HIFI-FORUM » Do it yourself » Elektronik » TDA1557Q my first DYI amp (need help) | |
TDA1557Q my first DYI amp (need help)+A -A |
whiz115
03:00
erstellt: 18. Jan 2007, |
Hallo!!! ich bin hier neu und ich komme aus Griechenland! ich fand Ihr Forum von Google und es schaut nett! i believe my German are worst than my English so i hope you don't mind if i use English language for my posts! ![]() As the title says...TDA1557Q is my fist DIY! i have made it on a bread board, and now i'm preparing to make my first PCB! i know..the specific chip-amp is not big deal! but it's nice IC for a newbie to make a start! The things i want to know are the characteristics of the IC which i haven't found in the PDF..and especially the SNR and Frequency response! ( if i remember correct somewhere in the PDF it says "channel seperation 45db" ![]() ![]() ![]() i know...for 3 Euros (22W Stereo/10% THD) it's not that bad... ![]() danke! [Beitrag von whiz115 am 18. Jan 2007, 03:03 bearbeitet] |
detegg
03:09
Hi Lefteris, wellcome to our community! ![]() ... the user Jacky_Lee is working on a DIY with TDA1558Q - seems to be equal to TDA1557Q ![]() Send him a PM about your specific problems. I´ll think, we ALL can give you little assistance ... ![]() cheers! Detlef [Beitrag von detegg am 18. Jan 2007, 04:10 bearbeitet] |
whiz115
04:01
my name is Lefteris...probably you saw part of my last name which i had by mistake in the "Origin tab".. my German are not so good ![]() here's the PDF i hope it can help someone else because i can't understand it that well.. ![]() i hope Jacky_Lee can answer here... ![]() |
detegg
04:17
corrected! ![]() I´ll think, Jacky would like to answer but I don´t know if he is firm with english language ... The TDA´s seems to be very close ... Detlef |
Jacky_Lee
Gesperrt |
18:19
English? Oh no... I don't no ^^ ![]() the link to the Datasheet ![]() and the "Layout" ^^ ![]() ![]() ![]() ![]() you could install a swich between Pin 3 and 11 . This switch are mute the Amp when its open. To fabricate this amp are very simple... build it on "punktrasterplatine" ähm... "pointboard" or so |
whiz115
22:58
Jacky_Lee ich möchte wissen, die Eigenschaften der IC... and besonders "SNR" und "Frequenzgang" gefunden haben irgendwo im pdf, das es sagt, daß "Kanaltrennung 40db" ist dieses zutreffende? können Sie erklären, wie ich Stift 12 zu Boden anbringe, also kann ich Verzerrung verringern? TDA1557Q sagt mit zwei Dioden ohne irgendeine Erklärung... und TDA1558Q sagt mit zwei zener Dioden! was versuchen wir hier mit dem Stift 12 und den Dioden? (Stift 15 für das TDA1558Q) ![]() |
Jacky_Lee
Gesperrt |
23:01
Die 40db sind die verstärkung (GAIN). Pin12 ist unconnected bei der Brückenschaltung! Zumindest normalerweise. Man kann aber auch versuchen genau die halbe V+ anlegen |
Marke Eigenbau - Need Help Peter_Pan am 14.05.2004 – Letzte Antwort am 15.05.2004 – 13 Beiträge |
Hilfe zur Anschlussbelegung(My first Amp-Restauration) TrainEntertain am 20.06.2014 – Letzte Antwort am 23.06.2014 – 3 Beiträge |
tragbarer vollröhren-kopfhörerverstärker-->need help am 13.12.2006 – Letzte Antwort am 21.12.2006 – 10 Beiträge |
TDA1557Q Fragen Dan2555 am 13.06.2007 – Letzte Antwort am 20.06.2007 – 13 Beiträge |
Defekte Weller WECP-20 .need help katarakt am 18.11.2015 – Letzte Antwort am 22.06.2020 – 27 Beiträge |
DYI Class-D Verstärker/Layout PeterFW am 22.09.2013 – Letzte Antwort am 22.09.2013 – 2 Beiträge |
HELP!!!!!!!!!!!!!! stifler88 am 11.05.2004 – Letzte Antwort am 11.05.2004 – 2 Beiträge |
help mose am 02.11.2004 – Letzte Antwort am 04.11.2004 – 29 Beiträge |
Verstärker mit TDA1557Q funktioniert nicht (Schaltplan: Datenblatt) Dan2555 am 17.07.2005 – Letzte Antwort am 18.07.2005 – 7 Beiträge |
Pimp my optischen Trennverstärker 10_BGS am 28.02.2006 – Letzte Antwort am 28.02.2006 – 6 Beiträge |
2007
Top Produkte in Elektronik
- Registrierte Mitglieder929.053 ( Heute: 8 )
- Neuestes MitgliedFid_Bruns
- Gesamtzahl an Themen1.559.572
- Gesamtzahl an Beiträgen21.729.537
