Budget=75-100K; Receiver = Undecided
stonedsufi
#1 erstellt: 25. Jun 2005, 18:46
Hi everyone,
I have decided to splurge about 100k on a really good receiver. Whatever I choose I will be telling my brother to lug from the US.
Now the parameters are:-
a) My choices are Arcam, Marantz, Denon, and Yamaha - Am i missing any good brands that I should be looking at???
b) Movies:Music will be 40:60
c)I can get some great discounts on Yamaha as brother works there but since
d) Once the receiver is in I will start buying speakers a pair at a time - probably starting with a good set of floor standers and then a surround +sub and so on....
e) Could you also suggest some Indian Built speakers that may be looked at for your respective suggestions as getting them from the US might be a pain....!!
If I am missing any question I will keep on adding them as and when I remember them...
For the moment this is it guys... thanks
sufi...
stonedsufi
#2 erstellt: 26. Jun 2005, 05:28
the price mentioned is in Indian Rupees and approx US$ 2000
stoned
hsmraj
#3 erstellt: 26. Jun 2005, 19:05
Since music is very important for you, I would go with systems from Arcam, NAD or Rotels for this range. You may also want to look at top of the range Yamaha's (~ USD 5000) if you can get very good discounts. With high importance to music, I would keep away from Denons.
Within your budget, you should be able to get Arcam AVR 300 or Rotel 1067. Arcams are reputed to be the most musical and Rotels sound brigter. Rotels have a power advantage over Arcams and may have HDMI for video.
Denons and Pioneer Elites may provide you with better features like room equlization. But this feature is rerely used and you can use an SPL meter to do this manually. iLink is another feature to consider if PC connectivity is important. iLink may become redundant when DRM issues are resolved on HDMI audio and high quality audio is enabled.
Basically, it all boils down to your music listening preferences. You need to have a good audition of receivers before you decide which one is for you. Do not rely only on our opinions for your purchasing decisions.
You will also need superb source to go with these receivers. Good ones that I would recommend are Pioneer Elite DV 59AVi, or the ones from Arcam. You may also want to check out competitive offerings from Denon and Rotel.
With this budget on the receiver, you will need to set aside a good deal of money on some audiophile speakers. You get some good speakers in India. You may want to audition them for and see how they image, their off axis response. You will need to look into these aspects before you put in such kind of money on speakers. One thing I have come to realize is that putting more money on your system does not automatically entitle you to better sound. The bigger the brand name the pricer the system. Some not so conspicuous imported and local speaker may provide you much better value for money. You will need to spend more time and efforts to get the system that suites your tasts and your wallet
Let me know how your efforts go
[Beitrag von hsmraj am 26. Jun 2005, 19:17 bearbeitet]
hsmraj
#4 erstellt: 26. Jun 2005, 19:20
Another option is to go in for separates. They provide you much better control and you can get a better processor. Check out the offereings from Arcam and Rotel.
hsmraj
#5 erstellt: 26. Jun 2005, 19:37
Frequency response of the Arcam AVR 300 and Rotel 1067 are ver similar. Arcam's are rated for flat response (comment from Manufacturer http://europe.rotel.com/products/specs/rsx1067.htm) from 20 to 20 KHz but have a much wider 3db response. The Rotel 1067 is for 3db over 10 to 120 KHz (http://europe.rotel.com/products/specs/rsx1067.htm).
I am not sure of the digital section though. If you are using a good external source, you may not have a problem using Arcam's with SACD or high quality vinyls.
Dipak
#6 erstellt: 29. Jun 2005, 17:33
the arcams really have a formidable reputation..
I don't know if it's something for you, but take a look on www.jungson.com
the av-1000D should be well under a 2000us$
however I've never been able to compare it to an arcam receiver (or rotel), I can only tell that it outstrips onkyo-702 and denon 3805 (which I have auditioned) by far. but I guess this can be said about arcam and rotel too..
hsmraj
#7 erstellt: 30. Jun 2005, 00:49
Jungson AV-1000D is about twice the weight of equivalent AVRs from Rotel or Arcam. It has a much bigger power supply and class A amp supporting it. However, there is hardly any reviews on this product in english. Are there any local dealers supporting / selling this product? Product support, firmware upgrade is another thing that needs to be considered.
benkenobi
#8 erstellt: 30. Jun 2005, 00:59
how about the sunfire "the ultimate receiver"..
anyone auditioned it..?hmm?
Dipak
#9 erstellt: 30. Jun 2005, 03:43
there are some posts on www.adioasylum.com but I guess you've already found those ones
I'm living in geneva and don't know about your local situation..
at least bout firmwares not that much, as the av-1000d is purely analogue and needs an external decoder, either a pre-amp, a receiver with pre-outs or a good dvd-player. the 1000C version comes with integrated decoders I believe, but they are very basic and do not offer any delay options. so its more to be looked at as a multichannel power-amp..
