Gehe zu Seite: |vorherige| Erste . 8 9 10 11 12 13 14 15 16 17 . 20 . Letzte |nächste|
A956 und A789 - Einstellungs Thread
Blackburn4717537
#551 erstellt: 14. Dez 2008, 12:47
Es gibt übrigens neue kalibrierte Einstellungen für den A786/A789.
Dank geht an mparter aus dem AVForums für seine tolle Arbeit!
Ich würde euch empfehlen erstere zu benutzen.
I was using my previously posted settings for SkyHD which is connected via HDMI but is locked at an HDMI Black Level of Normal so I recalibrated for this setting by using the PS3 again but setting the HDMI Black Level to Normal.
Below are the settings I've come to which are quite close to the standard also. So these settings are ideal if you have the HDMI Black Level setting set to Normal, the other settings I posted (on page 64) are based upon an HDMI Black Level of Low.
Picture Settings
Mode: Movie
Backlight: 6
Contrast: 95
Brightness: 39
Sharpness: 20 (personal preference this one)
Colour: 46
Tint: 49/51
Detailed Settings
Black Adjust: Off
Dynamic Contrast: Off
Gamma: -1
Colour Space
Red: 49/10/0
Green: 29/50/16
Blue: 8/3/55
Yellow: 45/53/17
Cyan: 41/45/51
Magenta: 46/18/44
White Balance: 21/25/22/27/25/14
Flesh Tone: 0
Edge Enhancement: Off
xvYCC: Off
Picture Options
Colour Tone: Warm2
Digital NR: Off
DNIe: Off
HDMI Black Level: Normal
Smart LED: On
Setup
Energy Saving: Off
OK, here goes, the settings.
Picture Settings
Mode: Movie
Backlight: 5
Contrast: 95
Brightness: 49
Colour: 48
Tint: 48/52
Detailed Settings
Black Adjust: Off
Gamma: 0
Colour Space
Red: 41/11/0
Green: 29/50/16
Blue: 8/3/55
Yellow: 45/53/17
Cyan: 41/45/51
Magenta: 46/18/44
White Balance: 23/25/23/24/25/12
Flesh Tone: 0
xvYCC: Off
Picture Options
Colour Tone: Warm2
Digital NR: Off
DNIe: Off
HDMI Black Level: Low (if available)
Smart LED: On
Setup
Energy Saving: Off
I think that's it, if I've missed anything then let me know. I've deliberately missed a few things out because these are down to personal preference, e.g. 100MHz, Size, etc
http://www.avforums.com/forums/8294677-post937.html
http://www.avforums.com/forums/8300367-post953.html
http://www.avforums.com/forums/8300455-post954.html
http://www.avforums.com/forums/8318155-post998.html
http://www.avforums.com/forums/8323825-post1015.html
[Beitrag von Blackburn4717537 am 14. Dez 2008, 12:48 bearbeitet]
oenson
#552 erstellt: 14. Dez 2008, 13:13
Blackburn4717537 schrieb:
Anleitung für A789 (großes Lob nochmal an pureffm für seine Arbeit!)
Achtung: Alle Änderungen und das Betreten des Service Menüs geschehen auf eigene Gefahr. Ich übernehme KEINE Verantwortung für irgendwelche Schäden! Desweiteren verliert man allein durch das Betreten des Service Menüs die Garantie...
Vorwort:
Ihr bewegt euch im Service Menü nur mit den Pfeiltasten oben und unten. Drückt NIEMALS die Pfeiltasten links oder rechts, es sei denn es steht in der Anleitung.
Die Ok-Taste bewirkt, dass man ein Untermenü betritt und mit der Menü-Taste kann man das Untermenü wieder verlassen.
1.) TV auf HDMI1 umschalten
2.) TV in Standby Modus versetzen
3.) 10 sek. warten
4.) Nacheinander schnell auf der Fernbedienung Info -> Menü -> Mute -> Power drücken. Ihr solltet nun das Service Menü sehen und Option Table(Service) ist gelb markiert.
5.) Drückt einmal die Ok-Taste.
Ihr seht nun das Option Table(Service) Untermenü und Factory Reset ist gelb markiert (ACHTUNG: NIEMALS FACTORY RESET MIT OK-TASTE ODER LINKER ODER RECHTER PFEILTASTE BETRETEN. Siehe auch Vorwort
6.) Notiert euch die Einstellungen. Am besten macht ihr ein Foto davon. Wenn ihr euch die Einstellungen nicht notiert, habt ihr keine Chance sie wieder auf die Werkseinstellungen zurückzusetzen.
7.) Drückt jetzt solange die Pfeiltaste oben oder unten, bis Gamma auf der rechten Seite gelb markiert ist.
8.) Wenn Gamma markiert ist, drückt ihr solange die linke Pfeiltaste bis Gamma auf Off steht.
9.) Drückt jetzt einmal die Menü Taste.
Ihr seid wieder im Hauptmenü und Option Table(Service) ist gelb markiert.
10.) Drückt jetzt einmal Pfeiltaste unten und WB Adjust ist gelb markiert.
11.) Einmal Ok Taste drücken.
Ihr seid im WB Adjust Untermenü und Calibration ist gelb markiert.
12.) Drückt jetzt 3mal Pfeiltaste unten bis Movie WB gelb markiert ist und drückt ok.
13.) Macht euch ein Foto von dem WB Movie Untermenü und vergewissert euch das W/B MOVIE auf Off steht.
14.) Verlasst das Menü mit der Menü Taste.
15.) Geht nun auf White Balance und drückt ok.
16.) Notiert euch die Werte.
17.) Gebt nun die folgenden Werte mit den Pfeiltasten ein.
