| HIFI-FORUM » English » Offtopic (Engl.) » Dealers having Demoroom + Equips | |
Dealers having Demoroom + Equips+A -A |
Arj
#51
erstellt: 25. Nov 2007, 21:02
Amp_nut, Thanks for the response.. i guess anyone using bookshelf speakers and a manual int/pre amp will have these two problems for point 1 the only two solutions are a speaker upgrade or integration of sub(s). while 1 is very expensive for the same sound quality the other is a tedious process to get right.but regarding point 2..does not manually getting up to adjust the volume give the same old fashioned feeling of cleaning an LP record ? i have grown to rather like that
totally with you here..imaging is anyway controlled by the recording engineer rather than anything else..but on the other hand it is a nice feeling whne on one of theose test discs you get the imaging exactly right..you know then that the system is "tuned" id go further on point 3 and mentions about hearing rustling o papers, the light cough in the audience etc etc. you know then that the source is doing its job of extraction and the rest of the chain in carrying it without any loss.
This is good info..from what i do know the 800 series had always been designed for audiophiles if got right...and if not partnerred well or setup well can sound very dry and/or forward and sterile.
LOng posts are Good as long as they are not a personal attack (and we do have enough of those)..and regrading the "ji" Yessir..done ! |
Amp_Nut
#52
erstellt: 26. Nov 2007, 07:02
Sorry to contradict, but in my experience, its quite the opposite. The B&W 800 series ( atleast the Floor standing models ) tend towards the more romantic, mushy, bland and with a bloated mid bass sound, if not set up and partnered well... Even under the worst of situations, they Image well Ofcourse this is my personal experience |
Amp_Nut
#53
erstellt: 26. Nov 2007, 07:10
Arj Said
I totally agree with you.... In this respect, the first 5 seconds of the 1st track of "Jazz By The Pawnshop" are BREATHTAKING |
Manek
#54
erstellt: 26. Nov 2007, 11:05
amp nut...Jazz at the pawnshop has got godd music throughout manek. |
Amp_Nut
#55
erstellt: 26. Nov 2007, 11:21
Manek ( & Prithvi) .... I have not fully "Grown Up " ... Yet ... |
Jeeves
#56
erstellt: 28. Nov 2007, 13:28
Kamal many thanks! |
ani
#57
erstellt: 28. Nov 2007, 18:47
Hello all, This thread on demo rooms was very interesting and except for AVI,Hermit,Nova and few others no new names came up. So that pretty much sums up the hifi/midfi scene. Dear ANji, my experience with PL-1 and GR20 was pretty much the same as yours except that only the last octave was missing. I think the electronics do play a major role in image height and depth perception. PL though good has its limitations in those areas but it does wonder in bringing out the realism. The singers and instruments are there in real flesh and blood The best part of that amp is that it tolerates compressed discs well, lets you hear the compression but one can enjoy the music at the same time. Pretty nice tube amp and a steal for the price. |
Amp_Nut
#58
erstellt: 28. Nov 2007, 19:15
Hi ani, I am Glad that you liked the PL-1. Given my taste for ROCK, I think the PL-2 is STREETS ahead of the PL-1... IMHO ofcourse |
Amp_Nut
#59
erstellt: 01. Feb 2008, 13:48
I had said :
Sorry to rake up this old issue, but I feel it only appropriate to publicly declare / confess that I was Wrong I was earlier told that though B&W ensures that their dealers do Not discount the Recomended Retail Price, they allow a 15% discount in Hong Kong during the Chinese New Year. Since that is comming up, I called HK today, to explore ... The B&W 802D has a current Recomended retail Price in HK of US $ 15,384 or HK $ 120K. Hence my earlier price calculations and expectations of a fair Indian price based on an International price of US $ 12K was WAY off. Apologies I will probably buy the 802Ds later this year - from A2V - when my 'Den' is ready. |
bhagwan69
