HIFI-FORUM » English » DIY (Engl.) » DIY Sub . | |
DIY Sub .+A -A |
sivat
13:39
erstellt: 18. Sep 2008, |
Based on Jochen feedback on my system's lack in Bass, i've decided the best way forward is a powered sub-woofer than a big three way speaker controlled with a passive crossover. Amp : I've looked around for the sub woofer amp. All are chinese made amps...none impressed me. So i've decided to purchase the coldamp module, throw in a PSU along with Rod Elliot's subwoofer equalizer setup (buying the PCB from him). I'm sure this will be a far better amp than anything else we get in the market. Woofer : I was thinking about the only Scanspeak sub-woofer combined with thier passive radiator...any one else have any other suggestions ? Deaf ...any suggestions ? Cabinet : MDF combined with Corian and bitumen....for effective dampeing...any suggestions. |
Arj
14:28
siva, this is one project which i am going to be following with very keen interest ![]() ![]() how are you going to do the crossover in order to manage speaker integeration ? also would you plan line inputs from the preamp or high level inputs form the amp ? |
sivat
14:45
That's the best part ... no passive crossover to do any integration between the subwooer and the two-way (or MTM) speakers. The natural roll-off of the two way speaker in the mids are just about sufficient. We then measure the FR and adjust the sub-woofer equalizer (which in turn will have an electronic crossover as well) to get the desired level of flatness....which is impossible in a conventional 3 way speaker with a passive crossover. Well...all the above is my own theory, based on my understanding of physics (which is quite limited). Only time will tell !! The subs will have only one channel input...directly from the preamp. [Beitrag von sivat am 18. Sep 2008, 14:48 bearbeitet] |
purnendu
11:41
erstellt: 23. Sep 2008, |
Hooray! Lets follow this. What about the Shiva woofer? Purnendu |
Savyasaachi
19:35
I thought Adire audio went under a while back... |
aks07
12:47
erstellt: 25. Sep 2008, |
Have you decided on your amp? Having built a Sub sometime ago I think its worthwhile to consider a good quality plate amp. I first built a Marchand Electronics mosfet amp coupled with their excellent active crossover. The amp and xo kit was imported from USA. A toriodal power transformer was custom wound by Miracle of banglore. Putting together the amp, making a housing, getting an aritight fit, getting the amp stable etc etc were too much of an hassle. I gave up. Now using the BASH Oaudio 500 watts plate amp. Its got all the controls that can possibly ask for. Continuously variable phase, notch filters, parametric equaliser, selectable subsonic filter. With a combination you can create any pole that you want For the driver I am using Lambda Acoustics SB12. Again so kindly lugged all the way from USA by our good Bangalore buddy George Ollapally. Again I will strongly recommend getting a plate amp Should you guys interested than I will my post details in a new thread. |
bombaywalla
14:42
VERY fancy avatar aks07!!! ![]() ![]() ![]() where did you find that tube girl?? ![]() |
sivat
16:39
AKS, Checkout the following link, before u decide on a plate amp. ![]() Also checkout Rod Elliot's solution for the xover... Regards Siva. |
deaf
19:02
erstellt: 06. Okt 2008, |
Hmmm DIY sub Siva. Well it all depends on the kind of bass you want. I would design one that works with my room boundaries rather than a text book perfect sub woofer. A H type open baffle is the easiest way with cheap 8" drivers, as they have figure of 8 pattern and can be judiciously directed to fill in the correct amount of SPL at the seating position. Wont go below 40, but a correct 40 is better than a bullshit inroom 50 in a box trying to do an inroom 30 . I love maximising cheap drivers in my DIY so please excuse my lack luster input. Deaf. |
square_wave
10:45
erstellt: 08. Okt 2008, |
Great ![]() This is one along with the TT project that I am going to follow. It was a pleasure listening to the setup last Sunday Siva. Even without the sub, your setup extends quite low. But I guess you will need a sub if you want “ true full-range” extension. Hope your room will be able to support the lowest octave waves…. ![]() |
sivat
10:57
Deaf, I agreee with you fully. Infact it is the same philosophy that pushed me to make the sub amp on my own along with with L-R active crossover between the main system and the sub. I did not want to drive the drivers beyond FS and also wanted to rely largely on the sub's natural roll off. This way i get what the drivers are capable off...and nothing more. I do have a big room in mind .. but room interaction related compensation will happen only after the initial version is ready. |
deaf
14:57
Well Siva since you like doing the crazy and have the large room for it, here goes an idea. Make a pair of floor to ceiling line source subs using relatively inexpensive 8" drivers and mount them against the front wall. You will have a 2Pi line source, effectively minimising lobing errors and pressure and suckout zones. Now you can build a very good mid powered amp and go to extreme spl levels, as efficiency is nice to have. Deaf. |
