Gehe zu Seite: |vorherige| Erste .. 20 . 30 . 40 . 50 . 53 54 55 56 57 58 59 60 61 62 . 70 . 80 . 90 . 100 . Letzte |nächste|
Alles rund um Subwoofer aus den USA!
Benares
#2807 erstellt: 09. Okt 2015, 22:37
Funk kündigt auf seiner Facebook-Seite eine günstigere Version des 21.0 an:
We are going to be offering a new more budget friendly 21" subwoofer. I would like to get some feedback on the standard configuration that we should offer it in first. If we go as budget friendly as possible it would be a simple cube shape, 26" wide 26" high 26" deep, enclosure. The driver would have a paper cone, with our standard anodized aluminum inverted dustcap. And powered by our 2400 watt amp. Cost should come in around $3500 each USD, with the Master/Slave package at $6200 USD. If we made the enclosure with curved sides we can keep the width and depth the same the height would be 31", it would taper smaller towards the back, This would add about $400 to the cost, also we could do it with the full Carbon fiber cone like the current 21.0, that would add about $100.
Either way the standard finish will be textured black with large 1.5" radius on all corners. Veneer options will be available for extra cost as usual.
As for performance it will offer the best output for the money from 30hz down. At ~45hz it will about match the 18.0, with about 1-2db lower output 50hz up. From 30hz down however it will have the output of two 18.0's. A little bit of a tradeoff compared to our other products as I would not recommend using it as high up as our 18.0 and 21.0 that excel above 80hz and can be used all the way up to 150-200hz, but for 60-80hz down range this new 21" will be a great way to get massive low end output.
The Motor we are using for this new driver is a Neodymium under hung design for very linear travel, with a full aluminum sleeve over the pole for low inductance and inductance linearity, it has 35mm Xmax with 42mm mechanical travel, each way.
Filou6901
#2808 erstellt: 10. Okt 2015, 08:23
Vielleicht kann hier jemand helfen ?
Habe mal eine Frage zu dem Menü von ALLDSP im FunkAudio :
Hier kann man bei High- und Low Pass folgende Einstellungen eingeben :
Zum einen die gewünschte Frequenz , dann noch folgende :
L-R 24db
But 6db
But 12db
Bes 12db
L-R 12db
But 18db
Bes 18db
But 24db
Bes 24db
Vom Werk voreingestellt :
High Pass : Fr. : Off But 6db
Low Pass : Fr. : 150 Hz L-R 24db
Was bedeuten nun diese ganzen Einstellungen,was machen u. verändern diese ?
Welche Einstellungen sollte ich hier am besten wählen,gibt es eine Empfehlung ?
Benares
#2809 erstellt: 10. Okt 2015, 08:48
Die Abkürzungen stehen für die Filterart: L-R heißt Linkwitz-Riley, But heißt Butterworth und Bes bedeuted Bessel. Die Zahl bezeichnet die Flankensteilheit. Die Filter unterscheiden sich in ihrer Charakteristik, siehe z.B. hier:
https://de.wikipedia.org/wiki/Butterworth-Filter
https://de.wikipedia.org/wiki/Bessel-Filter
https://de.wikipedia.org/wiki/Linkwitz-Riley-Filter
Welcher davon allerdings der Richtige für deine Situation ist, musst du selbst herausfinden. Das müssen dann die Ohren entscheiden.
[Beitrag von Benares am 10. Okt 2015, 08:48 bearbeitet]
Kratzfest
#2810 erstellt: 10. Okt 2015, 10:56
Irgendwo ist ja ganz praktisch wenn man viele Einstellungsmöglichkeiten hat, andererseits aber auch verwirrend und bringt im Gegenzug nicht viel. Mancher Besitzer ist damit schlichtweg überfordert. Ich selbst bin immer froh, wenn irgendwo nicht so viele Knöpfe und Schnickschnack dran sind.
Benares
#2811 erstellt: 10. Okt 2015, 11:05
Man muss sich halt damit beschäftigen. Das braucht natürlich Zeit und Muße. Wieviel das dann bringt, hängt natürlich von vielen Faktoren ab, v.a. vom Raum und der Aufstellung. Je besser die passen, desto weniger muss man nachher korrigieren. Die Möglichkeiten zum Feintuning, die heutige DSP bieten, sind schon toll.
Mine1003
#2812 erstellt: 10. Okt 2015, 11:18
Ich benutze für meinen Sub nen MiniDSP. Ist im Prinzip dasselbe, ich habe Abende gebraucht um mich erstmal reinzufinden..
