Gehe zu Seite: |vorherige| Erste . 10 . 15 16 17 18 19 20 21 22 23 24 . 30 . 40 . 50 . 60 .. 100 .. Letzte |nächste|
LG OLED 2022 - A/B/evo C/evo G mit Heatsink/Z2/Flex LX3 | 4K 42-97"/ 8K 77-88"/ A9 Gen5
celle
#906 erstellt: 05. Apr 2022, 18:33
blowfly6
#907 erstellt: 05. Apr 2022, 18:50
Vorhin gab's den 77C2 für 3499.- bei OTTO...
Aber nicht sehr lange!
cookiemonster89
#908 erstellt: 05. Apr 2022, 19:08
Das war aber vermutlich ein Preisfehler oder? Ist jetzt nicht mal bei Otto gelistet.
celle
#909 erstellt: 06. Apr 2022, 04:12
Bericht vom dem Videoersteller im AVS-Forum:
Even though the C1 measures around 100 nits lower it looks as bright or brighter when dynamic tone mapping is off. With HGiG on or in Cinema movie mode with DTM off the C2 appears to hold back some of its brightness potential to preserve more highlight detail. With DTM on in game or movie modes, the C2 is anywhere from a bit brighter to noticeably brighter but at the expense of detail and washing out colors.
Motion is probably 10x better. That may have been one of LGs biggest concerns and it shows. On the stock ticker Spears and Munsil demo, the C1 has artifacts like crazy at dejudder 1 while the C2 doesnt show them until 4-5 and even at 5-6 doesnt get as bad as the C1 at 1. At 1-3 on the C2 its very smooth, no artifacts, and only very slight SOE. Even off it was far less judder on the C2 than the C1. 2:09:00 in the stream to see the motion test.
Other than that, they mostly look the same, again when set to more accurate settings. If you turn on DTM then the C2 is quite different.
Also all AI functions arent functioning yet.
And Super Resolution on the Nintendo Switch does nothing until you set sharpness to 21. At 20 or lower its not activating. OLED motion pro while only having an on/off toggle, has much less flicker than the C1 (set to high) on the Nintendo Switch. Brightness was about the same with it on in SDR though, but a slight advantage to the C2.
https://www.avsforum...236262/post-61572472
BFI sollte man mal genauer unter die Lupe nehmen und am besten mit verschienden Frameraten. Zudem ist OLED-Motion-Pro auch in der Gamebar aktivierbar. Evtl. gibt es da auch einen Unterschied zum normalen Einstellungsmenü.
blowfly6
#910 erstellt: 06. Apr 2022, 04:37
Glaube ich nicht, war ein Link von idealo.
Bildschirmfoto 2022-04-05 um 20.50.19
ehl
#911 erstellt: 06. Apr 2022, 06:34
1. Es gibt kein oled motion pro beim c2
2.Das lässt dann doch auf rolling scan schließen, die Flimmerfrequenz liegt def. bei 60hz, die Dunkelphasen könnten aber verkürzt worden sein.
Mit dem cx lag die sichtbare Frametime bei 4ms (Stufe high), mit dem c1 bei ca. 8ms, hoffentlich erhöhen sie nicht noch weiter.
Es gibt kein oled motion pro beim c2!
Mit 120fps Zuspielung hat Vincent bereits die bfi getestet, ändert nichts!
celle
#912 erstellt: 06. Apr 2022, 07:09
Ja, BFI halt. LG hat eine Historie an teils kryptischen Fehlbezeichnungen und Funktionen, so dass es mich nicht wundern würde, wenn BFI im Einstellungsmenü anders arbeitet als die separate BFI-Funktion in der Gamebar. In früheren LG TVs musste man für eine saubere 24p-Funktion TruMotion gleichzeitig aktivieren und in den manuellen Einstellung die Regler für Judder und Blur jeweils auf 0 stellen, obwohl es noch einen separaten Kinomodus "echtes Kino" für die 24p-Wiedergabe gab. LG ist für solche "Glitches" leider bekannt.
