HIFI-FORUM » English » Stereo (Engl.) » Need help for buying Turntable | |
Need help for buying Turntable+A -A |
philipmorris
12:03
erstellt: 02. Nov 2005, |
Guys, My 1st post here. As I am planning to buy a turntable for the 1st time I have been shown this Philips model (Philips AF-834) which has a belt drive,hydraulic functioning,pitch control. Do u guys have any idea as how good this turntable would be for a starter like me? Please give your inputs. Regards, philip |
sbfx
12:16
Whats your budget? for the TT cart and Phono Stage. Satyam. |
philipmorris
15:24
Hi Satyam, I have a Yamaha Amplifier RX750 model which has a phono in option in built.Its a good hardy amp. For cartridge I am ready to pay a good amount provided its compatible with my Philips model 834.As of now it has an ordinary Classic cartridge fixed to it which is cheap. I have plans of buying a Technics cartridge but I am not sure whether it will be compatible with this model or not. please help. regards, Philip |
sbfx
18:30
Hi, I quickly tried to find info on your TT but dint come up with much so if possible can you provide the mass(weight) of your tonearm as its vital to know this when choosing a cart for the table otherwise it will resonate at a certain freq. One thing I can tell you for sure that is you will need to get a MM cart with sufficient GAIN (3.5+) as your receiver doesn’t have a step-up transformer for a MC (Low-output cart). Regards, Satyam. PS: Give me a day I will try and find more info on your TT. |
philipmorris
21:27
Sorry brother I dn't knw the mass weight of the tone arm as there is no manual available.My cartridge is MM only. Regards, Philip |
purnendu
10:56
erstellt: 03. Nov 2005, |
Hi Phillip, I dont know about this Phillips model, is it made in India? I used to have a Phillips TT twenty years ago and it served me fine. I think it still works. Are you getting it dirt cheap or for free? If so then it may be worth it. What kind of mount does it have? The technics cartrige is a PMount. Check the Shure site for cartridges, both P mount and conventional types are available. There is one very inexpensive cartridge (Rs 1500) from Shure which may be right for this level of turntable. Purnendu |
philipmorris
12:50
Hi Purnendu, Yes its a India make.Price will be around 50 US $. Can you please revert what you mean by mount? Yes I have seen this Shure cartridge which you are referring to.Is it M44-7-H? Regards, Philip |
purnendu
11:23
erstellt: 07. Nov 2005, |
Hi Phillip, There are two kinds of mount. A P-Mount is usually found in older turntables or very inexpensive ones. In this the cartridge comes with a headshell which you then slot into the arm. The other mount has two screws with which you fit the cartridge under the arm's fixed headshell. This is the more common arragement, although Technics comes with a P.Mount as do some of the Phillips'. Check the Shure site it gives the details about the diferent mountings. Dollars fifty does sound O.K.if everything is working. Are you buying this second hand? I need to check the model no. of the cartridge and will let you know. Purnendu |
philipmorris
13:07
My model has a mount with screw fitted in it.Yes I bought it 2nd hand only. Regards, Philip |
ani
14:14
erstellt: 08. Nov 2005, |
Dear Philip, I have used the turntable you have mentioned, it has its own limitations and you have to be carefull in getting new cartridges. Reasons are 1. The arm used on is of very poor quality, Plastic headshell and bearing mount. 2. The stobe and speed control circuits along with the DC motor used can cause hum with most of the new cartridges. 3. It is not a suspended or mass loaded rigid design, just a plastic body set on 4 springs with rubber bellows for damping. Most of the cartridges available are too good to be used on such a player. It would be nice if you can look for an used better quality turntable and take the plunge or return to vinyl (as the case may be) Hope you got my point and please dont feel bad about my remarks on the turntable which at one point of time was also my source ![]() |
purnendu
09:16
erstellt: 11. Nov 2005, |
Hi Phillip, Sorry for the delay. The cartridge I referred to is the same M44-7 you mention. Price quoted to me on 20/Aug/05 was Rs.2600. However this is way too much for your TT. Ani may well be right, although I owned a 'top of the Line' Phillips (Rs 3500 in 1989) and it worked fine. I was happy at any rate. You might want to check out a cheaper cartridge. Viren Bakshi once mentioned to me that he knows some one who sells Rs.500 Cartridges in Delhi. Try asking him? I suspect that they would be ceramic cartridges. Purnendu PS. where do you live |
philipmorris
20:43
erstellt: 13. Nov 2005, |
Hi Guys, Thanks for ur kind inputs.Its nothing to feel bad about.Wwell guys can u pls suggest me if I go for the 834 model at best what cartridge should I use?Aas I get it using Shure cartridge will be foolishness here. Also can you please suggest what are the better Turntables which I can go for in 2nd hand as thats wht is now available in India.1st hand models r too too cotly as these guys keep a huge margin on tht. Also pls suggest whether i shld go for a belt drive or a direct drive? regards, philip |
need help ! plasma am 23.04.2004 – Letzte Antwort am 12.06.2004 – 17 Beiträge |
Need your help, folks ! sandeep am 23.06.2005 – Letzte Antwort am 24.06.2005 – 13 Beiträge |
Need help ordering components for Passive zhopudey am 13.07.2007 – Letzte Antwort am 05.08.2007 – 38 Beiträge |
Need help with placement zhopudey am 23.01.2007 – Letzte Antwort am 07.02.2007 – 17 Beiträge |
Turntable godot am 17.05.2005 – Letzte Antwort am 18.05.2005 – 7 Beiträge |
21w8555-01 need help... am 15.03.2004 – Letzte Antwort am 15.03.2004 – 2 Beiträge |
Need help in choosing speakers trivisingh am 25.01.2005 – Letzte Antwort am 11.02.2005 – 25 Beiträge |
Help! I need some components. benkenobi am 28.06.2005 – Letzte Antwort am 01.07.2005 – 11 Beiträge |
speed box for turntable stevieboy am 05.06.2008 – Letzte Antwort am 05.06.2008 – 3 Beiträge |
Info. regd. in buying a direct drive turntable in Kolkata, India Rajat_India am 02.11.2005 – Letzte Antwort am 08.11.2005 – 2 Beiträge |
2005
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder929.076 ( Heute: 7 )
- Neuestes MitgliedSatfriends
- Gesamtzahl an Themen1.559.617
- Gesamtzahl an Beiträgen21.730.739