Filou6901
#2813 erstellt: 10. Okt 2015, 12:12
Nun ja........muss dazu sagen, mein 18.0 hängt ja auch an einem Dirac DDRC88A , das passt schon alles !
Allerdings möchte ich mich nicht unbedingt auf diese Einstellungen von Funk verlassen, da ich z.B auch sehen konnte, das hier HighPass 20 Hz eingestellt war, was ja überhaupt nicht geht, ich dies auf off gestellt habe !
Nun stellt sich halt die Frage , sind da noch so kleine Überraschungen eingebaut,die ich beseitigen könnte ...... ?
Daher meine Frage !
bmwfreggle
#2814 erstellt: 10. Okt 2015, 12:34
Biste zufrieden...??!!!
Filou6901
#2815 erstellt: 10. Okt 2015, 12:38
Ich bin sehr sehr sehr sehr zufrieden !!!
bmwfreggle
#2816 erstellt: 10. Okt 2015, 12:42
na super...
Filou6901
#2817 erstellt: 10. Okt 2015, 14:11
Habe echt keine Ahnung was diese ganzen Filter alle bedeuten,was sie machen,wie sie eingreifen.
Daher eben mal alle durchgegangen,alle einzeln gemessen .
Ergebnis : HighPass von L-R 24db nun auf Butterworth 6db gestellt , dadurch bei 60 Hz ( Übernahmefrequenz ) ein Plus von 3db erzielen können.
So wurde nun die letzte kleine Senke erfolgreich behoben !
Weiß nicht ob man diese ganzen Einstellungen alle brauch, aber schön das man drauf zugreifen kann
In diesem Sinne..........Schönes Wochenende !
Benares
#2818 erstellt: 10. Okt 2015, 14:20
Die Frage hast du dir damit doch schon selbst beantwortet. Wenn du vorher schon sehr zufrieden warst, wirst du durch einen anderen Filter sicher keinen Paradigmenwechsel erleben, aber wenn dadurch eine kleine Senke verschwindet, wars das doch schon wert. Schließlich nennt sich das nicht umsonst Feintuning. Perfektionisten mit Spieltrieb oder Leute mit bestimmtem Hörgeschmack haben mit heutigen DSP die Werkzeuge in der Hand, ihrer Passion freien Lauf zu lassen. Und der Rest setzt einfach einen oder zwei PEQ und gut ist.
#Belgarion#
#2819 erstellt: 10. Okt 2015, 14:29
Du solltest auch den Lowpass komplett deaktivieren. Wenn du Dirac benutzt ist jeder DSP Eingriff am Sub selbst unnötig bzw. eher hinderlich.
Filou6901
#2820 erstellt: 10. Okt 2015, 14:32
Benares @ So ist es !
Bin etwas erkältet,bin zu Hause und habe etwas Langeweile. Dann kommt man schon mal auf solche Gedanken, nennen wir es Feintuning.
Es ist halt immer wieder interessant,wenn man etwas neues entdeckt,etwas dazu lernt, so ist das halt mit unserem Hobby !
Filou6901
#2821 erstellt: 10. Okt 2015, 14:35
#Belgarion# (Beitrag #2819) schrieb:
Du solltest auch den Lowpass komplett deaktivieren. Wenn du Dirac benutzt ist jeder DSP Eingriff am Sub selbst unnötig bzw. eher hinderlich. :prost
Ahhh , da wären wir wieder beim dazu lernen
Warum hinderlich ?
Ich konnte nur feststellen, steht Lowpass auf 200Hz, hört man ein leises Rauschen direkt am Sub, verschwindet aber wenn ich auf 150 stelle.
Also trotzdem doch besser auf 200 oder off ?
bmwfreggle
#2822 erstellt: 10. Okt 2015, 14:40
kann mir mal jemand direc erklären, ?? wozu wieso weshalb??
Benares
#2823 erstellt: 10. Okt 2015, 14:52
Eigentlich bräuchte Filou das für seinen Sub nicht, da der Funk bereits das funktionalste und weitreichendste DSP aller mir bekannten Onboard-Lösungen hat. DIRAC verfügt allerdings auch über FIR-Filter (zumindest bis 200 Hz) und kann natürlich ein ganzes Heimkinosystem entzerren und nicht nur den Sub. Deshalb macht es bei ihm natürlich Sinn, v.a. in Verbindung mit dem miniDSP.
