HIFI-FORUM » Fernseher & Beamer » Plasma-Fernseher » Panasonic » Der ultimative Panasonic TX-P S10-Kalibrationsthre... | |
Gehe zu Seite: |vorherige| Erste . 10 . 20 . 30 . 40 . 44 45 46 47 48 49 50 51 52 53 . 60 . Letzte |nächste|
Der ultimative Panasonic TX-P S10-Kalibrationsthread+A -A |
hodg100
13:06
#2371
erstellt: 26. Jan 2010, |||||
[quote = "mgb"] G10B has an addition to the multi-tuner Sattuner and another interface to Ethernet. Similar to the hardware of the G15E. What is happening when transferring to G10E no one knows. Apparently there's then only a black screen. The question is therefore Whether the English firmware includes all the advanced settings. The English firmware is so radically different and includes Freesat and Freeview, not DVB-C. [/ quote] Yes it's quite different and that's why I have not changed the 03 to 10 on line 40 so far. We know it can be done as someone posted a video showing it with the eeprom edit blacked out. He definitely did the edit and then restarted followed by factory reset and change of country and region. It's a shame nobody but me believed him and he was Hounded from our forum: cut Maybe I try a factory resest without changing any EEPROM and see what happens in there .. Anyhow, data from a new UK V10 plus UK G15 sent to Marc and Moonwalker. Thanks all for Allowing me to post in this thread S10. I did start my own but only mgb replied ![]() Hodgson [Beitrag von hodg100 am 26. Jan 2010, 13:49 bearbeitet] |
mgb
13:33
#2372
@hodg100 You should check position 6 in line 40 for G15B, X10B and S10B. After that you may get a feeling what could be possible. |
hodg100
13:47
#2373
Hi mgb I haven't got the X10 data yet but so far V10 = 01, G15 = 02, G10 = 03, S10 = 04.... Would be no surprise if X10 was 05 but I am still waiting for that ![]() |
tunixx
14:10
#2374
Mist... habe gerade wie in der "Kalibrierungszusammenfassung" beschrieben die erweiterten Einstellungen freischalten wollen - aber nach dem "... solange Exit gedrückt lassen, bis der TV einen Neustart macht" ist der TV nur schwarz geblieben und hat nicht neu gestartet. Und ich komme auch nicht mehr ins Service Menü - wenn ich in einschalte so leuchtet nur die Betriebsanzeige grün - sons TOTE HOSE. Habe die 46 Zoll Version - und bei mir standen in der besagten Zeile 40 von vorne herein die Werte 19 06 19 00 31 11 02 00. Habe das dann auf 19 06 19 00 31 10 20 geändert.... Scheiße ... NIX geht mehr ....!!! Hat jemand ne IDEE! Oder kann ich mich gleich aus dem Fenster stürzen. Gruß Wolfgang |
Philipp84
14:14
#2375
Da steht doch ausrücklich drin, dass man nur die 11 auf 10 ändern soll und sonst nichts! ![]() Bleibt dir wohl nur der Panasonic-Service wenn echt nichts mehr geht. |
TaBaKMaN
14:20
#2376
Und somit hast du dem TV jetzt eine falsche Bilddiagonale gegeben. Der letzte Wert der Zeile 40 und der erste der Zeile 48 codieren zusammen die Diagonale. Dort ist jetzt der Fehler und eine ungültige Diagonale... Oh man Leute ![]() Nur die den 6. Wert in Zeile 40 von 11 auf 10 setzen, wie beschrieben.. |
tunixx
14:23
#2377
nachdem ich nur den einen Wert von 11 auf 10 verändert hatte waren keine erweiterten Einstellungen zu finden .... hab ca. 20 Minuten alles durchgesucht! Nur deswegen bin ich auf die wahscheinlich BLÖDE Idee gekommen noch den letzten Zahlenwert von 00 auf 20 zu ändern!!! Tja ich such mal wohl besser die Nummer vom PANA-Service in Südbayern. |
TaBaKMaN
14:25
#2378
Das kann nicht sein. Dann hast du wahrscheinlich vergessen mit OK zu speichern. |
blacpain
14:26
#2379
