| HIFI-FORUM » English » Stereo (Engl.) » Voltage conversion | |
Voltage conversion+A -A |
mmx_2
erstellt: 25. Dez 2004, 21:23
Does anyone know howto or if it is easy to convert a pair of Mark Levinson 33h to 240V:s? Anyone know how much it would cost to get it done by the distribuitor? |
Prithvi
erstellt: 26. Dez 2004, 07:41
Hi! First of all this is an awesome amp. Yes It can be converted to 230v, but better it is done by the authorised ML dealer. As then the warranty will hold good. Rgds Prithvi |
Manek
erstellt: 27. Dez 2004, 05:40
hey mmx_2... I would say if you can get away with using a 230v to 110v converter, then do it and not open the amp. yeah....very nice amp ! Manek. |
mmx_2
erstellt: 27. Dez 2004, 10:00
Maybe a 230V-110V converter would work but it would be rather expensive since the rated maxiumum power output of the 33h are very high. |
Manek
erstellt: 27. Dez 2004, 13:41
Sorry....maybe I'm on the wrong track....why would a simple external voltage convertor be expensive ? Correct me if I'm wrong but all you need is a 230v to 110v stepdown device connected to your amp mains input, right ? manek. |
mmx_2
erstellt: 27. Dez 2004, 14:02
Yes in priciple, but they are always limited in power. A converter this most likely costs about 2000$. So most likely it is cheaper to get them properly converted by I dealer. I was just interested so see if anyone had a schematic or something so I could do it by my self (quite skilled eletrical engineer). |
Prithvi
erstellt: 27. Dez 2004, 14:43
Hi! MMx2, If I were you, I will never use a step down converter as it will degrade the sound quality plus you will need a hi-power one. A client got his OUTLAW AUDIO (5 X 200W RMS) power amp running through a 5kva step down converter made in the USA. In India you get piddliy 20-50w converters, unless a manufacturer can make it for you. Send an email to ML and ask them for instructions to do the needful, they will give it or direct you to a ML dealer. where are you located??? Rgds Prithvi |
mmx_2
erstellt: 27. Dez 2004, 15:35
I live in Sweden. I actually sent an email to ML and they post poned me to the nordic distributor, they on the other hand post poned me back to ML... |
Manek
erstellt: 28. Dez 2004, 05:38
Going round in circles I see. Probably time to look at european brands to make sure your amp plugs into your mains without much trouble ? manek. |
Arj
erstellt: 28. Dez 2004, 08:14
As you have mentioned, With high power amps putting in a filter/convertor or any other current limiting device will definitely affect the dynamics of the sound.They seem to work OK only with Pure calss A amps which always draw the same amount of current. The best (only ?) way forward is modification of the power section.since you ar not gettingmuch joy from theDealers, Have you tried www.DIYaudio.com ? even Audio Asylum should be able to connect you to people who have done it or would do it for a feeThe PS audio power regenerators also would not be able to handle the instantaneous high power requirements by your amp ! BTW Other option may be to upgrade |
mmx_2
erstellt: 28. Dez 2004, 11:30
Thanks for the tip on diyforum! I'll have to check them! If you read my other topic, Help! you'll probably understand what this is all about |
Norge or Telome anyone? Neutral am 30.06.2005 – Letzte Antwort am 02.07.2005 – 12 Beiträge |
Component to S-video cables? Edges am 05.09.2005 – Letzte Antwort am 15.09.2005 – 8 Beiträge |
Expensive Audio CD player - what difference does it make? jayashree am 18.10.2008 – Letzte Antwort am 06.11.2008 – 33 Beiträge |
Anyone from Mumbai? Sonic_Master am 04.06.2006 – Letzte Antwort am 21.06.2006 – 11 Beiträge |
Buying on the Net purnendu am 29.04.2005 – Letzte Antwort am 25.08.2005 – 11 Beiträge |
Tupe Preamp options panditr am 20.01.2006 – Letzte Antwort am 26.01.2006 – 16 Beiträge |
How do computers filter frequencies? Neutral am 30.07.2005 – Letzte Antwort am 02.08.2005 – 4 Beiträge |
Dream setup. Arj am 21.08.2007 – Letzte Antwort am 06.12.2012 – 173 Beiträge |
Any Cassette deck repairer? Angshuman am 03.01.2006 – Letzte Antwort am 03.01.2006 – 2 Beiträge |
Technics sl1200 purnendu am 17.07.2008 – Letzte Antwort am 20.07.2008 – 4 Beiträge |
2004
Top Produkte in Stereo (Engl.)
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.952 ( Heute: 4 )
- Neuestes Mitglieds0r21
- Gesamtzahl an Themen1.564.251
- Gesamtzahl an Beiträgen21.848.217
