HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » Denon » Neues Denon Lineup 2015 X1200W X2200W X3200W X4200... | |
Gehe zu Seite: |vorherige| Erste . 10 . 20 . 30 . 33 34 35 36 37 38 39 40 41 42 . 50 . Letzte |nächste|
Neues Denon Lineup 2015 X1200W X2200W X3200W X4200W X6200W+A -A |
eggbird
12:28
#1801
erstellt: 23. Jul 2016, |||||
rendra
12:35
#1802
Cool, da bin ich ja mal gespannt, was die lange entwicklung uns bringt! ![]() |
ichweisswas
17:43
#1803
hi changelog des letzten Updates vom 19.07.16 für den x4200 und den x6200 aus dem avs-forum leider in englisch konnte nix finden auf deutsch. benutz einfach den Google Übersetzer. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ - When customer connects the AV receiver with the specific BD player (Sony BDP-CX960 and Sony CX-7000 Blu-ray Jukebox) via the HDMI and playback the contents of "DTS-HD", the AV receiver doesn't recognize the audio of "DTS-HD". Therefore, the specific BD player outputs the audio signal with Multi ch PCM. The symptom is a problem that the "DTS-HD" format signal is not output. - In a network environment in which AV receiver is connected, the network module of the AV receiver reboots when Netflix APP starts on the iOS device. The symptom is a problem that the network module of the AV receiver reboots when Netflix APP starts on the iOS device. - The audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround. The symptom is a problem that the audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround. - When the customer plays a specific file by USB Memory device, the track name is changed one after another in 25 seconds. (File that the number (01 and 02, etc.) are recorded at the beginning of the name.) The symptom is a problem that the track name is changed one after another in 25 seconds. - When the customer inputs the 2ch audio signal with the following specific condition to the AV receiver, the Center channel output signal is distorted. Sound mode: DTS Neural:X Input signal: amplitude = over 440mFFS (40% vs full scale) and frequency=720Hz / 2.7~4.1kHz The symptom is a problem that the Center channel output signal is distorted by the specified condition. - After the firmware updates to corresponding to the "DTS:X" feature, the following failure occurs in the AV receiver. When the surround mode is "DTS:X", the surround parameter "Neural:X" of the initial value is OFF. The symptom is a problem that the surround parameter "Neural:X" of the initial value is OFF when the surround mode is "DTS:X". (The correct initial value is ON.) - After the firmware updates to corresponding to the "DTS:X" feature, the following failure occurs in the AV receiver. When the customer inputs the DTS signal of 2ch to the AV receiver, the AV receiver shows "DTS Neural:X" on the display but the audio signal is not output with "DTS Neural:X". The symptom is a problem that the AV receiver shows "DTS Neural:X" on the display but the audio signal is not output with "DTS Neural:X" when the customer inputs the DTS signal of 2ch to the AV receiver. - When the customer switches the sound mode from the Denon Remote App, the following failure occurs in the AV receiver. Example: The sound mode becomes the "Dolby Surround" even if the customer selects the "DTS Neural:X" in the sound mode. The sound mode becomes the "DTS Neural:X" even if the customer selects the "Dolby Surrouds" in the sound mode. The symptom is a problem that the sound mode is not correctly selected even if the customer selects the sound mode. - When the customer connects iPod/USB and MediaServer to the product, and music is played, the product was a specification that do an unnecessary access. - When the black hole router was present between the Internet environment of the AV receiver and DPMS server (including the Internet service provider side equipment), the AV receiver might fail in the firmware update. (The black hole router is a router that destroy it when the divided IP packet cannot be forwarded.) [Beitrag von ichweisswas am 23. Jul 2016, 17:44 bearbeitet] |
Muchacho11
18:00
#1804
hallo, sind die neuen Denons alle HDR tauglich ? |
Harry2017
19:26
#1805
Seltsam - Soll laut Chengelog nun heissen, wir habens gefixt und DTSX läuft jetzt (richtig) aber der AVR zeigt euch das nicht an - Glaubt uns mal? :-) |
Scoty
12:32
#1806
erstellt: 26. Jul 2016, |||||
Ich bin ja mal gespannt ob der X2200W im August nun wirklich das dts:x Update bekommen wird. Warten ja schon lange genug drauf. |
embe71
13:49
#1807
Nein. Kannst Du kein Englisch?
