| HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » Emtec N200 | |
Emtec N200+A -A |
redlove
#51
erstellt: 09. Aug 2009, 21:57
Anleitung für FTP und NAS getestet!! You will find a package to install FTP and NAS for N200. This package MHD_install_N200.zip (V1) is Hier.This following commands are case sensitives. 1 - unzip this package to usb key. 2 - connect this usb key on N200 3 - connect to N200 with telnet (login: root) 4 - go to usb key's folder if you don't know where, type find / -name MHDWorld a path screen on and type: cd "path" (without "MHDWorld" folder) per example: / # find / -name MHDWorld /tmp/usbmounts/sda1/MHDWorld / # cd /tmp/usbmounts/sda1/ /tmp/usbmounts/sda1 # 5 - To check the right folder, type: ls per example: /tmp/usbmounts/sda1 # ls MHDWorld install.sh rw.txt /tmp/usbmounts/sda1 # 6 - type ./install.sh per example: /tmp/usbmounts/sda1 # ./install.sh ========================= ==== N200 ==== ==== FTP/NAS ==== ==== By Bogy ==== ==== MHDWORLD 2009 ==== ========================= Copie des binaires en cours, copy binaries in progress... Copie des binaires effectuée, copy binaries successfull ! Installation du FTP en cours, Install of FTP server in progress... Installation du FTP terminée, Install of FTP Server done ! Installation du NAS en cours, Install of NAS in progress... Installation du NAS terminée, Install of NAS done ! Veuiller rebooter votre N200, Please reboot your N200 ! /tmp/usbmounts/sda1 # If ./install.sh doesn't work, type chmod +x install.sh 7 - you must reboot your N200 to start FTP and NAS. Caution: A new install or upgrade of the firmware is made, re install this package. To force a copy of files by using NAS, please use teracopy and supercopier on Windows. This topic must be clean and understandable for all. Thank you for your questions by creating a new topic in the N200 forum. RoadMap V1.0: MHD_install_N200_V1.zip - adding bftpd - adding Samba (NAS) - starting USB partitions to read/write |
TecBoy
#52
erstellt: 11. Aug 2009, 14:41
redlove: Das hört sich ja interessant an aber kannst du mir mal erklären was ich dann anders bzw mehr machen kann mit der Box? Habe die jetzt in einem Heimnetzwerk über meinem Router Hängen und das geht eigentlich ganz gut. |
TecBoy
#53
erstellt: 15. Aug 2009, 13:45
Hier scheint keiner mehr so richtig bock zu haben zum Kritzeln oder findet keiner die 2. Seite |
Hoppala2005
#54
erstellt: 15. Aug 2009, 13:51
Ich gehe mal davon aus, dass noch zuwenige das Gerät haben :). Habe jetzt aufgrund meiner Probleme "Emtec" direkt angeschrieben. Deutschen Support gibt es dort aber nicht, sie wollten von mir alles in Englisch. Die Antworten brachten mich allerdings überhaupt nicht weiter, denn das wusste ich alles schon |
10Vorne
#55
erstellt: 17. Aug 2009, 11:42