Sub Bright: 128
Red Offset: 126
Green Offset: 128
Blue Offset: 122
Sub Contrast: 128
Red Gain: 146
Green Gain: 128
Blue Gain: 148
18.) Wenn fertig, Menü Taste drücken.
19.) Movie WB Untermenü betreten
20.) W/B MOVIE ist gelb markiert und auf Off. Dies ändert ihr in dem ihr einmal die rechte Pfeiltaste drückt.
W/B MOVIE ist auf On und das Bild sollte etwas dunkler sein.
21.) Menü Taste drücken und White Balance Menü betreten.
22.) Foto machen.
23.) Menü Taste drücken und wieder Movie WB Untermenü betreten und ein Foto machen.
24.) Navigiert nun mit den Pfeiltasten oben oder unten zu Mov. Gamma, welches auf M3 (anscheinend steht hier bei manchen schon Off; wenn dies der Fall sein sollte, dann könnt ihr diesen Schritt überspringen) stehen sollte. Dies ändert ihr indem ihr die Pfeiltaste rechts solange drückt, bis Mov. Gamma auf Off steht.
25.) Geht nun zu Warm2 R Gain, Warm2 B Gain, Warm2 R Offs und Warm2 B Offs.
Ändert diese Werte wie folgt um (mit den Pfeiltasten links und rechts):
Warm2 R Gain: 165
Warm2 B Gain: 42
Warm2 R Offs: 126
Warm2 B Offs: 127
26.) W/B MOVIE wieder auf Off stellen.
27.) Menü Taste drücken.
28.) Menü Taste drücken.
29.) TV mit Power Taste ausschalten.
30.) 10 Sek. warten und dann TV normal einschalten
31.) Nun für jeden Bildmmodus im normalen Menü die Reset Funktion betätigen.
.) Die folgenden Werte in das normale Menü übernehmen:
Film Modus
Hintergrundbeleuchtung: 5-8 (je nach Lichtverhältnissen)
Helligkeit: 43 (42 bis 45, je nach Film anpassen, da der Schwarzwert auf Grund von Local Dimming mit dem Bildmaterial schwankt)
Kontrast: 88 bis 93
- 88 ergibt einen gamma von 2,20
- 90 ergibt einen Gamma von 2,25
- 93 ergibt einen Gamma von 2,40
Farbe: 60 (ist bei mir standardmässig so aber die A789 Modellen haben 50)
Gamma: 0
HD Farbraum (geeignet für Kontrast=92):
R 50/0/6
G 35/62/17
B 0/10/50
Y 50/50/22
C 37/55/45
M 53/9/47
Hi Leute,
Ich bin seit kurzem Besitzer des 46A956 und wollt nun nach Blackburn's anleitung im Service Menu mein Gerät kalibieren.
Nun habe ich aber festgestellt, dass mein SM total anders aussieht.
Vermutlich habe ich eine neue Software version. Kann mir jemand helfen die Einstellungen wie sie Blackburn beschrieben hat bei meinem SM einzugeben? Vielleicht hat ja von euch auch schon jemand dies getan?
Vielen Dank für eure Hilfe
oenson
nils^
#553 erstellt: 14. Dez 2008, 14:03
Pureffm hat auch ne Anleitung gepostet für den 956. Nach der musst du gehen, die 786/789 haben das alte Service Menü, deswegen ists anders.
Filesharer
#554 erstellt: 15. Dez 2008, 09:18
Schönen guten Morgen!!!
Ich bin seit einigen Tagen auch stolzer Besitzer eines
46A786. Habe mich hier in diesem Thread schon gut vorran
gelesen. Nun kommen dann so einige Fragen auf, die ich mir
selber leider nicht beantworten kann.
Was heißt "unter WB Movie" ????
Benutze das TV momentan nur an einer Dream 7000S über Scart,
bringen mir die Parametereinstellungen aus diesem Thread auch
etwas, wenn ich noch kein Gerät habe, dass das Signal per
HDMI einspielt???? Bin da noch auf der Suche nach einem
gescheiten HD-Receiver.(Habe Sat-Anschluss, kein Kabel)
Nochwas, wie bekomme ich meinen Firmwarestand von dem TV
raus????? Tastenkombi???
Fällt mir gerade noch etwas ein, was für eine Antenne brauche ich für den Empfang von DVB-T????
Der Antennenanschluss sieht aus wie ein "normaler alte"
TV Buchse. Dachte immmer bis jetzt DVB-T wird über F-Stecker
an das TV angeschlossen???
[Beitrag von Filesharer am 15. Dez 2008, 14:02 bearbeitet]
MB993
#555 erstellt: 15. Dez 2008, 19:48
Hallo, ich habe einen Tip für lion.king (für alle anderen natürlich auch). Da auch ich über einen Kabelanbieter (primacom, Digitalpaket) meine Bilder eingespeist bekomme, nutze ich den HDTV-Receiver Technisat Digit HD8-C. Dieser ist per HDMI-Kabel (mitgeliefert) mit meinem 789 verbunden (HDMI-In 1). Das Fernsehbild ist top! Zusätzlich verfügt der Receiver über einen Conax-Karteneinschub, den ich für meine verschlüsselte primacom-Karte brauche. Und ein Kartenslot für den Kameraspeicher ist auch dabei. Ebenfalls gibt es zwei CI-Schächte für pay-TV. Kläre jedoch vorher ab, ob premiere damit läuft (habe ich nicht). Insgesamt kann ich den Receiver aber wärmstens für Kabelgucker empfehlen. Der Preis 249EUR (Händler vor Ort) ist perfekt umgesetzt.