Kratzfest
#2824 erstellt: 10. Okt 2015, 16:18
Ja, es wäre schön, wenn jemand mal die grundlegenden Unterschiede zw. Dirac, miniDSP, Antimode usw. erklären könnte. Bisher habe ich auch nicht gefragt, weil ich dachte, brauch ich nicht. Mittlerweile bin ich mir da gar nicht mehr so sicher.
Filou6901
#2825 erstellt: 10. Okt 2015, 16:37
Ganz ehrlich ........... ?
MiniDSP Dirac DDRC88A war die beste Investition die ich in Sachen Heimkino gemacht habe , für MICH - in MEINEM Raum !!!
Da es bei mir einfach unmöglich ist, akustische Maßnahmen zu treffen !
Habe es hier bestellt, allerdings noch für 1099,00 :
http://www.oaudio.de/Dirac-Raumkorrektur/miniDSP-DDRC-88A.html
Hat den Vorteil,man kann bis 8 Kanäle bearbeiten !
Voraussetzung sollte allerdings eine unsymetrische (Chinch) Verkabelung sein !
Für eine symetrische, also XLR , gibt es aber auch ein Gerät !
Benares
#2826 erstellt: 10. Okt 2015, 17:11
DIRAC ist eine Software, die ursprünglich aus dem professionellen Kinobereich kommt und inzwischen auch bei Heimkinofans beliebt ist. Damit kann man Mehrkanal-Systeme (z.B. 5.1. oder 7.1) entzerren.
miniDSP ist eine amerikanische Firma, die viele kostengünstige Hardware-Lösungen zur Raumkorrektur und Lautsprechereinmessung anbietet. Durch die Kooperation mit verschiedenen Software-Herstellern kann man miniDSP-Geräte auch mit einigen bekannten ab Werk aufgespielten Software-Lösungen kaufen, wie DIRAC oder Acourate.
Antimodes sind ebenfalls Stand-Alone Geräte, die im Gegensatz zu den meisten anderen mit einer vollautomatischen Einmessung arbeiten. Im Lieferumfang enthalten ist ein Messmikro, damit drückt man quasi nur einen Knopf und das Antimode misst automatisch ein und berechnet dann Korrekturfilter, ohne das dazu besonderes KnoHow erforderlich ist. Es gibt Antimodes nur für Subwoofer(AM 8033) und für Zweikanal-Sterero (Antimode Dualcore). Demnächst kommt noch ein Vierkanal-Modell für 2.2-Systeme (das allerdings exorbitant teuer ist).
[Beitrag von Benares am 10. Okt 2015, 17:11 bearbeitet]
bmwfreggle
#2827 erstellt: 10. Okt 2015, 17:16
ich denke das dirac mit Minidsp ist hier die beste Lösung, weil man damit das komplette System entzerren kann, bei Antimode 2.0 nur teilweise.
BennyTurbo
#2828 erstellt: 10. Okt 2015, 17:26
Du brauchst aber eine Vor- Endkombi dafür oder zumindest externe Endstufen. ..
Filou6901
#2829 erstellt: 10. Okt 2015, 17:38
Oh, das wusste ich jetzt gar nicht
Einfach hinter einen AVR klemmen geht nicht ?
BennyTurbo
#2830 erstellt: 10. Okt 2015, 17:50
Klar geht das, wenn der AVR Preouts hat. Du brauchst aber externe Endstufen oder Aktiv Lautsprecher. Die internen AVR Endstufen kannst du nicht mehr nutzen.
Filou6901
#2831 erstellt: 10. Okt 2015, 18:05
OK , wieder was gelernt ........
std67
#2832 erstellt: 10. Okt 2015, 18:12
es gibt auch eine Version mit zwei HDMI-In. Die Quellgeräte müssen dann natürlich auf (Multichanel)PCM eingestellt werden da das Gerät keine Decorder hat
bmwfreggle
#2833 erstellt: 10. Okt 2015, 18:18
wie dirac geht mit einer normalen AVR version nicht??
std67
#2834 erstellt: 10. Okt 2015, 18:29
doch
wie gesagt kommts dann per HDMI zwischen Quelle und AVR.
wugar
#2835 erstellt: 10. Okt 2015, 18:31
http://www.hifi-forum.de/viewthread-100-1886.html
BennyTurbo
#2836 erstellt: 10. Okt 2015, 18:35
std67 (Beitrag #2834) schrieb:
doch
klick
Aber nur 2 Quellen und die Höhen Lautsprecher werden nicht bearbeitet werden können da Dirac sie nicht kennt innerhalb der Tonspur.
