to get almost new ,Cadence ARITA at such a low price (compared to list price) !!!
PM me immediately
[Beitrag von G_S_Madhav am 21. Mai 2008, 13:38 bearbeitet]
G_S_Madhav
#3 erstellt: 14. Jun 2008, 09:30
SOLD!
It took time but finally the pair went to a new home. A fine gentleman got this. It is a WIN-WIN situation for both of us. I got the price I wanted and the buyer got the finest bookshelf speakers at this side of Rs. 100K.
I purchased this ARITA pair after a lot of research and auditioning about dozen+ speakers. I really loved them and was absolutely in tears while letting them go. How can I forget the hours and hours of joy these speakers gave to me?
Even though I now own a fine pair of ANINA Electrostatic speakers, I am going to miss those beauties a lot.
I thank you all who showed interest in this speaker pair and sorry that I couldn’t come down on price.
Regards
SUhas
[Beitrag von G_S_Madhav am 14. Jun 2008, 09:35 bearbeitet]
square_wave
#4 erstellt: 15. Jun 2008, 06:13
Congratulations Madhav
Good to see that you got a deserving customer. I heard the aritas for the first time a few weeks back. I agree with your evaluation of the Aritas.
Very nice speakers.
Cadence Stands on SALE.
abhi.pani am 04.07.2007  –  Letzte Antwort am 10.07.2007  –  44 Beiträge
CADENCE ARCA-4 for sale
antsy am 21.07.2006  –  Letzte Antwort am 08.05.2007  –  7 Beiträge
CADENCE AVITA FOR SALE
SNV am 15.04.2007  –  Letzte Antwort am 02.06.2007  –  6 Beiträge
Mint condition Cadence Diva loudspeaker for sale due to upgradation
Prithvi am 17.03.2006  –  Letzte Antwort am 22.03.2006  –  4 Beiträge
Cadence Amaya
Prithvi am 20.03.2007  –  Letzte Antwort am 23.03.2007  –  4 Beiträge
Many items for sale
Prithvi am 21.01.2006  –  Letzte Antwort am 23.05.2008  –  7 Beiträge
Cadence Amaya and Cadence VA1-HP
herculepirate am 28.10.2008  –  Letzte Antwort am 28.12.2011  –  19 Beiträge
Mint Condition Tannoy M2 for Sale
maxcoutinho am 21.05.2007  –  Letzte Antwort am 22.05.2007  –  2 Beiträge
Epos M12.2 for Sale
bharathana am 30.03.2010  –  Letzte Antwort am 05.04.2010  –  7 Beiträge
CADENCE Demo in Bangalore
goolimangala am 18.09.2006  –  Letzte Antwort am 12.10.2006  –  94 Beiträge
  • Gesamtzahl an Themen1.563.493
  • Gesamtzahl an Beiträgen21.826.938