MB993
lion.king
#556 erstellt: 15. Dez 2008, 21:29
MB993
Vielen Dank für deinen Hinweis, da Ich abba Premiere habe, bin ich jetzt auf den Humax PC1000 gekommen, da er ja direkt von Premiere lizensiert ist. Kann Ihn mir morgen von der Post abholen und dann bin ich schlauer, ob bessere Bilder damit entstehen, vor allem beim Fußball...!!!
Nun abba mal ne Frage für Alle, also der Schwarzwert ist wirklich ne Wucht, habe aber bei manchen Sendungen, das alles schwarz dargestellt wird (vom Sakko bis zur Hose als Bsp.) und man gar keine Details mehr mitbekommt. Gibt es eine Einstellungsmöglichkeit, wenn ja welche dieses zu ändern?!? PS: Abba bitte ohne in das Service-Menue eingreifen zu müssen... Vielen Dank im Voraus an Alle! Lg Majo
jpunkt
#557 erstellt: 16. Dez 2008, 09:26
@Filesharer
Der DVB-T Tuner hat einen ganz normalen Antenneneingang, koaxial 75 Ohm. Bei meinem 956er ist es ein Kombi Tuner (analog / DVB-T), der über die gleiche Antenneneinspeisung versorgt wird, also entweder kannst du Analoges TV oder DVB-T schauen.
Zur Antenne.
Je nach Wohnlage benötigst du mindestens eine Zimmerantenne. Wenn dein Sendeturm für Digitales Terestrisches Fernsehen etwas weiter weg steht, ev. eine aktive Zimmerantenne und wenn du weiter weg wohnst gar eine Aussenantenne.
Zu finden im gut sortierten Elektrohandel, MMarkt und Co. so ab 10,- € aufwärts.
F-Stecker werden hauptsächlich im Sat-Bereich eingesetzt.
MB993
#558 erstellt: 16. Dez 2008, 16:49
Hallo lion.king; meinst Du den Humax PR-HD 1000 C? Den habe ich im MM mit dem Technisat Digit HD8-C ausgiebig verglichen. Richtigerweise ist ersterer für Premiere lizensiert. Aber Menüführung (wichtig), Umschaltzeiten (wichtiger) und Bildqualität (am wichtigsten) sprachen für mich eindeutig für den Technisat. Ich bin schon auf Deine Erfahrungen mit dem Humax gespannt.
mb993
h8
#559 erstellt: 16. Dez 2008, 20:20
hey yo,
ich habe mir auch vor kurzem einen 40er Samsung a786 gegönnt und direkt die Einstellungen von pureffm übernommen. Dickes THX!
Nur habe ich da jetzt eine Frage. Was muss ich einstellen, damit ich wieder DNIe nutzen kann? Also DNIe ist jetzt ausgegraut. Wäre echt nett wenn mir das mal einer sagen könnte.
MFG
R-O-C
#560 erstellt: 17. Dez 2008, 17:30
Hallo ist jemand hier im Forum mal so liebt und postet einstellungen für HDTV(Blu Ray PS3)?
Mein Daddy hat auch nun nen 46"956
Hab ihn mir kurz angeschaut und war positiv angetan,zwar sind die Einstellungsmöglichkeiten nicht so viel wie bei meinem Pioneer Plasma aber Pal sah schon verdammt gut aus und son Kommentar von nem Pioneer Besitzer
Es wäre nett wenn jemand gute Einstellungen hat muss aber nicht unbedingt penibel 6500k eingehalten werden da meist nicht komplett abgedunkelt geschaut wird.
Bei 6500k ist es bei tageslicht ziemlich flau
Filesharer
#561 erstellt: 17. Dez 2008, 18:57
@jpukt Danke für den Tip, wieder etwas schlauer.
Aber ich habe da noch eine Frage bzw. bräuchte da mal nen
"heißen" Tip.
Schaue ja momentan über Scart mit Dream 7000S TV. Finde das
Bild so wirklich nicht so prall. Was könnt Ihr da so für
Grundeinstellungen, ohne im Service Menü etwas zu verstellen??
Wenn ich mir eine Dream 800er kaufen würde und dann über Hdmi
gehen würde, würde das Bild dann schon besser sein, oder liegt
das generell an dem PAL-Bild?????
Phoenix175
#562 erstellt: 17. Dez 2008, 22:02
Picture Settings
Mode: Movie
Backlight: 6
Contrast: 95
Brightness: 39
Colour: 46
Tint: 49/51
Detailed Settings
Black Adjust: Off
Gamma: -1
Colour Space
Red: 49/10/0
Green: 29/50/16
Blue: 8/3/55
Yellow: 45/53/17
Cyan: 41/45/51
Magenta: 46/18/44
Flesh Tone: 0
xvYCC: Off
Picture Options
Colour Tone: Warm2
Digital NR: Off
DNIe: Off
Smart LED: On
Setup
Energy Saving: Off
Hey Black,
haste die Einstellungen auch übernommen?! Und wenn ja, was kannste dazu sagen, sind die wirklich gut?! Mir macht die geringe Helligkeit und der Gamma - 1 Wert etwas Sorgen (ohne sie jetzt ausprobiert zu haben).
Habe die Einstellungen von pure von der ersten Seite, bei der er einen A789 kalibriert hatte und da schon fast perferkte Werte erziehlt hatte...
Ich denke, ich werde sie bei gelegenheit mal ausprobieren...
ANDYx1975
#563 erstellt: 17. Dez 2008, 22:09
h8 schrieb:
hey yo,
MFG
Wenn du die Einstellungen genau übernommen hast, befindest du dich im Kino Modus. Da gibts kein DNIe. Mussu z.B. in Dynamisch wechseln. Dann sind die Einstellungen aber unbrauchbar.