Ist einTermin im August offiziell von Denon angekündigt worden? [Beitrag von embe71 am 26. Jul 2016, 13:50 bearbeitet] |
Scoty
14:13
#1808
Laut dem Post zumindest schon: ![]() |
embe71
16:13
#1809
Danke! Na dann bin ich auch mal gespannt... |
Harry2017
19:56
#1810
Zumindest liest sich folgendes für mich - After the firmware updates to corresponding to the "DTS:X" feature, the following failure occurs in the AV receiver. So: Nach dem Firmware Update ....tritt der folgende Fehler im Receiver auf... Oder ist damit das letzte Firmware Update / Das DTSX Update von damals gemeint? |
Dadof3
Moderator |
20:54
#1811
Wer immer das geschrieben hat, kann offensichtlich auch kein Englisch. Die Formulierung ist ziemlich holprig. Jedenfalls ist der Fehler laut Beschreibung nur, dass im Surroundmode DTS X der Initialwert für Neural X Off ist, obwohl er On sein sollte. Was das aber für ein Initialwert sein soll und welche Folgen das hat, kann ich nicht nachvollziehen. Es wäre übrigens nett, Harry2017 und Scoty, wenn ihr diese Fullquotes bleiben lassen könntet. ![]() [Beitrag von Dadof3 am 26. Jul 2016, 20:55 bearbeitet] |
embe71
10:37
#1812
erstellt: 27. Jul 2016, |||||
Yep. Das ist ja keine Buglist, sondern ein Change-Log, worin man aufführt, was behoben wurde. Formuliert ist das allerdings wirklich unter aller Sau... [Beitrag von embe71 am 27. Jul 2016, 10:39 bearbeitet] |
megaknaller
16:49
#1813
erstellt: 29. Jul 2016, |||||
Kurze Frage,der Denon 6200 hat mein Interesse geweckt (eigentlich wollte ich den Yamaha 3060 aber der ist mir vielleicht zu teuer) Kann ich jetzt beim Denon zwischen Auro,DTS X Atmos hin und her schalten ohne neu einzumessen? Meine Boxen oben möchte ich nicht nach Atmos aufbauen sondern nach Auro weil es sich besser macht für mich (also nicht an die Decke) Was man aber über die großen Yamaha liest hört sich auch sehr interessant an,aber leider haben die kein Auro.3 D und darüber lese ich viel positives.Danke im voraus |
Lars_1968
17:01
#1814
Moinsen, Du brauchst einfach nur umschalten, neu einmessen mußt Du nur, wenn Du u.A. an der Pos. der LS etwas änderst. Meinst Du, Du möchtest Auro mit enabled LS hören? Ist das nicht ausschließlich für Atmos vorgesehen? Muß es der 6200 sein? Vielleicht reicht auch der 4300, der im Herst erscheint? VG Lars |
megaknaller
19:16
#1815
Ich hatte ein Angebot für einen gebrauchten 6200 (und deswegen hatte ich überlegt )und Auro war auch schon mit drauf. Ich dachte das ich gelesen das Atmos von den strengen vorgaben für die Deckeninstallation auch leicht zurück rudert. |
Lars_1968
19:51
#1816
Das ist natürlich was anderes und wenn Auro schon drauf ist.......Da würde ich nicht lange überlegen, wenn der Preis passt. Atmos funktioniert mit Height, Top und enabled LS, bzw. sollte jeder gucken, wie es sich für ihn am besten anhört und einfach mal rum probieren. |
AirRailey
20:49
#1817
Guten Muss ich neu einmessen, wenn ich den sub umstelle? Mein jbl es 250pw neigt bei dts Filmen manchmal zum dröhnen und beim normalen tv ist kein Bass hörbar |
megaknaller
20:49
#1818