Vincent hat nur An/Aus getestet und nicht genauer eventuelle Frequenzunterschiede des Rolling Scan zur Vorserie untersucht und eine Messung zum Leuchdichteverlust gibt es bisher auch nicht. Evtl. arbeitet BFI doch anders als noch bei einem C9, als es auch nur 60Hz-BFI gab.
[Beitrag von celle am 06. Apr 2022, 07:10 bearbeitet]
celle
#913 erstellt: 06. Apr 2022, 07:13
Rtings hat den G2 ja im Labor und testet auch BFI. Mal schauen was dann da raus kommt.
ehl
#914 erstellt: 06. Apr 2022, 07:49
Ja, aber er hat ein Statement zu oled motion mit 120fps Zuspielung abgegeben.
Wenn wie angegeben das Flimmern i.V. zum c1 sichtbar verringert wurde, KANN es sich gar nicht um die bfi aus 2019 und früher handeln!
[Beitrag von ehl am 06. Apr 2022, 07:52 bearbeitet]
celle
#915 erstellt: 06. Apr 2022, 07:56
Ja, aber das reicht nicht, zumal er nun sein Videoreview verschieben musste, weil es kurz zuvor ein Update gab, bei dem er nun alles wieder neu untersuchen möchte.
celle
#916 erstellt: 06. Apr 2022, 08:01
Nach dem ersten Verbrauchsvergleich durch das Energielabel sind die EX-Panels deutlich sparsamer als das QD-OLED-Panel. 2023 muss Samsung entsprechend nachkorrigieren, denn sonst wird es in der EU eng mit der Zulassung der TVs. Hoffentlich wird bis dahin das Panel effizienter und nicht nur dunkler.
http://www.hifi-foru...d=151&postID=355#355
Anilman
#917 erstellt: 06. Apr 2022, 08:40
Wenn die ZBB deutlich besser ist mit weniger Artefakten dann ist das sehr gut.
Das ist immernoch die größte schwäche von LG die haben also nochmals aufgeschlossen zu den Konkurrenten wie sich das liest.
Das mit bfi ist net so schlimm das habe ich nur auf niedrig genutzt über die interne youtube app.
Automatisch zu dunkel und niedrig passt gut genug.
Der lg g2 ist auf meiner kaufliste nur warte ich auf Angebote.
Inputlag ist ja identisch zu lg c1/g1
paradox1201
#918 erstellt: 06. Apr 2022, 12:23
Mir fallen auf meinen G1 keine Artefakte auf.
ssj3rd
#919 erstellt: 06. Apr 2022, 12:52
https://www.youtube.com/watch?v=yx7lmtMF_AM
„Motion is probably 10x better. That may have been one of LGs biggest concerns and it shows. On the stock ticker Spears and Munsil demo, the C1 has artifacts like crazy at dejudder 1 while the C2 doesnt show them until 4-5 and even at 5-6 doesnt get as bad as the C1 at 1. At 1-3 on the C2 its very smooth, no artifacts, and only very slight SOE. Even off it was far less judder on the C2 than the C1. 2:09:00 in the stream to see the motion test.“
Aber sicher hast du 0 Artefakte…
[Beitrag von ssj3rd am 06. Apr 2022, 12:53 bearbeitet]
paradox1201
#920 erstellt: 06. Apr 2022, 12:57
Mir fallen zumindest keine auf. :Prost
[Beitrag von paradox1201 am 06. Apr 2022, 12:59 bearbeitet]
ssj3rd
#921 erstellt: 06. Apr 2022, 12:58
Das klingt schon besser/ehrlicher
paradox1201
#922 erstellt: 06. Apr 2022, 13:01
Ich glaub Vincent ist da auch nichts negatives aufgefallen. Naja, was solls.
celle
#923 erstellt: 06. Apr 2022, 13:07
Naja, man schaut ja auch nicht solche scrollenden Testbilder mit feinen geometrischen Rastern und Linien. Ein Sony schaut da nicht deutlich besser aus. Mit Realenszenen und je nach Bildrate relativiert sich das schon wieder. Sollte er lieber mit Fußball, Eishockey und Tennis im Sport und Vogelschwarm in Naturdokus etc. testen. Da sieht man eher ob eine MCFI brauchbar ist oder nicht. Auch ein Gerät was in den Testszenen gut abschneidet, muss nicht zwangsweise in Realszenen besser abschneiden, als ein Gerät welches in der gleichen geometrischen Testszene schlechter abgeschnitten hat.
