| HIFI-FORUM » Do it yourself » Elektronik » Simulation mit Fehlern | |
Simulation mit Fehlern+A -A |
paga58
erstellt: 28. Aug 2008, 21:34
Hallo, wenn ich diese importierten Modelle unter LTspice laufen lasse hab ich Probleme: *LF412 LOW OFFSET, LOW DRIFT DUAL JFET INPUT OP-AMP MODEL * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | * | | | | | .SUBCKT LF412 1 2 99 50 28 * *Features: *Fast settling time (.01%) = 2uS *High bandwidth = 3MHz *High slew rate = 10V/uS *Low offset voltage = 1mV *Low supply current = 1.8mA *NOTE: Model is for single device only and simulated * supply current is 1/2 of total device current. * IOS 2 1 25.0P CI1 1 0 3P CI2 2 0 3P R1 1 3 1E12 R2 3 2 1E12 I1 99 4 1.0M J1 5 2 4 JX412 J2 6 7 4 JX412 R3 5 50 650 R4 6 50 650 C4 5 6 4.372P I2 99 50 800UA *EOS 7 1 POLY(1) 16 49 1E-3 1 BOS 7 1 v= 1E-3 + 1*v(16,49) R8 99 49 80K R9 49 50 80K V2 99 8 2.13 D1 9 8 DX412 D2 10 9 DX412 V3 10 50 2.13 EH 99 98 99 49 1 G1 98 9 5 6 20E-3 R5 98 9 10MEG VA3 9 11 0 C3 98 11 857.516P G3 98 15 9 49 1E-6 R12 98 15 1MEG C5 98 15 5.305E-15 G4 98 16 3 49 1E-8 L2 98 17 144.7M R13 17 16 1K F6 99 50 VA7 1 F5 99 23 VA8 1 D5 21 23 DX412 VA7 99 21 0 D6 23 99 DX412 E1 99 26 99 15 1 VA8 26 27 0 R16 27 28 50 V5 28 25 0.646V D4 25 15 DX412 V4 24 28 0.646V D3 15 24 DX412 .ENDS LF412 .MODEL DX412 D(IS=1E-15) .MODEL JX412 PJF(BETA=1.183E-3 VTO=-.65 IS=50E-12) * *** * * AD712J SPICE Macro-model 4/92, Rev. B * JCB/JW/PMI * * This version of the AD712 model simulates the worst case * parameters of the 'J' grade. The worst case parameters * used correspond to those in the data sheet. * * Revision History: * Rev B: Convert model into ADSpice format * Add noise generators * * Copyright 1990 by Analog Devices, Inc. * * Refer to "README.DOC" file for License Statement. Use of this model * indicates your acceptance with the terms and provisions in the License Statement. * * Node assignments * non-inverting input * | inverting input * | | positive supply * | | | negative supply * | | | | output * | | | | | .SUBCKT AD712J 1 2 99 50 30 * * INPUT STAGE * R3 5 50 5.305 R4 6 50 5.305 CIN 1 2 5.5E-12 I1 99 4 100E-3 IOS 1 2 12.5E-12 EOS 60 1 POLY(1) 17 24 3E-3 1 EN 7 60 42 0 1 GN1 0 1 45 0 1E-6 GN2 0 2 48 0 1E-6 J1 5 2 4 JX J2 6 7 4 JX GB1 2 50 POLY(3) 4,2 5,2 50,2 0 1E-12 1E-12 1E-12 GB2 7 50 POLY(3) 4,7 6,7 50,7 0 1E-12 1E-12 1E-12 * EREF 98 0 24 0 1 * * VOLTAGE NOISE GENERATOR * VN1 41 0 DC 2 DN1 41 42 DEN DN2 42 43 DEN VN2 0 43 DC 2 * * CURRENT NOISE GENERATOR * VN3 44 0 DC 2 DN3 44 45 DIN DN4 45 46 