Danke erstmal,ich habe nochmal nachgeschaut und es ist ein 5200 W und nicht 6200.ca.1 Jahr alt mit Auro und ich schätze um die 1000 bis 1100 euro.Aber ich denke ich warte noch.wollte noch lesen was die ersten über den Yamaha 3060 schreiben oder das Angebot für einen Denon wäre die nächsten Wochen als Auslaufmodel so gut das ich ihn nehmen muß ![]() |
Lars_1968
22:15
#1819
Wenn Du den Sub umstellst mußt Du theoretisch einmessen, da Audyssey die Laufzeit (Entfernung Sub zum 1. Meßpunkt) neu berechnet. Den 5200 würde ich nicht kaufen, da hast Du weder HDCP 2.2 noch DTS X und darauf würde ich nicht verzichten wollen, wobei Auro natürlich schon sehr gut ist (wie Du hier überall nachlesen kannst) [Beitrag von Lars_1968 am 29. Jul 2016, 22:46 bearbeitet] |
Fuchs#14
22:36
#1820
Der 5200 ist ne Mogelpackung, der müsste eigentlich 5100 heissen, da Modelljahr 2014 |
AirRailey
08:22
#1821
erstellt: 30. Jul 2016, |||||
Habt ihr noch ein paar Tipps zum einmessen? Was sollte aktiviert, deaktiviert werden? Ich glaube das der denon und ich bisher nicht beste Freude hatten, andere schwärmen, liegt b stimmt an falschen Einstellungen! Soll ich das ganze Gerät einmal zurücksetzen, dann neu einmessen? |
Fuchs#14
08:28
#1822
AirRailey
08:48
#1823
Hmm, dass habe ich mir heute morgen schon durchgelesen! Irgendwie mache ich was falsch! |
Fuchs#14
09:06
#1824
Was genau ist denn das Problem ![]() |
AirRailey
09:13
#1825
filme spiele ich über meine vu duo2 ab! ( only DTS) und normal tv gucke ich auch über die vu duo2 ! bei den filmen neigt es oft zum überdröhnen, in Passagen wo man gar nicht so viel bass erwartet, in andern Passagen kommt dann finde ich Zuwenig! beim normal tv betrieb ist es viel zu wenig bass... Sprachpegel: aus Sub Pegel: aus Surround Param: cinema eq: aus, Loudness: aus, LFE Pegel 0db audyssey: Multi xt: Reference, Dynamic eq: ein, RefPegel 10db, Dynamic Volume: light Lautsprecher knotig: alle auf klein, sub auf ja sub wurde bei +4db eingemessen Übernahmefrequenzen: Front 40Hz, Center 40Hz, Surround 60HZ Subwoofer modus: LFE Trennung bei 80HZ |
std67
09:32
#1826
Hi stell mal DynVol auf ¨ Aus¨ (derzeit ¨light¨) |
AirRailey
09:42
#1827
ich muss trotzdem einmal neu einmessen, weil ich meinen sub umgestellt habe! er stand zu eingeengt, zwischen sofa und terassentür! soll ich den denon einmal komplett resetten? |
std67
09:47
#1828
brauchst du nicht. Die alte Einmessung wird koplett überschrieben |
DeBaba
09:52
#1829
Die Übernahmefrequenz für die Heco Victa ist viel zu tief! Alle auf 80Hz, 40 bzw 60 ist falsch Subwoofer Modus ist wohl wieder mal dieser LPF, der gehört auf 120Hz. [Beitrag von DeBaba am 30. Jul 2016, 09:54 bearbeitet] |
AirRailey
10:01
#1830
So wurde es eingemessen, daran habe ich nichts verändert! Man liest sich überall das der sub bei 80hz sein muss |
std67
10:07
#1831
nee am Subwoofermodus ändert Audyssey/der AVR/die Einmessung nie automatisch was. Stells auf 120Hz (hab ich vorhin koplett übersehen) Die icta solltest du nach der Einmessng dann wirklich höher trennen. Die Fronts mnd auf 60Hz, evtl. höher. Kleinere Center Rears mind bei 80, evtl 100Hz |
Fuchs#14
10:10
#1832
Und wo überall liest man das mit den 80 hz? |
Lars_1968
10:14
#1833
Vermutlich liest man das im Zusammenhang mit der Nicht-Ortbarkeit bis 80 Hz, wobei 120 Hz auch keinf "Problem" darstellen. |