Mess
#924 erstellt: 07. Apr 2022, 08:40
[Interview] OLED.EX takes display technology to the next level
https://news.lgdispl...y-to-the-next-level/
LG Display Demonstrates OLED.EX’s Evolutionary Experience at 2022 OLED Korea Conference
https://news.lgdispl...ed-korea-conference/
[Learn OLED.EX] #1. What is Deuterium?
https://news.lgdispl...1-what-is-deuterium/
[Learn OLED.EX] #2. What are Personalized Algorithms?
https://news.lgdispl...onalized-algorithms/
celle
#925 erstellt: 07. Apr 2022, 09:01
Rtings.com hat nun mit dem Test des G2 begonnen. Der Test wird dann wie üblich wieder erst einmal nur registrierten Lesern zur Verfügung stehen. Bis er allen öffentlich zugänglich ist, wird es wohl wieder 2 Wochen dauern.
https://www.rtings.com/tv/suggestions
ehl
#926 erstellt: 07. Apr 2022, 14:00
Definitiv MEHR Blackcrush im hgig Modus als der c1, ernsthaft, lg?
Offenbar hat man dtm stark verbessert, ist ja nett und lieb, aber das rechtfertigt doch keine Verschlechterung der nativen hdr Wiedergabe.
Mcfi soll ein MASSIVES Upgrade erfahren haben, zmdst. stellt es sich in Testpattern so dar.
"Clarity, Detail, Sharpness - zero difference to the c1." Strange, hat er nur mit 4k Quellen getestet?
Keep it Classy tech ist eigentlich ein repektabler Reviewer, der durchaus kritisch auch Details beachtet.
[Beitrag von ehl am 07. Apr 2022, 14:26 bearbeitet]
real_neo
#927 erstellt: 07. Apr 2022, 20:22
LG G2 OLED Evo TV Review von AVForums:
https://www.youtube.com/watch?v=EjCwNn1g6dE
Anilman
#928 erstellt: 08. Apr 2022, 05:27
Ich hoffe das er wieder settings postet um den black crush zu minimieren ohne selbst den Fernseher kalibrieren zu lassen.
Wenn das kalibrieren per Knopfdruck geht würde ich das selbst machen.
BornChilla83
#929 erstellt: 08. Apr 2022, 09:03
Die Kalibrierung kann zwar theoretisch einfach "auf Knopfdruck" passieren, sie setzt nur immer eine Messung des jeweiligen Gerätes voraus. Dazu gehören dann wiederum andere Geräte inkl. Aufbauten.
[Beitrag von BornChilla83 am 08. Apr 2022, 13:11 bearbeitet]
ehl
#930 erstellt: 08. Apr 2022, 09:20
Na dann is ja gut.
JohnMainhard
#931 erstellt: 08. Apr 2022, 09:24
Also mit AutoCal geht doch kalibrieren auf Knopfdruck...
Gruß JM
ehl
#932 erstellt: 08. Apr 2022, 10:08
Schrieb er ja auch
BornChilla83 (Beitrag #929) schrieb:
Die Kalibrierung kann einfach "auf Knopfdruck" passieren...
Autocal benötigt auch erstmal ne Calman Lizenz und natürlich ein Colorimeter, außerdem für den richtigen perzeptiven d65 Weißpunkt ein Spectrophotometer.
BornChilla83
#933 erstellt: 08. Apr 2022, 13:09
Ich habe es mal präzisiert
MrWhite66
#934 erstellt: 09. Apr 2022, 10:29
C2 vs. C1 (jeweils in 55 Zoll)
paradox1201
#935 erstellt: 09. Apr 2022, 10:53
Wenn man den C1 hat lohnt sich ein upgrade null....
