| HIFI-FORUM » English » DIY (Engl.) » 300 watt Hi-fi power amp project. | |
300 watt Hi-fi power amp project.+A -A |
hydrovac
erstellt: 19. Jul 2013, 17:55
Hi all DIYers, Building a 300 watt Hi-fi power amp, which we designed and prototyped few years ago. Please follow the links for details. http://www.diyaudio....power-amplifier.html http://www.diyaudio....r-4.html#post1330047PCBs have been fabricated and gathering all components on hand. Few pictures of the same. ![]() ![]() IMG_4459 by hydrovac, on Flickr![]() ![]() IMG_4458 by hydrovac, on Flickr![]() ![]() IMG_4461 by hydrovac, on Flickr![]() ![]() IMG_4462 by hydrovac, on Flickr![]() ![]() IMG_4570 by hydrovac, on Flickr![]() ![]() IMG_4575 by hydrovac, on Flickr![]() ![]() IMG_4465 by hydrovac, on Flickr![]() ![]() IMG_4464 by hydrovac, on Flickr
hydrovac
erstellt: 22. Jul 2013, 17:15
Holes for output devices drilled on heat sinks using a TO3 jig. Input and speaker binding posts holes done and connectors mounted. ![]() ![]() IMG_4448 by hydrovac, on Flickr![]() ![]() IMG_4366 by hydrovac, on Flickr![]() ![]() IMG_4556 by hydrovac, on Flickr![]() ![]() IMG_4481 by hydrovac, on FlickrThis is the den for our hobby & passion, and where all our classics come to life. ![]() ![]() IMG_4399 by hydrovac, on Flickr![]() ![]() IMG_4398 by hydrovac, on Flickr![]() ![]() IMG_4397 by hydrovac, on Flickr![]() ![]() IMG_4396 by hydrovac, on Flickr![]() ![]() IMG_4315 by hydrovac, on Flickr![]() ![]() IMG_4314 by hydrovac, on Flickr![]() ![]() IMG_4313 by hydrovac, on FlickrPower transistors mounting process and progress. ![]() ![]() IMG_4420 by hydrovac, on Flickr![]() ![]() IMG_4412 by hydrovac, on Flickr![]() ![]() IMG_4409 by hydrovac, on Flickr![]() ![]() IMG_4416 by hydrovac, on Flickr![]() ![]() IMG_4414 by hydrovac, on Flickr![]() ![]() IMG_4412 by hydrovac, on Flickr![]() ![]() IMG_4449 by hydrovac, on Flickr![]() ![]() IMG_4442 by hydrovac, on Flickr |
hydrovac
erstellt: 02. Aug 2013, 11:20
Hi friends, Sorry for the long gap in my post as I was preoccupied with other commitments. In continuation to my earlier posts, here is progress in amp build. Checking the DC rail voltages: Left channel, Right channel, both channels ![]() ![]() IMG_4645 by hydrovac, on Flickr![]() ![]() IMG_4646 by hydrovac, on Flickr![]() ![]() IMG_4648 by hydrovac, on FlickrChecking full rail voltages: Left channel, Right channel, - Ve and +Ve rails ![]() ![]() IMG_4652 by hydrovac, on Flickr![]() ![]() IMG_4653 by hydrovac, on Flickr![]() ![]() IMG_4655 by hydrovac, on FlickrI am supposed to get around +62 and -62 volts DC on rails. The increase in reading is because of the mains input voltage (250 volts AC). Toroidal transformer winding is rated for 230 volts primary. ![]() ![]() IMG_4682 by hydrovac, on Flickr![]() ![]() IMG_4686 by hydrovac, on Flickr![]() ![]() IMG_4683 by hydrovac, on FlickrSetting the quiescent bias current for output stage: Fabricated a 10 ohm 5 watt wire wound resistor suitable for the fuse holder. ![]() ![]() IMG_4671 by hydrovac, on Flickr![]() ![]() IMG_4674 by hydrovac, on