Sonodyne Receiver
Jai
#1 erstellt: 09. Dez 2004, 17:05
can some body tell me the price of Sonodyne AV receiver 5.1
thnx
Manek
#2 erstellt: 10. Dez 2004, 10:20
sorry havent heard it..but heard of it from ads.
manek.
Tokon
#3 erstellt: 10. Dez 2004, 16:05
The price is approx. 18k INR. But its perfomance not satisfactory.
SUB_BOSS
Gesperrt
#4 erstellt: 28. Dez 2004, 13:41
Hey Manek you haven't heard of SONODYNE huh that's bad,it is India's first innovative revolution, what's with your cadence propoganda always....and how could you proclaim that they are best.haven't you seen or heard others??
Manek
#5 erstellt: 29. Dez 2004, 09:05
Hey ! I said I haven't heard the reciever ! i did not say havent heard of sonodyne. BTW..I still own sonodyne speakers and amp I bought 15 yrs ago. So i do know about sonodyne. Just havent heard their avr in an audition !
manek.
SUB_BOSS
Gesperrt
#6 erstellt: 30. Dez 2004, 05:31
Hi Manek that's great I too own a SONODYNE. It's the all time best Sonodyne product Uranus-2 . Can you tell me why does it distort when i try to connect DVD player thru equaliser, but the sound is clear when i bypass it.I also tried connecting to the amp direct and use the presets in the DVD player but it makes kind of 'chrrrrr' noises.the noises disappear when i set the presets at 'None'.Can you throw some light on this.
Manek
#7 erstellt: 30. Dez 2004, 09:15
My old sonodyne system(which i refuse to give up) are two floorstander speakers made of teak wood and heavy as hell. They were called spectrum 8000. The amp was also a sonodyne transistor based 180 watts. My dad bought this system for us when I was in the 7th standard ! I still have it and it hopefully still works, though I have not played it for more than a year now. I dont know why but I refuse to give this up. So many happy memories attached to that system I guess.
Now for your problem....I am assuming you connect your dvd player analogue audio line outputs to the line input of the amp and not a phono socket. I also used a separate equalizer my teens with my sonodyne amp. I would connect the cdp to the line input of the EQ, the eq output would be connected to the AUX input of the sonodyne amp. Never ever had a problem with the connections. does your equalizer behave the same way with other sources too ?
manek.
SUB_BOSS
Gesperrt
#8 erstellt: 30. Dez 2004, 13:09
Equalisers work fine with the tape deck, but they behave nasty with the DVD player, even the presets in the DVD player make the situation worse. I have connected the DVD to the CD/AUX in the amp and the performance is brilliant. The performance is more brilliant when i set the preset equaliser mode in DVD player to Rock or Pop, but it makes 'Chrr' noise at one particular frequency. It doesn't happen when I set the preset at 'None' mode.Is it got to do something with the audio set up in the DVD player as the amp is fine.
Manek
#9 erstellt: 03. Jan 2005, 06:06
What dvd player do you have ? and what are the possible audio settings in the dvd player ? does this happen when playing dvd/vcd or audio cd's ?
check your interconnects and your audio out rca pins.
manek.
SUB_BOSS
Gesperrt
#10 erstellt: 03. Jan 2005, 09:30
I have a philips dvd and it has Digital surround,Post dynamic range control, PCM option, Mono L+R , Stereo. I have noticed it inly in Audio Cd's
Manek
#11 erstellt: 03. Jan 2005, 12:11
Ok the first thing you should be doing is using the stereo mode and not the other fancy effects modes. does it give you a problem with stereo ?
other modes may create problems if they are not standard. i have seen it in some bass boost circuits implemented in some devices.
manek.
SUB_BOSS
Gesperrt
#12 erstellt: 06. Jan 2005, 07:06
it is absolutely set in stereo mode and can you tell me what PCM is?? should i set at 'off' or 'on' or 'PCM all'.
Alymangy
#13 erstellt: 06. Jan 2005, 08:02
Sonodyne AV300R costs 17k in Bangalore - Forum Mal - Sonodyne listening room.
It is ok. Looks massive !!
Also Sony has AVRs introduced to Indian markedt 497(5.1 - 15k),597(6.1 - 17k) and 897(7.1 - 21k). Fundo pricing!
Has anybody had a good long look at them?? Any comments on these.
Manek
#14 erstellt: 06. Jan 2005, 09:21
I've heard the sony 5.1...pretty decent for the price.
PCM stands for pulse code modulation which is a technique used to store analogue info in digital format. This is what your cd audio is all about.
manek.
SUB_BOSS
Gesperrt
#15 erstellt: 06. Jan 2005, 12:33
then what do you think the setting should be at ..PCM all or Auto
SUB_BOSS
Gesperrt
#16 erstellt: 06. Jan 2005, 13:04
Hi alymangy,
i have taken a demo and i feel sonodyne is better than SONY, but the speaker package is no great shakes.
Manek
#17 erstellt: 06. Jan 2005, 14:04
try both pcm and auto and see what works for you.
manek.
SUB_BOSS
Gesperrt
#18 erstellt: 07. Jan 2005, 10:18
both didn't help the situation.i feel there must be a catch somewhere...........
Manek
#19 erstellt: 07. Jan 2005, 12:32
wierd...very wierd...we are obviously missing out on something...but what could it be ?
SUB_BOSS
Gesperrt
#20 erstellt: 10. Jan 2005, 06:50
is it go to do something with the Dynamic Post control?
Sonodyne 2605
deepug am 02.09.2004  –  Letzte Antwort am 13.09.2004  –  25 Beiträge
Taking the plunge : sonodyne speakers - please advise!
trivisingh am 26.02.2005  –  Letzte Antwort am 01.03.2005  –  13 Beiträge
sonodyne genie system
pramod am 29.06.2005  –  Letzte Antwort am 30.06.2005  –  8 Beiträge
Spkrs: Telome vs Sonodyne. Rxr: Sonodyne vs Rest
kvish am 25.09.2005  –  Letzte Antwort am 26.09.2005  –  8 Beiträge
Denon 1404 or 1604 or Sonodyne AV 300 R
ajacob am 16.11.2004  –  Letzte Antwort am 27.12.2004  –  7 Beiträge
Sonodyne Sonus 2605 with Onkyo receivers/amps
Donie am 07.02.2005  –  Letzte Antwort am 24.02.2005  –  7 Beiträge
reviews on sonodyne avant required.
juggy_25 am 28.06.2006  –  Letzte Antwort am 30.06.2006  –  23 Beiträge
Opinion needed on sonodyne Sonus 2605
manishk13 am 26.01.2005  –  Letzte Antwort am 31.01.2005  –  18 Beiträge
Pulz versus Sonodyne
kspv am 11.09.2005  –  Letzte Antwort am 08.10.2005  –  136 Beiträge
Sonodyne Genie2 vs Kef Eggs
Debu am 25.02.2005  –  Letzte Antwort am 28.02.2005  –  3 Beiträge
2004
2005
  • Registrierte Mitglieder930.634 ( Heute: 6 )
  • Neuestes MitgliedHerr41
  • Gesamtzahl an Themen1.563.379
  • Gesamtzahl an Beiträgen21.823.718
