Shure M55 E
Behram
#1 erstellt: 11. Okt 2005, 06:33
Hi folks,
I am not sure whether or not this post is right for this sub group, but I require some help on the specs of the Shure M 55E cartridge. Since I am making an RIAA equalized pre amp stage particularly for this cartridge I am keen on knowing its input load impedance and capacitance. I tried the net but could not locate this figure although the other specs are available.
Would appreciate some feedback if possible.
Thanks and Regards.
Behram.
bhagwan69
#2 erstellt: 11. Okt 2005, 07:21
Shure Incorporated Product Line
Shure Incorporated >Recorders and Players > Accessory Products > Phono Cartridges and Styluses
Model: N55E
Single Stylus Replacement Needle for use with M55E Cartridge, Yellow
MSRP: Call For Price
Find a Source
Click here to find a dealer or other resource in your area.
Request for Information
Click here to get more information.
Email Forwarding
Click here to email this page.
The Model N55E is a Stylus Replacement Needle for use with M55E Cartridge.
Specs
Grip Color : Yellow
For Use With : M55E
Diamond Geometry : E
Stylus Radius : 0.2 X 0.7 Mils
Tracking Force : 0.75 to 2 grams
This is a replacement for the M55E
The new one is N55E
You may get the specs @
http://catalogs.infocommiq.com/AVCAT/CTL88/index.cfm/mlc_id/88/SID/14515008/pin_id/1642/ProdID/322213/T3/1001.htm
Just give it a try.
Regards,
BHAGWAN69
Behram
#3 erstellt: 11. Okt 2005, 08:34
Thats not what I am looking out for. The standard specs, viz. Tracking weight, frequency response, stylus measurements, replacement stylus nos. etc.are available.
What I specifically require is its inductance or its recommended load in kohms /loading capacitance in pf. This is required to optimize its high frequency peak.
screamgigi
#4 erstellt: 17. Okt 2005, 18:51
47k/400pF.
If you are DIY'ing your phonostage, then i would recomennd 6DJ8 in front followed up by 5814 type. Simple and cheap! Once you get the setup up and running, try CCS for the first stage. Will beat any high $$$ commercial stuf.
You my try loading the 6DJ8 with a FET input if it does not wound your pride.
Cheers
[Beitrag von screamgigi am 17. Okt 2005, 18:54 bearbeitet]
sbfx
#5 erstellt: 20. Okt 2005, 13:47
Inductance - 720 millihenries
DC Risistance - 630Omhs
Optimum Load - 47KOhms
Hope this helps,
Regards,
Satyam
[Beitrag von sbfx am 20. Okt 2005, 14:07 bearbeitet]
SOME SERIOUSNESS NEED BADLY ON THIS FORUM
Prithvi am 04.04.2005  –  Letzte Antwort am 08.04.2005  –  29 Beiträge
Help! I need some components.
benkenobi am 28.06.2005  –  Letzte Antwort am 01.07.2005  –  11 Beiträge
Problem in fixing Shure Cartridge to my Technics Headshell
jani am 16.10.2010  –  Letzte Antwort am 16.10.2010  –  2 Beiträge
Needing some vinyl advice and help.
Savyasaachi am 04.11.2010  –  Letzte Antwort am 17.12.2010  –  35 Beiträge
Where can I get a replacement of this cartridge!
abhi.pani am 13.07.2007  –  Letzte Antwort am 03.09.2007  –  29 Beiträge
Hey Abhi, This is for u
benkenobi am 25.02.2005  –  Letzte Antwort am 26.02.2005  –  6 Beiträge
Opinons on this combo? (NAD/Dynaudio)
remote am 09.02.2004  –  Letzte Antwort am 23.02.2004  –  20 Beiträge
Good quality amp for under £150 - possible?
gplatt2000 am 29.10.2003  –  Letzte Antwort am 17.11.2003  –  15 Beiträge
Budget amp and speakers. Help!!
Psycholic am 30.06.2005  –  Letzte Antwort am 30.06.2005  –  8 Beiträge
how about this
Sonic_Master am 02.06.2005  –  Letzte Antwort am 03.06.2005  –  4 Beiträge
2005
  • Registrierte Mitglieder930.662 ( Heute: 5 )
  • Neuestes MitgliedSven480
  • Gesamtzahl an Themen1.563.460
  • Gesamtzahl an Beiträgen21.826.135