Ich muss da auch noch mal was zu der wunderlichen Fernbedienung sagen, die das Teil nicht mehr einschalten kann. Ich hatte das erst mal für einen Defekt gehalten und zum Saturn geschleppt, aber das Ersatzgerät hat sich ähnlich verhalten. Der KD-Mann dort war aber genauso verblüfft; wollte mir auch Geld zurückgeben, da ich das Teil an sich nicht schlecht finde (wer spielt sonst schon rm/rmvb/wmv ?) habe ich es erst mal behalten. Dann habe ich mal an den Emtec-Support gemailt (jo, den gibt es wirklich !), kam eine Antwort auf Englisch, die hatten mich so ganz nicht verstanden; habe das noch mal erklärt, warten wir mal ab. Dass das ein Feature und kein Bug ist wie das hier einige meinen, kann ich aber nicht wirklich glauben. Indiz: Nach dem "Ausschalten" per remote gibt es sekundenbruchteilkurz ein rotes Licht - wozu sollte das gut sein, wenn nicht für einen dauerhaften Standby-Modus. Also: Ich hoffe mal auf eine neue Firmware, die einen echten Standby mitbringt. |
redlove
#56
erstellt: 17. Aug 2009, 13:10
Laut Emtec soll die nächste Firmware diese Funktion + DTS ermöglichen |
redlove
#57
erstellt: 17. Aug 2009, 13:23
mikezimmermann
#58
erstellt: 18. Aug 2009, 07:55
Ich habe vor zwei Wochen bei SATURN Düsseldorf einen EMTEC N200 gekauft. Als ich nach der Vorrätigkeit des Dongles fragte, wurde mir gesagt, der müsse bestellt werden. Als ich dies gestern tun wollte, hieß es nach Rückfrage mit dem Hersteller, der Dongle w300 sei frühstens zum Weihnachtsgeschäft zu erwarten. Ich finde es nicht korrekt, beide Produkte zusammen zu bewerben,wie es auf der Homepage von EMTEC geschieht, und dann monatelang nur eines von beiden liefern zu können. Gibt es hier jemanden, der anderslautende Informationen zum Thema Lieferfähigkeit Dongle hat? Die WLAN-Möglichkeit war kaufentscheidend für mich . Sicher bin ich damit nicht der Einzige. Wer kennt eine deutsche Ansprechstelle von EMTEC? Grüße |
serial123
#59
erstellt: 18. Aug 2009, 09:02
Ich habe den N200 inkl. WLAN Dongle in der letzten Woche im Mediamarkt in Mülheim mitgenommen. Prinzipiell ist der Dongle also verfügbar. Ich kann aber im Moment nicht 100%ig sagen, ob es das 300er Modell ist. [Beitrag von serial123 am 18. Aug 2009, 09:11 bearbeitet] |
mikezimmermann
#60
erstellt: 18. Aug 2009, 09:41
das wäre höchstinteressant. Insbesondere wäre auch interessant zu erfahren, ob der W200 Dongle - sofern es der ist - auch mit dem n200 zusammen arbeitet, was angeblich nicht der Fall sein soll. Grüße |
serial123
#61
erstellt: 18. Aug 2009, 10:32
Also ich bin mir zu 99% sicher, dass es der W200 ist und kann bestätigen, dass er mit meinem N200 funktioniert. |
JasonF
#62
erstellt: 18. Aug 2009, 11:06
Das gabs schon beim q120. Entweder mit oder ohne Dongle im Paket. Nachträglich einen zu bestellen war unmöglich (Lieferzeit unbekannt hiess es). Ist wohl typisch Emtec |
serial123
#63
erstellt: 18. Aug 2009, 11:40
Im besagten Mediamarkt Mülheim gibt es den W200 separat zu kaufen. Ein festes Bundle Set gibt es dort gar nicht. |
redlove
#64
erstellt: 18. Aug 2009, 20:55
Kurze INFO: Playon! HD Firmware funktioniert auch auf den Emtec N200 eben getestet, nicht nur das das Menü sieht viel besser aus, sondern man kan jetzt das Gerät mit der FB ein- und Auschalten!!!! http://www.acryan.co...ew&id=189&Itemid=141 [Beitrag von redlove am 18. Aug 2009, 21:06 bearbeitet] |
ccfreund
#65
erstellt: 19. Aug 2009, 15:00
hi redlove wie du hast einfach eine andere Firmware aufgespielt, die nicht von emtec ist Welche Unterschiede hat man da (Verbesserungen oder auch Nachteile) Wäre nett, wenn du eventuell ein paar Aussagen treffen könntest Danke auch für deine vielen Infos hier im Forum. Gruß ccfreund |