FlickrInserted in +Ve side holder and switched on the power. Adjusted the trim pot to get, 1.0 volt across the resistor. ![]() ![]() IMG_4658 by hydrovac, on Flickr![]() ![]() IMG_4660 by hydrovac, on Flickr![]() ![]() IMG_4661 by hydrovac, on Flickr![]() ![]() IMG_4662 by hydrovac, on Flickr![]() ![]() IMG_4657 by hydrovac, on Flickr![]() ![]() IMG_4659 by hydrovac, on FlickrYou can see the thermal sensing bias transistors mounted mid way between the power transistors on the heat sink. Good going so far. ![]() ![]() IMG_4678 by hydrovac, on Flickr![]() ![]() IMG_4680 by hydrovac, on Flickr![]() ![]() IMG_4679 by hydrovac, on FlickrNow, looking at output side. Measuring the speaker output terminals for DC. ![]() ![]() IMG_4669 by hydrovac, on Flickr![]() ![]() IMG_4668 by hydrovac, on Flickr![]() ![]() IMG_4667 by hydrovac, on FlickrLeft channel looks clean without any DC. But right channel is showing 0.04 volts. There seems to be a hitch somewhere. I will get back with updates after trouble shooting. Thanks for looking and following the post. |
hydrovac
erstellt: 13. Aug 2013, 03:46
Actually 40mv dc offset isn’t that bad. I traced it to a slightly leaky cap. Replaced it and now it reads 1.5mv on right channel and 2.8mv on left channel, in 200mv range of multi meter. My Dc offset is excellent and will not damage the speakers, but many say as high as 50mv is still OK. I connected a source and performed an extensive listening session. Must confess the amp has an amazing sonic quality. ![]() ![]() IMG_4441 by hydrovac, on Flickr![]() ![]() IMG_4445 by hydrovac, on Flickr![]() ![]() IMG_4478 by hydrovac, on Flickr![]() ![]() IMG_4482 by hydrovac, on Flickr![]() ![]() IMG_4580 by hydrovac, on Flickr![]() ![]() IMG_4579 by hydrovac, on Flickr![]() ![]() IMG_4577 by hydrovac, on Flickr |
Brueckenwaechter
erstellt: 19. Sep 2013, 09:23
Damn nice Job! Does it come in Pink? |
DIY 300B DHT SE Amplifier Project aks07 am 14.01.2009 – Letzte Antwort am 22.02.2009 – 84 Beiträge |
Eminence Lab 12 Subwoofer Project surrealistix am 14.11.2008 – Letzte Antwort am 27.11.2009 – 26 Beiträge |
DIY Headphone amp Manek am 20.09.2006 – Letzte Antwort am 21.09.2006 – 25 Beiträge |
DIY. Simple Back Loaded Horn project with vintage BOLTON drivers aks07 am 12.10.2008 – Letzte Antwort am 24.12.2008 – 27 Beiträge |
Working on ML-TL Transmissionline speaker project anilmn am 08.06.2010 – Letzte Antwort am 16.06.2010 – 5 Beiträge |
More tube projects on the starting block Savyasaachi am 24.03.2009 – Letzte Antwort am 11.03.2010 – 31 Beiträge |
Santa Claus DIY Tube Amp screamgigi am 14.10.2006 – Letzte Antwort am 09.10.2007 – 237 Beiträge |
25vdc regulated power supply Manek am 26.01.2011 – Letzte Antwort am 22.05.2011 – 9 Beiträge |
KT77 Pushpull integrated amp quadtech am 25.12.2008 – Letzte Antwort am 13.01.2009 – 10 Beiträge |
Old Arphi 60x2 watts amp Manek am 05.04.2009 – Letzte Antwort am 08.04.2009 – 6 Beiträge |
- Registrierte Mitglieder930.643 ( Heute: 7 )
- Neuestes MitgliedHolger72!
- Gesamtzahl an Themen1.563.397
- Gesamtzahl an Beiträgen21.824.300
