| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » SONY DAV-S800 COMPACT AV SYSTEM | |
SONY DAV-S800 COMPACT AV SYSTEM+A -A |
bmwpower
erstellt: 01. Mrz 2009, 23:46
HALLO HABE EIN GROSSES ANLIEGEN DAV-S800 COMPACT AV SYSTEM AUS MEIN SONY DAV-S800 COMPACT SYSTEM HCD-S800 SACD/DVD RECEIVER 5.1ch FULL DIGITAL AMPLIFIER FUNKTIONIERT EINWANDFREI BIS AUF DIE DVD WENN ICH DIE EINSCHALTE SCHREIBT DAS DISPLAY DAV-S800 DANACH STEHT GESCHRIEBEN DVD AM DISPLAY UND NACH ZIRKA 5 SEKUNDEN SCHALTET ER SICH AUS DANN KLICKT ES SO IN DER ART WIE EIN RELAIS KLACK UND SCHALT AB ABER WENN ICH AUF DER FUNCTION TASTE WEITER DRÜCKE SPIELT RADIO ALLES OK NUR BEI DVD BETRIEB SCHALTET ER AB 1 FOTO NACH DEM EINSCHALTEN http://s4b.directupload.net/file/d/1720/cz7hou9i_jpg.htm2 FOTO NACH ZIRKA 5-10 Sec http://s4b.directupload.net/file/d/1720/xmxwmiho_jpg.htm3 FOTO DAS PROBLEM http://s8b.directupload.net/file/d/1720/598qyw68_jpg.htmICH VERBLEIBE HOCHACHTUNGSVOLL UND SAGE IM VORAUS DANKE DANKE NOCHMAL LIEBE GRÜSSE |
tri-comp
erstellt: 02. Mrz 2009, 07:46
Hi, Most likely your laser pick-up is not reading the DVD. It tries to focus (the clicking sound) but is not successfull and after a few tries it shuts-off and disables the DVD function. A new complete laser pick-up type KHM-240AAA is available from ASWO, Germany partno.: 3880679 ASWO is a whole-dealer and parts should be ordered through shops that deal with them. The laser-unit is expensive and will probably cost around 150 Euro. Certainly you would like to confirm that the laser is actually defective before ordering a new. This will require a good deal of knowledge about electronic circuits, the service-manual and some test-gear (Mainly an oscilloscope). I can help with the service-manual. Where you will get the other is up to you mfg, /tri-comp |
Telefunken S800 Gleichlaufschwankungen elchupacabre am 02.09.2012 – Letzte Antwort am 24.08.2014 – 26 Beiträge |
Sony DAV-S500 Surround Laser defekt Kevagianer am 28.12.2007 – Letzte Antwort am 07.01.2008 – 8 Beiträge |
Telefunken S800 Hifi, reparieren lohnend? Moonlight3 am 30.01.2010 – Letzte Antwort am 19.08.2014 – 9 Beiträge |
Telefunken Compact 2000 M.Schopf am 06.03.2010 – Letzte Antwort am 07.03.2010 – 3 Beiträge |
Kirksaeter Compact 5000 shabbel am 01.12.2012 – Letzte Antwort am 20.12.2012 – 27 Beiträge |
Elac High fidelity compact 25 Sommerisch am 21.04.2007 – Letzte Antwort am 15.11.2015 – 2 Beiträge |
Saba Compact Stereo 963 Lautstärkepoti audimax am 06.12.2013 – Letzte Antwort am 13.12.2013 – 9 Beiträge |
Radioteil SABA Stereo Compact 963 morettnik am 14.05.2016 – Letzte Antwort am 16.05.2016 – 6 Beiträge |
Fehlersuche Telefunken Hifi Compact 2000 makad am 26.01.2022 – Letzte Antwort am 28.01.2022 – 3 Beiträge |
Telefunken hifi compact 2000 / Bagatellreparatur Skalenbeleuchtung? zonebattler am 23.07.2007 – Letzte Antwort am 26.07.2007 – 8 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.692 ( Heute: )
- Neuestes Mitglied
- Gesamtzahl an Themen1.563.550
- Gesamtzahl an Beiträgen21.828.585