Jogitronic
#936 erstellt: 09. Apr 2022, 11:08
Die bessere Zwischenbildberechnung des C2 wäre für mich ein entscheidendes Argument
paradox1201
#937 erstellt: 09. Apr 2022, 11:17
Für mich nicht.....Ich nehme die "schlechtere" nicht negativ wahr.
[Beitrag von paradox1201 am 09. Apr 2022, 11:18 bearbeitet]
drspeed610
#938 erstellt: 09. Apr 2022, 11:19
Sehe ich genauso
ssj3rd
#939 erstellt: 09. Apr 2022, 11:35
Da ich großen Respekt vor Regisseuren und ihren originalen Machwerken habe und deshalb die Filme genauso gucke wie die sich das mal vorgestellt haben, nutze ich die Zwischenbildberechnung überhaupt nicht.
Nativ ist und bleibt für mich das einzig Wahre.
[Beitrag von ssj3rd am 09. Apr 2022, 11:35 bearbeitet]
ehl
#940 erstellt: 09. Apr 2022, 11:39
Dann fällt der Vorteil des neuen dtm auch gleich weg, shadow detail/ black crush ist ja offenbar min. genauso schlecht wie auf dem c1. Zum Upscaling wurde sich bisher widersprüchlich geäußert.
Bfi eingeschränkter, Material billiger und...
kein analoger audio-Ausgang.
[Beitrag von ehl am 09. Apr 2022, 11:39 bearbeitet]
Jogitronic
#941 erstellt: 09. Apr 2022, 12:03
42-inch LG C2 OLED TV Review - "EVO" But Older Panel?
[Beitrag von Jogitronic am 09. Apr 2022, 12:04 bearbeitet]
Ralf_1
#942 erstellt: 09. Apr 2022, 12:46
Also für Kenner und Erbsenzähler ist der c2 eher nichts, für Ottonormalverbraucher, Filmeschauer und Gamer ein top TV?
Das Design und Platzierung der Anschlüsse ist doch sehr gut. Leichter gleich billiger?
Fanta_Klaus
#943 erstellt: 09. Apr 2022, 12:47
Habe selber den G1 im Wohnzimmer und den C1 im Schlafzimmer.
Der G1 ist minimal heller und hat mehr „Pop“, vorallem das SD Bild gefällt mir besser.
Könnt ihr mir sagen ab wann der G2 in 75 Zoll lieferbar sein könnte? Ich würde im Wohnzimmer gerne
von 65 auf 75 Zoll gehen
Danke und Grüße
JohnnyPlasmaBoy2000
#944 erstellt: 09. Apr 2022, 12:54
Microstutter bei 50hz? Also für PAL Fernsehen ein echtes Problem..
ssj3rd
#945 erstellt: 09. Apr 2022, 12:58
Danke und Grüße
75“ gibt es bei LG nicht, lediglich 77“, aber nah dran.
Und ab wann lieferbar? Seit knapp 5 Tagen:
https://www.electron...53+HG10+SO105+GR1054
Gönn dir doch endlich
[Beitrag von ssj3rd am 09. Apr 2022, 13:42 bearbeitet]
Jogitronic
#946 erstellt: 09. Apr 2022, 13:39
Zur Abwechslung mal ein Vergleich ...
Fanta_Klaus
#947 erstellt: 09. Apr 2022, 14:32
77 Zoll passt perfekt bei einem 180cm breiten Schrank. Weiß dann aber nicht ob die Wandhalterung das mitmacht.
Ralf_1
#948 erstellt: 09. Apr 2022, 14:49
Schau mal auf das Gewicht! Die 2er Serie ist um viele kg leichter.
paradox1201
#949 erstellt: 09. Apr 2022, 14:55
Warum sollte die Wandhalterung das nicht mitmachen?
Fanta_Klaus
#950 erstellt: 09. Apr 2022, 15:07
Ist eine sehr sehr alte die eigentlich nur bis 55 Zoll deklariert ist, jetzt hängt schon ein 65 Zoll dran und ein 77 Zoll macht mein Gefühl nicht mehr mit.