Phoenix175
#564 erstellt: 17. Dez 2008, 22:38
Habe die Einstellungen eben übernommen und muss sagen, das die Werte irgendwie sehr gelblastig sind, oder es kommt mir nur so vor, weil ich vorher zu viel rot drin hatte, was ich kaum glaube, da pure ja fotos von seiner Kalibrierung gemacht hat...
Die größte Änderung wurde sichtbart, als ich den Weißabgleich angepasst habe, den ersten Wert von 25 auf 21...
Deswegen hab ich den Wert jetzt auf 23 stehen und Gamma auf 0 gesetzt und muss sagen, dass das Bild sehr gut ist.
Ob es allerdings besser ist als meine vorigen kann ich nicht sagen, hab mich schon so an sie gewöhnt...
Das Bild scheint aber farbneutraler zu sein
[Beitrag von Phoenix175 am 17. Dez 2008, 22:41 bearbeitet]
Blackburn4717537
#565 erstellt: 17. Dez 2008, 22:48
Ich finde die Einstellungen von mparter ausgezeichnet. Allerdings werde ich mir jetzt auch ein Kalibriergerät bestellen und mich mit der Materie beschäftigen.
Phoenix175
#566 erstellt: 17. Dez 2008, 23:33
Habe eben ein paar BluRays probeweise angeschaut und muss echt sagen, dass das Bild sehr Farbneutral ist und ich vorher wohl einen zu großen Rotanteil drin gehabt haben muss...
Haben den ersten Wert vom Weißabgleich nun auf 22 reduziert und Gamma 0 beibehalten, da mir sonst zu viele Details im Dunklen verloren gehen.
Ich bin auch schon am überlegen, mir mal so ein Gerät zu kaufen, weil durch das ganze Gerede wird man ganz wuschig und will es selber mal ausprobieren
Ich hoffe, du optimierst die Werte noch weiter, so, das wir bald das Optimum aus diesem Gerät geholt haben
Alezan
#567 erstellt: 18. Dez 2008, 10:49
Bei mir liegt schon alles parat (Kalibriergerät und Bluray mit Testpattern), einzig die Zeit fehlt mir bisher. Hoffentlich komme ich über die Feiertage endlich mal dazu, die Kalibrierung durchzuführen. Ansonsten finde ich die Werte von Blackburn auch nicht schlecht; Gamma auf 0 werde ich aber auch noch mal versuchen.
Phoenix175
#568 erstellt: 18. Dez 2008, 17:28
Wo ich das grad so lese und auch von Black....
Sacht ma Jungs, kann man wirklich "ma eben so" kalibrieren?! Also wenn ich mir vorstelle, das der Samsung jede Farbe einzeln in 3 Unterfarben aufteilt, dazu noch den Weißabgleich, die Farbintensität, ... zur Kalibrierung anbietet, ist es da einem Ungeübten überhaupt möglich, ein optimales Ergebnis zu erlangen?!
Und was mich interessieren würde, ob mal jemand die selben Bilder wie pure im 1. Post online stellen könnte, nur eben mit den Werten von mparter
Blackburn4717537
#569 erstellt: 18. Dez 2008, 18:11
http://www.avforums....0-series-led-24.html
http://www.avforums....0-series-led-26.html
http://www.avforums....es-led-part-2-a.html
http://www.avforums....-led-part-2-a-2.html
http://www.avforums....-led-part-2-a-3.html
Du musst in die Anhänge gucken. Da sind alle Ergebnisse drin.
Und Kalibrieren geht nicht mal ebenso. Man muss viel Zeit und Geduld mitbringen. 100% bestätigen kann ich das nicht, weil ich es noch nicht gemacht habe, aber jeder, der schonmal kalibriert hat, sagt das.
aven00
#570 erstellt: 18. Dez 2008, 18:48
Hi an alle :
Mensch also ich war ja jetzt dicht davor mir den z4500 zu kaufen(sony) da ich das dunkle bild des samsungs 956 bemängelt habe (is ja durch die led nen bisschen bedingt) aber es meinten ja viele das das zu hause nichmehr auffällt.Naja also was soll ich erzählen war heute nochmal in nem andern blödmarkt wo sie eben auch alle samsungs +sonys hatten (das besondere , der markt hatte was ich ziemlich gut fand eine eigene abteilung für fernseher die extrem dunkel war , also keine leuchten oder so alles ziemlich duster ) und ich fand natürlich wieder mal das bild nen bisschen zu dunkel aber hab dann bei dem teil mal wirklich fast alles verstellt und siehe da er wurde heller (auch mit led an).Ich hab das hintergrund licht auf maximum gestellt=10 (war vorher 4or5) ,gut vielleicht werden hier einige jetzt sagen damit versaust dus dir doch das schöne bild aber ich fand das bild dadurch viel besser .Mit der Helligkeit hab ichs auch mal probiert aber dadurch wird das bild schlechter, meiner meinung nach .
Ach ja und im bildmodus "dynamsisch" wird das bild auch gleich nochmal heller und wärmer ohne dabei den kontrast oder schwarzwert zu tangieren.
Mensch also jetzt bin ich wieder voll auf samsung .
Aber wär trotzdem noch super wenn ihr noch zu meinen einstellungen was sagen könntet, kann ja sein das wenn das hintergrundlicht auf 10 ist das dadurch ein eventuelles "pro" des samsungs nicht mehr zur geltung kommt oder was weiß ich.
K MFG aVen
five_angel
#571 erstellt: 18. Dez 2008, 18:57
Das Pro ist m.E. folgendes:
Vom Bild ahben mir in MM und Co immer nur Plasma gefallen. Das grelle, unnatürlich und vollig überezeichnte Bild von LVD fand ich immer schlecht, habe daher auch lang mit dem Kauf gewartet.