bzw. an den händler als defekt zurücksenden und sich einen neuen (am besten zug um zug) senden lassen. bei tunixx dürfe nun der tv hochfahren ganz kurz anthrazit werden (als würde ein bild kommen) gleich wieder auf totes schwarz wechseln. nach einiger zeit kurz klacken und schlussendlich ganz abschalten und g einen fehlercode anzeigen, indem er 13 rot hintereinander blinkt. |
tunixx
14:36
#2380
@TaBaKMAN ich habe sicher auf OK gedrückt. Danach hat der TV auf wieder gestartet. Im Servicemenü war die Einstellung des 6. Wertes auch auf 10!!! Nur waren nirgends erweiterte Einstellungen. Danach meine fehlerhafte Änderung. Scheiße so ein Mißt ist mir noch nie passiert. Obwohl ich auch bei meinem alten Plasma viel und vor allem vorsichtig probiert habe... Bin da eher ein riesen Angsthase! @blacpain ... stimmt so mach er das ... was meint Ihr ... Der Plasma lief absolut ruhig - kein surren zirpen, summen .... Ihr wisst was ich meine. Absolut perfektes Gerät! Ich glaube ich lasse mir den Techniker kommen. Kann der auf das Servicemenu denn zugreifen und mir die beiden Zahlenwerte zurückstellen. |
AtzeSchröder
14:39
#2381
WO hast Du den danach nach den "erweiterten Einstellungen" gesucht? |
rocahimself
14:50
#2382
Überall, hat er doch gesagt! ![]() ![]() Lass nen Techniker kommen oder melde es direkt als Defekt! |
mgb
14:53
#2383
Der Techniker kann auch auf nichts mehr zugreifen. Du bekommst ein neues Board. Melde dein Gerät einfach als defekt und erzähl nichts von deiner Eeprom Geschichte. |
Fireblade999
14:54
#2384
Hallo, Ich habe die Software 1213 drauf und habe mir das Gamma Menü freigeschaltet mit dem ändern von 11 auf 10. Allerdings bekomme ich beim Selftest eine Fehlermeldung.....stört mich erstmal nicht weiter, allerdings wie verhält es sich wenn ich jetzt auf 1215 updaten will, kann ich dies gefahrlos machen oder soll ich den Wert erst wieder ändern? Bleibt das Gamma Menü erhalten oder muss ich die Änderungen wieder erneut ausführen? Danke [Beitrag von Fireblade999 am 26. Jan 2010, 14:57 bearbeitet] |
AtzeSchröder
14:57
#2385
Hey Fireblade, was für ein Selftest und welche Fehlermeldung wird ausgegeben? Ich hab zuerst das Update ausgeführt dann das Menü freigeschaltet. Wie es aussieht wenn man erst Menü freischaltet und dann updatet kann ich Dir leider nicht sagen, dürfte aber keine Probleme geben. Und wenn das Menü weg ist dann einfach wieder ändern :-D |
Fireblade999
15:04
#2386
Irgendwo hatte Marc den Selftest gepostet, mit Volumetaste und ich glaub dreimal Null oder dreimal i, muss daheim nochmal schauen, bin grad in der Firma. Der Selftest meldet ganz oben "Selftest failed" links wurde alles mit OK angezeigt und rechts stand eine ganze Menge von dem ich absolut keine Ahnung habe :-). Rausgekommen bin aus dem Menü auch nur durch ausschalten des Fernsehers. [Beitrag von Fireblade999 am 26. Jan 2010, 15:07 bearbeitet] |
tunixx
15:04
#2387
So nun weiß ich mehr - allerdings schlechte Nachrichten. Hab mir dem Panasonic Service Süd telefoniert. Platine muss eingeschickt werden da sie als Techniker nicht in Service Menü kommen. Wird dann neu programmiert. Kostet ca. 100 €. Mit dem 13 mal rot blinken wusste er nix anzufangen. Hat ne Fehlerbeschreibung mit 12 mal und 14 mal blinken gehabt. Soll ich beim Händler reklamieren wegen Defekt??? Die werden mir nicht gleich ein Austauschgerät geben - oder? Sondern das Ding einschicken, feststellen dass ich am Servicemenü "geschraubt" habe und mich auch zahlen lassen. Bleibt sich also egal! Was meint Ihr soll ich tun? |
Fireblade999
15:09
#2388
Au das ist bitter,tut mir leid, ich hatte zwei Seiten vorher genau das mit dem Unterschied 20 und 00 gefragt, da ich auch en 46" habe, und mir nicht sicher war. |
