| HIFI-FORUM » English » Stereo (Engl.) » Voltage Converter 220V/50Hz to 120V/60Hz | |
Voltage Converter 220V/50Hz to 120V/60Hz+A -A |
swamipr1977
erstellt: 25. Apr 2005, 08:08
Hi, Is it possible to get a 220V/50Hz to 120V/60Hz converter. I am able to only find a step down converter that converts 220V/50 Hz to 110V/50Hz. i am not able to get the cycles/frequency also converted. Any suggestions on where to get such a converter from, Delhi/Chennai/Bangalore please. I need it for using with my A/V receiver ( A Pioneer D914-K). Thanks in advance Regards Swami |
ariban
erstellt: 14. Jun 2005, 11:32
Hi Swami I faced the same problem when I moved to Bangalore from oveseas. Luckily I was able to buy a 1000 watts transformer doing both step up and step down. Having said that you really need a step down don't you. Don't worry about the cycle. Its immaterial in the case of the AV receiver. The other thing is that FM frequency bands are made differently for different countries. IN my case I can receive some channels but not all...There is a big technical explanation here which I am not gettiung into, but for all practical purposes a step down should be fine. Arijeet |
jsa_ind
erstellt: 14. Jun 2005, 12:06
Dear Arijeet, If you were refering to Swami post of "I am not able to get the cycles/freuency also converted" ...I feel the reference was to converting the transformer frequency from 50 Hz to 60Hz and not about Frequency Modulation of the air waves ! Regards, Junia. [Beitrag von jsa_ind am 14. Jun 2005, 12:10 bearbeitet] |
jsa_ind
erstellt: 14. Jun 2005, 12:23
Dear Swami, Any Transformer manufacturer would be able to help you out as to a step down transformer. You need to decide if you want an E.I. core or Toridal (Donut) or R core transformers. EI are the least efficient then comes Toridial & finally R core. Cost wise EI core is the cheapest. Please make sure you overate the current ratings as most transformer manufacturers don't keep up to the prescribed ratings in terms of current load & insulation specifications. Regards, Junia. |
ariban
erstellt: 15. Jun 2005, 06:16
Hi Junia I appreciate the difference. The FM issue was a "side issue" that I mentioned. What I was trying to say is that for purposes of amplification (Swami has a Pioner AVR) a step down transformer would do the trick adequately and the frequency/AC cycle is not relevant. Cheers Arijeet |
Voltage Converter for nad320bee amplifier. Hemanth am 17.01.2005 – Letzte Antwort am 18.01.2005 – 2 Beiträge |
USB to Digital converter msb1 am 05.11.2008 – Letzte Antwort am 08.11.2010 – 249 Beiträge |
Voltage conversion mmx_2 am 25.12.2004 – Letzte Antwort am 28.12.2004 – 11 Beiträge |
Krell voltage conversion?? hifidude100 am 03.08.2004 – Letzte Antwort am 07.08.2004 – 3 Beiträge |
Voltage stabilizer cheraz am 02.02.2004 – Letzte Antwort am 03.02.2004 – 8 Beiträge |
Voltage stabilizer for audio system. Which one? Neutral am 18.08.2006 – Letzte Antwort am 12.10.2006 – 68 Beiträge |
Denon AVR1505/485s Receiver Help apurba999 am 07.12.2005 – Letzte Antwort am 10.12.2005 – 2 Beiträge |
NAD 320BEE in US Srini am 20.01.2005 – Letzte Antwort am 21.01.2005 – 12 Beiträge |
Technics Turntable availability in India?? philipmorris am 17.03.2006 – Letzte Antwort am 21.03.2006 – 6 Beiträge |
Connecting SMPS devices to Hi-Fi hifinovice1 am 12.04.2005 – Letzte Antwort am 18.04.2005 – 3 Beiträge |
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.692 ( Heute: )
- Neuestes Mitglied
- Gesamtzahl an Themen1.563.537
- Gesamtzahl an Beiträgen21.828.254
