HIFI-FORUM » English » Music & film (Engl.) » Manger Test CD ? | |
Manger Test CD ?+A -A |
bhagwan69
13:10
#51
erstellt: 27. Aug 2007, |||||||||
All said; The problem still exist. Most CD's cannot be played and appreciated / enjoyed on high end set ups. You need to have set ups that are forgiving and do not show all the apparent flaws in recorded music. Simple. This is my take. Forget the Ferrari and what ever else on Mumbai's roads........ |
Kamal
15:29
#52
Oh I agree! I remember I once borrowed a Mukesh compilation by Saregama from my brother for auditioning Virens' setup-it was unlistenable ! And yet, thru my brothers' Yamaha HT spkrs, it sounded wonderful-of course I love Mukesh & have developed the art of "listening through", irrespective of the system, if you understand what I'm trying to convey. This is esp true of old ,beloved music. |
Neutral
22:51
#53
Re recording / mastering quality, have you guys faced any problems with Indian releases of international albums. I found two CDs - one of Eric Clapton and the other of Jimi Hendrix - sounding really bad compared to my expectations. While I don't have the originals for comparisons, I definitely feel that the local music companies are messing up big time. ![]() What I hate the most is the hyped up sound and the use of unnecessary processing effects like flange, wah-wah etc that remove the purity and naturalness of the sound. That's why I like artistes like Diana Krall as to me her recordings sound much more pure. |
Neutral
22:57
#54
Will certainly contact you when I next visit my hometown, Mumbai ![]() ![]() Bhagwan, you say that your CD player won't play CDRs! Many folks say that using EAC to rip CDs actually improves the quality in the CDR copy version. It's sad that you can't take advantage of this. |
Neutral
23:00
#55
I actually saw her on U tube by chance singing along Andrea Bocelli. After that marvellous experience, I promptly obtained her Treasure album. ![]() |
Neutral
23:07
#56
Do take a look at my profile Shahrukh ![]() I guess even Viren's single-driver won't reproduce these upper harmonics. It's a design philosophy of the engineer - a decision on which tradeoffs to make - as no speaker design is ever perfect. |
Kamal
06:14
#57
erstellt: 28. Aug 2007, |||||||||
Interesting! If it sounds good to you, well, that is what is the most important! Could you plz post a picture of the spkrs, close ups? |
Shahrukh
08:41
#58
Hmmm... never really heard something like this. Would really like to do. I was always under the impresssion that Viren's spkrs were full range. |
Arj
09:28
#59
not true ! A copy can only be as good or worse than a CD never better. what could happen is the te redability of a CDR in a particular cd might be better than the original... |
anto
10:56
#60
I never found the CDR to be better sounding than original. I used EAC for grabbing the wav from the original CD and used Nero for writing. But because of some problem (may be with the software, or with the drive or with the CDR) I cant reduce the write speed to lesser than 16x. CDRs "may" sound better if written at lower speed, say @ 2x or 4x. |
SNV
13:14
#61
About a decade ago i had bought a professional stand alone cd recorder from a brand called HHB. I never have liked copies from a pc based writer. This recorder made copies identical to the orginal bit by bit. Infact i had to use cddar (compact disc digital audio recordable) and not our regular cdrs as they were not compatible with the recorder. Each blank would cost about rs 500. One can record only audio on these blanks and not data or video like on the regular cdrs. At this point all other stand alone recorders used scms (serial copy management system) which prevents you from making unlimited digital clones. But the HHB had a setting to bypass scms and one could make as many digital copies as required. Regards SNV |
Krish
13:49
#62
They are ! |
Shahrukh
13:59
#63
So I presumed! Neut, is urs a 2 way speaker / 3 way without a tweeter? It's certainly not a single driver from what I understand! |
Manek
14:03
#64
Thats one driver trying to reproduce the entire spectrum.....the drivers used (fostex, lowther, etc) are have a generic reference of being "full frequency drivers". They do roll off at higher frequencies > 10Khz and at the bottom octave or two. But then there are fans and I do have a liking for fostex over the lowthers. Manek |
