Upgrade to sub or center or surrounds?
nimz
#1 erstellt: 04. Okt 2007, 06:08
Hi people,
I have a Marantz SR4600 and Wharfedale diamond 8.4 series floor standers for the fronts.
I am planning an upgrade shortly. What do you guys think I should upgrade?
- Go for a sub woofer
- Go for a center and surrounds
- Anything else?
My listening would be 80% music and an occasional movie on weekends.
What do you guys suggest.
Thanks
Nimz
Krish
#2 erstellt: 04. Okt 2007, 06:12
nimz schrieb:
Hi people,
- Anything else?
Thanks
Nimz
The sub, methinks
abhi.pani
#3 erstellt: 04. Okt 2007, 10:04
Sub..the best possible one.
Krish
#4 erstellt: 04. Okt 2007, 11:23
BTW why do you want to upgrade ?
What are you missing ?
What are you looking for ?
nimz
#5 erstellt: 04. Okt 2007, 12:32
Thanks Abhi and Krish..
@Krish - good question.. well I have a 7.1 AVR and what am I doing with just 2 front speakers!! Am not missing bass but could do with some occassionally.. hmmm.. thinking again.. maybe I just need that surround sound and hear gun shots and stuff loud and clear.. when I watch movies..
In that case I guess it would be the surrounds?
Any particular make I should go for considering I have wharfedale fronts??
nimz
Arj
#6 erstellt: 04. Okt 2007, 14:12
personally i would suggest a sub as a 2. is preferable to a 5.0 setup to me ! would rather hear an impactful Thud of the bullet than the ambient sound..
this is especially true if you do listen to TV via your HT as in that case a sub will definitely improve the sound as tv encoding is either mono or Stereo and definitely not 5.1 and i really do not have a great opinion on the DSP for conversion of 2 channel to 5.1.
perhaps the best combuination would be a Sub + a center channel
Kamal
#7 erstellt: 04. Okt 2007, 19:24
In my opinion-
Sub + Centre + Surrounds !
Jahan Satyanass Wahan Sava Satyanass
Like losing your virginity,it will pain & you will bleed only the first time, after that its pure pleasure everytime!
Kamal
#8 erstellt: 04. Okt 2007, 19:27
Arj bhai, the bullet whines as it flies; the thud is your body hitting the floor thereafter!
For full maza you need both the whine + the thud + the screams from the sides!
[Beitrag von Kamal am 04. Okt 2007, 19:33 bearbeitet]
abhi.pani
#9 erstellt: 04. Okt 2007, 22:16
I suggested a sub because it would help improve the Stereo experience as well. Diamond 8.4 are just average on bass lines, adding a decent sub with proper placement should take the whole experience to a different level...additionally it would also enhance HT experience as there is so much information on DVDs which only a sub can do justice to.
Arj
#10 erstellt: 05. Okt 2007, 04:13
Kamal sir, I fully agree. but since he said 80% music and movies only 20% and I am not really sure if that is only DVDs with DTS/DOlby since only then does the surround sound really good.
if he is willing to increase his budget then Yes going the full hog is worth it.
Krish
#11 erstellt: 05. Okt 2007, 04:21
-If it's just music, add a sub.
-If it's the crash,boom & bang, go the whole hog.
If it's the latter, go Warfedale all the way to avoid tonality issues.
k
Savyasaachi
#12 erstellt: 05. Okt 2007, 06:10
I would suggest you invest in a sub( a def tech or a wharfedale)and get the daimond 8 center. For surrounds you can hunt around for used mini-compo speakers( it is likely that your friends or relatives would have a unit taht doesn't work save for the speakers).
nimz
#13 erstellt: 06. Okt 2007, 09:42
thanks people..
After much introspection (virginity and all..) I think with my usage it should be a good center and sub.
For tonality issues I think a Wharfie center would do.
For SUB - Wharfedale? I was thinking of the Sonodyne too..
thanks so much
Nimz
Savyasaachi
#14 erstellt: 06. Okt 2007, 09:51
Strongly suggest the DEftech Prosub 100TL, have it with the same setup you have(8,4s and diamond 8 center), it gels superbly. My room is a 16.3 foot X12.6 foot about 196square feet just so you are wondering.
nimz
#15 erstellt: 08. Okt 2007, 08:48
Any ideas on how much the Deftech would set me back by?? Bangalore India prices if possible..
Also visited the Def tech webpage.. they have only active subqwoofers.. Would I need an active sub?? I have an AVR?? a little confusing..
