HIFI-FORUM » English » Surround (Engl.) » LFE in 5.1 & 2.1 | |
LFE in 5.1 & 2.1+A -A |
raj
#1 erstellt: 05. Dez 2005, 06:24 | |
Does the .1 channel of a DD/DTS encoded DVD contain any additional LFE that is not present in the stereo layer i.e. If a DD/ DTS encoded DVD is played in a 2.1 setup (through a stereo amp) will there be any loss of LFE as compared to playing it in a 5.1 setup (through a AV receiver) (other things such as speakers being the same). Thanks |
lohifi
#2 erstellt: 05. Dez 2005, 06:55 | |
Hello Raj, DD/DTS is downward compatible with stereo, that is you can play Any Dolby Digital/DTS movie on stereo without any loss of sound. There is no separate stereo layer in DVD but is always 6 channels. They are mixed togetherto create the stereo channels. for example stereo left is created by mixing front left, surround left, center and LFE (With different weightage). If you are interested you can see the dolbylabs website. LoHiFi |
raj
#3 erstellt: 05. Dez 2005, 11:19 | |
Thanks Lohifi. I was not aware of this. This would mean that the subwoofer in a 2.1 setup should have the same sound effects as that in a 5.1 setup. Thanks |
eric_clapton
#4 erstellt: 13. Dez 2005, 10:57 | |
Actually, no. Lohifi is correct. There are 6 discrete channels and if you want to play in 2.1 the DSP will mix down the 6 channels to 2, and then the 2.1 setup will use its internal filters to make three soundstreams for it. This is the reason 2.1 systems use a single stereo cable. So if you pop in a DVD into a DVD player connected to a 2.1 system, the sub will not be representative of the originally recorded .1 layer, but all the LF (not E) below crossover frequency. |
anirvan
#5 erstellt: 13. Dez 2005, 13:29 | |
hi, what if i am using 2 floorstanders with 8" woofers and no sub- in that case what happens to the LFE in a 5.1 setup basically can towers with woofers almost compensate a subwoofer?? regs anirvan |
eric_clapton
#6 erstellt: 13. Dez 2005, 14:11 | |
Depends on The quality of your speakers The amount and kind of bass you like The amount of bass in the source So both yes, and no. |
anirvan
#7 erstellt: 14. Dez 2005, 05:06 | |
but what about the .1 channel of sound- i dont like too much bass, my speakers have one tweeter-1 6' mid and a 8' side woofer- rated max 140 w rms @ 8 ohms- they are locally made- r anirvan |
eric_clapton
#8 erstellt: 14. Dez 2005, 06:53 | |
When you take a stereo output from a 5.1 stream, the decoder normally mixes the .1 channel into the stereo stream. That particular information is not directly retrievable any more. A stereo aplification setup will then process it in stereo, so a 2.1 channel will create its own 'LF' channel and a standard 2 channel stereo will treat it as stereo. As far as personal preference goes, if you're happy with what you have, that's great. If not, then look for new stuff. Personally, I don't like using subwoofers for music, if that's what you want to know. |
lohifi
#9 erstellt: 14. Dez 2005, 13:23 | |
Dear Anirvan, If you want to totally block out the .1 channel, you can do it like this. In the receiver, keep "subwoofer" option as yes and since you don't have subwoofer the .1 channel as well as the bass will be suppressed. |
anirvan
#10 erstellt: 15. Dez 2005, 04:46 | |
thanks boss, i like a lill bass, too much becomes a problem- even wife starts rumbling - r anirvan |
lohifi
#11 erstellt: 15. Dez 2005, 13:29 | |
Hi Anirvan, Then you can buy a subwoofer and play at low level or change your wife whichever is convenient , just jokin. |
5.1 SPEAKERS vominhtan74 am 14.09.2004 – Letzte Antwort am 22.09.2004 – 2 Beiträge |
Indian Brand 5.1 setup Tim_Choco am 16.01.2007 – Letzte Antwort am 04.02.2007 – 80 Beiträge |
5.1 sound for 30K rshri am 07.02.2006 – Letzte Antwort am 02.03.2006 – 39 Beiträge |
sonodyne cinque 5.1 kousik_s am 01.03.2006 – Letzte Antwort am 26.04.2006 – 27 Beiträge |
5.1 vs 7.1 juggy_25 am 20.01.2006 – Letzte Antwort am 31.01.2006 – 11 Beiträge |
kindly help in buying 5.1 speakers COOLGUYNO1 am 12.02.2006 – Letzte Antwort am 15.02.2006 – 6 Beiträge |
Logitech X-230 2.1 brummt/summt am Beamer! Sörn_kennt_keine_mörn am 15.03.2012 – Letzte Antwort am 06.06.2012 – 2 Beiträge |
Power amplifier & 5.1 setup @ 50k praful am 27.09.2006 – Letzte Antwort am 07.10.2006 – 8 Beiträge |
plz suggest 5.1 speakers for TX-SR503 juggy_25 am 26.01.2006 – Letzte Antwort am 08.02.2006 – 20 Beiträge |
Suggest a HT Sys w/ Amp and 5.1 (INDIA) kush251188 am 11.07.2010 – Letzte Antwort am 12.07.2010 – 2 Beiträge |
2005
Top Produkte in Surround (Engl.)
- Registrierte Mitglieder927.822 ( Heute: 2 )
- Neuestes Mitgliedxxl.hardy
- Gesamtzahl an Themen1.556.660
- Gesamtzahl an Beiträgen21.662.779
