connecting mini hifi to av receiver
kousik_s
#1 erstellt: 02. Mrz 2006, 08:20
i have a philips mini combo (fw 630) which i intend to connect to avr for listening to tapes. the philips system has only headphone port for audio out.
will there be a degradation in sound quality if i connect the system to avr via headphone out? do i need to convert it to rca input for av receiver (sonodyne av 300r)?
the same query applies to my tv also, which has a headphone port as audio out only.
thanks,
kousik
abhi.pani
#2 erstellt: 02. Mrz 2006, 11:47
Check if your Philips has a line out....it should be there.
Headphone out is normally not reccomended
kousik_s
#3 erstellt: 02. Mrz 2006, 12:08
There is no line out, only line in. The headphone impedance is stated as 32 ohm to 1000 ohm (3 Vemk - 150 ohm). Output power of the amplifier is 2x45W RMS/6 ohm/THD 10%. This is what stated in the manual.
Thanks
Amp_Nut
#4 erstellt: 02. Mrz 2006, 12:23
Since you dont have a choice, use the Headphone out from the mini combo, to feed your avr.
However, I would be more cautious conning your TV to anything else that draws power from the Mains.
Some TVs have a 'Live' chassis, and Sparks could fly .... literally !
kousik_s
#5 erstellt: 02. Mrz 2006, 12:32
Amp_Nut, could you elaborate on this please. At present I have connected my other TV, Thomson 29" Scenium to Altec Lansing VS4221 (2.1) only recently by headphone out. Previously it was connected to the DVD player only. Its rating is only 35 W RMS only. Should I disconnect it from TV and reconnect to DVD then.
Thanks
Shahrukh
#6 erstellt: 02. Mrz 2006, 15:45
Only?? Isn't that enough?
kousik_s
#7 erstellt: 02. Mrz 2006, 21:00
Shahrukh schrieb:
Only?? Isn't that enough? :L
when i play dvd i have to really crank up the volume to about 75-80% of max. also, the tweeters are really small. the sub is good though.
Connecting Worldspace to AV Receiver...
juggy_25 am 07.02.2006  –  Letzte Antwort am 08.02.2006  –  7 Beiträge
Connecting PC sound card to Denon receiver
shashankmittal am 13.09.2005  –  Letzte Antwort am 30.09.2005  –  2 Beiträge
which receiver to choose?
robert_j am 28.12.2003  –  Letzte Antwort am 14.01.2004  –  19 Beiträge
AV receiver- Denon vs Onkyo
Debu am 15.08.2005  –  Letzte Antwort am 16.08.2005  –  2 Beiträge
AV-receiver w/ ASW Cantius
dawnrazor am 10.11.2003  –  Letzte Antwort am 12.11.2003  –  8 Beiträge
AV receiver in 2 channel mode
Bibs am 15.03.2006  –  Letzte Antwort am 15.03.2006  –  2 Beiträge
Sound card or AV receiver?
Neutral am 21.05.2005  –  Letzte Antwort am 21.05.2005  –  2 Beiträge
can ipod be connected to AVR?
juggy_25 am 12.02.2006  –  Letzte Antwort am 22.03.2006  –  16 Beiträge
optical cable
Bibs am 13.02.2006  –  Letzte Antwort am 14.02.2006  –  6 Beiträge
av receiver+DVD player in budget
Sonic_Master am 23.05.2005  –  Letzte Antwort am 30.06.2005  –  23 Beiträge
2006
  • Registrierte Mitglieder930.991 ( Heute: 4 )
  • Neuestes Mitgliedcinisi
  • Gesamtzahl an Themen1.564.370
  • Gesamtzahl an Beiträgen21.852.050