I myself own a jungson ja-88d stereo-amp and am really happy with it. I haven't actually auditioned the av-1000d myself, the dealer said in stereo it would perform a bit under the ja-88d's level. however I auditioned the av-899c and in bypass-mode the stereo-sound was really nice and already outstripped the two receivers (onkyo & denon) mentioned above..
greets dipak
hsmraj
#10 erstellt: 30. Jun 2005, 04:49
Sufi, personally, I would choose a good pair of fronts in India with an option of a compatible centre channel upgrade. For movie performance the fronts and TIMBRE matched centre are most important. Since the question is on the receiver, I will not discuss this further. A point to keep in mind is that the speaker and the HT features you are looking at determine which receiver you may want to choose ultimately.
Benki, Sunfire is well outside the range requested by Sufi and may need a different thread. Sufi, if you are able to get the receiver in the US, I suggest you look at getting a Marantz SR-8400 on ebay or ubid. At about $500, there is nothing you can get of this quality in this range. I have only heard Marantz in stereo mode though.
In the range of 75-100K (USD 2000), you will also be able to choose any of the following:
o Denon 2805/3805 with an external amplifier
o Pioneer Elite 55TXi (not sure of the equivalent asia/europe model number)
o Rotel 1056 (1067 is more expensive)
o Arcam DiVA series AVR-250 (not recommeded) and AVR-300
o NAD ??
o Harman Kardon AVR 630
o Marantz SR-8400, SR-8500
o Yamaha higher end (if you get an excellent discount)
If you are interested in a very musical receiver, I would like to suggest Arcam, NAD or Rotel from the list above. All these receivers perform well for both Music and HT. Marantz is respected in Asian markets for its musical properties but is not very popular in the US. Denon 2805/3805 with external amps may be an equally good choice.
If connectivity and features is very important, I would look at Denon or Pioneer Elite series. Denons in the US only come in 110 volt version. You may not get support if you buy outside the authorized channels. However, you can get very good discounts on Denons in the US (25-30%) if you buy it as part of a package with speakers.
Arcam has a lot higher sticker price (still within your range) and you could possibly get it without the traditional Indian retailer premium in the grey market. Arcam is flexible on support and responds requests on public forums as well as their official support line. It also has support for 220/100 volt in a single box. Overall, my price for the Denon and Arcam was very similar, so I picked up Arcam and saved on my universal player.
You may also want to seriously look at Rotel and NAD. Rotel, NAD and Arcam do not have a whole lot of features but have an overall better build qualitiy in my opinion.
If you clarify your requirements i.e., SACD playback, HDTV connectivity, I can give you better inputs on the choice you have. Good luck with your receiver hunting
hsmraj
#11 erstellt: 30. Jun 2005, 04:59
Dipak, dedicated amps and good audio source will anyday outclass an integrated receiver. What is most interesting is that the Jungson amps are Class A devices. I believe similar offerings from traditional markets cost 5 times as much.
Has anybody considered flying through China to pick up high end audio gear Seems like this is a lot better place to pick up software and Hi end audio gear and the tour to china would be free with just the savings on the audio gear
Dipak
#12 erstellt: 03. Jul 2005, 03:20
hy hsmraj
yes, that's for sure. I have to admit we used the Jungson Cd-player as source, but:
I (also) auditioned the av-899c and in bypass-mode the stereo-sound was really nice and already outstripped the two receivers (onkyo & denon) mentioned above..
this is an avr, but the smaller one, as you can see on their homepage. here in switzerland it is sold for a good 1000US$ I believe.
AND it didn't only oustrip the two receivers mentioned above but it also got dangerously close to the classic 6.6 (in direct comparison), which is a dedicated stereoamp about the same price.. if I would have been looking for an avr I would most probalby have gone with this one.
greets dipak
av receiver+DVD player in budget
Sonic_Master am 23.05.2005  –  Letzte Antwort am 30.06.2005  –  23 Beiträge
Perfekter Receiver?
gamingo am 14.02.2005  –  Letzte Antwort am 26.02.2005  –  2 Beiträge
Marantz Receiver
neono am 19.08.2005  –  Letzte Antwort am 06.12.2005  –  7 Beiträge
SPEAKERS FOR RECEIVER
Anandjacob am 09.07.2005  –  Letzte Antwort am 19.07.2005  –  17 Beiträge
Speakers under 30K for Onkyo 503
ADM am 26.09.2005  –  Letzte Antwort am 30.09.2005  –  10 Beiträge
Help me decide on Speakers & Receiver
vjsvohra am 21.04.2004  –  Letzte Antwort am 20.10.2004  –  17 Beiträge
NAD v/s Marantz A/V receiver
pulcino am 06.04.2004  –  Letzte Antwort am 07.04.2004  –  2 Beiträge
25K Budget - Please help - Sony/Onkyo or Custom
ipodpune am 25.09.2005  –  Letzte Antwort am 03.11.2009  –  39 Beiträge
which receiver to choose?
robert_j am 28.12.2003  –  Letzte Antwort am 14.01.2004  –  19 Beiträge
Sound Setup[marantz receiver]
neono am 11.02.2006  –  Letzte Antwort am 17.02.2006  –  6 Beiträge
2005
  • Registrierte Mitglieder931.184 ( Heute: 1 )
  • Neuestes MitgliedAshalino
  • Gesamtzahl an Themen1.564.885
  • Gesamtzahl an Beiträgen21.870.617