Den Samsung, auch dank der Einstellung hier ganz am Anfang, zeichnet ein sogar noch bessers bild ohne die Anchteile des Plamsa wie hoher TSromverbrauch und Einbernnempfindlichkeit sowie Emfpfindlichkeit beim Transport.
Mit deinen Einstellungen konterkarierst du das. Wäre mir für meine Augen zu anstrengend.
aven00
#572 erstellt: 18. Dez 2008, 19:30
Hmm naja , muss ma sehen was ich da mache , aber ich will halt nicht das es zu dunkel ist (auch wenn ich eigentlich immer nur abends gucke )und ich mir dann immer sorgen machen muss das ich dadurch irgendwas nicht sehe was eigentlich da ist nur durch die dunklere auslage eben doch nicht.(Der satz war jetzt nen bisschen vorschulmäßig aber ich lass ihn mal so )
Alezan
#573 erstellt: 18. Dez 2008, 20:55
Und was mich interessieren würde, ob mal jemand die selben Bilder wie pure im 1. Post online stellen könnte, nur eben mit den Werten von mparter :prost
So mal eben auf die Schnelle geht das nicht. Ich denke mal das man sich schon so 2-3h Zeit nehmen sollte. Eine Anleitung die ich von pureffm empfohlen bekommen habe findet man unter: Link. Wenn man der dort beschriebenen Anleitung folgt entstehen die geposteten Abbildungen automatisch. Wenn ich durch, werde ich die Bilder hochladen.
pRofi1e
#574 erstellt: 19. Dez 2008, 02:46
hi@all
ich hab mal ne frage an euch was bewirkt die einstellung scannig backlight im service menu das steht bei mir auf 7
und hat schon jemand von euch die firmware geuppt ?
bei meinem 789 steht da bei T-PERLDEUC-1014.2
das ist doch die firmware version oder?
ich bin am überlegen ob ich ein firmwareupdate machen soll bloss bin ich mir net sicher ob es was bringt
Lxey
#575 erstellt: 19. Dez 2008, 11:31
Hallo zusammen!
bin nun auch stolzer Besitzer eines LE-40A786 und durfte letzens mal einen Spyder3TV für die Bildkalibrierung ausprobieren. Das Gerät ist mit einer sehr einfachen Kalibriersoftware ausgestattet und kann leider nur Kontrast, Helligkeit, Farbe und Farbton optimieren. Als Zuspieler habe ich einen Dvico Tvix 6500 Media-Player verwendet. Die Werte sind sehr ähnlich zu den Ergebnissen von mparter:
Bildeinstellungen
Modus: Movie
Backlight: 6 (hab ich so eingestellt)
Kontrast: 98
Helligkeit: 41
Schärfe: 20 (Geschmackssache)
Farbe: 48
Tönung: 50/50
Farbraum und Weißabgleich kann ich mit dem Spyder leider nicht modifizieren und habe sie bei den Werkseinstellungen erstmal so belassen.
Die restlichen Einstellungen sind von mparter und pureffm übernommen und waren auch beim Messvorgang so eingestellt:
Black Adjust: Off
Gamma: -1
Flesh Tone: 0
xvYCC: Off
Picture Options
Colour Tone: Warm2
Digital NR: Off
DNIe: Off
Smart LED: On
Setup
Energy Saving: Off
Das Bild mit den Einstellungen wirklich tiefschwarz. Ich bin mir aber nicht sicher, ob nicht einige Details verloren gehen ("black crush"). Kann jemand von Euch vieleicht etwas zu den Ergebnissen des Spyder sagen (von der fehlenden Farbraum-Justage und Weißabgleich mal abgesehen)?
Phoenix175
#576 erstellt: 19. Dez 2008, 12:42
Also langsam hab ich mich an die Farben gewöhnt und sehr glücklich mit dem Einstellungen, nur was mir aufgefallen ist, die Balken oben und unten sind heller geworden, was wohl mit dem Backlight auf 6 und der niedrigeren Helligkeit zusammenhängt.
Daher hab ich jetzt wieder das Backlight auf 5 und die Helligkeit auf 41.
Desweiteren, wenn ich mir so den Post von Lxey durchlese, werd ich immer stutzig, wie man die selben guten Werte haben kann, obwohl pure und mparter komplett unterschiedliche Weißabgleiche haben.
Mal ganz ehrlich, ich sehe nicht, ob ich jetzt ne Farbe von 48 oder 50 hab, oder ob die Tönung von 50/50 auf 51/59 gestellt wurde, auch die Schärfe fällt mir bei 10er Schritten nicht auf. Genauso mit dem Kontrast, sollte er nur um 5-10% verändert werden, ist bei mir fast alles gleich.
Einzig der Weißabgleich bringt schon bei Änderung von +-2 deutliche Veränderung und daher frag ich mich, wie die beiden "optimale" Werte erhalten, obwohl das Bild komplett anders aussieht!
(persönlicher Geschmack ist ja immer das eine, nur hier wurde ja mit Messgeräten gearbeitet)
Lxey
#577 erstellt: 19. Dez 2008, 13:29
@Phoenix:
Tja, dazu kann ich Dir leider nichts sagen. Der Spyder3TV hat mir nach zwei Messdurchgängen die identischen Werte ausgespuckt. Sämtliche Bildparamter des Zuspielers waren dabei auf neutral eingestellt. Ich habe lediglich ein paar geläufige Voreinstellungen (Kino-Modus, LED Smart on, HDMI-Farbraum normal usw.) aus dem Forum vor der Messung am Samsung übernommen. Farbraum und Weißabgleich habe ich nicht angefasst.
Blackburn4717537
#578 erstellt: 19. Dez 2008, 14:48
Laut pureffm darf man für die Greyscale Kalibrierung nicht mehr die bisherigen Testmuster verwenden.
