Revox B 710 stoppt nach zwei sekunden
Kubra
#1 erstellt: 03. Feb 2009, 20:14
Hallo erstmal,
ich bin neu hier im Forum und kenn mich noch nicht so gut aus. Hoffe dass ich mit meinem Problem hier richtig bin.
Also, seit kurzem darf ich ein Revox B710 Tapedeck mein eigen nennen. Ist ein wunderschönes Erbstück. Nun gibt es allerdings ein Problem. UNd zwar wenn ich ein Tape einlege und auf PLay drücke, stoppt die wiedergabe nach ca 2 sec. Spulen funktioniert einwandfrei.
Hat jemand eine Idee was das Problem ist?
tri-comp
#2 erstellt: 03. Feb 2009, 20:43
Hi Kubra,
This tape-deck is extremely complicated and it's impossible to say where the fault is without doing some measuring/investigation into the control circuits...
The Dual Capstan Motor system is very special. It has a dual tacho-control system and if the motors are out-of-sync, the sync detector sends info to the microprocessor about the fault. I assume in that case the processor will go from PLAY to STOP.
Just what may CAUSE an out-of-sync situation is impossible to guess on. Fault in a capstan-motor, fault in control-electronics, fault in power-supply ....or maybe even a mechanical fault that causes a motor to run slow. That could be something as simple as a Pinch-roller bearing needing cleaning and lubrication.
All this is speculation, only.
Do you need the service-manual?
mfg,
/tri-comp
Kubra
#3 erstellt: 04. Feb 2009, 16:01
Thank you for answering!
Yes, the manual would be very helpfull.
stevevdb
#4 erstellt: 08. Feb 2009, 10:52
ftp://ftp.studer.ch/Public/Products/Revox/
The must for every revox fan
About the B710:
-is there tape transport visible when in play function?
If not: capstan maybe ok but the left spooling motor may not react so the tape is blocked. When this happens: tapedeck thinks the tape is at the end so it must stop.
The-Luxman
#5 erstellt: 08. Feb 2009, 12:06
Besides: It's a generally problem with all REVOX-tapedecks.
I got the same problems with my B 215 - and still I have.
Revox B 710 Mk I zerknittert Band
maddin2 am 16.12.2012  –  Letzte Antwort am 18.12.2012  –  8 Beiträge
Hall Sensor Revox B 215, B 710 Defekt oder gut?
Manfred_K. am 21.01.2022  –  Letzte Antwort am 29.01.2022  –  24 Beiträge
Nakamichi Dragon - stoppt nach 10 Sekunden
hbanko am 28.06.2022  –  Letzte Antwort am 09.07.2022  –  7 Beiträge
Revox B-251
kossfan am 05.12.2007  –  Letzte Antwort am 05.12.2007  –  4 Beiträge
Revox-B 790
Musicbyalex am 16.04.2010  –  Letzte Antwort am 25.04.2010  –  5 Beiträge
Revox B 790 Reparatur
quarryman4ever am 18.04.2012  –  Letzte Antwort am 19.04.2012  –  4 Beiträge
Revox B 77 spinnt
Ulrichgoslar am 05.07.2015  –  Letzte Antwort am 09.07.2015  –  3 Beiträge
Revox B 150 tonlos
Calosso am 10.09.2017  –  Letzte Antwort am 10.09.2017  –  2 Beiträge
Doppelkassettendeck stoppt
rudeboyheiko am 15.06.2015  –  Letzte Antwort am 01.07.2015  –  3 Beiträge
Revox Agora B Verstärker defekt
Applelunatic am 23.09.2014  –  Letzte Antwort am 04.03.2015  –  8 Beiträge
  • Registrierte Mitglieder928.383 ( Heute: 2 )
  • Neuestes MitgliedKire2025
  • Gesamtzahl an Themen1.558.081
  • Gesamtzahl an Beiträgen21.693.929
