| HIFI-FORUM » English » Offtopic (Engl.) » PLINIUS 9200 INT AMP & CD-101 CD PLAYER ON DEMO AT... | |
PLINIUS 9200 INT AMP & CD-101 CD PLAYER ON DEMO AT ABSOLUTE PHASE+A -A |
Prithvi
erstellt: 22. Sep 2007, 05:12
Hi! Guys, Absolute Phase is happy to announce that we have the amazing Plinius 9200 Integrated amp & the CD-101 CD player. PLINIUS 9200 INT AMP:- ![]() ![]() To own a separate control and power amplifier is the dream of many music enthusiasts. Imagine having that level of performance in a single box. The design team responsible for the PLINIUS Odeon have forged and moulded a chassis system of function and beauty from the very best materials and this heritage guarantees performance and long term reliability. The PLINIUS 8150 set the standard for higher powered Integrated Amplifiers some years ago and each iteration of that model has kept PLINIUS at the forefront of this very important amplifier genre. The PLINIUS design team have kept the 9200 features in the now familiar curved chassis and have included Balanced Inputs for CD to satisfy the demands of audiophiles. Several aspects of previous PLINIUS Integrated Amplifiers have been continued in the 9200 including low noise, low distortion J FET input circuitry and the very best of discrete componentry. The 9200 will allow the connection of up to 4 source components plus Phono and has both Balanced and Single Ended connection for digital inputs while a Processor Loop allows full integration with a home theatre system. The Phono section has been highly praised and allows connection of both Moving Coil and Moving Magnet cartridges. An easily accessible gain change will give optimum results for both types of cartridges. The large toroidal transformer will drive the 9200 to power levels in excess of 200 watts per channel into 8 Ohms. The power supply has been given priority with an extremely low impedance stiff design being implemented. Difficult speaker loads are driven with ease to the most satisfying levels of volume while maintaining control and finesse. ![]() ![]() ![]() ![]() PRODUCT SPECIFICATIONS Power:200 watts per channel into 8 Ohms. Both channels driven from 20Hz to 20kHz at less than 0.2% total harmonic distortion Frequency Response:20Hz to 20kHz ±0.2dB, -3dB at 5Hz and -3dB at 70kHz Distortion:Typically <0.05% THD at rated power 0.2% THD and IM worst case prior to clipping Current Output:40A short duration peak per channel. Fuse protected Slewing:50V/µs Hum & Noise:90dB below rated ouput 20Hz to 20kHz unweighted Gain:Line inputs to speaker out: 40dB Phono Input To Pre-Out: 66dB on high gain, 60dB on low gain Input Impedance:47kOhms all inputs Input Overload:5V RMS Rated Pre Out Level:1.5V RMS into 47kOhms or higher Pre Out Source Impedance:Typically 1.5k Ohms Pre Out Minimum Recommended Load:47kOhms Tape Output Level:190mV at 200 Ohms. Tape loop muting at 5V RMS input Dimensions:Height 120mm (4.75"), Width 450mm (17.75"), Depth 400mm (15.75"), Weight 14kg (30lbs) PLINIUS CD-101 CD PLAYER: ![]() ![]() At the time we had no real idea where this journey would take us but as time moved on and new amplifiers evolved we realised that we had created something very special. The new PLINIUS look has been very well received by the Audio Public but the distinctive curves have created a gap. Very quickly we found that a source component was needed to match. We didn't really want to develop a CD Player as there are many very competent designs available but we were unable to withstand the constant pressure from our customers. In true PLINIUS tradition we have approached the development of our CD Player from a different angle. We have always felt that the potential of Redbook CD has held promise but has been short on delivery. In our research we have listened long and hard to SACD and other formats but we have elected to stick with Redbook because of the results achieved and to support the extensive CD collections our customers already have. Our DAC development has been time consuming. An initial false start using some of the latest technology (asynchronous upsampling, and bitstream conversion) lead to a disappointing sonic result. We then re-thought and developed a DAC following a very conservative path. Noting the DIY enthusiast's endorsement of simple solutions, and with our general philosophy of avoiding unnecessary complexity, we evaluated a DAC design that used simple