Yamaha Receiver RX -1300 – US edition 110 Volts
khanmadari
#1 erstellt: 13. Dez 2005, 09:13
Hi Folks, I am back again..
I have bought this receiver in US back in 2001, now I am back in India.
Is it possible to switch it from 110 Volts to 220 Volts (I believe they are switched to 110 volts in US) or I need to use Step down transformer.
Has any one in this forum faced similar issues?
Would really appreciate if some one can help me out with this problem.
Regards
[Beitrag von khanmadari am 13. Dez 2005, 09:18 bearbeitet]
eric_clapton
#2 erstellt: 13. Dez 2005, 12:08
You need a step down, if there's no universal voltage switch on the back. Usually a label on the back of electronic mains-operated equipment specifies the operating voltage. Voltage selection, if available, is also available from somewhere on the back panel, sometimes near the mains entry point.
Some manufacturers will hide the voltage selection inside the uits, then a technician will be able to switch the voltages for you. To simplify inventory manufacturers normally get dual winding transformers made and create PCBs that can switch the voltages by soldering/removing a few jumpers on the board.
A Yamaha Tech should be able to help you better, if you want hassle-free operation a step down is not a bad investment.
And yes, I have faced this first hand. Not a pretty or cheap result.
khanmadari
#3 erstellt: 13. Dez 2005, 13:42
thanks eric,
there is no such switch provided on the back of panel, but as indicated by you, Yamaha should have some internal switch for voltage shift, I am going to chk with Yamaha service center.
do we have any Yamaha service Centers in Mumbai?
regards
110volts to 220 volts
SUB_BOSS am 02.02.2005  –  Letzte Antwort am 09.02.2005  –  13 Beiträge
NAD 320BEE in US
Srini am 20.01.2005  –  Letzte Antwort am 21.01.2005  –  12 Beiträge
How is YAMAHA's RX 450 receiver
SUB_BOSS am 06.01.2005  –  Letzte Antwort am 12.01.2005  –  13 Beiträge
Yamaha RX-V557B 6.1 Digital Home Theatre Receiver
srikantahu am 07.11.2005  –  Letzte Antwort am 07.11.2005  –  5 Beiträge
Best turntable/arm under 5k US$ ?
koetsu am 27.06.2005  –  Letzte Antwort am 27.06.2005  –  3 Beiträge
What Hifi Indian Edition - First Impressions
Krish am 08.11.2005  –  Letzte Antwort am 08.11.2005  –  3 Beiträge
Denon AVR1505/485s Receiver Help
apurba999 am 07.12.2005  –  Letzte Antwort am 10.12.2005  –  2 Beiträge
Yamaha RX-V450+Bose AM5 - Setup Help Req
Nitin am 27.11.2005  –  Letzte Antwort am 28.11.2005  –  5 Beiträge
Audio Quality with 220-110 V stepdown transformer..
hifinovice1 am 01.04.2005  –  Letzte Antwort am 02.04.2005  –  3 Beiträge
Impedence matching YAMAHA RXV450
Betelguese am 19.04.2005  –  Letzte Antwort am 19.04.2005  –  2 Beiträge
2005
  • Registrierte Mitglieder930.985 ( Heute: 2 )
  • Neuestes MitgliedFCSpieler1965
  • Gesamtzahl an Themen1.564.358
  • Gesamtzahl an Beiträgen21.851.536