Dies liegt daran, dass der Gamma aufgrund des Local Dimmings mit dem Bildinhalt fluktuiert.
Allerdings gibt es schon passende neue Testmuster:
http://www.burosch.de/shop/shop_content.php?coID=123&
Ihr findet diese ganz unten auf der Seite (,,Contrast Evaluation Test Suite"). Eine Beschreibung, wie das Ganze funktioniert, wird auch mitgeliefert. Für mich klingt das einleuchtend.
Ich habe mir heute das Eye One Display LT bestellt und hoffe, dass es nächste Woche ankommt. Die Test Suite werde ich dann auch bestellen.
Edit:
Man kann also sagen, dass alle bisherigen Messungen, die mit den bisherigen Testmustern ermittelt worden sind, falsch sind.
[Beitrag von Blackburn4717537 am 19. Dez 2008, 14:49 bearbeitet]
ANDYx1975
#579 erstellt: 19. Dez 2008, 15:42
Das ist generell so. Ich muss sagen, ich hatte auch mal die Farbeinstellungen von Pureffm übernommen. Also die Standardwerte, nicht die fürs Service-Menü und naja ich konnte im Vergleich zu Farbraum "Auto" keinen wirklichen Unterschied feststellen.
Der Sammy bietet zwar sehr viele Möglichkeiten, aber wenig Spielraum zur tatsächlichen Verbesserung. Ein Beweis dafür dass der Sammy schon sehr gut eingestellt ist.
Ich bin sowieso der Meinung, dass das Thema Einstellungen zu übertrieben dargestellt wird. Ist wie Autotuning von 200ps auf 203ps.
Aber Helligkeit auf 41 und Backlight auf 5 ist schon recht dunkel. Kommt es da noch nicht zu Black Crush?
Tornhoof
#580 erstellt: 19. Dez 2008, 16:36
Das ist nicht ganz korrekt, die Messungen stimmen für den entsprechenden Backlight level. Ich hab mal mein Spider2 an mehreren Positionen aufgehängt und verschiedene Backlights eingestellt und die je nach Position bleibt die Kurve gleich und je nach Backlight verschiebt sie sich, bleibt aber prinzipiell gleichförmig, bei mir hat sich die Kurve nur leicht geändert. Perfekt gleichförmig dürfte aber wirklich fast unmöglich sein.
Blackburn4717537
#581 erstellt: 19. Dez 2008, 19:43
Hast du dir mal die PDF Datei durchgelesen?
Was meinst du dazu?
Hast du schon oft kalibriert?
vms01
#582 erstellt: 19. Dez 2008, 20:48
Hi, mein 46" 786er ist heute angekommen und ich werde ihn gleich mal austesten ob mir die 46" reichen oder obs ein 55" sein muss...
Zuerst aber noch 2 Fragen:
1.) ich weiß es ist das EU Modell im gegensatz zum 789er. Aber habt ihr auch nur eine Anleitung in English und den Ostsprachen? Oder lag bei Euch zusätzlich noch eine Deutsche Anleitung dabei?
2.) Welche Einstellungen sollte man jetzt verwenden bzw. austetsten (ohne ins Service Menu zu müssen!!! will nicht das die Garantie erlischt). Welche sind zu empfehlen bzw. auf welcher der 13 Seiten stehen die erstmal besten? Hab zwar den ganzen Thread vor einiger Zeit schonmal gelesen, aber das schaff ich heute wohl nimma nochmal.
vielen Dank schonmal.
[Beitrag von vms01 am 19. Dez 2008, 20:51 bearbeitet]
Tornhoof
#583 erstellt: 19. Dez 2008, 21:14
Was meinst du dazu?
Erfahrung beim Kalibrieren primär für Monitore (CRT/LCD) und jetzt 3-4 Versuche für den 789.
Die Ausführungen zu FullScreen Testbildern sind ziemlich sicher korrekt, das wird so auch bei einem Großteil der Guides gesagt.
Ich hab halt meine Zweifel an dessen Aussage zu Constant Backlight, das is imho nur korrekt für Global Dimming und nicht für Local Dimming. Denn genau sein konstanter Grauwert fordert vom Display eine uniforme Beleuchtung die eher für Global Dimming gedacht ist.
Wenn man den Samsung Engineers aus
http://www.iitk.ac.in/asid06/proceedings/papers/TC2_3-C.pdf
glaubt soll ja Local Dimming genau das erreichen, nur der Bereich der "aktiv" ist soll die Lichtstärke erreichen und der Rest schwächer/aus sein.
Daher müßte eigentlich gerade bei Local Dimming Panels, die Window Frames für Graustufen Messungen besser funktionieren als die Full Frames, gerade weil wir dann nicht in Netzteil-Probleme usw laufen und bei normalen Filmszenen (bei denen nicht der komplette Bildschirm > 50% Helligkeit hat), sollte Local Dimming dazu beitragen das wir nie in Beleuchtungsprobleme laufen. Aber um eine genaue Antwort geben zu können müßte man wissen wo die LED Blocks sind wenn die Mitte aktiv ist. Die Formel aus dem Paper oben ist Block abhängig und damit praktisch gesehen alle Annahmen aus dem Burosch Paper nicht zutreffend, den jegliche Art von Gammaverschiebung betrifft nur einen dedizierten Block.
Unabhängig davon:
Ich hab meinen Fernseher auf die Werte von pureffm im Servicemenu eingestellt und die anderen Werte per bluray aus dem avsforum und SpyderII kalibriert.
Die Graustufen sind im Bereich >20% (niedriger ist wohl durch den SpyderII nicht korrekt messbar), der Fehler (deltaE) zwischen 4-8.
