Old Arphi 60x2 watts amp
Manek
#1 erstellt: 05. Apr 2009, 15:43
Hi guys
Just opened up this old arphi 60x2 watts amp I used to use upto about 10 yrs ago, out of sheer curiosity. It was a real sweet sounding transistor amp. No edgyness at all. It is black with the same chasis as the pulz stereo amps. Some things never change :-)
To my surprise I saw a torroid transformer. Neatly laid out components (don't know if its a pcb or a hardwired board, there is a 2-3mm layer of dust on it so can't make out).
Apart from the uptron caps I saw ones made by websen(isn't this the company that makes electro's under license from rubycon?).
Very ordinary carbon pots. I am sure nothing works now since its all under a ton of dust.
Now guys, this amp has amazing memories associated with it so I want to know if can be resurrected or should I strip out the parts and keep the torroid and chasis for later ?
And Aks, since you know a whole lot about old indian amps...your pearls of wisdom ?
Manek
Soundsgreat
#2 erstellt: 06. Apr 2009, 09:53
Hmm good to know you have kept them for all these years !!
Manek I've not seen a SS Amp or pre hardwired !! its in all probability a PCB !
The Caps that you mention was infact the rubycon Avataars (Webson or Webelson were the license holders )
I know the feeling ! So I will strongly Recommend you to get it serviced or if are one of Us (the DIY folks) then get your hands dirty and make it happen !
If not for anything else you can perhaps use it for some bedroom or a small study room purposes !
Again if you are the adventurous Kind,Then get the Caps replaced with some good make (as anyhow they would've lost the charge ), you can try Panasonic FC series for a budget yet super sound ones, or the Nichicon Muse !
If you really don't mind the cost then the Blackgates and the Elna for Audio is the one's !!
Alternatively you can choose to replace the Pots with some Alps ones ! Money no bar ? the Alps Black Beauty or Velvet is the best choice !
Rest should be good enough ! but still another mod is to change all the resistors to the Vishay/Dale or Halco one's ! Vishay is bit cheaper but sonically good (I think you know bout these things ) !
Anyways I given my feedback on this ! Hope it makes some sense !!
Let me know your thoughts on the same !
Regards.
bombaywalla
#3 erstellt: 06. Apr 2009, 15:07
Manek
Manek, you just might be assuming too much!
Use a clean paint brush to dislodge the dust & a canister type vacuum cleaner (which usually have a long pipe to the vacuum cleaning attachment) to suck out the dust.
Use some Caig ProGold on the pots & get them making better (good?) electrical contact. Check the fuse. Check the chassis ground connection.
Power the amp up & see whether it plays or not - it might & then, it might not.
Once you ascertain for sure what the present status of the amp is, make an appropriate restoration plan.
Since the amp has such fond memories, I would say that this alone is reason enough to resurrect the amp.
Manek
#4 erstellt: 07. Apr 2009, 06:01
Soundsgreat
I am not heavily into diy but don't mind getting my hands dirty :-) I just shouldnt mess it up further....:-) any accidental fireworks would tick off the missus and probably put an end to my project ! Got to obey the ground rules !
Btw the caps are "websen". They are still available cause I saw then at a shop recently. No website though :-( anyone used them ? If so how would you rate them ?
Bombaywalla, it needs a lot of work from the looks of it.
I will clean it up thoroughly first and then decide on the action plan. Will use the lightbulb method to try and slowly bring it back to life.
Manek
Soundsgreat
#5 erstellt: 07. Apr 2009, 07:21
Glad to hear that Manek ! Don't worry I don't think you can have fireworks !
Moreover you are a guy with lot experience with using them and I think you know far too well to do some silly mistakes ! But yeah The Ground Rules,Have to adhere to them !!
Bout the Caps, Manek as far as my knowledge goes they should be some old stock ! coz they stopped them some years ago and I haven't seen them since !
I have used them in some of my earlier projects,Nothing to write home bout ! just your average quality one's !
Yes please clean it thoroughly and see the result ! the Bulb trick is very very novel !
Try it out and let Us know the result so that we can suggest your next move ! Also if possible please do post some pics of it so that we can see the actual condition and things !
Regards.
Manek
#6 erstellt: 08. Apr 2009, 03:39
Pics !
Good idea !
Before or after the cleaning ?
He he, I am just messing with you....
I put them up.
Manek
DIY Headphone amp
Manek am 20.09.2006  –  Letzte Antwort am 21.09.2006  –  25 Beiträge
KT77 Pushpull integrated amp
quadtech am 25.12.2008  –  Letzte Antwort am 13.01.2009  –  10 Beiträge
Santa Claus DIY Tube Amp
screamgigi am 14.10.2006  –  Letzte Antwort am 09.10.2007  –  237 Beiträge
LM318+LM3886 MyRef amp completed
quadtech am 14.04.2009  –  Letzte Antwort am 18.04.2009  –  7 Beiträge
300 watt Hi-fi power amp project.
hydrovac am 19.07.2013  –  Letzte Antwort am 19.09.2013  –  5 Beiträge
Not so Genuine OPA2134
Manek am 29.04.2012  –  Letzte Antwort am 12.05.2012  –  6 Beiträge
My second DIY tube amp .The starving student Millet Hybrid
Savyasaachi am 11.03.2009  –  Letzte Antwort am 18.03.2009  –  13 Beiträge
Slightly OT - CNC cutting for DIY
quadtech am 16.02.2009  –  Letzte Antwort am 29.03.2009  –  6 Beiträge
Bought my first tubes.now need an amp to put them in
Savyasaachi am 09.02.2009  –  Letzte Antwort am 11.02.2009  –  5 Beiträge
DIY Sub .
sivat am 18.09.2008  –  Letzte Antwort am 30.10.2008  –  24 Beiträge
  • Registrierte Mitglieder930.640 ( Heute: 11 )
  • Neuestes MitgliedBrummkreisel17
  • Gesamtzahl an Themen1.563.389
  • Gesamtzahl an Beiträgen21.823.932