Kamal
14:14
#65
They do! I have auditioned Virens Amp/Harmony Spkrs extensively, on several occasions with a wide variety of music & hence can vouch for their ability to do so. Of course, at the lower end ,they go down to 40 Hz so in that sense they can't be termed full range, but they cover the usable range to which 99% of the music conforms, easily. Their strength is the glorious midrange & highs alongwith a nice, controlled bass. Remember, they use a pretty special driver, the Fostex (Plz google to get more details of this driver) |
Kamal
14:18
#66
Arj wrote
I remeber reading a response from a senior Forum member that indeed copies can be better than originals provided the copy is made using black CDs. Care to add your opinion to that? |
Arj
14:35
#67
well if i remember right even i used to think that CDRs make perfect copies to the original untill I came across the Reed Solomon Error Correction. ![]() CDs dont store directly in 0s/1s but in terms of words which are a sequence of bits hence need to be decoded. since most cd players are not able to do that without errors initial attempts at CDs were failures. it was only with this error correction in whose reading some amount of extrapolation is also used, was cd able to be launched as a medium. thats is the reason transports DO make a difference. Bhagwan69 had posted an excellent link on the Nova Memory player which did multiple reads untill ALL the data was correctly read..thats is when yo have a perfect lossless. so all of us who have been making lossless copies without the multi read/error protection option may not be having the original..and if you write it in a CD you will not be having the original again (also take into account write errors by CD players) hence my statement
theoretically it can SOUND better if you have a perfect copy from the original and you use a good CDR (black are supposed to be good). but from what I know of CDs there is always losses of info right from the redbook to cd Father template and then to the mother masters. and finally from the Mother masters to the actual cds. how relevant they are and are they noticeable i really do not know. |
Shahrukh
14:47
#68
Bang on Arj! BTW, I think we've discussed this topic atleast twice on this forum! [Beitrag von Shahrukh am 28. Aug 2007, 14:48 bearbeitet] |
Kamal
16:06
#69
OK,Arj. While discussing the Nova Physics Music Player in the thread "25 Years of the CD", a senior member of the Forum had opined that Exact Audio Copy also enabled one to retrieve most of the data-your take on that? |
Arj
17:36
#70
should be true. i believe EAC has a mechanism of reread during errors ie in case it does not gat a reading or gets an error reading from the cdRom it re-reads so will not be surprised if you actually get a perfect copy. |
Kamal
18:51
#71
Did'nt know that! Thanks for the input, Arj. Is the process of making copies using EAC the same as in Nero? |
Arj
19:09
#72
well i would not be too confident of Nero..it is a cd writing software so may not rip well enough |
zhopudey
19:35
#73
For the purpose of ripping audio cds, EAC has no competition ![]() |
Neutral
19:52
#74
erstellt: 30. Aug 2007, |||||||||
Hi Shahrukh, It's a 2-way speaker: Bass: 12" Philips studio driver Midrange and lower treble: 3" Bolton driver Cabinet dimensions: breadth: 42cms, depth: 42cms, height: 80cms (simply huge ![]() Sorry, Kamal, don't have a digital camera, so can't post pics right now. Cabinet is made of 2cm thick plywood and is well damped with glass wool. Uses a Bolton crossover. My subjective opinion: Great for bass and mid range Effortless power Huge soundstage Natural sound No boom or resonance However, Air is subjectively less than in conventional speakers. Therefore, I conclude that higher treble harmonics were missing. Don't have a dB meter to verify these opinions, so they remain subjective. Re: Viren's speaker: Apologise for commenting on something I have not heard. ![]() However, from my reading, single drivers strength is a very clean midrange (due to no crossover distortions). The tradeoff is that a single driver rolls off at the two frequency extremes. I may be wrong, but it would be unfair to expect Viren's driver to go as my low as my 12" monster in a gigantic trunk-sized cabinet ![]() Speaker design is all about tradeoffs. Good full-range drivers are certainly more expensive than Bolton / Philips drivers, so maybe cost is the tradeoff here? [Beitrag von Neutral am 30. Aug 2007, 20:17 bearbeitet] |