#60
erstellt: 01. Feb 2008, 14:08
Respected Sir, This itself is incorrect; The Suggested Retail price 'was' US $'s 12/- K. To the best of my humble understanding. Kindly Check in Paragon - Singapore. With the B & W Dealer. They may offer you the 'correct' suggested retail price. p.s. Do you 'like' the look of the 802D or its 'voicing' ??? |
bhagwan69
#61
erstellt: 01. Feb 2008, 16:12
Price References :- http://www.ultraaudio.com/equipment/bw_802d.htm http://www.hometheat...ox_System_p/802d.htm [14 K - here]Speciications Description: Three-way, floorstanding, reflex-loaded loudspeaker. Drive-units: 1" diamond-dome tweeter, 6" Kevlar FST-cone midrange unit, two 8" Rohacell-cone woofers. Crossover frequencies: 350Hz, 4kHz. Frequency response: 34Hz–28kHz, ±3dB, on axis (–6dB at 27Hz and 33kHz). Dispersion within 2dB of reference response: ±60° horizontal, ±10° vertical. Impedance: 8 ohms nominal, 3.5 ohms minimum. Sensitivity: 90dB/2.83V/m. Harmonic distortion (second and third harmonics, 90dB/m): <1% (40Hz–100kHz), <0.5% (70Hz–100kHz). Recommended amplification: 50–500W. Dimensions: 44.7" (1138mm) H by 14.5" (363mm) W by 22.2" (565mm) D. Weight, each: 176 lbs (80kg) net, 196 lbs (89kg) shipping. Finish: Rosenut-veneer with leather accents, woofer enclosure, lacquered Marlan (synthetic mineral-filled resin) mid and HF enclosures. Serial numbers of units reviewed: 557, 558. Price: $12,000/pair. Approximate number of dealers: 250. Manufacturer: B&W Loudspeakers, Dale Road, Worthing, West Sussex BN11 2BH, England, UK. US: B&W Group North America, 54 North Concord Street, North Reading, MA 01864-2699. Tel: (978) 664-2870. Fax: (978) 664-4109. Web: www.bwspeakers.com. http://www.stereophile.com/floorloudspeakers/1205bw/index2.htmlThis might be a reliable price reference....... [Beitrag von bhagwan69 am 01. Feb 2008, 16:23 bearbeitet] |
Amp_Nut
#62
erstellt: 01. Feb 2008, 18:22
Thanks for your inputs, bhagwan. I wrote today
I wrote that 30 minutes after I spoke to B&W distributor in HK. I had earlier TODAY called the B&W dealer in Mong Konk ( you know, less upmarket place... better price ) He told me that they do not sell the 800 series and I would have to speak to the B&W disty.The HK 120K price was from the HK disty ! Me thinks, that like the rest of Audio & consumer products, the US market has the LOWEST prices compared to anywhere else in the world. So its probably US $ 12 K in the US and US $ 15K3 for the rest of Earthlings Will explore Spore and Dubai too.... Anyone knows For Sure, do post. Thanks |
Amp_Nut
#63
erstellt: 01. Feb 2008, 18:29
The looks and finish, I find superlative, so they DO get brownie points there. The sound ... I have written my views on this thread
and
[Beitrag von Amp_Nut am 01. Feb 2008, 18:30 bearbeitet] |
**** MERRY CHRISTMAS**** Kamal am 24.12.2007 – Letzte Antwort am 28.12.2007 – 4 Beiträge |
Introduction? OregonDual am 22.11.2006 – Letzte Antwort am 02.12.2006 – 36 Beiträge |
Good RCA male plugs square_wave am 07.07.2011 – Letzte Antwort am 12.07.2011 – 14 Beiträge |
Denon service center Kamal am 30.01.2008 – Letzte Antwort am 12.02.2008 – 5 Beiträge |
300% as much the price of the system isnt it cheap? i think its cheap what do u say. Sonic_Master am 09.09.2006 – Letzte Antwort am 13.09.2006 – 3 Beiträge |
Suggestions needed for HTPC Ronnie22 am 24.09.2006 – Letzte Antwort am 20.10.2006 – 14 Beiträge |
Sledgehammer and the NRA 2_of_7 am 12.10.2003 – Letzte Antwort am 17.10.2003 – 9 Beiträge |
Speaker Switch paj4x4 am 04.02.2007 – Letzte Antwort am 28.02.2007 – 12 Beiträge |
PLINIUS 9200 INT AMP & CD-101 CD PLAYER ON DEMO AT ABSOLUTE PHASE Prithvi am 22.09.2007 – Letzte Antwort am 22.09.2007 – 5 Beiträge |
- Registrierte Mitglieder930.997 ( Heute: 6 )
- Neuestes Mitgliednisio
- Gesamtzahl an Themen1.564.404
- Gesamtzahl an Beiträgen21.852.914
) about whether the singer is 4 & half feet in height or 5feet 6 inches... or whether the 2 tablas are 2 feet or 4 feet apart...