Bei den Farben ist der Fehler zwischen 1 (cyan) und 12 (grün).
Damit kann ich ganz gut leben erstmal, mal sehen wie sich die Werte im Laufe der Zeit ändern.
[Beitrag von Tornhoof am 19. Dez 2008, 21:34 bearbeitet]
Nimmnenkeks
#584 erstellt: 20. Dez 2008, 00:18
Hallo zusammen,
mich würde die optimale Kalibrierung auf einem 956er sehr interessieren. Habe einen sehr starken Pink-Stich. Rot knallt überstrahlt und alles was irgendwie rosa ist säuft ins Pink (strahlend) ab.
Der Servicemitarbeiter meinte, das der G red Wert im SM von 168 zu hoch wäre.....
Da es ja jetzt eine neue Firmware gibt, könnte man ja von einem "ziehmlich einheitlichen Stand" ausgehen.Purffms Einstellungen beziehen sich ja auf den "alten Firmwarestand".
Die 786er Einstellungen bringen mich auch nicht weiter, das Bild wird fast unbrauchbar.
Blue2Light
#585 erstellt: 20. Dez 2008, 12:14
Hab nun meinen 786 nach den Einstellungen von Blackburn4717537 eingestellt die er von mparter Übernommen hat aus dem AVForum.
Nur war mir das Bild mit diesen Einstellungen viel zu Dunkel und Gelbstichig.
Darum noch etwas Eingestellt und siehe da Perfekt
Einstellungen von mparter:
Picture Settings
Mode: Movie
Backlight: 6
Contrast: 95
Brightness: 39
Colour: 46
Tint: 49/51
Detailed Settings
Black Adjust: Off
Gamma: -1
Colour Space
Red: 49/10/0
Green: 29/50/16
Blue: 8/3/55
Yellow: 45/53/17
Cyan: 41/45/51
Magenta: 46/18/44
Flesh Tone: 0
xvYCC: Off
Picture Options
Colour Tone: Warm2
Digital NR: Off
DNIe: Off
Smart LED: On
Setup
Energy Saving: Off
Meine Einstellung:
Picture Settings
Mode: Movie
Backlight: 6
Contrast: 95
Brightness: 45 (bei 39 verschwinden viele Details im Dunkeln)
Sharpness: 10 (etwas weniger Schärfe)
Colour: 46
Tint: 49/51
Detailed Settings
Black Adjust: Off
Gamma: 0 (Bild sonst an manchen Stellen zu Dunkel)
Colour Space
Red: 49/10/0
Green: 29/50/16
Blue: 8/3/55
Yellow: 45/53/17
Cyan: 41/45/51
Magenta: 46/18/44
White Balance: 22/25/22/27/25/14 (Leicht Verändert)
Flesh Tone: 0
xvYCC: Off
Picture Options
Colour Tone: Warm1 (Bild wirkt bei Warm 2 zu Gelbstichig)
Digital NR: Off
DNIe: Off
Smart LED: On
Setup
Energy Saving: Medium (Warum auf Aus ?)
Danke nochmal an Blackburn4717537 und mparter
herby84
#586 erstellt: 20. Dez 2008, 13:47
hi welche werte sind jetzt die besten für den 40A786?
gruß herby
vms01
#587 erstellt: 20. Dez 2008, 14:34
gruß herby
genau und noch eine zusätzliche Frage :
2.)wie oben: Welche Einstellungen sollte man jetzt verwenden bzw. austetsten (ohne ins Service Menu zu müssen!!! will nicht das die Garantie erlischt). Welche sind zu empfehlen bzw. auf welcher der 13 Seiten stehen die erstmal besten? Hab zwar den ganzen Thread vor einiger Zeit schonmal gelesen, aber das schaff ich heute wohl nimma nochmal.
Blue2Light
#588 erstellt: 20. Dez 2008, 14:50
@vms01
Ich hab nur eine Anleitung in Deutsch dazu bekommen.
Reicht mir auch, wobei Englisch auch net schlimm gewesen wäre.
Die Beste Einstellung gibt es nicht, weil jeder das Bild anderes Empfindet.
Ich empfehle einfach mal die hier genannten zu Testen und dann zu schaun was einem am Besten gefällt.
highdefinition
#589 erstellt: 21. Dez 2008, 10:32
@Blue2Light: Respekt! Deine Einstellungen sind mit ABSTAND die Besten! Hab ein perfektes Bild über SCART und HDMI!
Bei den bisherigen Einstellungen war immer eine Farbe total extrem dargestellt, was mir den Genuss etwas versaut hatte.
Blackburn4717537
#590 erstellt: 21. Dez 2008, 11:48
Was meinst du dazu?
Unabhängig davon:
Ich habe mir jetzt zusätzlich noch die DVE Video Essentials Basic Blu-Ray bestellt. Ich schätze mal, da man jahrelang die Testmuster verwendet hat, werden die schon nicht so falsch sein.
jim76
#591 erstellt: 21. Dez 2008, 15:19
hi ich habe ein problem, und zwar habe ich ins service menü eingegriffen, das hat auch alles gut geklappt doch nun wollte ich es wider umstellen und siehe da mein usb stick hat seinen geist aufgegeben und alle bilder sind weg...wäre jemand so nett und macht bilder von den original servicemenü einstellungen des LE40A786? Danke schonmal im vorraus
[Beitrag von jim76 am 21. Dez 2008, 15:31 bearbeitet]
marcel1703
#592 erstellt: 21. Dez 2008, 15:52
So leid es mir tut, aber da hast du wohl grosses Pech gehabt.
Für das Service Menü gibt es keine Standard Einstellungen, da diese je nach TV unterschiedlich sind.