tunixx
15:16
#2389
Ich glaube ich melde das Gerät beim Händler wo ich es gekauft habe einfach als defekt. Glaubt Ihr die schicken mir einen Techniker der mir eine neue Platine mitbringt? Hab nämlich keine Lust Tage bzw. Wochen auf den Ferseher zu verzichten. Meiner Frau darf ich das erst gar nicht erzählen ![]() |
mgb
15:27
#2390
@tunixx Garantie bekommst du von Panasonic. Dein Händler kann auch nur den Panasonic Service anfordern. Ruf die Plasma Hotline von Panasonic an, erzähl denen dein Gerät funktioniert nicht mehr und erzähl ja nichts vom Eeprom. |
tunixx
16:22
#2391
Habe soeben mit dem Panasonic Service telefoniert. Habe gesagt das der Plasma nach einschalten kein Bild mehr bringt. Und auch auf die Fernbedienung nicht mehr reagiert. Kurzum. Die nette Dame gab mir eine Auftragsnummer und teilte mir mit dass in ca. 2-3 Tagen ein Techniker die Platine des Gerätes gegen eine neue tauschen wird. Dauert ein paar Minuten. Hoffentlich lesen die die Daten meiner Platine nicht aus und ich muss doch noch zahlen!!! Scheint so als bin ich nochmal mit einem "blauen Auge" davongekommen. Das ist mir eine Lehre ... ich glaube ich lasse in Zukunft die Finger vom Service Menü. Gruß Wolfgang [Beitrag von tunixx am 26. Jan 2010, 16:24 bearbeitet] |
blacpain
16:24
#2392
anrufen - "das gerät funkioniert nicht mehr und du würdest gerne deine garantie in anspruch nehmen" normal würde dein händler auch entsprechend einen panasonic techniker in auftrag geben. |
tunixx
16:29
#2393
hallo blacpain, da waren wir fast zeitgleich... |
MarcWessels
16:31
#2394
Aber ganz wichtig: Du hast das erw. Menu nicht gefunden, weil die Bildeinstellungen zweiseitig sind! Du hättest einfach nur weiter herunterscrollen müssen, dann hättest Du die erw. Einstellungen gesehen! Die einzige Änderung im EEPROM, für die wir quais 100 Prozent Funktionsgarantie geben können, ist die 11 auf die 10 zu ändern. Bitte nichts anderes auf der ersten Seite ändern, keine Zeile und erst Recht keinen einzelnen Wert! Auf der ersten seite des EEPROMS befinden sich sozusagen die grundlegenden Körperfunktionen des S10. [Beitrag von MarcWessels am 26. Jan 2010, 16:34 bearbeitet] |
mgb
16:33
#2395
Und was sollte Panasonic beim auslesen da feststellen? Ein Bit ist gekippt und hat eine Fehlfunktion ausgelöst. Muss wohl ein schadhaftes Eeprom gewesen sein. |
Xale
16:34
#2396
Du weisst aber wo das erweiterte Menü normalerweise zu finden sein sollte, oder? |
MarcWessels
16:35
#2397
In den bislang gefundenen Logs werden ebenfalls keine Zugriffe aufs SM geloggt. |
MarcWessels
16:36
#2398
MarcWessels
16:38
#2399
[Beitrag von MarcWessels am 26. Jan 2010, 16:47 bearbeitet] |
tunixx
16:41
#2400
Hallo Marc, das die Menüs unten weiter gehen können wenn sie "zu lang" sind das wußte ich - vielleicht war ich zu blöd bzw. blind und habs "überlesen". Eigentlich war ich erst beim Optiker und hab ne stärkere Brille bekommen. ![]() Glaub mir falls ich jemals noch "Hand an das Servicemenü anlege" dann ändere ich sicher nur diesen einen Wert von 11 auf 10. Das mit dem Update der Software hat ja auch nach Eurer Anleitung problemlos funktioniert. |
Moonblue
18:00
#2401
@Marc Das würde mich auch mal interessieren,was ist wenn man nach den ganzen Änderungen mal updaten will sollte das gehen oder muss man wieder alles in Urzustand versetzen? Übrigens ich habe auch den Fehler beim Self Check keine Ahnung warum und obs dem Gerät schadet. [Beitrag von Moonblue am 26. Jan 2010, 19:13 bearbeitet] |
rocahimself
18:02
#2402
Wie führt man den Selftest denn durch? ![]() |
AtzeSchröder
18:41
#2403
Das interessiert mich auch ... |
whopper1
19:06
