110volts to 220 volts
SUB_BOSS
Gesperrt
#1 erstellt: 02. Feb 2005, 11:31
Hi ,
can a sub brought in from US : 110v and can it be converted to 220 v for Indian use?? If possible what would be the effect on sound quality??
[Beitrag von SUB_BOSS am 02. Feb 2005, 11:32 bearbeitet]
Arj
#2 erstellt: 02. Feb 2005, 11:37
SUB_BOSS schrieb:
Hi ,
If it is for HT you should not have any problem as you will only use it for the LFE output.
But most subs have an option of a 220 V (Hsu, Velodyne, SVS etc)hence do explore that...
big-ears
#3 erstellt: 02. Feb 2005, 11:43
You shouldn’t have any problem, whatsoever.
All you need is to get a good step-down transformer. I had once faced a similar problem with speakers purchased from the US which had built-in 110V powered subs. I bought a couple of ARCO transformers (they are probably the best) from their shop at Lamington Road, Bombay, and I was in business. I used the speakers and the transformers for over 4 years without any hassles.
SUB_BOSS
Gesperrt
#4 erstellt: 02. Feb 2005, 12:07
Ya I would be using for HT and the make is ONKYO....can you tell me where is it available in bangalore.i mean the step down transformer.
benkenobi
#5 erstellt: 02. Feb 2005, 12:25
you will get them in SP road. but if u are getting the sub from the US i would say it would be better to get the step down transformer also from the US.
mind you the step down transformer needs to be able to supply the sub with more power than the maximum power consumption of the sub.
SUB_BOSS
Gesperrt
#6 erstellt: 03. Feb 2005, 14:44
In case if i choose to use a voltage converter for an amp what effects can I get out of it.will it hamper the performance??
filmguy
#7 erstellt: 03. Feb 2005, 23:49
hey sub boss
was just curious to know how u r planning to get the sub shipped/brought over frm the US. i'm asking bcoz i'd examined the idea of ordering an svs sub but the hassles didnt seem worthwile..
SUB_BOSS
Gesperrt
#8 erstellt: 04. Feb 2005, 05:43
Hi film guy mr brothers coming down in another 3-4 months from US back to our home country and since it's a TR he can get lotsa stuff.so I'm planning for it right now
benkenobi
#9 erstellt: 04. Feb 2005, 06:56
i posted your query on diyaudio.com and it seems ther would not be any problem with the sub as long as the step down transformer is of good quality.
another suggestion was to look for a sub with a 220volt switch.
benkenobi
#10 erstellt: 04. Feb 2005, 07:05
i too had plans of getting my receiver from the us though a person who too was coming on TR. well that did'nt happen.
anyway when i was searching for the receiver i too had the same problem and had located a great supplier of such products.
check it out and please don't at laugh at the name of the dealer.
gandhiappliances.com
(he's based in chicago! not India)
filmguy
#11 erstellt: 06. Feb 2005, 21:52
hey sub boss
i can not believe how lucky u r..sice yr brother is coming down frm the us i wld say u shld seriously look at the svs subs. their latest model pb10-isd is for just $429 and has some amazing specs and even better reviews. and u can order the 230v model so that u dont hv any problems on that end.
i was seriously looking for a way i cld buy one for myself but the unquantifiable duties etc make it risky. if it werent for that i wld jump at that model. maybe u cld buy two of them and sell me one ?!!!
skoka123
#12 erstellt: 09. Feb 2005, 07:02
When I was returning from US on TR, I had plenty of 110Volt appliances. I bought two of these.
The best part is it is a voltage regulator. It serves the purpose of both a voltage stabilizer and voltage convertor. Voltage converters are cheaper than the regulator and they both convert 220v to 110v and vice versa.
I bought two of these: http://www.voltageco...6628CC85}&ic=SVC3000
It can convert 110 to 220 and 220 to 110. The best part is it can provide output for 110 and 220 volts SIMULTAENOUSLY. The only drawback I find is it has one 110 volts outlet and two 220 volts outlet and both are shaped similarly though cleary marked. As I have more 110v components than 220 it is a negative for me. If you have only one 110v component then it is great as you can use the other two 220v outlets for connecting your TV and other high value equipments. It also comes with two spare fuses (also available in India) it is compact and cute looking.
It is a servo motor controlled stabilizer (No idea what the heck it does). The one minor drawback is whenever there is a voltage fluctuation for heavry current draw the servo motor makes a brief sound.
Over all I am highly satisfied with this and highly recommend this regulator.
You can find other models at http://www.voltageconverters.com/voltage_regulators.html .
You can find voltage convertors at http://www.voltageconverters.com/voltage_converters.html . Please note that a voltage regulator is slightly expensive compared to a convertor but it also provides very good voltage stabilizer functionality.
If you have any questions, send them an email and they used to reply very promplty.
If you have more than one 110v equipment or plan to own more than one 110v equipment ask your brother to get a good 110v surge protector with atleast 1000joules capacity. Some of the good brands are Tripp Lite, APC, Belkin etc. http://www.tripplite.com/products/product.cfm?productID=2811 is specifically built for home theater. These things cost around $30 to $40. They are a good long term investment.
It has taken me over an hour composing this reply. Hope it is useful to you. If you would like to know what other products to get from US let me know and I can suggest some of the must get products like Networked (RJ-45) based upscaling DVD players with Sigma Designs upscaling chipset etc.
-Srikanth Koka
SUB_BOSS
Gesperrt
#13 erstellt: 09. Feb 2005, 07:05
Hi srikanth,
thanks a lot for the input and your valuable time spent...I will definetely seek your help in future..
thanks again
Yamaha Receiver RX -1300 ? US edition 110 Volts
khanmadari am 13.12.2005  –  Letzte Antwort am 13.12.2005  –  3 Beiträge
Planning to move to speakers.
Savyasaachi am 12.07.2007  –  Letzte Antwort am 09.08.2007  –  22 Beiträge
Audio Quality with 220-110 V stepdown transformer..
hifinovice1 am 01.04.2005  –  Letzte Antwort am 02.04.2005  –  3 Beiträge
What to buy?
onion am 03.09.2003  –  Letzte Antwort am 29.10.2003  –  22 Beiträge
which amp to buy ???
johnny69 am 12.11.2003  –  Letzte Antwort am 17.11.2003  –  8 Beiträge
Advise to a beginner
arun_rookie am 26.09.2004  –  Letzte Antwort am 27.09.2004  –  6 Beiträge
Hifi to PC?
djfonti am 07.11.2004  –  Letzte Antwort am 20.11.2004  –  5 Beiträge
What Cables to use ??
abhi.pani am 19.01.2005  –  Letzte Antwort am 19.01.2005  –  6 Beiträge
Visit to Junia's place
Neutral am 20.06.2005  –  Letzte Antwort am 13.07.2005  –  42 Beiträge
Which Way To Go?
kspv am 16.09.2005  –  Letzte Antwort am 24.09.2005  –  71 Beiträge
2005
  • Registrierte Mitglieder930.657 ( Heute: 8 )
  • Neuestes Mitgliedhansano715
  • Gesamtzahl an Themen1.563.440
  • Gesamtzahl an Beiträgen21.825.398