Plan an die Wand will ich den G2 nicht haben, deswegen bestelle ich mit lieber auch noch eine neue Wandhalterung. Warte aber bis der G2 ein wenig fällt, zum UVP kaufe ich den nicht, aber spätestens wenn er bei 5000 ist
Frauchen wird das schon verkraften… zum aufhängen hole ich aber lieber meinen Bruder ran
Könnte mir auch den G1 in 77 Zoll für 3500 Euro holen aber neu ist immer besser …… außer BFI
ehl
#951 erstellt: 09. Apr 2022, 15:09
Und kein analoger Audioausgang
paradox1201
#952 erstellt: 09. Apr 2022, 15:10
Was gefällt dir nicht daran, wenn er plan an der Wand hängt?
Fanta_Klaus
#953 erstellt: 09. Apr 2022, 15:15
Würde einfach nicht aussehen, mein aktueller TV ist auch genau bündig mit der Kante vorne der Regale.
Müsste mindestens eine Elle lang von der Wand weg. Aber jetzt genug hier…. Hier soll es ja um Technik gehen und nicht um Aufstellmöglichkeiten
Das mit dem Analogen Ausgang betrifft mich hier nicht und stört mich nicht, kann den Unmut aber verstehen
Fanta_Klaus
#954 erstellt: 09. Apr 2022, 15:17
Wobei, vielleicht hast du recht. Wenn der direkt an der wand hängt, dann hat der TV links und rechts eine natürliche Einhausung und kein Lichteinfall würde rechts vom Fenster aus kommen … mmmhhhh
Vielen Dank auch …..
paradox1201
#955 erstellt: 09. Apr 2022, 15:20
gern geschehen
Plan an der Wand fetzt
Plan
[Beitrag von paradox1201 am 09. Apr 2022, 15:25 bearbeitet]
nimsa67
#956 erstellt: 09. Apr 2022, 15:22
Wenn der 77er dann Plan an der Wand hängt kommt er dir im Endeffekt aber nicht größer als dein jetziger 65er vor.
Kannst du ja sogar an deinem Bild jetzt schon sehen …
[Beitrag von nimsa67 am 09. Apr 2022, 15:25 bearbeitet]
LG OLED 2023 - A/B/evo C/evo G + Z mit MLA/evo M3 wireless | 4K 42-97"/ 8K 77-88"
celle am 27.09.2022  –  Letzte Antwort am 10.11.2024  –  4668 Beiträge
LG OLED 2021 A/B/C/evo G/Z1 | 4K 48-83"/ 8K 77-88"/ A9 Gen4 AI Pro/ webOS 6.0
celle am 29.10.2020  –  Letzte Antwort am 03.09.2024  –  11568 Beiträge
LG Oled evo Rückseite
maik2244 am 30.09.2022  –  Letzte Antwort am 30.09.2022  –  2 Beiträge
LG OLED 2024 - B4 α8/evo C4 α9/evo G4, M4 mit MLA α11/ SIGNATURE T/ 42-97"
celle am 11.10.2023  –  Letzte Antwort am 03.12.2024  –  3491 Beiträge
LG Oled 3 evo besser als OLED65G19LA ?
octopussy9 am 17.09.2023  –  Letzte Antwort am 18.09.2023  –  2 Beiträge
LG Evo 77 G2 kaufen bei Expert.de?
Bruce1980 am 22.07.2023  –  Letzte Antwort am 22.07.2023  –  2 Beiträge
IFA 2018: LG 8K OLED-TV in 88"
celle am 29.08.2018  –  Letzte Antwort am 30.08.2018  –  10 Beiträge
LG Evo G 2 weißes Licht?
Bruce1980 am 15.08.2023  –  Letzte Antwort am 19.08.2023  –  4 Beiträge
Sendersortierung LG evo G19LA
mister.burns1 am 09.08.2021  –  Letzte Antwort am 09.08.2021  –  4 Beiträge
LG gallery EVO Wandhalterung
Kardi am 05.01.2022  –  Letzte Antwort am 05.01.2022  –  2 Beiträge
  • Registrierte Mitglieder928.687 ( Heute: 1 )
  • Neuestes Mitgliedskylover_de
  • Gesamtzahl an Themen1.558.753
  • Gesamtzahl an Beiträgen21.709.861