Thanks
Nimz
[Beitrag von nimz am 08. Okt 2007, 08:52 bearbeitet]
Arj
#16 erstellt: 08. Okt 2007, 09:52
nimz schrieb:
[They have only active subqwoofers.. Would I need an active sub?? I have an AVR?? a little confusing..
you need only an active sub.
the avr ouputs Line level ie equivalent for a Pre out. IF you do not have an active sub you would need a separate amp and a passive woofer.
Savyasaachi
#17 erstellt: 08. Okt 2007, 15:36
Thanks
Nimz
abt 25k..a bit less if u haggle with the dealer.
nimz
#18 erstellt: 09. Okt 2007, 07:59
Now suddenly the Diamonds seem to have more bass..
Savyasaachi
#19 erstellt: 09. Okt 2007, 16:12
LOL...well, they are not that bad really...but the deftech does make a world of difference. Probably the best sub you could buy at that price..YOu could at least audition a few subs if it is possible.
I suggest going to the Wharfedale dealer and ask him to hook up the 8.4s in a 5.1 setup and then switch between the Sub and the speakers(keep the sub out of the loop) to see what you are losing out on..
nimz
#20 erstellt: 10. Okt 2007, 13:26
Sure dude.. will do some listening and let me check out..
Thanks
Nimz
nimz
#21 erstellt: 29. Feb 2008, 06:01
Hello,
Due to pre budget and other financial constraints. I have deceided to first go for a Wharfedale 8 center. There are 2 shops in Blore. However I would like to know what would be the going rate for a Wharfedale 8 Center alone in the current times.. considering Wharfies 8 is a bit dated..
Thanks
Nimz
Savyasaachi
#22 erstellt: 29. Feb 2008, 09:37
My folks have a wharfedale diamond 8 center in their HT (diamond 8.4 fronts, aiwa surrounds, def tech prosub 100TL).
Personally if you have the wahrfedale diamond 8 series fronts then go for it.
Oh, and I paid 9k for it...hmm almost 4 years ago i would think. (for which i still haven't received the receipt from the stupid dealer)
It is a well built unit with a good sound (can't really articulate it with all the audiophile jargon). YOu are welcome to listen to the setup at my home if you are in Bangalore. My dad would be more than happy to let you audition it. Reign had been to my place only last week.
So its not a problem at all.
YOu could even check out the Def Tech sub in action and maybe help you crystallise on one for a future purchase.
Saachi
[Beitrag von Savyasaachi am 29. Feb 2008, 09:45 bearbeitet]
nimz
#23 erstellt: 29. Feb 2008, 09:55
Thanks Savyasaachi.
I will PM you for your house address/contacts and maybe one of these weekends will call up and see your set up as its very similiar to mine (8.4 Diamonds and Marantz 4600). Surrounds / Subs and Center are in the pipeline
Nimz
yamaha or boston ???
THE_COOK am 21.09.2005  –  Letzte Antwort am 25.09.2005  –  2 Beiträge
Marantz & Boston or Mordaunt
SDhawan am 13.10.2005  –  Letzte Antwort am 04.11.2005  –  18 Beiträge
help needed for surrounds
nindo am 18.01.2006  –  Letzte Antwort am 19.01.2006  –  3 Beiträge
Satellites or full range??!
jeetu_AVFreak am 27.01.2007  –  Letzte Antwort am 01.03.2007  –  46 Beiträge
Denon 1604 or HK AVR130 or something else ? Confused
abhi.pani am 17.01.2005  –  Letzte Antwort am 18.01.2005  –  2 Beiträge
Yamaha dvd s657 ???? or not ?
THE_COOK am 25.02.2006  –  Letzte Antwort am 26.02.2006  –  2 Beiträge
Yamaha or Marantz
ajit_tirkey am 21.07.2006  –  Letzte Antwort am 18.08.2006  –  19 Beiträge
MS subwoofer - 309i or 409w?
sandipb am 02.01.2008  –  Letzte Antwort am 03.01.2008  –  6 Beiträge
panasonic XR55 or denon 1905
sidhu am 06.01.2006  –  Letzte Antwort am 09.01.2006  –  3 Beiträge
Sound card or AV receiver?
Neutral am 21.05.2005  –  Letzte Antwort am 21.05.2005  –  2 Beiträge
  • Registrierte Mitglieder930.661 ( Heute: 2 )
  • Neuestes MitgliedNeroNepolus333
  • Gesamtzahl an Themen1.563.448
  • Gesamtzahl an Beiträgen21.825.646