DIN VN4 0 46 DC 2 * * CURRENT NOISE GENERATOR * VN5 47 0 DC 2 DN5 47 48 DIN DN6 48 49 DIN VN6 0 49 DC 2 * * SECOND STAGE & POLE AT 32 HZ * R5 9 98 7.96E5 C3 9 98 6.25E-9 G1 98 9 5 6 1.88E-1 V2 99 8 2.2 V3 10 50 2.8 D1 9 8 DX D2 10 9 DX * * COMMON-MODE GAIN NETWORK WITH ZERO AT 2.4kHZ * R11 16 17 1E6 C8 16 17 6.695E-11 R12 17 98 1 E3 16 98 POLY(2) 1 98 2 98 0 79.24 79.24 * * POLE AT 15 MHZ * R13 18 98 1E3 C9 18 98 10.61E-12 G5 98 18 9 24 1E-3 * * OUTPUT STAGE * R14 24 99 500E3 R15 24 50 500E3 CF 24 0 1E-6 ISY 99 50 -93.2E-3 R16 29 99 110 R17 29 50 110 L1 29 30 1E-8 G6 27 50 18 29 9.09E-3 G7 28 50 29 18 9.09E-3 G8 29 99 99 18 9.09E-3 G9 50 29 18 50 9.09E-3 V4 25 29 0.675 V5 29 26 0.675 D3 18 25 DX D4 26 18 DX D5 99 27 DX D6 99 28 DX D7 50 27 DY D8 50 28 DY F1 29 0 V4 1 F2 0 29 V5 1 * * MODELS USED * .MODEL JX PJF(BETA=1.78E-1 VTO=-2.000 IS=75E-12 RD=0 + RS=0 CGD=1E-12 CGS=1E-12) .MODEL DX D(IS=1E-15 RS=0 CJO=1E-12) .MODEL DY D(IS=1E-15 BV=50 RS=10 CJO=1E-12) .MODEL DEN D(IS=1E-12 RS=30909 KF=2.651E-15 AF=1) .MODEL DIN D(IS=1E-12 RS=12090 KF=0 AF=1) .ENDS AD712J Beim LF412 klappt Frequenzgang und Klirranalyse, Rauschen ist dubios. Beim AD412 stimmen Frequenzgang und Rauschen, bei der Transientenanalyse mit 1k Sinus hängt sich Spice nach der ersten Halbwelle auf. Stimmen die Modelle nicht oder passen sie einfach nicht zu LT? Grüße Achim |
Brückengleichrichter und "Split Power Supply" Spl-Mistress am 04.09.2009 – Letzte Antwort am 13.09.2009 – 50 Beiträge |
LM3886 Model Subckt kap am 11.09.2008 – Letzte Antwort am 14.09.2008 – 4 Beiträge |
Shunt regulated power supply - Vorteile? stopbit am 05.09.2010 – Letzte Antwort am 11.09.2010 – 26 Beiträge |
Split Power Supply? Wo bekommen? killertiger am 29.12.2006 – Letzte Antwort am 30.12.2006 – 6 Beiträge |
Input und Output Voltage Karkarov am 23.01.2021 – Letzte Antwort am 23.01.2021 – 2 Beiträge |
LJM-15D Power supply mit DC füttern Junta am 31.05.2018 – Letzte Antwort am 03.06.2018 – 7 Beiträge |
Trafo; dickes Kabel = Input/Output? mercNr am 22.05.2009 – Letzte Antwort am 22.05.2009 – 3 Beiträge |
Amp mit Single 24V Supply Spl-Mistress am 23.12.2010 – Letzte Antwort am 28.12.2010 – 5 Beiträge |
Frage bezüglich Input Verkabelung für Stereo Amp Keskin am 28.02.2009 – Letzte Antwort am 28.02.2009 – 3 Beiträge |
Input Bias Current Obes am 19.12.2019 – Letzte Antwort am 29.12.2019 – 10 Beiträge |
- Registrierte Mitglieder930.976 ( Heute: 1 )
- Neuestes Mitgliedkingeradon
- Gesamtzahl an Themen1.564.327
- Gesamtzahl an Beiträgen21.850.521