#2404
V- und 1x info, aber vorsicht, bei mir haben sich die Einstellungen im normalen Menue zrückgesetzt, nach neustart kam dann wieder der Staartmanager mit dem zu Hause oder im Laden und deutsch auswählen ond so weiter! Ich hatte alles auf ok auser rechts oben nen Fehler mit einer roten 4 stelligen nummer! |
TaBaKMaN
19:26
#2405
So erstes Update im Zusammenfassungsthread steht. Es betrifft das 2. Byte in Zeile 98, welches auch die Diagonale codiert. Außerdem wurde der Zugang zum Memoryeditor und zu den EEPROMS sowie das Freischalten des erweiterten Menüs mit Bildern anschaulicher gemacht. Gruß |
Fireblade999
19:52
#2406
Also ich hab gerade ein update von 1213 auf 1215 gemacht, ich hatte als Änderung nur den Hotelmodus aktiviert und das Gamma Menü freigeschaltet. Dies ist beides erhalten geblieben und die Kiste läuft noch. In den Selftest kommt man mit V- und info. Aber vorsicht man muss danach die Einstellungen wieder vornehmen, und raus kommt man wohl nur mit Kiste aus und wieder an. Der Selftest ist bei mir nun auch ok. Keine ahnung warum. [Beitrag von Fireblade999 am 26. Jan 2010, 19:58 bearbeitet] |
rocahimself
19:57
#2407
Welche EInstellungen meinst du genau? Die normalen User-Einstellungen in "Bild" und "Setup"? |
Fireblade999
20:01
#2408
Genau, Sprache, Land, Bild usw. |
whopper1
20:03
#2409
Ja die User Settings, die SM Settings sind die gleichen geblieben! |
whopper1
20:57
#2410
Hab jetzt alle Settings einschließlich 2.Byte gesetzt, nach langem hin und her testen sehe ich kaum einen Unterschied zu den Standard Settings be den SM Settings, geht das noch jemandem so? Ich bin sehr empfindlich und merke auch kleinste veränderungen, hier bemerke ich eigentlich nur das der Kino Modus minimal unschärfer ist als Normal und Spiel, allerdings hab ich im User Menue verschiedene settings hergenommen, hab momentan aber bei allen drei Modi in etwa das gleiche Bild und schaue momentan im Normal Modus da etwas schärfer, aber nur ein Hauch! Die rosig rötlichen Gesichter sind immernoch vorhanden, auserdem immernoch diese Maske im Gesicht wenn es etwas weiter weg ist, weiss ned wie man das nennen kann, wirkt plastis und ausgesetzt, das hatte ich beim alten HD Ready Pana nicht, liegt viewleich auch darann das der Full HD viel weiter hochscallieren muss, weil bei SD Sendungen ist es deutlicher! |
snake339
21:48
#2411
Wenn ihr den Selftest ein 2tes Mal macht sollte er gut werden. (zumindest wenn ihr nur das erweiterte Menü habt). So ist es zumindest bei mir! [Beitrag von snake339 am 26. Jan 2010, 22:05 bearbeitet] |
Moonblue
22:02
#2412
Also ich habe alle einstellungen gemacht erweitertes Menü ,Farbraum und die Scaler. Bei mir steht beim Self Test immer Failed. Auch wenn ich die Orginalwerte wieder eingebe,weiss jemand warum das so ist? @ snake39 auch wenn ich es 5mal mache immer links alles Ok und mitte steht failed! [Beitrag von Moonblue am 26. Jan 2010, 22:04 bearbeitet] |
mgb
22:06
#2413
Mach den Selftest zweimal hintereinander. Beim zweiten Mal sollte der Fehler weg sein. |
Moonblue
22:39
#2414
Egal immer das gleiche! |
xtremelover
22:47
#2415
Hier meine Werte: Zeile 80: 01 00 00 AA 00 00 00 0F Zeile 88: 00 0E 01 02 00 01 00 81 Zeile 90: 00 00 02 00 00 00 00 00 Zeile 98: 00 00 00 51 06 33 00 FF 42 Zoll vor kurzem mit 1215 Firmware geliefert! |
fifamania
22:53
#2416
folgendes : ich möchte bald den service anrufen weil mein s10 ziemlich laute geräusche beim tv schauen macht ( das typische surren, nur sehr laut wie ich meine) meine frage ist nun: soll ich mit dem service menu noch warten? wollte den hotelmodus einschalten um HDMI 1 als startkanal festlegen und die erweiterten einstelungen freischalten. ist es "besser" wenn der service mitarbeiter noch einen unveränderten s 10 vorfindet oder kann ich trotzdem schon im service menu was machen? |
