| HIFI-FORUM » English » Stereo (Engl.) » Connecting SMPS devices to Hi-Fi | |
Connecting SMPS devices to Hi-Fi+A -A |
hifinovice1
erstellt: 12. Apr 2005, 03:58
Is it advisable/ok to connect a device having SMPS(Switched Mode Power Supply)(e.g.Laptop, even worldspace BPL Diva) which uses,SMPS in it's power supply,to a Hi-Fi system,which employs linear power supplies.Since, if anything goes wrong with the source and you present high voltage to the Hi-Fi,and damaging it to a great extent. I happen to witness,this combination go wrong,at my friends place. |
Manek
erstellt: 12. Apr 2005, 06:59
I know where you are coming from, especially when the bpl diva has a line out to be connected to your hi-fi. A lot of people do connect these deviced to their hi-fi. A friend of mine connects it to his classe/EAD combo. Scary huh ? another one has bought a separate entry level amp and speakers for it so that his expensive system stays safe :-) If you are apprehensive about using the diva or any other similar deivce, just ask around first if the deivce itself is a reliable one with not too many SMPS related problems. manek. |
ravi
erstellt: 18. Apr 2005, 16:54
Yes, its a very unsafe combination, scared the hell out of me. One way to reduce this risk is to "float" all the equipment - ie; nothing should have a third pin connected to earth. Mostly the SMPS equipment failure mode is such that both the signal and shield (ground wire) would be driven to high voltage. If there is no other earth reference at the AVR end, there would be no damage per se (although the situation still needs to be rectified quickly due to risk of electrocution etc). I removed the third pin from my powered sub mains cord to achieve the above floating. However in the other failure mode it could fail such that there is a high voltage between signal and shield (although much less likely) - God help us in this case. Somebody should make inline surge suppressors for audio interconnects! I would be interested if any of you know a better way of protection or if such surge suppressors are already available anywhere. |
hi-fi stores einuj am 14.08.2003 – Letzte Antwort am 15.08.2003 – 2 Beiträge |
Headphones - Cheaper Solution to Hi-Fi ???? bhagwan69 am 05.12.2005 – Letzte Antwort am 19.01.2006 – 27 Beiträge |
Connecting a walkman to NAD 320 vinodt am 05.01.2005 – Letzte Antwort am 06.01.2005 – 3 Beiträge |
Connecting PC sound card to Denon receiver shashankmittal am 12.09.2005 – Letzte Antwort am 12.09.2005 – 2 Beiträge |
Connecting two power amps to Preamp ckn am 14.04.2006 – Letzte Antwort am 14.04.2006 – 3 Beiträge |
Hi-Fi suggestions sanathan am 28.03.2005 – Letzte Antwort am 29.03.2005 – 14 Beiträge |
Hi end Hi-fi In India sidvee am 07.11.2005 – Letzte Antwort am 12.11.2005 – 20 Beiträge |
Hi fi in Chennai Neutral am 05.08.2005 – Letzte Antwort am 08.08.2005 – 5 Beiträge |
Midi Hi Fi system souravin am 16.01.2006 – Letzte Antwort am 31.01.2006 – 13 Beiträge |
Help Required -Startup Hi Fi Anand.Patil am 28.03.2005 – Letzte Antwort am 30.03.2005 – 16 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.991 ( Heute: 4 )
- Neuestes Mitgliedcinisi
- Gesamtzahl an Themen1.564.370
- Gesamtzahl an Beiträgen21.852.050