sivat
03:18
erstellt: 09. Okt 2008, |
Deaf, Cool thoughts. I would love to try this...but i think i will most likely be thrown out of my own house. However, since i intend to use a L-R active between the sub and the main setup, i'm hoping to minimize the lobing. Infact this was the primarily reason for me to take the sub route - rather than taking the conventional approach of a three way crossover. Regards Siva. |
deaf
13:00
Dear Siva, A sealed bass using a Classic Scan 10" paper carbon is also an option. A stereo set ought to do it. Deaf. |
Arj
20:45
Any reason why a Cylindrical design is not being considered ? i have heard only of the SVS and Hsu (in the past) with cylindrical designs. does this form have any disadvantages ? |
sivat
05:23
erstellt: 10. Okt 2008, |
Deaf, I'm planning to use the Radiator 9" sub with the passive raditor. I feel this should be a better solution than a closed one. Yes.It will be a stereo set. Arj, Having non-parallel walls in a speaker cabinet is always an advantage...not only in sub. It is the logistics that makes it difficult... Regards Siva. [Beitrag von sivat am 10. Okt 2008, 05:24 bearbeitet] |
deaf
05:24
Dear Arj They have only advantages and no disadvantages. I wont go into details as they are numerous, I will only say that the best material is cardboard much like car audio cylindrical subs. Deaf. |
Arj
12:03
Thanks Deaf and Siva. Cosidering cardboard and Cylindrical shape, isnt this one of the easier sub to make once you already have a Driver and an Amp ? I am asuming it cannot be a sealed box ( ?) but could a Bass Trap + Sub be an option in design ? where I am coming from is that corner placements might actually be a "2 birds with one stone" kind of a thing. |
deaf
05:21
erstellt: 13. Okt 2008, |
Dear Arj, Same shape different purposes and hence different construction. But I will grant you that corner placement subs are the best. The only problem is the time relationship with the main pair. If that gets sorted out then everything is gung ho. Since we are in the cylindrical domain, the best subwoofer is the BOSE Acoustic WaveCannon, would love to make one. Deaf. |
Arj
05:42
Deaf, Wow.. this is something am doing some reading on it. Must say its very very male. ![]() Frequency Range 25 Hz – 125 Hz Active Equalization (from 402TMC, 502®C or 802®C Series II systems controller) Required Nominal Impedance 8Ohm. Maximum acoustic output 115 dB-SPL average, 118 dB-SPL peak Maximum recommended amplifier power 600 Watts Sensitivity 90 dB-SPL (30 Hz, 1 W, 1 m) Enclosure construction Custom-extruded polyvinyl chloride Mounting points Four 12.7 mm-diameter (0.5") holes on two flanges Connectors 2-conductor spade lugs (barrier strips) Dimensions 3.81 L x 0.43 W m (150" x 17") Weight 29 kg (63 lb) From what i could find out it costs about 4500 USD !!! [Beitrag von Arj am 13. Okt 2008, 05:52 bearbeitet] |
Arj
06:03
All specs talk of a 12" woofer and 12 feet in length and seems to be designed for conference rooms . i wonder, if a smaller one around a 8" would be possible..can "easily" be placed in a corner I am sure with some ingenuity it can be disguided as a potted tree ![]() [Beitrag von Arj am 13. Okt 2008, 06:04 bearbeitet] |
sivat
08:08
You can also checkout the Tymphany LAT .. |
deaf
04:56
erstellt: 14. Okt 2008, |
The LAT is something you can give a shot at. Ok the best best sub is still as good as the room allows. So a pair of corner placed downward firing subs are the best bet. |
square_wave
15:05
erstellt: 30. Okt 2008, |
Here is sub Danny Richie of GR Research is doing. ![]() Some good discussions also. |
Working on ML-TL Transmissionline speaker project anilmn am 08.06.2010 – Letzte Antwort am 16.06.2010 – 5 Beiträge |
Santa Claus DIY Tube Amp screamgigi am 14.10.2006 – Letzte Antwort am 09.10.2007 – 237 Beiträge |
DIY. Simple Back Loaded Horn project with vintage BOLTON drivers aks07 am 12.10.2008 – Letzte Antwort am 24.12.2008 – 27 Beiträge |
Upgrading Clock , I/V stage and regulators on a DAC Savyasaachi am 19.01.2009 – Letzte Antwort am 25.01.2009 – 21 Beiträge |
LM318+LM3886 MyRef amp completed quadtech am 14.04.2009 – Letzte Antwort am 18.04.2009 – 7 Beiträge |
DIY SUB India (Bangalore) cmsajith am 03.08.2009 – Letzte Antwort am 04.08.2009 – 6 Beiträge |
My new DIY headphones Savyasaachi am 25.01.2009 – Letzte Antwort am 15.05.2011 – 6 Beiträge |
My DIY Speaker Cable ! Soundsgreat am 29.03.2009 – Letzte Antwort am 30.03.2009 – 4 Beiträge |
Bought my first tubes.now need an amp to put them in Savyasaachi am 09.02.2009 – Letzte Antwort am 11.02.2009 – 5 Beiträge |
My DIY Interconnects ! Soundsgreat am 29.04.2009 – Letzte Antwort am 17.01.2010 – 10 Beiträge |
- Registrierte Mitglieder929.093 ( Heute: 8 )
- Neuestes MitgliedGebhardt_Dietmar
- Gesamtzahl an Themen1.559.672
- Gesamtzahl an Beiträgen21.732.066