Tommy536
22:55
#2417
Ich kann nur jedem empfehlen seinen Bildschirm einzeln zu kalibrieren. Nach ettlichen Testmessungen - mit dem Spyder3 - habe ich ohne SM Menü - aber mit EEPROM Änderungen einen nahezu perfekten RGB Abgleich für 6500K hinbekommen. Meine Werte unterscheiden sich aber gründlich von den bisher geposteten Werten für SM und User Menü. Ich habe keine Farbstiche mehr aber bei manchen Grauwerten minimale Ausschläge bei Rot oder Blau. Ganz exakt habe ich es nicht hinbekommen was auch am Spider liegen mag. Ich habe jedoch die Deinterlacer EEPROM Einstellungen nicht übernommen. Dürfte ja nichts mit der Farbe zu tun haben? Danke aber an alle fleißigen Helfer hier! Ohne euch wäre ich nicht ansatzweise so weit gekommen. Gruß |
TaBaKMaN
23:02
#2418
Was für ein Spyder hast du denn? Pro? Elite? Ich will ehrlich gesagt nich wirklich 200 € ausgeben, nur um meinen Plasma zu kalibrieren ^^ Möchtest du mir deine Messergebnisse nochmal zukommen lassen bzw. sie mal uploaden? Gruß |
Moonblue
23:03
#2419
Es wäre immer hilfreich wenn ihr dazuschreiben würden wieviel Zoll. |
Tommy536
23:39
#2420
Habe den Pro. Aber zum kalibrieren verwende ich HCFR + AVC Forum Test DVD von der PS3 abgespielt. Dazwischen hängt aber noch ein Onkyo 606 wobei der ja nur durchschleust. Die Display Diagonale ist 50 Zoll. Ich werde die Werte demnächst ausführlicher Posten evtl. später noch. Bin mit dem Bild jetzt zufrieden wobei bei Gamma 2.5 das Bild doch relativ dunkel ist. Etwas merkwürdig finde ich den Schwarzwert der sich bei mit zwischen 0.055 und 0.059 bewegt. Ist das nicht zu hoch für nen Plasma? Kommt restlicht zum Sensor? Ist der Spyder für dunkle Bilder nicht so geeignet? Spyder Einstellungen: Messzeit 5 Sekunden + längere Messzeit bei dunklen Bildern. Melde mich wieder. @Tabakman: Du hattest doch auch HCFR Bilder von der Kalibration gepostet. Wie hast du die gemacht bzw. welches Colorimeter hast du benutzt? |
TaBaKMaN
23:43
#2421
Nein, da verwechselst du was ![]() ![]() Aber ich hab mir überlegt, ne Elite bei Amazon zu holen, einmal durchkalibrieren, und ohne Angabe von Gründen zurück ![]() ![]() Ich weiß, bissl Assi, aber wenn ich keins zum Leihen finde, wirds darauf rauslaufen.. ![]() |
Der ultimative TX-P S10 Thread schnutinio am 11.04.2009 – Letzte Antwort am 05.09.2014 – 11566 Beiträge |
Der ultimative TX-P S10 Settings Thread Italia99 am 30.05.2009 – Letzte Antwort am 15.06.2011 – 1633 Beiträge |
DER ULTIMATIVE TX-P--X10THREAD spartain am 12.02.2009 – Letzte Antwort am 06.07.2013 – 1968 Beiträge |
TX-P S10 Problem Chupa1965 am 29.12.2009 – Letzte Antwort am 29.12.2009 – 5 Beiträge |
Der ultimative TX-P - - GW10 Thread windschief am 24.03.2009 – Letzte Antwort am 29.01.2019 – 6251 Beiträge |
TX-PF 42 S10 vs. TX-P 42 S10 sevenup666 am 25.09.2009 – Letzte Antwort am 29.09.2009 – 5 Beiträge |
TX-P S10 oder S20? Gabberfreak2010 am 23.04.2010 – Letzte Antwort am 23.04.2010 – 2 Beiträge |
Der ultimative TX-P - - G15 Thread windschief am 28.04.2009 – Letzte Antwort am 19.12.2013 – 484 Beiträge |
Der ultimative TX-P--C10 Thread Dj-BinIchNicht am 30.05.2009 – Letzte Antwort am 06.06.2009 – 4 Beiträge |
Der ultimative TX-P X10 Settings Thread chimba am 14.12.2009 – Letzte Antwort am 14.12.2009 – 5 Beiträge |
- Teletext Problem
- Teletext Problem
- Registrierte Mitglieder926.886 ( Heute: 3 )
- Neuestes MitgliedSethyras
- Gesamtzahl an Themen1.554.238
- Gesamtzahl an Beiträgen21.608.416
