| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Grundig T5000 frequency problem | |
Grundig T5000 frequency problem+A -A |
zoso-yu
erstellt: 15. Jul 2020, 16:00
Hello everyone, I’m a proud owner of Grundig 5000 system. Thanks to good people from this forum I’ve managed to repair everything, and everything is working. Recently I’ve bought brown version of t5000 tuner (I have silver version) couldn’t resist. I’t had the well known defect with rectifer. I’ve changed the rectifier and tuner started to work again after many years. It has good signal and everything works but I found a problem because I’ve compared the two tuners. On very weak stations let’s say 101.00mhz my first silver tuner turns the tunescope to green because that’s the stations frequency and plays with little noise. The brown tuner does the same thing but on 101.02mhz. On 101.00mhz turns the tunescope to green but it has less noise on 101.02mhz and one red signal LED more. So it has 0.02mhz miss match. How can I fix that? It’s not noticeable on strong stations only on weak ones. Thank you! |
Bertl100
erstellt: 16. Jul 2020, 08:23
Hello, a re-adjustment of the center detection would be necessary. Adjustment point "b". However, if you do not have suitable tools in your hands you should not try to change anything on these adjustments. Best regards, Bernhard |
zoso-yu
erstellt: 16. Jul 2020, 12:08
Hi Bernhard, thank you for your reply! So you think it’s the problem with discriminator? Maybe I didn’t explain it right. If the right frequency of the station is 101.00mhz the tuner lights up green tunescope light, but on 101.02 the tuner has one more red signal diode and less noise. As I’ve said that’s only on very weak stations. The tuner normally lights up mpx on 101.00mhz and on 101.02mhz. I have very precise multimeter and plastic adjustment screw drivers :). So the problem isn’t on HF part of FM? On FM tuner almost every ferrite core is sealed with wax. After a good comparison between two tuners the good one has a better reception on weak stations. So I think that’s the problem. I think that the FM head is out of tune a little. How can i tweak it? Turn the trimmer capacitors to max signal strength? [Beitrag von zoso-yu am 16. Jul 2020, 17:51 bearbeitet] |
Grundig T5000 Displaybeleuchtung reparieren stallion007 am 05.08.2008 – Letzte Antwort am 07.08.2008 – 10 Beiträge |
Grundig T5000: Fragen 8bitRisc am 07.11.2010 – Letzte Antwort am 12.03.2011 – 79 Beiträge |
Grundig T5000 intakte Selengleichrichter tauschen? hifibastler2 am 06.03.2010 – Letzte Antwort am 23.03.2010 – 26 Beiträge |
Grundig T5000 Drehregler Frequenz defekt Kaffeepeter am 29.11.2011 – Letzte Antwort am 28.04.2021 – 12 Beiträge |
Grundig V5000 und T5000 sanieren cbmuser am 04.12.2011 – Letzte Antwort am 08.12.2011 – 24 Beiträge |
Grundig MT100: Fragen 8bitRisc am 04.12.2010 – Letzte Antwort am 04.12.2010 – 6 Beiträge |
Grundig R2000: Fragen 8bitRisc am 20.11.2010 – Letzte Antwort am 28.11.2010 – 35 Beiträge |
Grundig T 5000 Handabstimmung defekt 1oll2 am 21.10.2016 – Letzte Antwort am 24.04.2022 – 14 Beiträge |
Problem mit Grundig RPC200 StevenvdF am 15.08.2008 – Letzte Antwort am 20.08.2008 – 4 Beiträge |
Problem am Grundig A5000 stallion007 am 12.09.2008 – Letzte Antwort am 28.12.2008 – 19 Beiträge |
2020
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.678 ( Heute: 5 )
- Neuestes Mitgliedmarschechter
- Gesamtzahl an Themen1.563.494
- Gesamtzahl an Beiträgen21.826.954
