| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Telefunken Studio M1 defekt | |
Telefunken Studio M1 defekt+A -A |
stevenrob
erstellt: 08. Feb 2017, 17:29
Guten Morgen. Ich verwende Google-Übersetzung, wir danken Ihnen für nachsichtig ... Nach einem Telefunken CR100, I Studio M1 Boombox gekauft. Als ich eingesteckt ist, war es ein Rauch und Brandgeruch. Die Symptome sind die gleichen mit Batterien. Meine Frage: glaubst du, es ist möglich, das Gerät zu reparieren, ohne zu viel Geld? Es wäre gut, weil es große Material ist und ist in sehr gutem Zustand.Danke |
shabbel
erstellt: 09. Feb 2017, 10:55
It might be easier for you to receive answers in English. If you recently bought the Boombox, try to give it back to the seller. Otherwise you should open the Telefunken, switch it on for a short time and look from which electronical part the smoke comes. To ensure not to cause further damage it is helpful to reduce the mains voltage by using a light bulb in a row with the boombox. |
stevenrob
erstellt: 19. Feb 2017, 14:56
Hi, The amplifier works great. But there is a problem with lights. There is electricity (10v) on + and also on - . It is very strange |
Monsterle
erstellt: 22. Feb 2017, 01:39
Hi, it is difficult to give a precise diagnosis from remote. But possibly the problem might be a blown electrolytic capacitor. This type of capacitors tend to dry out after quite a time. This could also happen, if the device was stored over a long time without being used. In the worst case, there is now some collateral damage. Since there are several voltages and circuits in the device, it is likely, that just one fuse is blown, so that other unconcerned circuits still work. If you don't have a certain experience in electronics, please do not open the device and get it repaired by a specialist. |
stevenrob
erstellt: 22. Feb 2017, 19:24
OK, thanks. I'll try to change chemical parts. |
Telefunken M1 Tuner defekt matthiascp am 30.06.2016 – Letzte Antwort am 30.06.2016 – 3 Beiträge |
Telefunken Studio Center 5004 - Trafo defekt ? urst am 23.02.2019 – Letzte Antwort am 20.08.2020 – 26 Beiträge |
Telefunken Studio 1M derblaueklaus0815 am 08.09.2009 – Letzte Antwort am 14.08.2011 – 3 Beiträge |
Telefunken HIFI Studio 1 karli10000 am 15.01.2017 – Letzte Antwort am 15.01.2017 – 3 Beiträge |
Telefunken Studio 1M Tunerprobleme wschlager am 15.11.2021 – Letzte Antwort am 24.12.2021 – 75 Beiträge |
Telefunken HiFi Studio 1 Skalenbirnchen Zuendi am 13.06.2008 – Letzte Antwort am 20.06.2008 – 12 Beiträge |
Telefunken Hifi Studio M1Frontplatte geht nicht ab? tomtuxx am 01.01.2014 – Letzte Antwort am 25.03.2021 – 6 Beiträge |
Telefunken Hifi Studio 1M - Kassettendeck jim_bocho am 04.05.2012 – Letzte Antwort am 05.05.2012 – 3 Beiträge |
Telefunken Opus Studio 2650 Potentiometer Dommes am 14.05.2021 – Letzte Antwort am 14.05.2021 – 8 Beiträge |
Werte der Leuchtdioden vom HiFi Studio M1 spike12 am 19.01.2015 – Letzte Antwort am 20.01.2015 – 8 Beiträge |
2017
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.988 ( Heute: 4 )
- Neuestes MitgliedRainer_Hechtl
- Gesamtzahl an Themen1.564.361
- Gesamtzahl an Beiträgen21.851.781