Filou6901
#2837 erstellt: 11. Okt 2015, 08:06
Muss jetzt nochmal fragen :
Warum sollte der Lowpass deaktiviert werden, warum wäre dies eher hinderlich ?
Verstehe auch nicht was Dirac damit zu tun hat , Sub wurde auf Lowpass 150 gestellt , dann wurde erst gemessen ?
Joe_43
#2838 erstellt: 11. Okt 2015, 10:27
Hallo Benny,
ist zwar OT hier, interessiert mich aber trotzdem.
Wenn ich das mit dem nanoAVR richtig verstehe, wird das Teil VOR dem AVR angeklemmt.
Auch wenn jetzt die Presence nicht mit eingemessen werden, dürfte es ja dann trotzdem keine Laufzeitunterschiede geben.
PEQ dürfte dann auf direkt einzustellen sein.
Benares
#2839 erstellt: 11. Okt 2015, 12:02
Neulich stellte ich hier den Link zum einem PSA-Protoypen mit 6 15-Zöllern ein. Das Teil wurde an einen Kunden verkauft, der jetzt seine erste Messung postete. Zusammen mit seinen drei XS 30 SE kommt er in room auf gemächliche 136 Db@10 Hz...
http://www.avsforum....80.html#post37955289
BennyTurbo
#2840 erstellt: 11. Okt 2015, 18:33
Joe_43 (Beitrag #2838) schrieb:
Hallo Benny,
Korrekt Uwe... Die Signalbearbeitung hat zwar ein Delay aber dies bezieht sich ja auf das ganze Signal. Nur werden eben die Presence unkorrigiert weiter gegeben. Bedenke nur das du die Quellen also Bluray und SAT dann direkt dort anschließt ... Leider sind es eben nur 2 Quellen. Hat man noch Mediaplayer Konsole usw. Wird es schwer... Und du musst wohl an der Minidsp Box die Eingänge wechseln... Da an der Vorstufe ja nur ein Eingang genutzt wird.
Joe_43
#2841 erstellt: 11. Okt 2015, 18:51
Wäre eine interessante Geschichte, nur wird hier leider kein bitstream- sondern PCM-Signale verarbeitet ...
BennyTurbo
#2842 erstellt: 11. Okt 2015, 19:05
Korrekt anders geht es nicht ...
#Belgarion#
#2843 erstellt: 12. Okt 2015, 04:10
Aus dem gleichen Grund, warum man auch bei jedem "normalen Sub" den Crossover - wenn es denn überhaupt möglich ist - deaktivieren sollte: jeder Filter erzeugt gewisse Phasendrehungen. Da der Crossover schon durch das miniDSP bzw. ansonsten durch den AVR erledigt wird, ist ein zusätzlicher Lowpass am Sub unnötig und erzeugt ungewünschte Phasendrehungen, die die Integration mit den restlichen LS behindern können. Daher im Regelfall aus damit.
In seltenen Fällen kann es sinnvoll sein, den Sub steiler zu trennen, als es der AVR zulässt oder der Sub soll in ein System ohne Bassmanagement integriert werden, nur dann sind die Lowpassfilter sinnvoll.
Tobi1990
#2844 erstellt: 12. Okt 2015, 14:47
Also nachdem ich auf Power Sound Audio etwas aufmerksam geworden bin, wollte ich mal fragen
ob denn schon jmd. den V3600i importiert hat und etwas darüber sagen kann?
Ich hab nämlich grad mit einem auf deren HP gechattet(sehr toller Kontakt) und sie haben mir versichert, es wird
in naher Zukunft definitiv keinen EU-Vertrieb außer dem bisherigen geben.
Finde ich allerdings echt schade aber angenmmen der Euro-Kurs wird mal wieder besser, lohnt es sich m.M.n schon auch in UK zuzuschlagen
für diesen Woofer
Benares
#2845 erstellt: 12. Okt 2015, 14:58
PSA ist wegen dem ohnehin guten P/L-Verhältnis und dem UK-Vertrieb momentan wohl der attraktivste amerikanische Hersteller für europäische Endkunden. Ein Besitzer eines V3600 ist mir in Deutschland allerdings noch nicht begegnet. Der Sub ist allerdings auch noch ziemlich neu. In den amerikanischen Foren wird er hervorragend bewertet. Ein BR-Sub mit zwei 18-Zoll Treibern und 1700W RMS ist auch für amerikanische Verhältnisse eine Hausnummer, da ansonsten normalerweise nur geschlossene Modelle vergleichbare Membranfläche und Wattzahlen haben. Der Bolide wird jedenfalls wirklich mächtig Druck machen, soviel dürfte sicher sein.
