HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » problem with Telefunken CR100 | |
problem with Telefunken CR100+A -A |
stevenrob
21:20
erstellt: 17. Dez 2016, |
Hello, I'm a french people and sorry I speak Deutsch very, so I try English. I have a problem with this boombox that I just buy. When I plug it to AC and I put radio or cassette : the boombox works 5 seconds and stops. I Have changed the electrical transformer but no change. Have you an idea ? Best regards |
kadioram
10:57
erstellt: 18. Dez 2016, |
Hi, does it work when you use batteries (=DC)? If yes, you have probably a problem with your power supply (faulty soldering connections, broken rectifier diodes, worn out charging capacitors...) If it won´t work with batteries, the variety of faults can be very wide spread... I recently reworked a little "boombox" (not really "BOOM", a Sanyo ROBO), with the same fault. There had been some faulty soldering connection and worn out charging capacitors. After resoldering and a complete recapping it worked again. [Beitrag von kadioram am 18. Dez 2016, 11:05 bearbeitet] |
stevenrob
22:55
Hello, you're right. With DC, all works fine. Could you show me with internet links the sort of resistor I must change ? I have the service manual but I'm novice in electronic. Best regards |
kadioram
13:44
erstellt: 21. Dez 2016, |
Hello, it would be helpful, if you could post some images of the circuit board. You can order parts at ![]() BR [Beitrag von kadioram am 21. Dez 2016, 13:47 bearbeitet] |
stevenrob
15:52
Rabia_sorda
21:02
Check the rectifier diodes, resistors and transistors in the power supply. The transistor (4) is a good idea. At the power plug socket should be a switch which also check. Does the voltage at the secondary output of the transformer remain, or does it collapse? Also look for bad solder joints. [Beitrag von Rabia_sorda am 21. Dez 2016, 21:04 bearbeitet] |
stevenrob
07:12
erstellt: 30. Dez 2016, |
Hello, I have changed transistor number 4 and now the boombox works fine. Thanks for your help guys Best regards |
Rabia_sorda
12:37
Fine! ![]() |
Telefunken CR100 verschiedene Probleme SebW am 10.10.2020 – Letzte Antwort am 23.11.2020 – 7 Beiträge |
Telefunken Studio M1 defekt stevenrob am 08.02.2017 – Letzte Antwort am 22.02.2017 – 5 Beiträge |
Telefunken TL70 renovieren arusha am 07.04.2015 – Letzte Antwort am 10.04.2015 – 7 Beiträge |
Telefunken 5031 Lautstärke-Problem Lonelywolf33 am 08.12.2011 – Letzte Antwort am 21.12.2011 – 6 Beiträge |
Telefunken Tuner ToplineVR6 am 15.10.2013 – Letzte Antwort am 28.10.2013 – 3 Beiträge |
Telefunken Stp franzel28 am 04.12.2009 – Letzte Antwort am 06.12.2009 – 6 Beiträge |
Telefunken HA850 Mr.T.GO am 22.04.2020 – Letzte Antwort am 21.05.2020 – 9 Beiträge |
MAGNETOPHON 3000 HIFI TELEFUNKEN UMSCHALTER VORBAND/HINTERBAND GIORGIO_MARTINI am 01.08.2020 – Letzte Antwort am 01.08.2020 – 3 Beiträge |
Problem mit Telefunken RA 200 Segelflieger85 am 15.04.2012 – Letzte Antwort am 15.04.2012 – 7 Beiträge |
Telefunken 6001 Rumpel-Schalter-Problem volker225 am 31.05.2013 – Letzte Antwort am 01.06.2013 – 3 Beiträge |
2016
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder928.874 ( Heute: 12 )
- Neuestes MitgliedPowerTower
- Gesamtzahl an Themen1.559.206
- Gesamtzahl an Beiträgen21.720.254
