| HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Grundig SXV6000 dead left channel | |
Grundig SXV6000 dead left channel+A -A |
lubomir.germany
erstellt: 13. Sep 2014, 19:24
Good day, I have Grundig SXV6000. For several months laid in the bookshelf. Now when I turn it ON, the left channel is dead. I tried every input and the result is the same. Even sound from built-in tone generator goes only from right channel, left is dead... I dont know yet where could be the problem... Few months ago I had problems with this left channel, but from a certain level of dB. Anything bellow 0dB, -2dB works both channel, everything above 0dB, +2dB... works only right channel... - that problem was solved by replacing tantal capacitors C103 and C106. But in this case they are all OK... The problem must originate elsewhere... Thank you in advance |
oldiefan1
erstellt: 14. Sep 2014, 02:36
Hello Lubomir, remote diagnosis is difficult. Can only guess. Could be the output stage transistors of the left channel. Faulty part has to be located by measurements. Best Regards, Reinhard |
Grundig SXV6000 Phono Stufe Klangkurve~ am 02.12.2018 – Letzte Antwort am 09.05.2019 – 25 Beiträge |
Grundig V5000.Noise in the left channel. José_Ramón_Ameijeiras_F. am 17.10.2013 – Letzte Antwort am 17.10.2013 – 4 Beiträge |
Grundig studio RPC 450a bad left channel lubomir.germany am 03.06.2014 – Letzte Antwort am 22.06.2014 – 28 Beiträge |
grundig vorverstärker sxv6000: Relais Fehler 0572sirius am 02.05.2010 – Letzte Antwort am 05.05.2010 – 3 Beiträge |
Grundig SXV6000 Krachen linker Kanal Walter9 am 23.11.2015 – Letzte Antwort am 16.12.2015 – 8 Beiträge |
Grundig SXV6000 und ST6000 leicht defekt? fastnixdigitales am 31.01.2010 – Letzte Antwort am 15.02.2010 – 11 Beiträge |
Grundig SXV6000 brummt wenn er ausgeschaltet ist beetle-fan am 29.11.2012 – Letzte Antwort am 03.12.2012 – 10 Beiträge |
Endstufe für Grundig SXV6000 in Aktiv-Box jörg-525-touring am 03.05.2022 – Letzte Antwort am 05.08.2022 – 281 Beiträge |
Grundig SXV6000 - nur ein Phono-Kanal masblat am 11.02.2024 – Letzte Antwort am 10.03.2024 – 37 Beiträge |
Grundig V5000 ploppt jörg-525-touring am 08.05.2022 – Letzte Antwort am 22.05.2022 – 39 Beiträge |
2014
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder930.950 ( Heute: 5 )
- Neuestes MitgliedBlade_Runner_92
- Gesamtzahl an Themen1.564.233
- Gesamtzahl an Beiträgen21.847.557