Tobi1990
#2846 erstellt: 12. Okt 2015, 14:59
Ja laut Aussage des Vertrieblers wäre ich der 1. gewesen der ihn DIREKT bei Ihnen gekauft hätte und nach DE gegangen wäre aber hätte ja sein können, dass ihn schon jmd. in UK geordert hat und hierzulande was berichten kann
Würde den echt verdammt gerne mal live hören
Benares
#2847 erstellt: 12. Okt 2015, 15:04
Kein Problem, stell dir einfach 3 - 4 SVS PB 13 Ultra vor, die zusammen in einem Raum spielen - und die rund dreimal soviel kosten wie der PSA. Wenn du dich dann noch für den PB 13 interessierst, hast du irgendwas nicht verstanden...
Tobi1990
#2848 erstellt: 12. Okt 2015, 15:07
Haha ja ich glaube das kommt so ziemlich hin - Können wir nur hoffen, dass der Euro mal wieder auf 1,40 steigt
submann
#2849 erstellt: 12. Okt 2015, 15:19
Würde den echt verdammt gerne mal live hören :D
Wie gross ist denn Dein Raum?
Tobi1990
#2850 erstellt: 12. Okt 2015, 15:26
Den gibt es noch nicht - Bauphase dauert leider noch etwas aber ich denke es könnten zwischen 30 und 40 werden.
Wie gesagt, der Raum ist erst mal noch nur in Planung.
submann
#2851 erstellt: 12. Okt 2015, 15:29
Gut Danke, dann würde ich Dir eher auf Sealed Subwoofer raten, oder ist der Raum offen mit Küche etc.?
Tobi1990
#2852 erstellt: 12. Okt 2015, 15:34
Nee wird nur ein reines HK im Keller.
Da ist weit und breit dann mal keine Küche - zum Glück
Tobi1990
#2853 erstellt: 12. Okt 2015, 15:34
Aber warum Sealed?
submann
#2854 erstellt: 12. Okt 2015, 15:37
Tobi1990 (Beitrag #2853) schrieb:
Aber warum Sealed?
Schau mal hier paar Seiten zurück, wurde schon soviel drüber geschrieben hier
Tobi1990
#2855 erstellt: 12. Okt 2015, 15:51
ok also wieder einmal durchstöbern...
submann
#2856 erstellt: 12. Okt 2015, 16:03
Achsoo dachte Du bist hier schon länger unterwegs, weil Dich ja über PSA informiert hast!
Tobi1990
#2857 erstellt: 12. Okt 2015, 16:03
Naja in 1. Linie im SVS-Forum und XTZ-Forum aber bei den Woofern aus den USA ehrlichgesagt "Noch" nicht
Alles rund um Subwoofer aus UK
wugar am 24.06.2015  –  Letzte Antwort am 08.11.2019  –  45 Beiträge
Subwoofer aus USA?
/Toronto am 06.03.2015  –  Letzte Antwort am 06.03.2015  –  14 Beiträge
SW-315 aus USA
donmuellos am 31.08.2004  –  Letzte Antwort am 01.09.2004  –  2 Beiträge
Buttkicker aus den USA?
flortown am 06.06.2006  –  Letzte Antwort am 26.07.2011  –  12 Beiträge
Subwoofer für rund 1000?
Andi1986 am 13.05.2007  –  Letzte Antwort am 17.05.2007  –  7 Beiträge
Velodyne DD18 aus USA
olli-moe am 18.01.2010  –  Letzte Antwort am 08.03.2010  –  9 Beiträge
50 hz Subwoofer in den USA
BigMajorDawg am 03.12.2015  –  Letzte Antwort am 03.01.2016  –  3 Beiträge
Spannungsprobleme mit Aktiv-Sub aus USA?
dumbass am 16.03.2005  –  Letzte Antwort am 16.03.2005  –  2 Beiträge
Vienna acoustics active sub aus USA läuft der an 230V?
mistersister am 08.11.2009  –  Letzte Antwort am 17.12.2009  –  3 Beiträge
429$ Sub schlägt locker alles bis 1000? ?????
Gallopollo3 am 08.12.2004  –  Letzte Antwort am 08.12.2004  –  8 Beiträge
  • Registrierte Mitglieder928.473 ( Heute: 14 )
  • Neuestes MitgliedShawnglicK
  • Gesamtzahl an Themen1.558.284
  • Gesamtzahl an Beiträgen21.698.840