Gruss Marcel
jim76
#593 erstellt: 21. Dez 2008, 16:26
hmm aber wenns keine originaleinstellungen gibt wie soll man dann die garantie verlieren? So kann samsung einem ja wohl schlecht nachweisen ins servicemenü eingegriffen zu haben oder irr ich mich da?
beginner17
#594 erstellt: 21. Dez 2008, 16:28
Ich gehe davon aus, dass Samsung ganz genau weiß, was im Lieferzustand im Servicemenü steht und irgendwo gibt es bestimmt noch eine Serviceschnittstelle, wo allerhand ausgelesen werden kann.
Nur eine Vermutung meinerseits.
LE-40F86BD
#595 erstellt: 21. Dez 2008, 16:38
Laß es doch einfach mal darauf ankommen und wende Dich mit Deinem Problem an den Samsung-Service.
Sag denen einfach daß etwas mit dem LCD nicht mehr so ist wie vorher ...
sonictrasher
#596 erstellt: 22. Dez 2008, 13:53
Mit den richtigen Einstellungen sieht das Bild wirklich perfekt aus. Habe noch nie ein so tolles Bild auf nem LCD gesehen.
Mein 46A786 wurde vor 3 Tagen geliefertt und ist seitdem im Dauerbetrieb! Klasse Teil.
2 Fragen dazu habe ich aber noch:
1) Beim Switchen der Sources habe ich ein dunkles Bild mit hellen Wölckchen hier und da. Sobald die Source dann allerdings gfefunden ist, passt wieder alles. Ist das akzeptabnel oder hab ich ein Clouding Exemplar erwischt?!
2) Ich verstehe die Zoom Funktion nicht. Wenn ein TV Sender ein 4:3 Letterboxed Bild überträgt, würde ich es gerne Bildschirmfüllend heranzoomen, so daß der schwarze Rahmen oben, unten, rechts und links verschwindet. Das bekomme ich aber nicht hin. Bei Sony geht das per Knopfdruck.
Wie geht Ihr mit dem 4:3 letterboxed Bild um (also ein fett umrahmtes TV Bild?). Ich kenne Leute, die machen immer das Bild auf breit.... Sowas kommt bei mir nicht in Frage....
Danke schonmal. Wäre schön, wenn Ihr mir hier weiterhelfen könntet.
Jedi_Georg
#597 erstellt: 22. Dez 2008, 20:09
Hallo!
Spiele Digital-Kabel per HDMI zu. Nun gibt´s da Sender, die senden anamorphotisch in 16:9 und andere in 4:3 und wieder andere in 16:9 aber nicht anamorphotisch.
Das eigentliche Problem, das ich nun habe ist, dass man per HDMI zugespielt scheinbar keine automatische Bildformaterkennung einstellen kann!
Wie löst Ihr das Problem? Jedes Mal manuell umstellen ist lästig, vor allem beim Zappen.
nack_de
#598 erstellt: 23. Dez 2008, 11:29
@Sonictrasher:
Ich denke bei deinem Gerät passt alles. Ist bei mir auch. Aber wer schaut schon TV ohne Quelle?
Wenn im normalen Betrieb alles passt ist doch alles OK.
Blackburn4717537
#599 erstellt: 23. Dez 2008, 11:41
Unter welchen Lichtbedingungen sollte man kalibrieren?
In einem komplett dunklem Raum, oder so wie man später dann auch Filme gucken wird?
Filesharer
#600 erstellt: 23. Dez 2008, 11:44
Moin Zusammen!
Mußte nun bei meinem 786er auch diese hochfrequenz-Pfeifen
feststellen, stört allerdings nur in leisen Passagen.
Ist das ein Garantiefehler, würden Die das Gerät austauschen,
oder vor Ort reparieren?
Ist mir am Anfang garnicht aufgefallen, hoffe es wird nicht
lauter!?
Grüße Filesharer
[Beitrag von Filesharer am 23. Dez 2008, 18:51 bearbeitet]
epsongun
#601 erstellt: 23. Dez 2008, 12:07
Deine Tastatur ist defekt, !!! ??????
Bildqualitätsunterschied zwischen A789 und A956
RealSeth am 11.01.2009  –  Letzte Antwort am 11.01.2009  –  2 Beiträge
Der A956 und A789 Owners-Thread- Erfahrungsberichte nur von Besitzern!
GerryTB am 07.10.2008  –  Letzte Antwort am 10.10.2008  –  11 Beiträge
Grantiefrage bezüglich A786, A789 und A956
The_igel am 02.10.2008  –  Letzte Antwort am 06.10.2008  –  10 Beiträge
A 699 Einstellungs Thread
munichguy am 27.01.2009  –  Letzte Antwort am 31.01.2009  –  18 Beiträge
A 656 Einstellungs Thread
CSolero am 13.04.2008  –  Letzte Antwort am 21.01.2013  –  5090 Beiträge
Samsung UE55C8XXX Einstellungs Thread
AxelT am 28.04.2010  –  Letzte Antwort am 03.11.2010  –  63 Beiträge
B650 Einstellungs Thread
Merc85 am 06.04.2009  –  Letzte Antwort am 05.05.2009  –  7 Beiträge
oddone am 28.05.2008  –  Letzte Antwort am 28.05.2008  –  3 Beiträge
LE37A699M Einstellungs Thread
Inventar am 01.12.2008  –  Letzte Antwort am 31.01.2009  –  6 Beiträge
Samsung HU82xx Einstellungs-Thread
0815_User am 09.11.2014  –  Letzte Antwort am 17.11.2014  –  3 Beiträge
  • Registrierte Mitglieder930.545 ( Heute: 4 )
  • Neuestes MitgliedDiscotools
  • Gesamtzahl an Themen1.563.126
  • Gesamtzahl an Beiträgen21.817.196