redlove
#66
erstellt: 19. Aug 2009, 20:38
ganz genau einfach eine andere Firmware draufgemacht und das Gerät funktioniert immer noch Hier ein paar Infos: Vorteile: - Bootzeit ist kurzer Das Menü ist schön geworden,kannst du hier sehen http://www.mpcclub.c..._acryan_playonhd.pdf- Stantdbye- Option funktioniert jetzt !!! - es gibt auch ein Kopie- Option um Daten z.b von einer Speicherkarte direkt auf eine Externe Festplatte (USB-sStick) zu kopieren - Firmware für die DTS Unterstützung soll spätestens am Wochenende zur Verfügung stehen - Code für Harmony FB gibt es auch... Nachteile: Die Option-Taste funktioniert nicht mehr - IP- Adresse eingeben bzw. ändern mit der FB geht leider nicht (nur mit der Harmony) - FTP funktioniert noch nicht mit der aktuellen Firmware |
ccfreund
#67
erstellt: 20. Aug 2009, 09:42
Hi redlove danke für deine Antwort... kann man eigentlich nach der Installation der Software wieder auf die Originale emtec zurück flashen Ich habe die Harmony und bin sehr zufrieden damit und wenn dann alle Funktionen damit gesteuert werden können ist es ok. Das mit der Kopierfunktion habe ich auch schon gelesen und finde diese sehr gut, aber was mir sorgen macht, ist dass nicht mehr die Optionstaste funktioniert Wie komme ich denn nun ins Menü beim Filme glotzen Gruß ccfreund |
redlove
#68
erstellt: 20. Aug 2009, 10:29
ja du kannst jede Zeit die Originale emtec Software zurück flashen!! - Mit der Harmony sollte kein Problem mit der Option Taste geben. Hier sind die Codes für Deine Harmony: http://www.acryan.com/downloads/ACR-PV73100_RC_Codes.jpg http://www.acryan.com/downloads/ACR-PV73100_RC_Codes.txt |
redlove
#69
erstellt: 20. Aug 2009, 13:12
und noch eine alternative Firmware und diesmal von Fantec http://www.fantec.de...0112090/article.htmlDie Obefläche ist gleich wie Playon! HD !!! [Beitrag von redlove am 20. Aug 2009, 14:31 bearbeitet] |
l.lenzen
#70
erstellt: 20. Aug 2009, 20:49
zunächst einmal vielen Dank an redlove für die guten Beiträge zum Thema! das emtec n200 unterstützt zwar upnp und es funktioniert auch sehr gut beim Zugriff auf einen upnp Server. Leider ist es mir nicht gelungen, das Gerät über einen upnp controller z.B. cidero fernzusteuern hat jemand hiermit Erfahrungen? Beste Grüße L. Lenzen |
Hoppala2005
#71
erstellt: 21. Aug 2009, 09:24
Hiho !
Juchu Kannst Du vielleicht auch bitte was zu den Bookmarks/Lesezeichen schreiben ? Also unter der Übersicht bei "all usb" funzen die dort ? Das wäre für mich das wichtigste, weil ich sehr viele setzen muss aufgrund meiner Serien, dass ich immer direkt zu der letzten Episode springen kann und mich nicht erst durch 1000 DIRS kämpfen muss Thxxxx Hopps |
redlove
#72
erstellt: 21. Aug 2009, 10:47
sei mir bitte nicht böse, aber was hälst du davon wenn du die Firmware selber testet, und wie ichschon sagte, man kann jede Zeit die Oiginale Fimware zurückflashen!! [Beitrag von redlove am 21. Aug 2009, 10:48 bearbeitet] |
Hoppala2005
#73
erstellt: 21. Aug 2009, 10:57
Hätte ja sein können, dass Du es weisst. Da ich schon öfters Probs beim flashen hatte, lass ich mal die Finger davon. |
redlove
#74
erstellt: 21. Aug 2009, 11:00
