| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Grundig RPC 2500-2 Radio DEFEKT | |
Grundig RPC 2500-2 Radio DEFEKT+A -A |
Tolis_athens
erstellt: 27. Dez 2011, 19:13
Hallo from Greece. Sorry i don't speak German, I just joined and i need all the help i can get from the forum. I have an Grundig RPC 2500 which worked great all those years. Suddenly the radio stopped to function and i hear nothing but a FFFZZZZ and no stations all over the scale, either in FM or LW or MW. When i try to change stations go only 0,05 MHz up or down and then everything "locks". Cassette and Turntable works great. I found a topic with the same problem but i cannot understand the internet translation and how our friend fix the problem with his stereo. Its a great looking compact stereo. Please if anyone can help me email me at: t.tsakmakis@gmail.com or give an answer to this forum. Thanks in advance. All the best from Greece, Tolis |
anymouse
erstellt: 27. Dez 2011, 20:38
You mean this thread?Sounds really like the same situation -- luckily there is also a solution given. I do not have the device, just translating the other post. Do you have a voltmeter? Can you measure the 32V-rail-voltage (this should be printed on the board)? For axel.jahr this voltage collapsed to 0V, due to a defect in the PSU. If this is true, check the following: in the PSU there should be a (now maybe defective, maybe not) Zener-Diode (seems D322). Parallel to this Z-diode is a tantal-capacitator, which developed a short. axel.jahr replaced the capacitator with a electrolytic capacitor with a sufficient high voltage strength, and the Z-Diode with a 33V new one. ------------ Translation of axel.jahrs post:
I hope, this helps. [Beitrag von anymouse am 27. Dez 2011, 20:39 bearbeitet] |
Tolis_athens
erstellt: 28. Dez 2011, 17:34
Hallo to the Forum. Thanks to the answer given by our friend anymouse, problem SOLVED!!!!!!! I just finished the repair and everything its perfect. Radio stations loud & clear. Up & down search (both manually and automatic) works fine. My German friend i have no words to express my gratitude. Thanks for your time and effort for the accurate translation. All the best and Happy New Year, Tolis |
Grundig RPC-2500 geschenkt Kampfmuffin am 26.12.2012 – Letzte Antwort am 27.12.2012 – 4 Beiträge |
Grundig RPC 2500-2 32 V Spannungsversorgung defekt axel.jahr am 21.10.2010 – Letzte Antwort am 03.02.2018 – 3 Beiträge |
Grundig RPC 300 Tuner defekt Eißpin am 31.05.2015 – Letzte Antwort am 05.06.2015 – 10 Beiträge |
Grundig RPC-650TP Lautsprecherschalter sunny-ko am 02.07.2011 – Letzte Antwort am 04.07.2011 – 7 Beiträge |
Grundig RPC 500-Umschaltung der Geräte defekt neo1966 am 31.08.2020 – Letzte Antwort am 05.09.2020 – 3 Beiträge |
Grundig RPC 450 Reparatur Hero90 am 24.11.2008 – Letzte Antwort am 25.11.2008 – 12 Beiträge |
Grundig RPC 200 -> Probleme punkmanaffe am 22.07.2012 – Letzte Antwort am 25.07.2012 – 4 Beiträge |
Grundig Studio RPC 650 TP, defekt matula am 07.10.2004 – Letzte Antwort am 31.10.2004 – 11 Beiträge |
Grundig RPC 300 (B) Netzteil-Defekt cbmuser am 31.01.2013 – Letzte Antwort am 10.02.2013 – 9 Beiträge |
Grundig RPC-2000-2 repaieren ChrisConspiracy am 16.02.2021 – Letzte Antwort am 19.02.2021 – 8 Beiträge |
2011
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.546 ( Heute: 5 )
- Neuestes MitgliedNoushka
- Gesamtzahl an Themen1.563.173
- Gesamtzahl an Beiträgen21.818.251
