wharfedale diamond SW 150
purnendu
#1 erstellt: 15. Feb 2007, 10:03
Hi all,
I auditioned the SW diamond 150 sub recently. Has anyone heard these subwoofers. The price is really quite attractive. The sound with the the diamond satelittes was also impressive although not a patch on the quad sub sat which was also there. I have not yet auditioned them with my own proac tablettes. Pricewise they would be a complete mismatch, however the matching Proac sub costs an arm and a leg. But you never know the budget wonder might work. Has anyone heard this wharfedale sub. Reviews are favourable. Right now I am having to blast my system to get any bass at all. This is creating domestic problems, and I too am not so keen on high volume listening. Will I compromise my sound quality by bringing in a lower quality sub or should I give it a try.In a nut shell has anyone tried this i.e., modest sub with quality main speakers. Please give me some feed back
Purnendu
Arj
#2 erstellt: 15. Feb 2007, 10:24
purnendu, if you have Proac speakers then you need a much much better sub to go along with it.
ideally the Rels and even the newer Quad subs are OK (But I would really only recommend the REL or even if you can get hold of a MJ acoustics one)
Wharfedales subs are very very much entry level HT offerings and in these cases no bass is really better than bad bass ;0 (All IMHO of course)
Since Tonality is more or less non existant below 100 hz (To mos average ears anyway) having a different brand sub should not be an issue (Usually it is the ease of integration which might make them attractive)
The REL stampede entry level starts at around 55K...
Manek
#3 erstellt: 15. Feb 2007, 10:41
the quad sealed box sub is very good.
manek.
Arj
#4 erstellt: 15. Feb 2007, 11:14
Manek, any idea of the price range for these ?
Manek
#5 erstellt: 15. Feb 2007, 11:16
the last i heard ...around 70k
purnendu
#6 erstellt: 15. Feb 2007, 11:54
Thanks for the replies,
More or less what I thought.The diamond sw could muck it up.
In matter fact I have been having a long running problem with the low frequencies. The Tablettles are hard to drive and the Lyrita Integra does not have enough grunt and starts distorting if I turn up the vol. So recently after extensive audition and back and forth I have gone in for the audio Analogue Cento vt amplifier, rated at 100 watts, while retaining the valve integre for quieter listening. The added power has made a lot of difference to the low frequency performance, and it matches the Tablettes rather well otherwise. However it has cost a decent packet and I cant possibly go in for an expensive sub for the next year at least. The Diamond sub is only Rs. 18000, and I was rather tempted. I will probably audition it at home some time but may be I should also audition the Quad you speak well of. I wonder if its the same model that I heard at the dealer. At last Jaipur has a proper dealer.
The price of the the Quad is around 70 grand. The Proac should be nearly 1 lakh. So its going to have to wait. Long wait
Purnendu
soulforged
#7 erstellt: 15. Feb 2007, 12:09
Purnendu,
If it for a stereo setup, why don't you look at going for a set of speakers with a better bass response rather than going for a sub? Say the Totem Rainmaker or a floorstander...
purnendu
#8 erstellt: 19. Feb 2007, 07:18
Hi SF,
I doubt if I can upgrade the speakers easily without losing a good deal of money. Also the Proac pair is less than a year old, and I do like them. The sound is quite balanced and controlled even a loud volumes, and the human voice is most natural. The high freqs are all there, and much less gritty than in some other systems I have heard. I am quite happy with my system now, the only thing really missing is a solid bass foundation. A larger speaker of lesser qualty might bring some heaviness into the human voice. My system ( although it is an entry level system) has come to a point of balance where any change will have to be done with a lot of care, and only if there is loads of cash to spare. I would have to go to a Proac D15 lets say to get what you are suggesting, and that is much much more expensive. Thanks for the suggestion all the same. Should I get get an opportunity I would certainly try out my system with a pair of larger quality speakers.
Purnendu
Arj
#9 erstellt: 19. Feb 2007, 08:45
If you have a budget constraint And you need SPL below 45 Hz, then a sub and a bookshelf is definitely the better option from getting more value for money..floorstanders doing that well cost an arm/leg more
the pitfall is that integerating a sub into your room is much much tougher and akes time..but if done well it can be really good.
wharfedale diamond.5
srikarkav am 30.11.2005  –  Letzte Antwort am 05.12.2005  –  5 Beiträge
opinions on wharfedale diamond series
stevieboy am 01.02.2005  –  Letzte Antwort am 02.02.2005  –  9 Beiträge
Subwoofer: Wharfie SW-150 or the Velodyne VX-10?
juggy_25 am 18.06.2006  –  Letzte Antwort am 20.06.2006  –  9 Beiträge
which is better - Sonodyne Sonus 2605 or Wharfedale Diamond 8.4?
juggy_25 am 02.06.2006  –  Letzte Antwort am 06.06.2006  –  2 Beiträge
Sand filling of Diamond 8.4
benkenobi am 03.03.2005  –  Letzte Antwort am 03.03.2005  –  7 Beiträge
budgeted music ( wharfedale + denon )
alpotnis am 02.09.2005  –  Letzte Antwort am 26.09.2005  –  28 Beiträge
Wharfedale Diamonds
Alymangy am 24.01.2005  –  Letzte Antwort am 25.01.2005  –  22 Beiträge
Marantz + Wharfedale
Doc_hi_fi_novice am 10.05.2005  –  Letzte Antwort am 17.05.2005  –  8 Beiträge
Gorgeous 10 !
Soundsgreat am 04.04.2009  –  Letzte Antwort am 06.04.2009  –  7 Beiträge
Wharfedale Opus 2...............
TjMV3 am 23.04.2004  –  Letzte Antwort am 04.09.2004  –  31 Beiträge
2007
  • Registrierte Mitglieder927.588 ( Heute: 3 )
  • Neuestes MitgliedOctoputer77_
  • Gesamtzahl an Themen1.555.985
  • Gesamtzahl an Beiträgen21.649.825