synchronous oversampling, and a multibit DAC. This needed no additional analogue filtering, and was in keeping with our like of simplicity. The outcome was more than we expected. This design, coupled with a low jitter master clock feeding the transport, has delivered Redbook CD performance that surpasses that which we have previously heard. Physically the PLINIUS CD101 matches our range of Integrated, Pre and Power Amplifiers. The operational styling of the CD101 has only one control button on the front panel with all other functions driven from the distinctive remote control. The remote control also has some basic functions allowing volume and mute adjustment on PLINIUS Pre and Integrated Amplifiers. We put much effort into understanding the interface requirements, and decided that as music is the goal, the interface should distract as little as possible. Considering the user interaction with vinyl replay, where there are no digital track-time-elapsed displays, and the focus is on just listening to music, we decided to make the user interaction with the CD101 similar. The display consists of a series of micro LEDs showing the progress of the tracks through the disc. This is simple, elegant, and directs the listener's focus to the music and away from the technology. The mechanical design has also seen much effort go into ensuring the transport is isolated, and the chassis is well damped. We have developed a substantial tray support and bearing system, and applied damping material and compliance where necessary. The build quality is beyond reproach. As with other PLINIUS products it is the music that matters most. The CD101 is a worthy addition to our range. PRODUCT SPECIFICATIONS Conversion:24-bits 353kHz Frequency Response:20Hz to 20kHz ±0.2dB Distortion:<0.01% THD at rated input level Hum & Noise:-100dB at rated input level, A Weighted Maximum Output Level:2V RMS into 10kohms or higher Output Source Impedance:Typically 100ohms Digital Output Impedance:75ohms Dimensions:Height 105mm (4"), Width 450mm (17.75"), Depth 400mm (15.75"), Weight 10kg (22lb) Please call on 98440-94669 for Demo appointments. No walk-ins. Rgds Prithvi. |
bhagwan69
erstellt: 22. Sep 2007, 05:50
Nice ! Give more demo's............... All the best; I am sure the 'audiophiles' will listen and change. You are going a nice job. How I wish this kind of a service would be available in Mumbai too. So many budding audiophile would get a chance to get exposed to nice mid-fi audio. This is the right way to do it; Keep it up !!! I do hope all the Bangalore forum members take this chance and make the most of it. |
bhagwan69
erstellt: 22. Sep 2007, 06:14
Prithvi
erstellt: 22. Sep 2007, 10:27
Why? You dont have this service in Mumbai, that too with all the distributors in Mumbai. Funny !!!!!!!! |
bhagwan69
erstellt: 22. Sep 2007, 11:01
Hello Prithvi ! You are correct; The Distributor is present in Mumbai. However with the absence of a demo room or a show room - like what AVI has got - we cannot go for a listen. At least from that point - the forum members in Bangalore have the chance to drop by for an audition. That is so important. At least we can listen and form our own opinions instead of reading some magazine; |
Latest Arrival at Absolute Phase, Just awesome Prithvi am 23.08.2007 – Letzte Antwort am 25.08.2007 – 18 Beiträge |
Recording DVD Media on Normal CD-R SUNILYO am 28.08.2006 – Letzte Antwort am 05.09.2006 – 19 Beiträge |
CYRUS 'SE' CD PLAYERS - A REVELATION SNV am 22.08.2008 – Letzte Antwort am 14.11.2008 – 14 Beiträge |
Request Suggestions On How To Organise My CD Collection Amp_Nut am 31.01.2010 – Letzte Antwort am 04.02.2010 – 19 Beiträge |
Broadcast 2007 at World trade center Manek am 03.11.2007 – Letzte Antwort am 04.11.2007 – 5 Beiträge |
Mumbai Meet On Tuesday 24th July ? Amp_Nut am 21.07.2007 – Letzte Antwort am 14.08.2007 – 35 Beiträge |
Sniffing Out A Pirated CD / DVD ! Amp_Nut am 06.04.2007 – Letzte Antwort am 06.04.2007 – 2 Beiträge |
conversion of audio cassettes to cd Manek am 27.05.2008 – Letzte Antwort am 27.05.2008 – 3 Beiträge |
Anyone on Orkut.com abhi.pani am 01.12.2006 – Letzte Antwort am 15.05.2008 – 21 Beiträge |
VAT on all imports. Prithvi am 11.01.2007 – Letzte Antwort am 13.01.2007 – 10 Beiträge |
2007
- Registrierte Mitglieder930.997 ( Heute: 6 )
- Neuestes Mitgliednisio
- Gesamtzahl an Themen1.564.401
- Gesamtzahl an Beiträgen21.852.796