std67
10:15
#1834
nur das DIESE Einstellung eben nur den LFE betrifft, und nicht die Trennung zu den Satelliten |
AirRailey
10:25
#1835
Sub auf 120 gestellt, Front auf 80, Center auf 100 und rear 100 Sub wurde bei + 5,5 eingemessen [Beitrag von AirRailey am 30. Jul 2016, 10:43 bearbeitet] |
megaknaller
10:35
#1836
Habe nochmal nachgeschaut,es ist ein 5200 und nicht 6200. |
Lars_1968
10:54
#1837
Den würde ich nicht kaufen, wie Fuchs sagte, ist das eigentlich ein 5100. Wenn Du noch Zeit hast mit dem Kauf, würde ich den 4300 nehmen, der im Herbst raus kommt und erfahrungsgemäß im Frühjahr 2017 bezahlbar ist, bzw. bin ich bereit, dann das Geld dafür auszugeben. |
megaknaller
11:41
#1838
Danke erstmal,möchte dann den 5200 w nicht haben,vielleicht wie ihr sagt auf den 4300 warten oder der 6200 scheint ja auch zu fallen ( ist er vielleicht sogar dann besser als der4300 ?) Der Peis nimmt sich dann wohl nicht mehr viel in den nächsten Wochen oder Monaten denke ich.Und den teureren Yamaha 3060 werde ich auch im Auge behalten,leider geht bei mir das Geld komischerweise schneller raus als rein ![]() |
Dadof3
Moderator |
13:11
#1839
Irgendwie verstehe ich deine Auswahl nicht. Du scheinst irgendwie ein bestimmtes Budget zu haben, und suchst nun die Alternativen aus, die das Budget so weit wie möglich ausreizen, ohne zu wissen, was die Geräte überhaupt bieten und was nicht. Das ist doch völlig unlogisch. Wenn du dein Geld unbedingt loswerden willst, es gibt zahlreiche Spendenorganisationen, die es gut gebrauchen können. Überlege dir, welche Ausstattungsmerkmale du wirklich benötigst oder möchtest, und dann suche dir das günstigste Gerät, das diese Ausstattung hat. Wenn du also mit einem X4300 liebäugelst, warum dann nicht mit einem X4200? Da gibt es fast keinen Unterschied. Und übrigens auch nicht zum X6200. Ich halte wenig von den Geräten oberhalb der X4x00-Reihe. Die bieten für die meisten Anwender praktisch keinerlei Mehrwert, kosten aber erheblich mehr. |
Lars_1968
13:22
#1840
Der 4200 ist sehr gut, ohne Frage, ich habe ihn schließlich selbst, jedoch bietet der 4300 9 Endstufen, was ich bei 5.1.4 deutlich besser finde als eine externe Endstufe kaufen und hinstellen zu müssen und die "Audyssey Zielkurven-App" |
RheaM
13:27
#1841
Die Preise fallen, den X 1200 gibts bei hificorner.nl für 314,- |
megaknaller
13:35
#1842
Möchte 9 Endstufen und bei Yamaha lese ich halt viel gutes darüber das man dann bei Atmos die Yamaha DSP Programme noch rüberlaufen lassen kann ( 5100 und bald 3060 so habe ich es jedenfalls verstanden) Soll ja gut klappen und man kann dort wohl sein Spieltrieb sehr gut ausleben.Da ich mein letzten Receiver jetzt glaub über 13 Jahre hatte schaue ich mich halt um weil es auch dann wieder für länger ist.Schade finde ich das bei Yamaha Auro 3 nicht zur verfügung steht Und Marantz passt mir glaub von der Optik nicht so.Habe auch kein Problem mit einen gut gebrauchten oder Austeller.Danke für die schnellen Antworten. |
Dadof3
Moderator |
13:42
#1843
