HIFI-FORUM » English » Stereo (Engl.) » OPERA Audio - Pre + Power Amplifier - Sound Smith | |
OPERA Audio - Pre + Power Amplifier - Sound Smith+A -A |
Bob_Ludwig
15:23
erstellt: 24. Dez 2005, |
![]() Power Amplifier ![]() Pre Amplifier CYBER-800 Mono Block Tube Power Amplifier SPECIFICATION: CONTROL FUNCTIONS: Power On/Off POWER OUTPUT: 78 watt x 2, RMS 1kHz ( Ultra-linear ) TOTAL HARMONIC DISTORTION: less than 1%( 50watt, 1kHz ) FREQUENCY RESPONSE: ( -3dB points at 50 watt ) 6Hz-100kHz INPUT SENSITIVITY: 700mV INPUT IMPEDANCE: 100k ohms OUTPUT IMPEDANCE: 4, 8 ohms. ( User selectable ) SIGNAL/NOISE: 90dB CONSUMPTION: 90watt x 2 INPUT INTERFACES: 1 group ( RCA ) OVERALL NEGATIVE FEEDBACK: Little VACUUM TUBE: EL34/6CA7 x 8, 5687x 2, 6922 x4 DIMENSIONS: 420(L) x 185(W) x 330(H) mm WEIGHT: 30kg x 2 CYBER-222 Tube Balanced Line Stage with Separated Power Supply SPECIFICATION: Frequency response: 2Hz-150KHz(-1B) Signal-to-noise ratio: 90dB Distortion: Less than 0.05%(70Hz/7KHz 4:1) Consumption: 40W Input Sources: 4 selectable inputs switched by gold plated relays Input Terminals:Gold plated phono/RCA unbalanced and gold plated XLR balanced Output terminals: Gold plated phono/RCA unbalanced Vacuum tube:6SN7x4 5AR4x1 Remote Control: RC-5 compatible IR system 36KHz moudulation Dimensions: 8cm x 43cm x32cm (HxWxD) Weidht:15Kg This combination has just arrived @ Sound Smith - Bombay. Has anyone 'auditioned' it ? Initial Impression / Comments ? BOB |
Why amplifier power is important SUB_BOSS am 10.07.2006 – Letzte Antwort am 13.07.2006 – 48 Beiträge |
Amplifier SUB_BOSS am 28.02.2006 – Letzte Antwort am 28.02.2006 – 7 Beiträge |
How much amplifier power do you need? bombaywalla am 17.09.2009 – Letzte Antwort am 15.10.2009 – 53 Beiträge |
Voltage Converter for nad320bee amplifier. Hemanth am 17.01.2005 – Letzte Antwort am 18.01.2005 – 2 Beiträge |
What is the difference between Pre Amp & Amplifier? philipmorris am 19.07.2006 – Letzte Antwort am 19.07.2006 – 6 Beiträge |
Opera Pavarotti speakers Dzigi10 am 13.02.2004 – Letzte Antwort am 23.02.2004 – 2 Beiträge |
Opera, Rega CDP's Manek am 11.09.2006 – Letzte Antwort am 15.09.2006 – 26 Beiträge |
LYRITA AUDIO' S NEW SET AMPLIFIER Kamal am 28.10.2007 – Letzte Antwort am 22.04.2008 – 55 Beiträge |
Amplifier problem Albertinho am 16.01.2006 – Letzte Antwort am 24.01.2006 – 11 Beiträge |
best power cord? sledgehammer am 30.09.2003 – Letzte Antwort am 06.10.2003 – 19 Beiträge |
2005
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder929.004 ( Heute: 10 )
- Neuestes Mitgliedirafewings563
- Gesamtzahl an Themen1.559.483
- Gesamtzahl an Beiträgen21.727.596