welche Probleme hattest du denn beim flashen? |
Hoppala2005
#75
erstellt: 21. Aug 2009, 11:06
Hat leider mittendrinne aufgehört. Habe da schon Blut und Wasser geschwitzt, habs dann aber doch noch hinbekommen. Naja, ich lese mich mal weiter um |
redlove
#76
erstellt: 21. Aug 2009, 11:15
ich persönlich hatte bis kein Problem beim flashen gehabt, obwohl ich 2 andere Firmware geflaht habe (PlayON HD , und Fantec) |
Hoppala2005
#77
erstellt: 21. Aug 2009, 12:03
Naja, vielleicht bin ich mutig und probiers nachher mal aus, wobei wenn die Option Taste nicht geht, wird das glaub nichts mit dem Lesezeichen, es sei denn die Belegung ist komplett anderster hmmmm. |
redlove
#78
erstellt: 21. Aug 2009, 12:11
Probier es einfach aus, es kann wirklick nicht schief gehen!! Die Geräte sind halt hardwaremäßig identisch!!! |
Yogi1965
#79
erstellt: 21. Aug 2009, 12:48
Hallo! Bin ebenfalls Besitzer des Emtec N 200. Meine Frage ist wenn ich die alternative Firmware nehme ist es dann auch möglich jeden x beliebigen Wifi Dongle zu verwenden oder muß es trotzdem der von Emtec sein. |
redlove
#80
erstellt: 21. Aug 2009, 12:54
sorry, kann Dir leider kein Info geben, nutze das Gerät nämlich über LAN |
Yogi1965
#81
erstellt: 21. Aug 2009, 13:02
Hallo Redlove! Kannst du mir vielleicht sagen ob die Harmony Fernbedienung wirklich so gut ist?Kann sie meinen Panasonic Fernseher komplett steuern oder meinen Onkyo Receiver in vollem Umfang.Oder wo kann man es nachlesen.Möchte nämlich nicht das ich nur eingeschräkte Funktionen mit ihr habe. Für eine Antwort wäre ich dir sehr dankbar. |
redlove
#82
erstellt: 21. Aug 2009, 13:11
Zitat von Harmony:
Hoppala2005
#83
erstellt: 21. Aug 2009, 13:59
Dein Wort in Emtecs Ohren :). Ich teste beruflich nebenbei Software und das Problem ist, das sämtliche Bugs immer bei mir auftauchen... bin mal gespannt, wann die Programmierer ein Anti Hopps eröffnen ..egal ob bei Spiele oder Anwendungssoft, die Fehler kommen als erstes zu mir Naja, ich probiers nachher mal aus. Die Fernbedienung klingt intressant... meine Rapsody wollte von heute auf morgen nicht mehr, ich muss ca. 1 Meter vor dem Gerät stehen, nur dann gehts, ganz seltsam.. auch ein Fall für "Akte X", aber wenn das TEil so gut ist, sollte ich mal schauen woher ich die kriege |
Hoppala2005
#84
erstellt: 21. Aug 2009, 15:33
Hiho ! Habe die Fantec mal installiert, gefällt mir von der Übersicht besser und das "Standby" funktioniert, nur leider schaltet die USB HD nicht ab, solang das Gerät im Standby Modus sich befindet, an der Seite kann ich das Gerät auch nicht komplett ausschalten, erst wenn ich die HD abziehe, schaltet das Gerät ganz aus. Die Searchfunktion reagiert ebensowenig wie die Optionstaste beim Filmablauf. Stoppe ich den Film, habe ich die Optionstaste, kann aber kein Lesezeichen setzen...hm würde gerne mal wissen wie das bei der Fantec Version sonst möglich ist. Die Pause Taste funktioniert bei mir übrigens auch nicht, also kann den Film nicht pausieren, nur stoppen. Sooo, dass war meine erste Erfahrung ![]() EDIT: Andere Firmware auch getestet.... gleiche Probleme wie oben ((gefiel mir allerdings noch en Tick besser)), aber hinzu kam, dass ich das Gerät gar nicht komplett ausstellen konnte, sondern es nur im Standbymodus blieb. Bei Fantec musste man den ein/ausschalter ein paar Sekunden gedrückt halten. Fazit: Extrem schade, hätte gerne einer der beiden anderen Firmwares benutzt. [Beitrag von Hoppala2005 am 21. Aug 2009, 15:58 bearbeitet] |
