Anybody heard these things ?
square_wave
#1 erstellt: 06. Nov 2006, 11:12
screamgigi
#2 erstellt: 06. Nov 2006, 11:56
For around 100K INR (plus a little change) they don't look too bad.
I can see quality components all over. WIMA caps, Alp motorised volume pot, Copper Speaker Binding posts, IRF MOSFETS, relays for source selection, beefy PSU, heat sinking and that lovely calibrated Volume knob.
If it looks nice, it should sound nice. Well mostly
square_wave
#3 erstellt: 06. Nov 2006, 13:04
I keep seeing users at Audio Asylum singing praises of them all the time. The v6i at 150 watts/channel sells for around 1300 dollars (street price) and is pretty popular.It weighs in at about 70 pounds and build like a tank. And they are all Hyper Class A…(what is hyper class A ?) I wonder how they sound. I wonder how they do it at this price point……..
Arj
#4 erstellt: 06. Nov 2006, 14:12
I think it is a OEM (MIC) for Mark Levinsons Red Rose products and they were introduced in singapore/HK as Korsun. their V6 was pretty good
I am guessing here, but hyper class A seems to be a marketing ploy and most probably would be AB with a high Class a bias
square_wave
#5 erstellt: 06. Nov 2006, 14:29
Is there any connection with the DK Design group? I remember reading somewhere they are done by the same people.
screamgigi
#6 erstellt: 06. Nov 2006, 15:07
square_wave schrieb:
...what is hyper class A ? ...
Looks like shallow Class A operation. First few watts in Class A then moving over to Class AB at higher levels. Sensible thing actually.
Just guessing.
Arj
#7 erstellt: 06. Nov 2006, 16:31
Just guessing.
S.gigiji,
thats what i meant by the following in my post..does it mean something else ?
screamgigi
#8 erstellt: 06. Nov 2006, 18:25
Arj schrieb:
Just guessing.
S.gigiji,
Yes same same Glass half full or half empty
But its more than just marketing ploy. I dont think any Class A amp stays Class A through the power delivery range.
Amp_Nut
#9 erstellt: 07. Nov 2006, 07:34
A brief explanation for those interested .......
CLASS A refers to a mode of operation where the amplifying device ( Transistor or tube ) nevers runs out of current ( ie current thru the decive never falls to zero, and the device never switches off )
The reason is that the device, if it switches off, will take some finite time to once again 'Switch On' and the time lag causes a 'dead time' and distortion.
The Simple equation
Power = Current x current X Impedance
can determine the amount of current required to deliver the rated output current. As an example, a 100 Watt amplifier, feeding an 8 Ohm resistive load will need12.5 Amperes per channel, RMS .
Lets say that an amplifier is designed to deliver a Peak Current of 20 Amperes to the speakers.
A CLASS A amplifier is ten designed so that the Output devices continiously carry atleast 20 Amperes of current. Say 21 Amperes so that the output devices never run out of current.
CLASS AB : Here the output devices carry only a small amount of current say: about 50 mili Amperes ( 1,000 milli amperes = 1 ampere ).
When the speakers demand more current, this is drawn from the power supply, as required.
An amplifier biased higher into class A, may be set for a continious current draw of say 1 Ampere or even 5 amperes.
the 'Hyper Bias' scheme refered to, the Dussun amp is a SLIDING BIAS configuration, Not a Class AB with a higher standing current.
What sliding bias does is to establish a constant bleed current through the transistors... say 1 ampere ( No Idea what Dussun have set ).
ADDITIONAL current will be drawn from the Power supply, on demand.
Hence if the Speaker were to demand 10 amperes, :
The Class AB Amp will draw 10 amperes
The Dussun will draw 10 + 1 ampere.
The 1 ampere is a 'saftey margin' to ensure that the output transistors never run dry.
Hope this is helpful
abhi.pani
#10 erstellt: 07. Nov 2006, 08:28
The Simple equation
Correction buddy amp_nut.....
For a 100 wpc amp feeding a 8 ohm resistive ohm, the current required would be around 3.5 amp and not 12.5 amp.
100 = 3.5 x 3.5 x 8 approx
Amp_Nut
#11 erstellt: 07. Nov 2006, 09:48
Thanks Abhi Pani.
You R a whiz !
It should have been square root of 12.5 = 3.5
Cheers
Focal JMlabs 826V
Krish am 16.01.2009  –  Letzte Antwort am 24.01.2009  –  5 Beiträge
Advance Acoustic, Norh Le Amp - Heard anyone?
surrealistix am 05.12.2006  –  Letzte Antwort am 13.12.2006  –  11 Beiträge
anybody tried velodyne from music ranch?
Sonic_Master am 26.04.2005  –  Letzte Antwort am 27.04.2005  –  2 Beiträge
Among these
SUB_BOSS am 17.03.2005  –  Letzte Antwort am 23.03.2005  –  18 Beiträge
Anyone heard Jamo S408?
zhopudey am 03.06.2006  –  Letzte Antwort am 26.06.2006  –  10 Beiträge
Open baffles..anyone heard one?
Savyasaachi am 21.04.2006  –  Letzte Antwort am 27.04.2006  –  18 Beiträge
Do you know these cables?
Webon am 22.10.2003  –  Letzte Antwort am 15.12.2003  –  58 Beiträge
Siltech cables ? check these out !
square_wave am 26.08.2008  –  Letzte Antwort am 01.09.2008  –  37 Beiträge
anybody dealing with VELODYNE SPL 1200?
Sonic_Master am 25.04.2005  –  Letzte Antwort am 27.04.2005  –  7 Beiträge
Jeff Rowland Concentra 2 anybody auditioned it?
Sonic_Master am 06.06.2005  –  Letzte Antwort am 13.06.2005  –  4 Beiträge
2006
  • Registrierte Mitglieder930.757 ( Heute: 2 )
  • Neuestes MitgliedLangerlulatsch
  • Gesamtzahl an Themen1.563.716
  • Gesamtzahl an Beiträgen21.833.787
