Sand filling of Diamond 8.4
benkenobi
#1 erstellt: 03. Mrz 2005, 03:15
i own a pair of Wharfedale diamond 8.4 speakers.
i want to know if they can be filled with sand.
and if so what is the recommended amount.
BTW has anyone tried this. what are ur views on this.
thanks
benkenobi
#2 erstellt: 03. Mrz 2005, 04:35
hey prithvi,
can u help me with toeing in my speakers.
what i want to know is this, myspeakers are almost 6.5 feet apart (measured between the center of the baffles) and my listening spot is usually 9 to 10 feet away.
now according to the equilateral triangle rule my listening spot has to be within the tip of the triangle that is, within 7 feet from either speaker. so at what anlge do u achieve this ideal position and at what angle can i get the same result by sitting almost 9 -10 feet from each speaker.
thaks
Ben
big-ears
#3 erstellt: 03. Mrz 2005, 05:34
Benks,
Experimentation is the name of the game, there are no hard and fast rules.
It all boils down to your room, but IMHO, an equilateral triangle doesn’t always work out to be the best option. Most speaker manufacturers recommend that the distance between the listener and the speakers should be somewhat more than the distance between the speakers. So, if you have the speakers 6.5 ft apart, which is quite normal, then your current distance of around 9 ft should be okay.
The basics of toeing in are somewhat thus. If you have the speakers firing straight ahead, you will probably get the most expansive soundstage, but imaging will not be at its best. As you turn them inwards, you will find the imaging improving but the soundstage getting restricted. You will have to play around to find out what sounds best to you.
I find I am most comfortable with the speakers crossing a wee bit behind my ears, the combination of imaging and soundstaging seems just right at this point. But, you must check this out for yourself as this may not work for you, remember, I do have big ears….
Arj
#4 erstellt: 03. Mrz 2005, 05:36
Try this site out
http://www.cara.de/ENU/quickindex.html
this will help you model your setup to some extent and also tell you about some Room specific Nasties...
this way you would be able to get a good idea about your options.
cheers !
benkenobi
#5 erstellt: 03. Mrz 2005, 05:57
thanks arj, that i really helpful. unfortunately they don't have Wharfedale in their database.
besides i think my dad may start building the first and second floors of our house and i have alredy started making plans for a theater and audio specific room. till then i will try to experiment as much as i can. the thing is, as of now there is too much of furniture in the room and it is very difficult for me to let myself go and really experiment.
thanks for the tip big ears.
BTW how ever can we forget about those wonderfully 'big ears' of urs .
Ben
abhi.pani
#6 erstellt: 03. Mrz 2005, 10:23
What happened to the Sand Filling part ?? The main subject is still unanswered ?
SUB_BOSS
Gesperrt
#7 erstellt: 03. Mrz 2005, 10:29
Hi Abh
Arj wrote
generally not recommended to play around with the insides of the speaker cabinet as it affects the internal volume which is one of the basic parameters in speaker design..what you gain in one area , you might actually be losing something in some other area..hence be vey careful with what you do ..
With regard to wharfedales i am not really aware of specific tweaks, other than generic stuff like Mass loading, granite/wooden footers etc etc. try the net ..you should find something
DIY Speaker Filling Suggestions
vjcritic am 18.08.2007  –  Letzte Antwort am 27.08.2007  –  29 Beiträge
which is better - Sonodyne Sonus 2605 or Wharfedale Diamond 8.4?
juggy_25 am 02.06.2006  –  Letzte Antwort am 06.06.2006  –  2 Beiträge
opinions on wharfedale diamond series
stevieboy am 01.02.2005  –  Letzte Antwort am 02.02.2005  –  9 Beiträge
what type of reciever would best suit my wharfedale speakers
Pvikid am 13.01.2005  –  Letzte Antwort am 14.01.2005  –  6 Beiträge
Wharfedale 8.4 and Rotel RA 01 - wud u recommend?
raftuq am 31.05.2006  –  Letzte Antwort am 07.06.2006  –  48 Beiträge
Better combination
Doc_hi_fi_novice am 11.12.2007  –  Letzte Antwort am 25.01.2008  –  31 Beiträge
wharfedale diamond.5
srikarkav am 30.11.2005  –  Letzte Antwort am 05.12.2005  –  5 Beiträge
wharfedale diamond SW 150
purnendu am 15.02.2007  –  Letzte Antwort am 19.02.2007  –  9 Beiträge
Audio Pro Black Diamond vs Dali 5005 vs Axiom m50ti
gverde am 10.02.2004  –  Letzte Antwort am 16.02.2004  –  5 Beiträge
Diamond 9's have arrived
benkenobi am 02.03.2005  –  Letzte Antwort am 17.03.2005  –  8 Beiträge
2005
  • Gesamtzahl an Beiträgen21.827.007