Wenn jemand die 9 Endstufen unbedingt möchte, ist das ja ok. Wobei das eine teure Sache ist: Einen X4200 gibt es zurzeit für gut 900 €, auf den X4300 muss man noch warten und dann kostet er zu Anfang fast 700 € mehr. Wenn ich mir stattdessen eine SMSL-Endstufe dranhänge, spare ich immerhin noch 600 €. Die sind auch kompakt genug, um sie irgendwo verstecken zu können. |
std67
23:11
#1844
AirRailey
07:21
#1845
erstellt: 31. Jul 2016, |||||
Ich? Habe ich doch schon morgens gemacht |
AirRailey
18:11
#1846
erstellt: 04. Aug 2016, |||||
hallo ich habe ja meinen sub umgestellt und neu eingemessen, vorher habe ich dir conifig übers webui gespeichert! einige andere sachen wurden ja auch noch geändert, daher wollte ich den sub doch nochmal an der alten stelle testen! also habe ich übers webui meine config geladen! lief alles ohne Fehler durch, allerdings wird mein sub jetzt nicht mehr angesprochen, alles komplett ohne bass! dann habe ich die andere config geladen und da das gleiche! woran kann es liegen? |
Dadof3
Moderator |
18:31
#1847
An einer fehlerhaften Verbindung zum Subwoofer...? |
AirRailey
18:32
#1848
habe zwei unterschiedliche Kabel getestet, bevor ich die config datei geladen hatte, ging ja alles ich habe den ganzen avr redetet und die config neu geladen, immer noch kein bass, subwoofer wird mir unter Lautsprecher angezeigt etc [Beitrag von AirRailey am 04. Aug 2016, 19:08 bearbeitet] |
AirRailey
06:55
#1849
erstellt: 07. Aug 2016, |||||
Ich habe jetzt neu eingemessen und Bass ist wieder da! Allerdings nicht mehr so schön wie vorher! Der Sub abstand wurde zweimal auf 0,03m eingemessen, obwohl die Entfernung bei ca 3,50m liegen müsste! Die Front LS wurde mit dieser Entfernung eingemessen und dass kommt gut hin! Der sub steht ja daneben, also können die 0,03m ja nicht stimmen |
Dadof3
Moderator |
08:17
#1850
Die physische Entfernung entspricht nicht unbedingt der akustischen. Es kann durchaus sein, dass ein ganz anderer Wert der richtige ist. Es kann aber auch ein Messfehler vorliegen. 3 cm kommen mir schon seltsam vor. Ich würde die Messung wiederholen. Steht der Phasenregler auf 0? |
AirRailey
09:13
#1851
Ich denke ja, bin gerade auf der Arbeit und will morgen früh nochmal in Ruhe einmessen, wenn niemand zu Hause ist |
Denon X6200W / MultEQ Rauschen richardb am 04.11.2016 – Letzte Antwort am 11.10.2017 – 14 Beiträge |
Denon X4300H oder X6200W? dulf am 28.11.2016 – Letzte Antwort am 30.11.2016 – 5 Beiträge |
DENON AVR x6200W Laser6Pinguin am 05.05.2017 – Letzte Antwort am 05.05.2017 – 2 Beiträge |
Denon X1200W - Preouts Thief_55 am 28.03.2016 – Letzte Antwort am 29.03.2016 – 3 Beiträge |
Denon X4200W Impedanz Eleusius am 27.06.2016 – Letzte Antwort am 27.06.2016 – 8 Beiträge |
Wertanfrage Denon X3200W JensHS am 12.09.2018 – Letzte Antwort am 12.09.2018 – 2 Beiträge |
Denon AVR X1200W H1953 am 20.12.2016 – Letzte Antwort am 22.12.2016 – 6 Beiträge |
Neues Update für AVR X2200W benjamin1* am 23.03.2017 – Letzte Antwort am 23.03.2017 – 2 Beiträge |
Denon AVR-X3300w oder AVR-X4200w? Rebl am 08.10.2016 – Letzte Antwort am 09.01.2017 – 10 Beiträge |
Denon X4200W Einmessung outbid am 01.06.2016 – Letzte Antwort am 06.06.2016 – 16 Beiträge |
- Registrierte Mitglieder926.909 ( Heute: 5 )
- Neuestes MitgliedTheo1968
- Gesamtzahl an Themen1.554.292
- Gesamtzahl an Beiträgen21.609.658