Neutral
20:05
#75
EAC is an excellent software! It will read data from the CD a few times and compare these reads to ensure that it is getting the right information. Will take much much longer than regular ripping software. However, as far as I know, it will only make a copy on the hard drive? So, you may well need Nero / other writing software to prepare a CDR. My understanding of commercial CD making process: A master is used to make the CD copies. Towards the end of this master's life, it gets worn out and can no longer make good quality CD copies. So, if you get one of these 'lemons', then using EAC to write a CDR will 'really' give you a copy that is better than the original. Otherwise, the copy will be roughly the same as the original. Unless the original CD is in a really bad state, it is very unlikely that the differences will be apparent on a casual listen. I raised the issue with Bhagwan because he is privileged to have a highly resolving system. ![]() ![]() |
Kamal
20:14
#76
Nice, lucid explanation. Thanks,Neut! |
Amp_Nut
04:21
#77
erstellt: 31. Aug 2007, |||||||||
EAC Does include CD-Writing capabilities. Check out the lowest icon on the Left Hand Side. Also Tools / Write CD-R. However, EAC supports only select CD Writers ( Murphy's law - my CD Writer is not supported ![]() EAC's expertise is in a Perfect Read... Not write. Writing is only an incidental feature. Hence I use Nero or iTunes to Write the CD from the extracted wav file. iTunes permits me low speed writing ( 2x ) which Nero does not... Guys, check out EAC. Its FREE.... ![]() [Beitrag von Amp_Nut am 31. Aug 2007, 04:23 bearbeitet] |
bhagwan69
06:34
#78
erstellt: 22. Sep 2007, |||||||||
Dear Kamal, You got your Manger Test Disc [CDR]. Did you listen to it ? How was it ? Liked anything ? Comments !!! Thanks, |
Kamal
09:05
#79
Dear Bhagwan, unfortunately,around the 13th inst(the day of your visit)one of the woofers in my speaker system developed a fault-started distorting badly at a particular frequency-hence I am unable since then to listen to any music! Am trying to get it fixed up... Will get back to you then. Did you & S-I-O have a good, fruitful time during your Amritsar visit? |
bhagwan69
10:56
#80
Yes Sir, Amritsar was great; Golden Tample & Wagha Border were nice to visit. Ate some great Fish; The audio part was the best ! ![]() I really liked the set up. Was worth it. |
Kamal
13:21
#81
Thats nice. Could you plz give some details of the setup you auditioned & of the listening experience? |
bhagwan69
14:18
#82
I have sent a PM to you !!! All details are there. |
Kamal
18:11
#83
Saw it, thanks. I have PM'd back with a query-plz see. |
SDhawan
20:08
#84
Hi Guys ! Me too ! Please forward the PMs to me as well. |
deaf
15:08
#85
erstellt: 27. Sep 2007, |||||||||
Hi guys hated by wives forum, I have got 20 Manger test discs in, whoever wants one should pay Rs 1500/- for each. In God we trust, the rest in cash, is the mode of payment. Regards Deaf. |
deaf
17:18
#86
Ok guys I am down to 17 discs. First come first served. Deaf. |
deaf
11:53
#87
erstellt: 28. Sep 2007, |||||||||
12 discs left dudes. Deaf. |
Reference Recordings Manek am 08.10.2007 – Letzte Antwort am 25.10.2007 – 10 Beiträge |
Your latest CD purchases. Savyasaachi am 18.09.2007 – Letzte Antwort am 07.06.2015 – 102 Beiträge |
"Roja" tamil Audio CD from Magnasound ravi am 01.01.2006 – Letzte Antwort am 02.01.2006 – 2 Beiträge |
Miles Davis - Kind of Blue - Remasterd Gold CD Neutral am 11.02.2007 – Letzte Antwort am 26.02.2007 – 22 Beiträge |
Terminator 1 stvdc3 am 29.01.2004 – Letzte Antwort am 29.01.2004 – 2 Beiträge |
"Hero" SDhawan am 04.11.2005 – Letzte Antwort am 10.11.2005 – 5 Beiträge |
Nawang Khechgo SDhawan am 20.10.2006 – Letzte Antwort am 21.10.2006 – 3 Beiträge |
varying bit rates SUNILYO am 10.09.2007 – Letzte Antwort am 12.09.2007 – 8 Beiträge |
New CDs Krish am 05.05.2010 – Letzte Antwort am 06.05.2010 – 2 Beiträge |
software in Mumbai - reasonable price. bhagwan69 am 09.08.2008 – Letzte Antwort am 16.08.2008 – 24 Beiträge |
- Registrierte Mitglieder929.132 ( Heute: 7 )
- Neuestes MitgliedAruz953
- Gesamtzahl an Themen1.559.774
- Gesamtzahl an Beiträgen21.734.474