redlove
#85
erstellt: 21. Aug 2009, 16:35
Die Firmware von PlayON! HD gefällt mir auch am besten. Wie ich oben erwähnt habe, soll diese Woche noch eine neue Firmware geben, und da sind noch ein paar Bugs gefixt + natürlich DTS unterstützung, worauf ich viel Wert lege!!! |
Hoppala2005
#86
erstellt: 21. Aug 2009, 16:39
Wenn die Pause/Search Taste funktionieren und auch die Lesezeichen, würde ich sofort umsteigen. Kannst Du mir mal bitte einen Link zu der Fernbedienung schicken, denn irgendwie fand ich mehrere, aber nicht die, welche abgebildet ist, oder habe ich da was falsch verstanden und es handelt sich gar nicht um einen AllinOne Fernbedienung ? Thxxx |
redlove
#87
erstellt: 21. Aug 2009, 16:45
die FB die da abgebildet ist die originale FB von PlayON! HD , du kannst aber eine Harmony nehmen http://images.google...ie=UTF-8&sa=N&tab=wi [Beitrag von redlove am 21. Aug 2009, 16:45 bearbeitet] |
Hoppala2005
#88
erstellt: 21. Aug 2009, 17:01
Ahh deswegen.. und ich habe gesucht und gesucht Okay, dann weiss ich bescheid ! Danke |
TecBoy
#89
erstellt: 21. Aug 2009, 20:22
Also ohne die Harmony Fernbedienung sollte man das wohl sein lassen ??? Ich hoffe doch das EMTEC hier bald nachlegt und ne vernüftige Firmware präsentiert. Aber was mir zu dem ganzen Treiben hier so duch den kopf geht is das es hier fast das gleiche ist wie mit den Digital Recivern da haben sich auch gute Programmierer dran gemacht und haben bei verschiedenen Receivern eine besser Firmware geschrieben als das original....villeicht ist das hier ja auch möglich... Bis dahin warte ich mal was EMTEC so ins Netz schmeißt als Update. |
Hoppala2005
#90
erstellt: 21. Aug 2009, 20:53
Wie geschrieben funktionieren die Pause/Option/Search Tasten nicht und wenn Du externe HDs anschliesst (wie ich die Western Digital), welche automatisch ausgehen, aber in diesem Falle nicht... naja, dann würd ich eher davon abraten und hoffen, dass Emtec noch eine gescheite Firmware aus dem Hut zaubert. |
FTW
#91
erstellt: 23. Aug 2009, 12:46
Hallo Zusammen, ich hab den N200 seit Vorgestern und ich komme damit NULL zurecht. Erstmal hatte ich Probleme freigegebene Laufwerke sichtbar zu machen. Hatte da etwas Probleme mit dem Windows 7 Freigaben. Klappt auch noch nicht so richtig, aber manches kann ich jetzt auswählen über den N200. Allerdings habe ich mir der Quali erheblich Probleme: Ein Video (xvid) sieht über einen USB echt gut aus, über das Netz aber grausam. Ich bekomme auch nicht alle Dateien angezeigt (keine MKV, ISO). Bin ratlos ... Danke schonmal für Ideen, Frank |
Yogi1965
#92
erstellt: 23. Aug 2009, 17:03
Hallo! Habe nach langen Suche den Dongle gefunden. Er ist hier zu bestellen. http://www2.computer...=30000854&home=false |
TecBoy
#93
erstellt: 23. Aug 2009, 17:08
Hay ! Wollte mal von euch hören welche Logitech Harmony ihr so verwendet .... die Preise sind ja schon extrem bei den Teilen |
redlove
#94
erstellt: 23. Aug 2009, 17:22
