| HIFI-FORUM » Fernbedienungen, Zubehör, Kabel, HiFi-Möbel » Kabel, Adapter, Tuning, Zubehör » Transparent MusicLink Super XL/ MM Chinch kabel | |
Transparent MusicLink Super XL/ MM Chinch kabel+A -A |
kallix
erstellt: 15. Jan 2007, 14:18
Kennt jemand den Unterschied Transparent MusicLink super in der Xl oder MM version ? gruss kalli |
KSTR
erstellt: 15. Jan 2007, 18:12
Ist zwar OT zu Kallis Frage, aber dennoch interessant... Hier ist ja mal wieder was oberfaul, ein exzellentes Beispiel wie ein Hersteller den Laien mit Technik-Geschwafel was in die Tasche lügt (und $$$ in die eigene). Eine von vielen Seltsamkeiten auf der Webseite des Herstellers:"We have tested a wide variety of flat cables, coaxial cables, and twisted pair, nonnetwork designs on high speed gain phase, impedance analyzers in our laboratory. When we fit the analyzer with a typical audio source impedance to drive such cables into a typical audio load impedance, the point at which these cables achieve resonance falls somewhere between 1500-2500 Hz (depending on the specific cable and its length). This means that such a cable becomes more capacitive at frequencies below 1500-2500 Hz, thereby resisting the transfer of frequencies below 1500-2500 Hz. Twisted pair cables typically have a lower resonant point (usually in the 1500-2000 Hz range) than flat or coaxial designs. [...] A serendipitous effect of limiting the bandwidth of Transparent Cable with a properly designed network is a lowering of the resonant point, or that frequency where the cable becomes more capacitive and starts to resist low frequencies. In our experience, the sonic byproduct of lowering the resonant point is that music fundamentals and lower order harmonics seem to be passed in the correct proportion to each other and their higher order harmonics." Nur ein Detail aus dieser Passage mal kurz beleuchtet: Resonanzbedingung für einen Schwingkreis: w²LC=1 (mit w=2*Pi*f) Die Resonanz soll lt. Hersteller-Webseite bei üblichen Kabeln also bei etwa 2kHz liegen. Zu welchen (für, wie gesagt, "normale" Kabel) total abartigen Werten für L und C man kommen muss um das zu erreichen (bzw. die dafür notwendige Kabellänge), kann man sich leicht ausrechnen... Nehmen wir mal ein (schon wohl hunderte meter langes) Kabel mit C=1µF ==> müsste dann L=6.3mH(!!!) haben... das kann kein Kabel mehr, sondern eine riesige Drosselspule aus einer quadratkilometergroßen Kupferfolie. Grüße, Klaus (sorry Kallix) |
kallix
erstellt: 15. Jan 2007, 18:28
danke schon mal ich verstehe zwar vom orginal nicht alles - aber sicher ist , dass die kabel überteuert sind. und klar - alle versprechen wunderdinge. ich habe übrigends transparent in amerika angschriebn - mal sehen was die meinen...... gruss kalli |
Uwe_Mettmann
erstellt: 15. Jan 2007, 20:57
Hallo, hier die Frequenzgang-Diagramme von vermessenen Kabeln: Billiges 2 m RG59, Ausgangsimpedanz des Quellgerätes 600 Ohm, Eingangkapazität des Pegelmessgerätes 100 pF ![]() Straight Wire Kabel, dankenswerterweise gemessen von Moire, Ausgangsimpedanz und Eingangskapazität nicht bekannt ![]() Wie man sehen kann, Frequenzgangabweichung im hörbaren Bereich weit unterhalb von 0,1 dB und nix von Resonanzen zu sehen. Hier die der zugehörige Thread (bitte bis zum Ende lesen): ![]() Viele Grüße Uwe |
op111
Moderator |
erstellt: 16. Jan 2007, 09:28
Hallo zusammen,
diese und weitere Absonderlichkeiten versteckt die Website unter dem Punkt DESIGN AND TECHNOLOGY->TECHTALKDer Hersteller wertet im Wesentlichen kapazitätsarme und "zu kurze" Kabel durch einige sachlich unbegründete und nicht nachvollziehbare Werbeslogans ab: - klangschädigung durch unmusikalische (= breitbandige kapazitätsarme) Kabel - negativer Einfluß der Gruppenlaufzeit bei kapazitätsarmen Kabeln - negative Energiebalance etc. Um eine "musikalisch klingende Abschirmung und Bandbreitenbegrenzung auch kurzer Kabel" zu erreichen versieht transparentcable diese mit passiven Filtern. transparentcable propagiert somit das Gegenteil dessen, was einige Kabelklanghörer im von Uwe verlinkten Thread Cinchkabel- Messung - Anpassung an Anlage als Voraussetzung für guten "Kabelklang" ansahen.Gruß [Beitrag von op111 am 16. Jan 2007, 09:29 bearbeitet] |
Cinchkabel transparent pioneerfan am 29.08.2011 – Letzte Antwort am 15.09.2011 – 8 Beiträge |
Chinch Kabel ralfne am 10.08.2007 – Letzte Antwort am 18.08.2007 – 20 Beiträge |
Lautsprecherkabel 24AWG transparent in Deutschland zu bekommen? otraupe am 23.10.2013 – Letzte Antwort am 24.10.2013 – 6 Beiträge |
Transparent High Performance Power Cord wummew am 05.06.2022 – Letzte Antwort am 07.06.2022 – 30 Beiträge |
!F.L.A.C.H.E.S! Chinch-Kabel?(mono) H3liX am 04.07.2007 – Letzte Antwort am 04.07.2007 – 2 Beiträge |
preiswerte chinch kabel JohKraus am 05.09.2009 – Letzte Antwort am 09.10.2009 – 9 Beiträge |
Chinch-Kabel-"Misere" Hardford am 02.10.2012 – Letzte Antwort am 07.10.2012 – 17 Beiträge |
Suche dringend Koaxialkabel ca.2mm TRANSPARENT Charly918 am 28.02.2016 – Letzte Antwort am 10.03.2016 – 10 Beiträge |
woran gute chinch-kabel erkennen? hydro am 19.03.2004 – Letzte Antwort am 05.04.2006 – 18 Beiträge |
Kabel mit XLR und Chinch massa16 am 16.04.2006 – Letzte Antwort am 21.04.2006 – 4 Beiträge |
2007
Top Produkte in Kabel, Adapter, Tuning, Zubehör
- Registrierte Mitglieder930.618 ( Heute: 1 )
- Neuestes MitgliedDalirium
- Gesamtzahl an Themen1.563.344
- Gesamtzahl an Beiträgen21.822.779