@ Frank Mit Windows 7 hatte ich auch Probleme gehabt!!! - welche Firmware hast du drauf?? @TecBoy hab die 555 in Betrieb, sehr zu empfehlen!! |
Shockwave71
#95
erstellt: 23. Aug 2009, 19:07
Logitech 885. Bin sehr zufrieden und mit 90 TEUROS auch bezahlbar.... |
Hoppala2005
#96
erstellt: 23. Aug 2009, 19:10
Habe mir die 515 mal bestellt für 40 Euro.. bin ich ehrlich ein bissl zu geizig für.. habe sie auch nur genommen, weil sie meine Rapsody Fernbedienung ersetzen soll |
FTW
#97
erstellt: 23. Aug 2009, 20:38
@ redlove danke schon mal fürs reagieren, bist auf Zack! Ich hab die 7.1.1 r1048 ... also die von weiter oben im Board. Kann es an den 100 MBit Leitung liegen? Oder am Switch? Oder an meinem Rechner (der ist recht lahm)? Grüße, Frank |
Shockwave71
#98
erstellt: 24. Aug 2009, 15:16
@FTW: Sei froh, bei mir läuft LAN überhaupt nicht. Hab eben alles über USB und da funktionierts super. Hatte es kurz als UPNP, aber da ruckeln HD Dateien fürchterlich......(LAN und WLAN). Wie es bei N Draft is, weiss ich nicht...... |
TecBoy
#99
erstellt: 24. Aug 2009, 17:19
Also Leute, wenn alles richtig eingestellt ist geht das Netzwerk 1a !!! Ich selbst nutze die Kiste im Netzwerk. Ist bei mir am DSL-Router abgeschlossen mit eingerichtetem Heimnetzwerk unter Windows XP Pro. |
Shockwave71
#100
erstellt: 24. Aug 2009, 19:08
@TECBOY: Sag mal, fragt der Player dich beim anwählen deines Rechners auch nach nem Benutzer/Passwort und bei den freigegebenen Ordnern nochmal???? Habe XP Home, auffen Rechner komm ich mit Gast, bei den Ordnern willer noch ne Anmeldung und da scheitere ich jedesmal. Hab schon alles durch........ |
Hoppala2005
#101
erstellt: 24. Aug 2009, 19:12
Bin zwar nicht Tecboy, aber bei mir will er kein Benutzer/Passwort. Habe bei Zonealarm die IP des Players eingetragen und danach hatte ich keine Probs mehr gehabt. Habe Emtec die 192.168.1.21 / 255.255.255.0 zugeteilt. Ansonsten läuft alles übern Router bei mir. |
Emtec n200 Netzwerkknofiguration Tater am 08.01.2010 – Letzte Antwort am 09.01.2010 – 4 Beiträge |
Emtec V120H, N200 jörg-525-touring am 13.06.2010 – Letzte Antwort am 16.06.2010 – 2 Beiträge |
Netzwerkanbindung EMTEC N200 Shockwave71 am 22.08.2009 – Letzte Antwort am 19.10.2009 – 12 Beiträge |
EMTEC N200 versteht Video-Format nicht agerer am 26.06.2010 – Letzte Antwort am 16.10.2010 – 5 Beiträge |
Emtec N200 Fehler: spielt max. 2 GB wgm am 09.08.2009 – Letzte Antwort am 12.08.2009 – 3 Beiträge |
Emtec Moviecube N200 - Wiedergabeprobleme mit HD-Videos k0lgrim am 16.12.2012 – Letzte Antwort am 18.08.2013 – 3 Beiträge |
s: USB (oder auch SD/MMC/MS) rein, HDMI raus intrcptr am 09.10.2008 – Letzte Antwort am 09.10.2008 – 2 Beiträge |
Emtec Multimediaplayer N200 mit Wlan Problemen StupidWhiteMan am 31.10.2009 – Letzte Antwort am 17.12.2009 – 10 Beiträge |
Emtec N200: Daten der Mediathek hinzufügen p0werbauer am 09.01.2010 – Letzte Antwort am 10.01.2010 – 2 Beiträge |
EMTEC N200 im Netzwerk nicht sichtbar? Shockwave71 am 15.08.2009 – Letzte Antwort am 17.08.2009 – 2 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Registrierte Mitglieder930.688 ( Heute: 6 )
- Neuestes Mitgliedmaggiekauper70
- Gesamtzahl an Beiträgen21.827.693
